    • simatec
      simatec Developer Most Active @radiorichter last edited by
      @radiorichter
      Auf welchen Wert steht denn dein Rolladen aktuell? Nur wenn der aktuelle Wert höher ist, wird der Rolladen gefahren.
      Eventuell ist der virtuelle Datenpunkt für deine Innentemp nicht als Zahl definiert
        passuff last edited by
        habe probleme mit der Trigger ID. Obwohl diese auf true geht, stoppt der Rolladen nicht.
        Hier meine Einstellungen:
        "_id": "system.adapter.shuttercontrol.0",
        "common": {
        "name": "shuttercontrol",
        "version": "0.3.2",
        "title": "shuttercontrol",
        "authors": [
        "simatec nais@gmx.net"
        "keywords": [
        "ioBroker",
        "Smart Home",
        "home automation",
        "Rollladen",
        "Jalousie",
        "Rollladensteuerung"
        "license": "MIT",
        "platform": "Javascript/Node.js",
        "main": "main.js",
        "icon": "shuttercontrol.png",
        "enabled": true,
        "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
        "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
        "loglevel": "info",
        "mode": "daemon",
        "type": "climate-control",
        "compact": true,
        "materialize": true,
        "installedVersion": "0.3.2",
        "host": "IoBroker-VM-Debian"
        "native": {
        "livingAutomatic": "livingSunriseSunset",
        "W_shutterDownLiving": "22:00",
        "WE_shutterDownLiving": "23:00",
        "WE_shutterUpLiving": "08:00",
        "W_shutterUpLivingMin": "06:30",
        "W_shutterUpLivingMax": "08:00",
        "driveDelayUpLiving": "5",
        "sleepAutomatic": "sleepGoldenHour",
        "W_shutterDownSleep": "20:00",
        "WE_shutterDownSleep": "23:00",
        "WE_shutterUpSleep": "08:00",
        "W_shutterUpSleepMin": "06:30",
        "W_shutterUpSleepMax": "08:00",
        "driveDelayUpSleep": "5",
        "latitude": "50.2982625",
        "longitude": "8.2650359",
        "astroDelayUp": "0",
        "astroDelayDown": "10",
        "driveDelayUpAstro": "0",
        "sunProtEndElevation": "28",
        "currentShutterState": false,
        "publicHolidays": false,
        "publicHolInstance": "",
        "triggerAutoSleep": "",
        "triggerAutoLiving": "",
        "heightDownSun": "30",
        "direction": "0",
        "type": "off",
        "directionRange": "50",
        "actualValueTemp": "javascript.0.Aussentemp.Temperatur-Mittel-24h_120",
        "actualValueLight": "",
        "actualValueTempInside": "mihome.0.devices.sensor_ht_158d000254d31b.temperature",
        "typeDown": "living-auto",
        "typeUp": "living",
        "triggerStateShutter": "true",
        "triggerChangeShutter": "onlyUp",
        "triggerDriveShutter": "100",
        "autoDriveShutter": "onlyUp",
        "heightDownShutter": "0",
        "heightUpShutter": "100",
        "triggerID": "CalcVal.0.Rolladen.Trigger_RL_Nord",
        "events": [
        "enabled": true,
        "shutterName": "RL_Nord:1.LEVEL",
        "name": "hm-rpc.0.OEQ1303336.1.LEVEL",
        "typeUp": "living",
        "type": "off",
        "direction": "0",
        "tempInside": "23",
        "tempSensor": "mihome.0.devices.sensor_ht_158d000254d31b.temperature",
        "outsideTempSensor": "javascript.0.Aussentemp.Temperatur-Mittel-24h_120",
        "tempOutside": "26",
        "lightSensor": "",
        "valueLight": "15",
        "heightUp": "100",
        "heightDown": "0",
        "triggerState": "true",
        "triggerDrive": "100",
        "triggerChange": "onlyUp",
        "elevation": "",
        "autoDrive": "onlyUp",
        "hysteresisOutside": "10",
        "hysteresisInside": "10",
        "hysteresisLight": "5",
        "currentAction": "",
        "currentHeight": "",
        "triggerHeight": ""
        "enabled": true,
        "shutterName": "RL_Süd_links:1.LEVEL",
        "name": "hm-rpc.0.OEQ1303335.1.LEVEL",
        "triggerID": "CalcVal.0.Rolladen.Trigger_RL_Süd_links_Küche",
        "typeUp": "living",
        "type": "in- & outside temperature and direction",
        "direction": "180",
        "tempInside": "23",
        "tempOutside": "25",
        "lightSensor": "",
        "valueLight": "15",
        "heightUp": "100",
        "heightDown": "0",
        "elevation": "",
