    4. Test Adapter lovelace v0.2.x
      Gwenselah last edited by
      Update. Mit der Version 0.1.3 wird das Datum angezeigt, allerdings sind nun die Texte weg:
        beroliv last edited by
        Leider läuft das bei mir überhaupt nicht stabil, alle paar Minuten startet der Adapter neu.
        Kann mir da ev jemand bisschen helfen. Sitze nun schon seit stunden daran..
        Log:
        lovelace.0 2019-08-04 21:38:40.791 info http server listening on port 8091
        lovelace.0 2019-08-04 21:38:40.695 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.16.1
        lovelace.0 2019-08-04 21:38:06.193 info cleaned everything up...
        lovelace.0 2019-08-04 21:38:05.184 info cleaned everything up...
        lovelace.0 2019-08-04 21:38:05.181 error at Timer.processTimers (timers.js:223:10)
        lovelace.0 2019-08-04 21:38:05.181 error at listOnTimeout (timers.js:263:5)
        lovelace.0 2019-08-04 21:38:05.181 error at tryOnTimeout (timers.js:300:5)
        lovelace.0 2019-08-04 21:38:05.181 error at ontimeout (timers.js:436:11)
        lovelace.0 2019-08-04 21:38:05.181 error at Timeout._updateTimer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:3146:22)
        lovelace.0 2019-08-04 21:38:05.181 error at WebServer.onStateChange (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1646:22)
        lovelace.0 2019-08-04 21:38:05.181 error at Array.forEach (<anonymous>)
        lovelace.0 2019-08-04 21:38:05.181 error at entities.forEach.entity (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1685:76)
        lovelace.0 2019-08-04 21:38:05.181 error at Date.toISOString (<anonymous>)
        lovelace.0 2019-08-04 21:38:05.181 error RangeError: Invalid time value
        lovelace.0 2019-08-04 21:38:05.180 error uncaught exception: Invalid time value
        lovelace.0 2019-08-04 21:34:39.765 info http server listening on port 8091
        lovelace.0 2019-08-04 21:34:39.667 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.16.1
        lovelace.0 2019-08-04 21:34:04.386 info terminating
        lovelace.0 2019-08-04 21:34:03.810 info cleaned everything up...
        lovelace.0 2019-08-04 21:34:03.807 error at Timer.processTimers (timers.js:223:10)
        lovelace.0 2019-08-04 21:34:03.807 error at listOnTimeout (timers.js:263:5)
        lovelace.0 2019-08-04 21:34:03.807 error at tryOnTimeout (timers.js:300:5)
        lovelace.0 2019-08-04 21:34:03.807 error at ontimeout (timers.js:436:11)
        lovelace.0 2019-08-04 21:34:03.807 error at Timeout._updateTimer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:3146:22)
        lovelace.0 2019-08-04 21:34:03.807 error at WebServer.onStateChange (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1646:22)
        lovelace.0 2019-08-04 21:34:03.807 error at Array.forEach (<anonymous>)
        lovelace.0 2019-08-04 21:34:03.807 error at entities.forEach.entity (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1685:76)
        lovelace.0 2019-08-04 21:34:03.807 error at Date.toISOString (<anonymous>)
        lovelace.0 2019-08-04 21:34:03.807 error RangeError: Invalid time value
        lovelace.0 2019-08-04 21:34:03.805 error uncaught exception: Invalid time value
        lovelace.0 2019-08-04 21:32:28.698 info http server listening on port 8091
        lovelace.0 2019-08-04 21:32:28.604 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.16.1
          apollon77 @beroliv last edited by
          @beroliv Bitte ein GitHub Issue erstellen!
            beroliv @apollon77 last edited by
            @apollon77 okay habe ich gemacht
              wie bekomme ich denn die Icons gewechselt? Adapter läuft mit 0.1.4 nun sauber durch!
                Welche Icons willst Du wechseln?
                  innerhalb der Karte, wäre cool wenn man da was anderes einsetzen könnte.
                    johni last edited by
                    hat hier wer eine idee wie ich das piface schalten kann? shellys sind kein problem mit einem schalter aber, das relais des piface wird nicht erkannt.
                      Raducanu @beroliv last edited by
                      @beroliv Du kannst sämtliche Icon von https://materialdesignicons.com/ verwenden.
                      In den Properties dann
                      icon: 'mdi:icon-name'
                      verwenden.
                      Je nach verwendeter Karte / Konfiguration ist die Syntax anders.
                      Beispiel:
                      • dontobi
                        dontobi last edited by dontobi
                        Hat jemand von euch einen Dim Aktor von Homematic in Lovelace eingebunden?
                        Ich habe es versucht... Das hier kam dabei raus...
                        Zur Erklärung:
                        Ich habe das Objekt LEVEL verwendet. Denn wenn ich das unter ioBroker -> Objekte von hand auf einen Wert von 75% setze, wird das Homematic Modul auch angesteuert.
