    4. JavaScript
    5. [Skript] Absolute Feuchte berechnen
      e-i-k-e last edited by
      Moin,
      ich nutze seit kurzem ach dieses tolle Skript.
      Es funktionierte auf Anhieb. 🙂
      Nur mir werden im log verschieben Warnungen angezeigt. Kann damit jemand etwas anfangen?
      javascript.0	2019-01-29 14:11:12.006	warn	at Timer.listOnTimeout (timers.js:290:5)
      javascript.0	2019-01-29 14:11:12.005	warn	at tryOnTimeout (timers.js:323:5)
      javascript.0	2019-01-29 14:11:12.005	warn	at ontimeout (timers.js:511:34)
      javascript.0	2019-01-29 14:11:12.005	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1793:34)
      javascript.0	2019-01-29 14:11:12.004	warn	at Object. <anonymous>(script.js.Raumklima:980:9)
      javascript.0	2019-01-29 14:11:12.004	warn	at calc (script.js.Raumklima:710:23)
      javascript.0	2019-01-29 14:11:12.002	warn	getState "undefined" not found (3)
      javascript.0	2019-01-29 14:11:10.010	warn	at Timer.listOnTimeout (timers.js:290:5)
      javascript.0	2019-01-29 14:11:10.010	warn	at tryOnTimeout (timers.js:323:5)
      javascript.0	2019-01-29 14:11:10.010	warn	at ontimeout (timers.js:511:34)
      javascript.0	2019-01-29 14:11:10.009	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1793:34)
      javascript.0	2019-01-29 14:11:10.009	warn	at Object. <anonymous>(script.js.Raumklima:980:9)
      javascript.0	2019-01-29 14:11:10.009	warn	at calc (script.js.Raumklima:710:23)
      javascript.0	2019-01-29 14:11:10.006	warn	getState "undefined" not found (3)</anonymous></anonymous>
        leider erhalte ich weiterhin die folgenden Warnungen.
        javascript.0	2019-02-22 12:30:00.523	warn	at Timer.listOnTimeout (timers.js:290:5)
        javascript.0	2019-02-22 12:30:00.523	warn	at tryOnTimeout (timers.js:323:5)
        javascript.0	2019-02-22 12:30:00.522	warn	at ontimeout (timers.js:511:34)
        javascript.0	2019-02-22 12:30:00.522	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1864:34)
        javascript.0	2019-02-22 12:30:00.521	warn	at Object.<anonymous> (script.js.Raumklima:988:9)
        javascript.0	2019-02-22 12:30:00.521	warn	at calc (script.js.Raumklima:718:23)
        javascript.0	2019-02-22 12:30:00.518	warn	getState "undefined" not found (3)
        Ich setze den o. g. Code ein.
        Wie behebe ich diese Warnungen?
          tempestas @e-i-k-e last edited by
          @e-i-k-e
          Zeile 710 im Skript, was steht denn da?
            e-i-k-e last edited by e-i-k-e
            Anbei ein Auszug.
                return rd; // rd = Dampfgewicht in g/m^3
            function calcMaxDampfgewicht(rd,r) {
                var maxrd = rd / r *100;
                return maxrd;
            // Berechnung: alle Werte je Raum
            function calc(raum) {                                           // Über Modul Dewpoint absolute Feuchte berechnen
                var t           = getState(raeume[raum].Sensor_TEMP).val;   // Temperatur auslesen
                var rh          = getState(raeume[raum].Sensor_HUM).val;    // Feuchtigkeit relativ auslesen
                t   = makeNumber(t);                                        // Temperatur in Number umwandeln
                rh  = makeNumber(rh);                                       // relative Luftfeuchtigkeit in Number umwandeln
                var toffset     = 0.0;                                      // Default Offset in °C
                var rhoffset    = 0;                                        // Default Offset in %
                if(typeof raeume[raum].Sensor_TEMP_OFFSET !=="undefined") {
                    // Temperatur, wenn ein Offset vorhanden ist, diesen auslesen und Default überschreiben
                    var idtoffset = pfad + raumPfad+ raum + "." + controlPfad + "Sensor_TEMP_OFFSET";
                    toffset = getState(idtoffset).val;  // Offset aus den Objekten/Datenpunkt auslesen
            710 = 11
              tempestas last edited by
              710 = 11 kann nicht stimmen, denn Zeile 11 lt. obigen Auszug ist leer.
              Mir scheint aber, dass es sich um Zeile 19 (im kleinen auszug) handelt, also um diesen Teil
              Da sagt er, er findet nichts beim Versuch, den State auszulesen ("undefined not found").
              Eventuell hast du einen Raum definiert, den es nicht gibt, oder es kommen keine Luftfeuchtigkeitsdaten an?
