    4. Adapter: ioBroker.unifi
      liv-in-sky @thewhobox last edited by
      @thewhobox - danke fürs programmieren
      jetzt kommt der erste fehler wieder 😞
      bei "const request = require('request');"
      10:08:00.824	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
      10:08:01.924	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
      10:08:01.924	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: registered 0 subscriptions and 0 schedules
      10:08:01.941	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: Login Fehler! Error: self signed certificate
      10:08:03.833	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
      bei "const request = require('request').defaults({ rejectUnauthorized: false });"
      thewhobox 1 Reply Last reply Reply Quote 0
      • dslraser
        dslraser Forum Testing Most Active @thewhobox last edited by
        @thewhobox sagte in Adapter: ioBroker.unifi:
        let cookies = [];
        bei mir auch
        10:15:42.843	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
        10:15:42.843	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Cookies: ["unifises=GyZZk8h1ERsg5Kn9AeYyD2sL5Lcduutx","csrf_token=dKB4b1jFoeScvPlh97hKMywEdt1oUdBI"]
        10:15:42.893	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
        10:15:42.893	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':200,'body':'{\'meta\':{\'rc\':\'ok\'},\'data\':[{\'_id\':\'5d3c5be0bc96040011365fe5\',\'enabled\':true,\'security\':\'open\',\'wep_idx\':1,\'wpa_mode\':\'wpa2\',\'wpa_enc\':\'ccmp\',\'usergroup_id\':\'5d3b2323bc9604001132d2c5\',\'dtim_mode\':\'default\',\'dtim_ng\':1,\'dtim_na\':1,\'minrate_ng_enabled\':false,\'minrate_ng_advertising_rates\':false,\'minrate_ng_data_rate_kbps\':1000,\'minrate_ng_cck_rates_enabled\':true,\'minrate_na_enabled\':false,\'minrate_na_advertising_rates\':false,\'minrate_na_data_rate_kbps\':6000,\'mac_filter_enabled\':false,\'mac_filter_policy\':\'allow\',\'mac_filter_list\':[],\'bc_filter_enabled\':false,\'bc_filter_list\':[],\'group_rekey\':3600,\'name\':\'Hübis Gäste\',\'is_guest\':true,\'x_passphrase\':\'dashieristprivat\',\'wlangroup_id\':\'5d3b2323bc9604001132d2c6\',\'schedule\':[],\'minrate_ng_mgmt_rate_kbps\':1000,\'minrate_na_mgmt_rate_kbps\':6000,\'minrate_ng_beacon_rate_kbps\':1000,\'minrate_na_beacon_rate_kbps\':6000,\'site_id\':\'5d3b231abc9604001132d2b8\',\'x_iapp_key\':\'0613db2263d118bc9e21936a202a964e\',\'fast_roaming_enabled\':false,\'no2ghz_oui\':true}]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin,Accept-Encoding','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'1000','date':'Tue, 27 Aug 2019 08:15:42 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{'Cookie':'unifises=GyZZk8h1ERsg5Kn9AeYyD2sL5Lcduutx; csrf_token=dKB4b1jFoeScvPlh97hKMywEdt1oUdBI'}}}
        10:15:42.893	error	javascript.0 script.js.Heiko.Unifi.unifi_wifi: SyntaxError: Unexpected token o in JSON at position 1
        10:15:42.893	error	javascript.0 at Request.request.get [as _callback] (script.js.Heiko.Unifi.unifi_wifi:39:31)
        • thewhobox
          thewhobox @liv-in-sky last edited by
          @liv-in-sky Ja hast recht. Hab den teil vergessen zu ändern.
          Hab das Skript oben angepasst. einfach mal das JSON.parse weg lassen.
          • dslraser
            @thewhobox
            @liv-in-sky
            Ich habe keine Ahnung davon, aber wenn ich google dazu befrage, dann kommt Sinngemäß oft die Antwort, das es schon ein Objekt ist und man es direkt verwenden kann und nicht parsen braucht ?
            Danke für die Mühe.
            • thewhobox
              thewhobox @dslraser last edited by
              @dslraser Ja das stimmt. Hab das Skript oben angepasst.
                liv-in-sky @thewhobox last edited by liv-in-sky
                @thewhobox cool - läuft
                könntest du das ein und ausschalten auch noch für uns machen 🙂 🙂
                	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: WLAN ist: an
                thewhobox 2 Replies Last reply Reply Quote 0
                • thewhobox
                  @liv-in-sky okay super 🙂 Kann ich später machen.
