    4. Adapter: ioBroker.unifi
      liv-in-sky @thewhobox last edited by
      @thewhobox
      • dslraser
        dslraser Forum Testing Most Active @thewhobox last edited by
        @thewhobox
        javascript.0	2019-08-26 18:12:12.553	error	at endReadableNT (_stream_readable.js:1145:12)
        javascript.0	2019-08-26 18:12:12.553	error	at IncomingMessage.emit (events.js:203:15)
        javascript.0	2019-08-26 18:12:12.553	error	at Object.onceWrapper (events.js:286:20)
        javascript.0	2019-08-26 18:12:12.553	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1083:12)
        javascript.0	2019-08-26 18:12:12.553	error	at Request.emit (events.js:198:13)
        javascript.0	2019-08-26 18:12:12.553	error	at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1161:10)
        javascript.0	2019-08-26 18:12:12.553	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22)
        javascript.0	2019-08-26 18:12:12.553	error	at Request.request.get [as _callback] (script.js.Heiko.04Telegram.Unifi:29:31)
        javascript.0	2019-08-26 18:12:12.553	error	at JSON.parse (<anonymous>:null:null)
        javascript.0	2019-08-26 18:12:12.552	error	script.js.Heiko.04Telegram.Unifi: SyntaxError: Unexpected token o in JSON at position 1
        javascript.0	2019-08-26 18:12:12.552	info	script.js.Heiko.04Telegram.Unifi: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 19
          @thewhobox
          falls nützlich: info vor fehler
          javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'63','date':'Mon, 26 Aug 2019 16:15:40 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.178.157:8443','port':'8443','hostname':'192.168.178.157','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5cadxxxxxxxxxxxxd7e5381','path':'/api/s/default/rest/wlanconf/5cadxxxxxxxxxxdd7e5381','href':'https://192.168.178.157:8443/api/s/default/rest/wlanconf/5cadca8e3b6a3967dd7e5381'},'method':'GET','headers':{}}}
          • dslraser
            dslraser Forum Testing Most Active @liv-in-sky last edited by dslraser
            @liv-in-sky
            @thewhobox
            das aus aus dem Log unterm Script
            26.8.2019, 18:16:40.833	[info ]: javascript.0 Start javascript script.js.Heiko.Unifi.unifi_wifi
            26.8.2019, 18:16:40.833	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: registered 0 subscriptions and 0 schedules
            26.8.2019, 18:16:41.126	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
            26.8.2019, 18:16:41.149	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
            26.8.2019, 18:16:41.149	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'63','date':'Mon, 26 Aug 2019 16:16:41 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{}}}
            26.8.2019, 18:16:41.149	[error]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: SyntaxError: Unexpected token o in JSON at position 1
            26.8.2019, 18:16:41.149	[error]: javascript.0     at Request.request.get [as _callback] (script.js.Heiko.Unifi.unifi_wifi:29:31)
            thewhobox 2 Replies Last reply Reply Quote 0
            • thewhobox
              thewhobox @dslraser last edited by
              @dslraser Okay, dann speichert er leider den Login cookie nicht automatisch. Muss ich mir heute Abend nochmal anschauen
              • thewhobox
                @dslraser @liv-in-sky Könnte einer von euch mal nach "Login erfolgreich" folgende Zeilen einfügen?
                console.log('HEADERS: ' + JSON.stringify(resp.headers));
                onsole.log('Cookies: ' + resp.getHeader("Set-Cookie"));
                  moin @thewhobox
                  thewhobox 1 Reply Last reply Reply Quote 0
                  • thewhobox
                    thewhobox @liv-in-sky last edited by thewhobox
                    @liv-in-sky Moin. Danke fürs ausprobieren. Hier nochmal das angepasste Script für die cookies.