              • N
                niceddes last edited by
                mittlerweile läuft das Skript bei mir einwandfrei. Vielen Dank erst mal für eure Mühen und großen Respekt vor dem Ergebnis. 😀
                Wird das Skript noch aktiv erweitert? Im Skript selbst stehen ja noch ausstehende Ideen. 😌
                Ich hätte großes Interesse daran eine Lüftungspriorität abzubilden. Sprich, eine Warnung oder Alexa Sprachansage auszugeben, wenn ein Lüften dringend erforderlich ist. Ggf. sogar einen Wert für die aktuelle Schimmelgefahr. Aktuell ist die Lüftungsempfehlung eher so zu verstehen, ob ein Lüften potentiell die Luftfeuchtigkeit reduziert. Derzeit ist die Empfehlung daher fast immer auf True.
                Hat hierzu jemand eine Idee? Hat sich schon jemand mit der generellen Logik diesbezüglich befasst? Welche Faktoren und Berechnungen sind hierzu im Detail erforderlich?
                Danke und Grüße
                  smooty1970 last edited by smooty1970
                  Hallo.
                  Wo kann ich denn das gesamte Script runterladen? Ich würde es gern einmal testen. Allerdings ist mir nicht klar, welche Scriptteile oben nun zu welcher Version gehören. Bitte, danke.
                    tempestas @niceddes last edited by
                    @niceddes
                    Meine Version entspricht sicherlich nicht dem aktuellsten Stand, aber ich habe folgendes eingebaut:
                    A) Drei Stufen, die die Lüftungspriorität definieren.
                    B) einen einstellbaren Tradeoff, d.h bin ich bereit, eine etwas höhere Luftfeuchtigkeit zu akzeptieren, wenn es dafür kühler wird.
                    Aktuell sagt das Skript ja nur lüften, wenn sowohl kühlen als auch entfeuchten true ist.
                      @smooty1970
                      Das Script aus dem Jahr 2016 von @paul53 habe auf GitHub gefunden und läuft. Damit dürfte das auch nicht die v0.6.4 oder höher sein. Mich würden natürlich die aktuellen Versionen auch interessieren. Danke
                      • I
                        ilker last edited by
                        @smooty1970 same here. Blicke als Anfänger nicht durch.
                        Ich habe eine Version auf Github gefunden. Diese wirft aber einige Fehler.
                        Welche ist die aktuelle Version?
                          dodi666 last edited by
                          besteht vielleicht die Möglichkeit, dass einer die letzte Version des Skriptes hier postet?
                          Ich werde aus dem ersten Post nicht schlau, und das Skript scheint bei der Forenübernahme auch nicht richtig übernnommen worden zu sein.
                          Vielen Dank
                          Sascha
                            sigi234 Forum Testing Most Active @dodi666 last edited by
                            @dodi666 sagte in [Skript] Absolute Feuchte berechnen:
                            Skript Raumklima.txt
                            D T 2 Replies Last reply Reply Quote 0
                              dodi666 @sigi234 last edited by
                              @sigi234 sagte in [Skript] Absolute Feuchte berechnen:
                              Herzlichen Dank!
                              • v522533
                                v522533 last edited by
                                hat schon jemand versucht, ob das Script auch mit Xiaomi Temperatur Sensoren funktioniert?
                                  Radi last edited by
                                  Ja, tut es. Habe als Außensensor einen Homematicsensor HM-WDS10-TH-O und in den Innenräumen nur die Xiaomis im Einsatz.
                                  v522533 1 Reply Last reply Reply Quote 0
                                  • v522533
                                    v522533 @Radi last edited by
                                    @Radi
                                    Perfekt. Danke Dir
                                      TemPeck @sigi234 last edited by
                                      @sigi234 said in [Skript] Absolute Feuchte berechnen:
                                      Hallo zusammen!
                                      Ich habe eine kleine Verständnisfrage zu dem Skript.
                                      Ich habe das Skript aus der Textdatei übernommen und entsprechend angepasst.
                                      Mein Ziel war es, in erster Linie den Waschkeller zu überwachen, da hier Wäsche getrocknet wird und die Luftfeuchtigkeit dementsprechend hoch ist.
                                      Über die Lüftungsempfehlung möchte ich Fensteröffner und einen Rohrventilator an steuern.
                                      Wie ihr auf dem Bild erkennen könnt, ist die Luftfeuchtigkeit im Waschkeller gerade extrem hoch, trotzdem wird das läuft nicht empfohlen. Die oberen Werte sind die Außenwerte.
                                      Was genau ist da der praktische Hintergrund? Ergibt das Sinn??
                                        TemPeck last edited by
                                        Da lief was schief - hier das Bild zum letzten Post
                                          paul53 @TemPeck last edited by
                                          @TemPeck sagte:
                                          Ich kenne zwar das konkrete Skript nicht, wenn aber mein Skript als Grundlage genommen wurde, dann werden auch die Temperaturen (Innen - Aussen) verglichen. Wenn die Aussentemperatur höher als die Innentemperatur ist, soll nicht gelüftet werden, was allerdings bei einem Waschkeller wenig Sinn macht.
                                          sigi234 T 2 Replies Last reply Reply Quote 0
                                            sigi234 Forum Testing Most Active @paul53 last edited by
                                            @paul53 sagte in [Skript] Absolute Feuchte berechnen:
                                            Kann man das hier nicht einstellen?
                                            Sensor_HUM_OFFSET
                                            740
                                            221499