        "triggerHeight": ""
        "enabled": true,
        "shutterName": "RL_Süd_rechts:1.LEVEL",
        "name": "hm-rpc.0.OEQ1303353.1.LEVEL",
        "triggerID": "CalcVal.0.Rolladen.Trigger_RL_Süd_rechts",
        "typeUp": "living",
        "direction": "180",
        "tempInside": "23",
        "lightSensor": "",
        "valueLight": "15",
        "heightUp": "100",
        "heightDown": "0",
        "elevation": "",
        "triggerHeight": ""
        "enabled": true,
        "shutterName": "RL_Küche:1.LEVEL",
        "name": "hm-rpc.0.OEQ1303333.1.LEVEL",
        "typeUp": "living",
        "direction": "270",
        "tempInside": "23",
        "lightSensor": "",
        "valueLight": "15",
        "heightUp": "100",
        "heightDown": "0",
        "elevation": "",
        "triggerHeight": ""
        Runterfahren ist auf "Wohnbereich (Auto)" gestellt und die Trigger sind in jedem Rollladen eingerichtet.
        • simatec
          simatec Developer Most Active @passuff last edited by
          @passuff
          Bei welchen Rolladen hast du denn die Probleme?
          Und wenn du sagst, du hast deine TriggerID auf true, wie ist der Wert der TriggerID bei geschlossenen Fenster?
            passuff @simatec last edited by passuff
            @simatec sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
            @passuff
            Alle Rollladen ignorieren den Trigger.
            Der Rollladen soll nur runterfahren, wenn der Trigger auf true steht.
            • simatec
              @passuff
              Nochmal die Frage, auf was steht dein trigger, wenn das Fenster geöffnet ist?
                ->False. Der Trigger ist eigentlich eine Oder-Verknüpfung zwischen Fenster geöffnet, Kontaktleiste Rolladen betätigt und Rollladenautomatik deaktiviert. Jede dieser Größen sollen den Lauf stoppen, oder gar verhindern können. Ich habe jetzt bemerkt dass zumindest letzteres funktioniert. Wenn aber der RL bereits losgefahren ist, hat der Trigger keine Auswirkung mehr.
                  @simatec : Was jetzt? ISt das ein bug?
                  • simatec
                    @passuff
                    Wenn eine Variable funktioniert, prüfe deinen Script dazu nochmal
                      Funktioniert alles. Nur der Adapter reagiert nicht auf den Trigger, wenn der RL gerade fährt.
                        slonnet @simatec last edited by slonnet
                        Das heißt in Klartext, wenn du als Sollwert 20 °C eingestellt hast und die Hysterese bei 10% eingestellt ist, dann fahren deine Rollläden bei Überschreitung der 20 °C runter und erst wieder bei unter 18 °C wieder hoch.
                        @simatec
                        Das heisst die Hysterese gilt nur nach unten (also nur -, nicht +/-)!
                        Das würde so einiges erklären! Das wurde hier denke ich teilweise anders verstanden.
                        Weiterhin sind mir die Sensor Verknüpfungen für den Sonnenschutz nicht ganz klar.
                        Zumal es ja wohl für das Hoch- und Runterfahren verschieden sein müssten.
                        @Homoran
                        wäre super wenn das etwas ausführlicher in die Doku käme, evtl mit Beispielen.
                        (Ich habe die knapp 1200 Beiträge schon ca dreimal komplett durchgearbeitet, Stichwort: UND bzw ODER, und auch denke ich verschachtelt)
                          passuff @passuff last edited by
                          @passuff sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                          @simatec bug oder feature?
                          • simatec
                            @passuff
                            Muss ich mir anschauen... falls es ein Big ist, fixe ich es in der nächsten Version
                              Homoran Global Moderator Administrators @slonnet last edited by
                              @slonnet sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                              Natürlich, wie denn sonst?
                              Beschattungsbeginn bei Überschreitung von Temperatur x, Beschattungsende wenn die Temperatur anschließend wieder darunter fällt.
                              Damit der Rollladen bei Temperaturen um den Entscheidungswert nicht bei jeder Messung rauf und runterfährt, sorgt die Hysterese für eine Beruhigung.