                        Zusätzlich habe ich eine Variable für Lovelace von Hand angelegt. Somit liegen auf dem einen Objekt 2 Variablen für Lovelace. Diese sind:
                        • light.Licht___Wohnzimmer_1
                        • input_number.Licht_Wohnzimmer_1
                        Auf dem 2 Bild sieht man dann, dass ich 2 unterschiedliche Cards hinzugefügt habe. Die Light Cards ist mit light.Licht___Wohnzimmer_1 parametriert und setzt beim Ändern unter Lovelace das Objekt nicht auf den gewünschten Wert. Da passiert überhaupt nichts.
                        Die andere Card ist eine Entities Card und mit beiden Variablen parametriert. Wie man sieht, wird bei der input_number "NaN %" angezeigt. Ändere ich den Wert über den Slider, so ändert sich der Wert des Objekts, aber in der Card bleibt der Wert auf "NaN %". Und die Variable light lässt sich ja (wie man sieht) nicht bedienen.
                        Ich Stelle mit die Frage, ob ich den Channel nicht für Lovelace angeben muss (anstelle von Objekt LEVEL). Aber vielleicht habt ihr ja einen Tipp für mich. Oder es ist am Ende ein Bug (Kombi aus HM Gerät und Lovelace).
                        B N 2 Replies Last reply Reply Quote 0
                          mafis90 last edited by mafis90
                          ich bin sehr begeistert von diesem Projekt hier. Aktuell versuche ich grade die mini-graph-card zu nutzen. Sie zeigt auch die Temperatur an, aber der Graph ist leer.
                          Was muss ich dort tun, damit dort so ein schöner Graph kommt, wie auf den anderen Bildern hier? Ich habe history & sql aktiviert für den Wert.
                          type: 'custom:mini-graph-card'
                          entities:
                            - sensor.Flur_Temp
                          hours_to_show: 24
                          points_per_hour: 0.25
                            svenallesclip.de last edited by
                            ist das bei euch auch, dass die Anmeldedaten im nicht gespeichert werden, wenn ich "Login speichern" bestätige. Oder habe ich etwas falsche eingerichtet?
                            • marcuskl
                              marcuskl last edited by
                              Bei mir kommt dauernd dieser Fehler
                              Caught	2019-08-26 17:09:21.660	error	by controller[0]: at Timer.processTimers (timers.js:223:10)
                              Caught	2019-08-26 17:09:21.660	error	by controller[0]: at listOnTimeout (timers.js:263:5)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at tryOnTimeout (timers.js:300:5)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at ontimeout (timers.js:436:11)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at Timeout._updateTimer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:3099:22)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at WebServer.onStateChange (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1644:22)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at Array.forEach (<anonymous>)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at entities.forEach.entity (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1683:76)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: at Date.toISOString (<anonymous>)
                              Caught	2019-08-26 17:09:21.659	error	by controller[0]: RangeError: Invalid time value
                              Was will mir dieser Fehler sagen ?
                              Bluefox 1 Reply Last reply Reply Quote 0
                              • marcuskl
                                Noch was, welchen Entity Typ wähle ich für eine schaltbare Steckdose ?
                                • Bluefox
                                  Bluefox @marcuskl last edited by
                                  @marcuskl Die sagt, dass man auf 0.1.5 updaten sollte
                                  marcuskl ? 2 Replies Last reply Reply Quote 0
                                  • marcuskl
                                    marcuskl @Bluefox last edited by
                                    @Bluefox
                                    Bei mir zeigtes aber die neuste Version 0.1.1 an
                                      eMd last edited by
                                      Wie bekomme ich die Werte hinten einheitlich hin?
                                      MfG eMd
                                        A Former User @Bluefox last edited by
                                        @Bluefox läuft bei mir leider immer noch nicht, beim starten ein TypeError: cannot read property '0' of undefined, hab ein Issue auf Git erstellt. mit Logfile.
                                        • Asgothian
                                          Asgothian Developer last edited by
                                          Ich hab auch mal angefangen mit dem Lovelace adapter, und klemme mit einem Problem:
                                          Ich habe einige Sensoren über deconz, und habe denen eine Funktion und einen Raum zugewiesen. Allerdings werden die Sensoren nicht als Entity Sensor sondern als Entity Switch erkannt.
                                          Auch bei den Lampen werden die Stati unsauber erkannt (siehe Bild)
                                          • switch.Motion_Sensor_Bathroom ist ein Sensor
                                          • das dim speed Attribut steuert nicht die Helligkeit der Lampen
                                          Kann/muss ich da noch etwas tun ?
                                            thorstenreichelt last edited by thorstenreichelt
                                            der Adapter ist echt Klasse und im gegensatz zur VIS wesentlich schneller und einfacher eingerichtet.
                                            Einige Fragen sind mir allerdings aktuell offen:
                                            • Hat jemand Shelly RGBW Geräte und diese bereits on Lovelace eingebunden? Ich hätte gerne ein Card mit Farbauswahl, Mode und Dimmfunktion.
                                            • Es gibt eine calendar-card für HA. Es es möglich die Werte dafür über den iCal Adapter zu holen? Oder gibt es andere Möglichkeiten?
                                            Update:
                                            • Ist es zudem möglich, den Compact-Custom Header im ioBroker zu nutzen?
                                            Viele Grüße
                                            thorstenreichelt
                                            1.2k
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            376644
