    4. Admin Update kein Admin Gui mehr erreichbar
    UNSOLVED Admin Update kein Admin Gui mehr erreichbar
      sigi234 Forum Testing Most Active @fischmir last edited by sigi234
      @fischmir
      iobroker set admin.1 --port 8089
      Was sagt:
      node -v
      npm -v
      Tipp:
      https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
        Habe noch eine weitere Instanz erzeugt, auch ohne Erfolg:
        pi@ioBroker-Pi:/opt/iobroker $ iobroker add admin --port 8089
        host.ioBroker-Pi create instance admin
        host.ioBroker-Pi object admin.2.connected created
        host.ioBroker-Pi object admin.2 created
        host.ioBroker-Pi object admin.2.info created
        host.ioBroker-Pi object system.adapter.admin.upload created
        host.ioBroker-Pi object system.adapter.admin.2.outputCount created
        host.ioBroker-Pi object system.adapter.admin.2.inputCount created
        host.ioBroker-Pi object system.adapter.admin.2.uptime created
        host.ioBroker-Pi object system.adapter.admin.2.memRss created
        host.ioBroker-Pi object system.adapter.admin.2.memHeapTotal created
        host.ioBroker-Pi object system.adapter.admin.2.memHeapUsed created
        host.ioBroker-Pi object system.adapter.admin.2.cputime created
        host.ioBroker-Pi object system.adapter.admin.2.cpu created
        host.ioBroker-Pi object system.adapter.admin.2.connected created
        host.ioBroker-Pi object system.adapter.admin.2.alive created
        host.ioBroker-Pi object system.adapter.admin.2 created
        pi@ioBroker-Pi:/opt/iobroker $ node -v
        v8.15.1
        pi@ioBroker-Pi:/opt/iobroker $ npm v
        npm ERR! code E404
        npm ERR! 404 'iobroker.inst' is not in the npm registry.
        npm ERR! 404 You should bug the author to publish it
        npm ERR! 404 (or use the name yourself!)
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR! 404
        npm ERR! 404  'iobroker.inst@latest' is not in the npm registry.
        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
        npm ERR! 404
        npm ERR!     /home/pi/.npm/_logs/2019-08-22T20_53_33_895Z-debug.log
        --> Das ist verrückt, weil früher am Abend gingen beide Befehle noch. Was heißt das nun?
          @fischmir sagte in Admin Update kein Admin Gui mehr erreichbar:
          Habe einiges mit putty versucht
          Und WAS?
            Hauptsächlich habe ich mir hier orientiert:
            https://forum.iobroker.net/topic/1597/gelöst-nach-admin-update-keine-verbindung-zur-8081-er-seite/7
            sigi234 dslraser 2 Replies Last reply Reply Quote 0
              Beitrag von 2016............?
                Ja, wieso? Zu alt?
                Mittlerweile wieder da.
                v8.16.1
                • dslraser
                  dslraser Forum Testing Most Active @fischmir last edited by
                  @fischmir
                  versuche mal den Fixer
                  curl -sL https://iobroker.net/fix.sh | bash -
                  • dslraser
                    v8.16.1
                    eben, ein Sück weiter oben hattest Du 8.15.1 ?
                      Der Fixer hat es wieder "kaputt" (?) gemacht?
                      pi@ioBroker-Pi:/opt/iobroker $ iobroker list instances
                        system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.admin.1                 : admin       -  enabled, port: 10123, bind: 0.0.0.0, run as: admin
                        system.adapter.admin.2                 : admin       -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                        system.adapter.backitup.0              : backitup    -  enabled
                        system.adapter.cloud.0                 : cloud       -  enabled
                        system.adapter.daswetter.0             : daswetter   -  enabled
                        system.adapter.discovery.0             : discovery   -  enabled
                        system.adapter.dwd.0                   : dwd         -  enabled
                        system.adapter.email.0                 : email       -  enabled
                        system.adapter.fritzbox.0              : fritzbox    -  enabled
                        system.adapter.habpanel.0              : habpanel    -  enabled
                        system.adapter.harmony.0               : harmony     -  enabled
                        system.adapter.hm-rega.0               : hm-rega     -  enabled
                        system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
                        system.adapter.ical.0                  : ical        -  enabled
                        system.adapter.ical.1                  : ical        -  enabled
                        system.adapter.ical.2                  : ical        -  enabled
                        system.adapter.icons-mfd-svg.0         : icons-mfd-svg -  enabled
                        system.adapter.info.0                  : info        -  enabled
                        system.adapter.javascript.0            : javascript  -  enabled
                        system.adapter.landroid-s.0            : landroid-s  -  enabled
                        system.adapter.mihome-vacuum.0         : mihome-vacuum -  enabled, port: 54321
                        system.adapter.musiccast.0             : musiccast   -  enabled
                        system.adapter.pollenflug.0            : pollenflug  -  enabled
                        system.adapter.tankerkoenig.0          : tankerkoenig -  enabled
                        system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.tr-064.0                : tr-064      -  enabled
                        system.adapter.tvspielfilm.0           : tvspielfilm -  enabled
                        system.adapter.vis-bars.0              : vis-bars    -  enabled
                        system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
                        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd -  enabled
                        system.adapter.vis-justgage.0          : vis-justgage -  enabled
                        system.adapter.vis-metro.0             : vis-metro   -  enabled
                        system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
                        system.adapter.vis.0                   : vis         -  enabled
                        system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      pi@ioBroker-Pi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                      ioBroker or some processes are still running:
                       io.admin.0
                      Please stop them first and try again!
                      pi@ioBroker-Pi:/opt/iobroker $ iobroker stop
                          Welcome to the ioBroker installation fixer!
                          Script version: 2019-07-21
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/3)
                          Checking ioBroker user and directory permissions (2/3)
                      Created /etc/sudoers.d/iobroker
                      Fixing directory permissions...
                          Checking autostart (3/3)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      pi@ioBroker-Pi:/opt/iobroker $ iobroker start
                      events.js:183
                            throw er; // Unhandled 'error' event
                      Error: listen EADDRINUSE 127.0.0.1:9001
                          at Server.setupListenHandle [as _listen2] (net.js:1360:14)
                          at listenInCluster (net.js:1401:12)
                          at doListen (net.js:1510:7)
                          at _combinedTickCallback (internal/process/next_tick.js:142:11)
                          at process._tickCallback (internal/process/next_tick.js:181:9)
                        Erst konnte ich die Instanzen noch anzeigen, dann nicht mehr?
                          @fischmir
                          Ich hoffe du hast ein Backup...........
                            Habe den Befehl, die Instanzen aufzulisten zu schnell abgeschickt...admin ist wieder da! 🙂
                              fischmir @sigi234 last edited by
                              @sigi234 sagte in Admin Update kein Admin Gui mehr erreichbar:
                              @fischmir
                              Ja 🙂
                              • dslraser
                                @fischmir
                                also nochmal (in opt/iobroker)
                                node -v
                                nodejs -v
                                npm -v
                                  sigi234 Forum Testing Most Active @dslraser last edited by
                                  @dslraser
                                  Jetzt bin ich gespannt........
                                    Nachdem die Einstellungen wieder in Ordnung sind, sollte man die neuen (port 8089 +10123) Instanzen deinstallieren, um die Ressourcen zu sparen.
                                    admin
                                    1674