                              Dazu fährt der Rollladen erst hoch wenn die Temperatur um die in der Hysterese eingestellten Prozent unter der Starttemperatur liegt.
                              Was eine +/- Abweichung bewirken soll ist mir nicht klar.
                                slonnet @Homoran last edited by
                                @Homoran sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                                Ich hatte angenommen das die prozentuale Abweichung in beide Richtungen greift! (Beispiel: 10°C / 10% = 11°C Beschattungsbeginn, 9°C Beschattungsende )
                                Genau so wie die Gradzahlangabe bei Azimut Sonne.
                                Gut, ist ja jetzt geklärt, gehört aber trotzdem in die Doku finde ich 😉
                                War einfach ein Denkfehler von mir! 🙄
                                Wie die Hysterese allgemein funktioniert ist mir vollkommen klar.
                                Genau das funktioniert bei mir nicht!
                                Eingestellt ist nur Himmelrichtung und Aussentemperatur.
                                Wenn jetzt der Lichtsensor unter die Starttemperatur minus die Hysterese fällt (aber das Fenster noch in dem Bereich der Himmelrichtung ist), fährt der Rolladen nicht wieder hoch.
                                Erst wenn der Bereich der Himmelsrichtung vorbei ist fährt dieser!
                                Wozu dann also noch die Hysterese? 😉
                                Oder sind Himmelsrichtung und Aussentemperatur bei Beschattungsende UND Verknüft? (Was für mich keinen Sinn ergebe)
                                  Locker aus der Hüfte würde ich sagen Nein. das sollte ein ODER sein.
                                  Das muss ich bei mir noch mal nachstellen. Ich glaube mich zu erinnern, dass ich auch irgendwo mit einer Einstellung so ein Phänomen hatte.
                                  Kann sein, dass da noch ein Bug drin ist
                                    Ich glaube ich habe den Fehler gefunden. Bzw konnte es nachstellen.
                                    Wenn man nur einen Sensor für die Aussentemperatur benutzen will muss dieser auch beim Aussentemperatur Sensor eingetragen werden, auch wenn es nicht die reale Aussentemperatur ist. In meinen Fall ist es ein Sonnensensor (Temperaturdifferenz Senor vom Weatherman von Eugen (stall.biz) ).
                                    Ich habe also den Sonnensensor beim Lichtsensor eingetragen und den Aussentemperatur Sensor leer gelassen. Das gibt wohl Probleme, bzw scheint noch ein Bug zu sein.
                                      Das scheint mir selbsterklärend.
                                      Ist bei mir auch so.
                                        dos1973 last edited by
                                        Hallo zusammen
                                        @simatec
                                        bei mir lief der Adapter einigen Wochen absolut zuverlässig. Aber seit einigen Tagen fahren die Rolladen nicht mehr automatisch weder hoch noch runter 😞
                                        Ich habe das Logging erst jetzt eingeschaltet... aber vielleicht hat jemand eine Idee anhand der Konfiguration.
                                        • simatec
                                          simatec Developer Most Active @dos1973 last edited by
                                          @dos1973
                                          Anhand deiner Config kann ich nix auffälliges sehen.
                                          Poste mal den Debug Log zu den Zeiten, wann die Rollläden fahren sollten.
                                            Adnim last edited by
                                            nutze den Adapter jetzt auch schon ein paar Wochen, funktioniert bei mir wunderbar.Danke für die Arbeit!
                                            Habe noch ein paar Sachen die mir fehlen und wollte diese mal in den Raum werfen.
                                            • Auswertung von Sturmwarnungen um keine Markisen oder Klappladen ohne Aufsicht in diesem Zeitraum zu fahren.
                                            • Regensensor einbinden um Fenster sauber zu halten
                                            • die Erweiterung der Beschattungs Funktionen wenn der DWD Adapter (oä) Hitze für heute meldet oder das gleiche Szenario über einen der Wetter Adapter zu lösen, sprich wird es heute über 30 Grad ist Beschattung notwendig?
                                            Auch gut würde ich die Erstellung eines Logs durch den Adapter finden.Wann ist welcher Rolladen wegen was gefahren (Json Tabelle?)
                                            Hier gibt es bestimmt noch ein mehr Ideen das ganze Smarter zu machen! Sind wie gesagt nur Vorschläge evtl kann man ja etwas davon noch leicht umsetzten.
                                            Schönen Sonntag!
                                            332
                                            7408
                                            10572070