                    Edit: Siehe unten
                    liv-in-sky dslraser 2 Replies Last reply Reply Quote 1
                      @thewhobox - danke fürs programmieren
                      jetzt kommt der erste fehler wieder 😞
                      bei "const request = require('request');"
                      10:08:00.824	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
                      10:08:01.924	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
                      10:08:01.924	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: registered 0 subscriptions and 0 schedules
                      10:08:01.941	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: Login Fehler! Error: self signed certificate
                      10:08:03.833	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
                      bei "const request = require('request').defaults({ rejectUnauthorized: false });"
                      • dslraser
                        @thewhobox sagte in Adapter: ioBroker.unifi:
                        let cookies = [];
                        bei mir auch
                        10:15:42.843	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
                        10:15:42.843	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Cookies: ["unifises=GyZZk8h1ERsg5Kn9AeYyD2sL5Lcduutx","csrf_token=dKB4b1jFoeScvPlh97hKMywEdt1oUdBI"]
                        10:15:42.893	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
                        10:15:42.893	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':200,'body':'{\'meta\':{\'rc\':\'ok\'},\'data\':[{\'_id\':\'5d3c5be0bc96040011365fe5\',\'enabled\':true,\'security\':\'open\',\'wep_idx\':1,\'wpa_mode\':\'wpa2\',\'wpa_enc\':\'ccmp\',\'usergroup_id\':\'5d3b2323bc9604001132d2c5\',\'dtim_mode\':\'default\',\'dtim_ng\':1,\'dtim_na\':1,\'minrate_ng_enabled\':false,\'minrate_ng_advertising_rates\':false,\'minrate_ng_data_rate_kbps\':1000,\'minrate_ng_cck_rates_enabled\':true,\'minrate_na_enabled\':false,\'minrate_na_advertising_rates\':false,\'minrate_na_data_rate_kbps\':6000,\'mac_filter_enabled\':false,\'mac_filter_policy\':\'allow\',\'mac_filter_list\':[],\'bc_filter_enabled\':false,\'bc_filter_list\':[],\'group_rekey\':3600,\'name\':\'Hübis Gäste\',\'is_guest\':true,\'x_passphrase\':\'dashieristprivat\',\'wlangroup_id\':\'5d3b2323bc9604001132d2c6\',\'schedule\':[],\'minrate_ng_mgmt_rate_kbps\':1000,\'minrate_na_mgmt_rate_kbps\':6000,\'minrate_ng_beacon_rate_kbps\':1000,\'minrate_na_beacon_rate_kbps\':6000,\'site_id\':\'5d3b231abc9604001132d2b8\',\'x_iapp_key\':\'0613db2263d118bc9e21936a202a964e\',\'fast_roaming_enabled\':false,\'no2ghz_oui\':true}]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin,Accept-Encoding','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'1000','date':'Tue, 27 Aug 2019 08:15:42 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{'Cookie':'unifises=GyZZk8h1ERsg5Kn9AeYyD2sL5Lcduutx; csrf_token=dKB4b1jFoeScvPlh97hKMywEdt1oUdBI'}}}
                        10:15:42.893	error	javascript.0 script.js.Heiko.Unifi.unifi_wifi: SyntaxError: Unexpected token o in JSON at position 1
                        10:15:42.893	error	javascript.0 at Request.request.get [as _callback] (script.js.Heiko.Unifi.unifi_wifi:39:31)
                        • thewhobox
                          @liv-in-sky Ja hast recht. Hab den teil vergessen zu ändern.
                          Hab das Skript oben angepasst. einfach mal das JSON.parse weg lassen.
                          • dslraser
                            @thewhobox
                            @liv-in-sky
                            Ich habe keine Ahnung davon, aber wenn ich google dazu befrage, dann kommt Sinngemäß oft die Antwort, das es schon ein Objekt ist und man es direkt verwenden kann und nicht parsen braucht ?
                            Danke für die Mühe.
                            • thewhobox
                              @dslraser Ja das stimmt. Hab das Skript oben angepasst.
                                liv-in-sky @thewhobox last edited by liv-in-sky
                                @thewhobox cool - läuft
                                könntest du das ein und ausschalten auch noch für uns machen 🙂 🙂
                                	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: WLAN ist: an
                                • thewhobox
                                  @liv-in-sky okay super 🙂 Kann ich später machen.
                                  dslraser liv-in-sky 2 Replies Last reply Reply Quote 2
                                  • dslraser
                                    @thewhobox
                                    klappt 👍 👍 👍
                                    10:33:43.645	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
                                    10:33:43.645	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Cookies: ["unifises=JA7z7GVM4cnOB6sZnqkcjBFBFpFzJw5S","csrf_token=GcAjwdvcY6hc58t6E4gLi4X3X7g490mn"]
                                    10:33:43.689	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
                                    10:33:43.690	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':200,'body':'{\'meta\':{\'rc\':\'ok\'},\'data\':[{\'_id\':\'5d3c5be0bc96040011365fe5\',\'enabled\':true,\'security\':\'open\',\'wep_idx\':1,\'wpa_mode\':\'wpa2\',\'wpa_enc\':\'ccmp\',\'usergroup_id\':\'5d3b2323bc9604001132d2c5\',\'dtim_mode\':\'default\',\'dtim_ng\':1,\'dtim_na\':1,\'minrate_ng_enabled\':false,\'minrate_ng_advertising_rates\':false,\'minrate_ng_data_rate_kbps\':1000,\'minrate_ng_cck_rates_enabled\':true,\'minrate_na_enabled\':false,\'minrate_na_advertising_rates\':false,\'minrate_na_data_rate_kbps\':6000,\'mac_filter_enabled\':false,\'mac_filter_policy\':\'allow\',\'mac_filter_list\':[],\'bc_filter_enabled\':false,\'bc_filter_list\':[],\'group_rekey\':3600,\'name\':\'Hübis Gäste\',\'is_guest\':true,\'x_passphrase\':\'dashieristprivat\',\'wlangroup_id\':\'5d3b2323bc9604001132d2c6\',\'schedule\':[],\'minrate_ng_mgmt_rate_kbps\':1000,\'minrate_na_mgmt_rate_kbps\':6000,\'minrate_ng_beacon_rate_kbps\':1000,\'minrate_na_beacon_rate_kbps\':6000,\'site_id\':\'5d3b231abc9604001132d2b8\',\'x_iapp_key\':\'0613db2263d118bc9e21936a202a964e\',\'fast_roaming_enabled\':false,\'no2ghz_oui\':true}]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin,Accept-Encoding','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'1000','date':'Tue, 27 Aug 2019 08:33:43 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{'Cookie':'unifises=JA7z7GVM4cnOB6sZnqkcjBFBFpFzJw5S; csrf_token=GcAjwdvcY6hc58t6E4gLi4X3X7g490mn'}}}
                                    10:33:43.690	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: WLAN ist: an
                                      @thewhobox noch ne frage:
                                      kann ich die function getStatus auch dafür benutzen (ohne header) , um mit dem simpleapi adapter eines anderen iobroker zu kommunizieren ?
