    4. IRobot Roomba Adapter
      HerrStrich @Zefau last edited by
      @Zefau
      code_text
      ```pi@raspberrypi:~ $  npm install -g dorita980
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/dorita980
      npm ERR! path /usr/lib/node_modules/dorita980
      npm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/dorita980'
      npm ERR!  { [Error: EACCES: permission denied, access '/usr/lib/node_modules/dorita980']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/usr/lib/node_modules/dorita980\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/usr/lib/node_modules/dorita980' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!     /home/pi/.npm/_logs/2019-08-14T12_59_51_462Z-debug.log
      events.js:174
            throw er; // Unhandled 'error' event
      Error: connect ECONNREFUSED 192.168.2.117:8883
          at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
      Emitted 'error' event at:
          at emitErrorNT (internal/streams/destroy.js:91:8)
          at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
          at process._tickCallback (internal/process/next_tick.js:63:19)
      Habe ein Roomba 960 mit der 2.4.6-3 Frimware.
      • Zefau
        Zefau @HerrStrich last edited by
        @HerrStrich Das ist kein Fehler aufgrund des Roomba's, des Adapters oder der zugrundeliegenden Library. Du hast laut Log keine Schreibrechte auf den Ordner, in dem du dorita980 installieren willst (steht ja auch da).
        Guck mal im ioBroker Ordner. Dort solltest du dorita schon installiert haben.
        Entweder unter
        /opt/iobroker/node_modules/dorita980
        oder
        /opt/iobroker/node_modules/iobroker.roomba/node_modules/dorita980
        In diesem Ordner kannst du dann der Anleitung https://github.com/koalazak/dorita980#how-to-get-your-usernameblid-and-password folgen und npm run getpassword <robotIP> ausführen.
        Sollte das dann fehlschlagen, poste das Log nochmal hier im Forum.
          @Zefau
          Passwort bekomm ich nun geb es auch ein aber :
          roomba.0	2019-08-14 18:07:08.487	info	Connecting to Roomba..
          roomba.0	2019-08-14 18:07:08.416	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.roomba, node: v10.16.2
          roomba.0	2019-08-14 18:07:38.576	warn	Connection lost! Roomba offline.
          Er bekommt einfach keine verbindung zum Roomba!
          • Zefau
            @HerrStrich Hast du denn parallel die App auf dem Handy offen oder so?
              @Zefau
              Nein, hab alles ausgemacht leider keine verbindung möglich 😞
                Tariot last edited by
                Ich habe genau das selbe Problem... das pw wird nicht automatisch eingefügt... gebe ich es manuell ein bekomme ich die gleiche Meldung... roomba is offline... hatte ihn vorher im ifttt.. auch dort das Gerät gelöscht..
                Trotzdem der gleiche Fehler... würde dir meine logs schicken aber die sind identisch zu herrstrich
                • Zefau
                  Zefau @Tariot last edited by
                  @Tariot @HerrStrich Wenn ihr bewusst ein falsches Passwort eingebt, bekommt ihr dann einen Fehler (by controller[0]: { Error: Connection refused: Not authorized) ?
                    @Zefau
                    Nein bekomme keine Fehler Meldung nur das Wasser ich dir schon gezeigt habe!
                    Habe die Raspberry jetzt auch nochmal komplett neu aufgesetzt aber leider wieder mit dem gleichen Ergebnis!
                    Langsam weiß ich auch nicht mehr weiter 😞
                    • Zefau
                      Zefau @HerrStrich last edited by Zefau
                      @HerrStrich @Tariot Habe auf Github und npm die Version v1.0.4 veröffentlicht. Diese aktualisiert die zugrundeliegenden Pakete, was ggf. das Problem behebt.
                      Der Passwort-Abruf sollte nun ebenfalls wieder funktionieren.
                      Sollte die Version nach wie vor nicht funktionieren, bitte unter Instanzen den Adapter von info auf debug stellen.
                      Dann werden im Log mehr Informationen ausgegeben. Ggf. hilft uns das, das Problem einzugrenzen.
                        Tariot last edited by Tariot
                        ja PW wird nun automatisch erkannt, ein fortschritt^^ aber leider keine verbindung
                        er schreibt in die loggs nun
                        roomba.0	2019-08-16 11:44:49.928	debug	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                        roomba.0	2019-08-16 11:44:49.926	debug	Roomba Connection closed.
                        roomba.0	2019-08-16 11:44:47.371	debug	Updated state states._connected to value false (from null).
                        roomba.0	2019-08-16 11:44:47.370	debug	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                        roomba.0	2019-08-16 11:44:47.370	debug	Roomba Connection closed.
                        roomba.0	2019-08-16 11:44:47.370	debug	undefined
                        roomba.0	2019-08-16 11:44:47.368	warn	Connection lost! Roomba offline.
