    3. Entwicklung
    4. broadlink2 objChange error wegen TypeError
      Max last edited by Jey Cee
      Re: Adapter: broadlink2
      Mit broadlink V. 2.0.0 lerne ich eine Toshiba IR-Ferbedienung über RM mini 3 für eine Klimaanlage an.
      Neuer Code wird gelernt, erscheint aber nicht als Datenpunkt in der Baumstruktur.
      Was mach ich falsch?
      2019-08-20 22:22:32.347 - info: broadlink2.0 Start -learning for device: RM:RMMINI-16-d0-6a
      2019-08-20 22:22:32.365 - info: broadlink2.0 Should learn on RM:RMMINI-16-d0-6a
      2019-08-20 22:22:35.204 - info: broadlink2.0 Learned new Code RM:RMMINI-16-d0-6a (hex): 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
      2019-08-20 22:22:35.236 - warn: broadlink2.0 objChange error: broadlink2.0.RM:RMMINI-16-d0-6a.L.CODE_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 TypeError: Cannot read property 'FORBIDDEN_CHARS' of undefined
      2019-08-20 22:22:35.480 - info: broadlink2.0 Stop learning for RM:RMMINI-16-d0-6a!
      • AlCalzone
        AlCalzone Developer @Max last edited by AlCalzone
        @Max Welche Version hat dein JS-Controller? Der Adapter scheint eine neuere Version zu erwarten.
        Möglicherweise was für @frankjoke
          Max last edited by
          JS scripte engine V 4.0.7.
          • AlCalzone
            Nicht Skript-Engine. JS-Controller.
              Max last edited by
              JS controller 1.5.3
                Max last edited by
                auf einem windows 10 system
                  Max last edited by
                  unter JS controller 1.5.14 derselbe fehler
                  • AlCalzone
                    @Max Ok dann liegt es definitiv am Adapter.
                      Max @AlCalzone last edited by
                      @AlCalzone danke für die Rückmeldung. Muss ich dann die Fehlermeldung woanders posten?
                        Max @Max last edited by
                        @Max habs auch in GitHub bei @frankjoke unter frankjoke/ioBroker.broadlink2 als issue abgesetzt.
                        262