                                      • thewhobox
                                        @liv-in-sky Jain, da die Funktion nur auf die spezielle zurückgabe vom Unifi Controller angepasst ist.
                                        Du musst das im Callback anpassen und die Header weglassen.
                                        Vereinfacht geht:
                                        request.get("http://192.168.0.xxx/get/system.adapter.admin.0.alive", (err, resp) => {
                                            if(!err) {
                                                let state = JSON.parse(resp);
                                                console.log("State hat den Wert: " + state.val);
                                            } else {
                                                console.log("Es trat ein Fehler auf: " + err);
                                        liv-in-sky 1 Reply Last reply Reply Quote 1
                                          @thewhobox danke dir - werd das mal testen
                                          • thewhobox
                                            @liv-in-sky So, hier auch noch mit ein und ausschalten. Änderungen sind:
                                            • Bei Aufruf von getStatus oder setWifi wird automatisch vorher eingeloggt.
                                            • Es gibt nun auch ein logout
                                            • Über setWifi(true/false) kann das WLAN ein/aus geschaltet werden.
                                            const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                                            const unifi_username = "user";
                                            const unifi_password = "pass";
                                            const unifi_controller = "https://192.168.x.xx:xxxx";
                                            const wifi_id = "dsa4fsda6g46fdsg984";
                                            let cookies = [];
                                            let loggedIn = false;
                                            async function login() {
                                                return new Promise(async (resolve, reject) => {
                                                    let resp = await request.post({
                                                        url: unifi_controller + "/api/login",
                                                        body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                                                        headers: { 'Content-Type': 'application/json' }
                                                    }).catch((e) => reject(e));
                                                    if(resp != null) {
                                                        console.log("Login war erfolgreich!");
                                                        let set_cookies = resp.headers["set-cookie"];
                                                        for(i = 0; i < set_cookies.length; i++) {
                                                            let cookie = set_cookies[i];
                                                            cookie = cookie.split(";")[0];
                                                            cookies.push(cookie);
                                                        console.log("Cookies: " + JSON.stringify(cookies));
                                                        loggedIn = true;
                                                        resolve();
                                                    } else {
                                                        reject("resp = null");
                                            async function getStatus() {
                                                    if(!loggedIn) await login().catch((e) => reject(e));
                                                    let resp = await request.get({
                                                        url: unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id,
                                                        headers: { Cookie: cookies.join("; ") }
                                                    if(resp != null && resp.statusCode == 200) {
                                                        console.log("Status erfolgreich geholt!");
                                                        console.log(resp);
                                                        let status = JSON.parse(resp);
                                                        let wlanOn = status.data[0].enabled;
                                                        console.log("WLAN ist: " + (wlanOn ? "an" : "aus"));
                                                        resolve(wlanOn);
                                                    } else {
                                                        reject(JSON.parse(resp.body).meta.msg);
                                            async function logout() {
                                                        url: unifi_controller + "/logout",
                                                    if(resp != null) {
                                                        console.log("Du bist nun ausgeloggt.");
                                                        console.log(resp);
                                                        resolve();
                                                    } else {
                                            async function setWifi(enabled) {
                                                    let resp = request.post({
                                                        body: JSON.stringify({ _id: "", enabled }),
                                                        headers: { 'Content-Type': 'application/json', Cookie: cookies.join("; ") }
                                                        console.log("Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                                                        console.log(resp);
                                                        resolve();
                                                    } else {
                                            Aufruf über:
                                            async function test() {
                                                await setWifi(true).catch((e) => console.log("Es trat ein Fehler auf: " + e));
                                                let isWlanOn = await getStatus();
                                            test();
                                            1.0k
                                            unifi
                                            171
                                            1010
                                            386342