                        • Zefau
                          @Tariot Das genügt. Danke dir. EPROTO deutet scheinbar darauf hin, dass der SSL handshake abbricht. Liegt also nicht direkt am Adapter, sondern der library, die genutzt wird, um mit dem Roomba zu kommunizieren.
                          • Zefau
                            Zefau @Zefau last edited by Zefau
                            @Tariot @HerrStrich Habt ihr die Möglichkeit per SSH oder Samba Dateien anzupassen?
                            Könntet ihr bitte in den folgenden Ordnern (sofern vorhanden) eine Datei anpassen?
                            /opt/iobroker/node_modules/iobroker.roomba/node_modules/dorita980/lib/v2/
                            und
                            /opt/iobroker/node_modules/dorita980/lib/v2/
                            die Datei local.js.
                            Dort findet ihr ab Zeile 18:
                              var options = {
                                port: 8883,
                                clientId: user,
                                rejectUnauthorized: false,
                                protocolId: 'MQTT',
                                protocolVersion: 4,
                                clean: false,
                                username: user,
                                password: password
                            Dort die folgenden zwei Zeilen hinzufügen (https://github.com/nodejs/node/issues/3692#issuecomment-158414743)
                                ciphers: 'ALL',
                                secureProtocol: 'TLSv1_method'
                            zu
                              var options = {
                                port: 8883,
                                clientId: user,
                                ciphers: 'ALL',
                                secureProtocol: 'TLSv1_method',
                                protocolId: 'MQTT',
                                protocolVersion: 4,
                                clean: false,
                                username: user,
                                password: password
                            Speichern und Adapter neustarten.
                            brandonros created this issue in nodejs/node
                            closed HTTP/HTTPS client requests throwing EPROTO #3692
                              @Zefau said in IRobot Roomba Adapter:
                              also beide datein geändert... gleiche fehler weiterhin ;(
                              Zefau 2 Replies Last reply Reply Quote 0
                              • Zefau
                                @Tariot Welche Node.js Version hast du?
                                • Zefau
                                  Zefau @Tariot last edited by Zefau
                                  @Tariot sagte in IRobot Roomba Adapter:
                                  Ist leider ein rumprobieren, da ich den Fehler nicht rekonstruieren kann bei mir.
                                  Nimm bitte
                                  wieder raus und versuch folgende Optionen:
                                      minVersion: 'TLSv1',
                                      ecdhCurve: 'auto'
                                  also:
                                    var options = {
                                      port: 8883,
                                      clientId: user,
                                      ciphers: 'ALL',
                                      ecdhCurve: 'auto',
                                      protocolId: 'MQTT',
                                      protocolVersion: 4,
                                      clean: false,
                                      username: user,
                                      password: password
                                  EDIT: Und unbedingt Adapter neustarten.
                                    @Zefau
                                    ecdhCurve: 'auto'
                                    damit geht es leider bei mir auch nicht....
                                    Zumal ich
                                    gar nicht habe....
                                    node -v
                                    v10.16.3
                                    • Zefau
                                      @HerrStrich sagte in IRobot Roomba Adapter:
                                      Welchen der beiden Ordner gibt es denn bei dir?
                                      Ich habe einen Roomba 980 mit FW v2.4.6-3 auf Node.js v10.16.1 und bei mir funktioniert's.
                                      Der Fehler EPROTO deutet (laut Google) auf einen Fehler im SSL Handshake. Ist aber eine reine Vermutung von mir, da ich, wie gesagt, den Fehler nicht habe.
                                      Bei dir ist es ein Roomba 960 mit FW 2.4.6-3 auf Node.js v10.16.3. Also eigl. nicht so anders.
                                      Der Adapter lädt bei dir gar keine Daten? Also auch keine Config-Einstellungen?
                                      Sprich du kannst nicht sehen, was in roomba.0.device.versions.navSwVer bzw roomba.0.device.versions.wifiSwVer steht?
                                      • Zefau
                                        Ich hab ein Issue aufgemacht: https://github.com/koalazak/dorita980/issues/95
                                        Zefau created this issue in koalazak/dorita980
                                        closed EPROTO error while connecting #95
                                          ok die neuen zeilen eingebaut.
                                          nun ist ein teil des fehlers weg
                                          vorher
                                          nun noch
                                          oomba.0	2019-08-17 09:52:03.003	debug	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                                          roomba.0	2019-08-17 09:52:03.001	debug	Roomba Connection closed.
                                          bei mir ist der pfad zu denn datein anders als beschrieben. hoffe das ist egal... immerhin beide gefunden
                                          node version = v10.16.2.
                                          • Zefau
                                            @Tariot Ist möglicherweise nicht egal. Wenn du die falschen Dateien bearbeitest, dann haben die Änderungen ja keine Auswirkungen. Die Frage ist, welche Datei konkret vom Adapter gezogen wird, denn die muss geändert werden.
                                            1.2k
                                            81.1k
                                            851
                                            300979