                  dslraser liv-in-sky 2 Replies Last reply Reply Quote 2
                  • dslraser
                    @thewhobox
                    klappt 👍 👍 👍
                    10:33:43.645	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
                    10:33:43.645	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Cookies: ["unifises=JA7z7GVM4cnOB6sZnqkcjBFBFpFzJw5S","csrf_token=GcAjwdvcY6hc58t6E4gLi4X3X7g490mn"]
                    10:33:43.689	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
                    10:33:43.690	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':200,'body':'{\'meta\':{\'rc\':\'ok\'},\'data\':[{\'_id\':\'5d3c5be0bc96040011365fe5\',\'enabled\':true,\'security\':\'open\',\'wep_idx\':1,\'wpa_mode\':\'wpa2\',\'wpa_enc\':\'ccmp\',\'usergroup_id\':\'5d3b2323bc9604001132d2c5\',\'dtim_mode\':\'default\',\'dtim_ng\':1,\'dtim_na\':1,\'minrate_ng_enabled\':false,\'minrate_ng_advertising_rates\':false,\'minrate_ng_data_rate_kbps\':1000,\'minrate_ng_cck_rates_enabled\':true,\'minrate_na_enabled\':false,\'minrate_na_advertising_rates\':false,\'minrate_na_data_rate_kbps\':6000,\'mac_filter_enabled\':false,\'mac_filter_policy\':\'allow\',\'mac_filter_list\':[],\'bc_filter_enabled\':false,\'bc_filter_list\':[],\'group_rekey\':3600,\'name\':\'Hübis Gäste\',\'is_guest\':true,\'x_passphrase\':\'dashieristprivat\',\'wlangroup_id\':\'5d3b2323bc9604001132d2c6\',\'schedule\':[],\'minrate_ng_mgmt_rate_kbps\':1000,\'minrate_na_mgmt_rate_kbps\':6000,\'minrate_ng_beacon_rate_kbps\':1000,\'minrate_na_beacon_rate_kbps\':6000,\'site_id\':\'5d3b231abc9604001132d2b8\',\'x_iapp_key\':\'0613db2263d118bc9e21936a202a964e\',\'fast_roaming_enabled\':false,\'no2ghz_oui\':true}]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin,Accept-Encoding','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'1000','date':'Tue, 27 Aug 2019 08:33:43 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{'Cookie':'unifises=JA7z7GVM4cnOB6sZnqkcjBFBFpFzJw5S; csrf_token=GcAjwdvcY6hc58t6E4gLi4X3X7g490mn'}}}
                    10:33:43.690	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: WLAN ist: an
                      @thewhobox noch ne frage:
                      kann ich die function getStatus auch dafür benutzen (ohne header) , um mit dem simpleapi adapter eines anderen iobroker zu kommunizieren ?
                      • thewhobox
                        @liv-in-sky Jain, da die Funktion nur auf die spezielle zurückgabe vom Unifi Controller angepasst ist.
                        Du musst das im Callback anpassen und die Header weglassen.
                        Vereinfacht geht:
                        request.get("http://192.168.0.xxx/get/system.adapter.admin.0.alive", (err, resp) => {
                            if(!err) {
                                let state = JSON.parse(resp);
                                console.log("State hat den Wert: " + state.val);
                            } else {
                                console.log("Es trat ein Fehler auf: " + err);
                        liv-in-sky 1 Reply Last reply Reply Quote 1
                          @thewhobox danke dir - werd das mal testen
                          • thewhobox
                            thewhobox @liv-in-sky last edited by thewhobox
                            @liv-in-sky So, hier auch noch mit ein und ausschalten. Änderungen sind:
                            • Bei Aufruf von getStatus oder setWifi wird automatisch vorher eingeloggt.
                            • Es gibt nun auch ein logout
                            • Über setWifi(true/false) kann das WLAN ein/aus geschaltet werden.
                            const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                            const unifi_username = "user";
                            const unifi_password = "pass";
                            const unifi_controller = "https://192.168.x.xx:xxxx";
                            const wifi_id = "dsa4fsda6g46fdsg984";
                            let cookies = [];
                            let loggedIn = false;
                            async function login() {
                                return new Promise(async (resolve, reject) => {
                                    let resp = await request.post({
                                        url: unifi_controller + "/api/login",
                                        body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                                        headers: { 'Content-Type': 'application/json' }
                                    }).catch((e) => reject(e));
                                    if(resp != null) {
                                        console.log("Login war erfolgreich!");
                                        let set_cookies = resp.headers["set-cookie"];
                                        for(i = 0; i < set_cookies.length; i++) {
                                            let cookie = set_cookies[i];
                                            cookie = cookie.split(";")[0];
                                            cookies.push(cookie);
                                        console.log("Cookies: " + JSON.stringify(cookies));
                                        loggedIn = true;
                                        resolve();
                                    } else {
                                        reject("resp = null");
                            async function getStatus() {
                                    if(!loggedIn) await login().catch((e) => reject(e));
                                    let resp = await request.get({
                                        url: unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id,
                                        headers: { Cookie: cookies.join("; ") }
                                    if(resp != null && resp.statusCode == 200) {
                                        console.log("Status erfolgreich geholt!");
                                        console.log(resp);
                                        let status = JSON.parse(resp);
                                        let wlanOn = status.data[0].enabled;
                                        console.log("WLAN ist: " + (wlanOn ? "an" : "aus"));
                                        resolve(wlanOn);
                                    } else {
                                        reject(JSON.parse(resp.body).meta.msg);
                            async function logout() {
                                        url: unifi_controller + "/logout",
                                    if(resp != null) {
                                        console.log("Du bist nun ausgeloggt.");
                                        console.log(resp);
                                        resolve();
                                    } else {
                            async function setWifi(enabled) {
                                    let resp = request.post({
                                        body: JSON.stringify({ _id: "", enabled }),
                                        headers: { 'Content-Type': 'application/json', Cookie: cookies.join("; ") }
                                        console.log("Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                                        console.log(resp);
                                        resolve();
                                    } else {
                            Aufruf über:
                            async function test() {
                                await setWifi(true).catch((e) => console.log("Es trat ein Fehler auf: " + e));
                                let isWlanOn = await getStatus();
                            test();
                              @thewhobox also wenn ich dich richtig verstehe
                              kann ich mit setWifi(true) einschalten bzw setWifi(false) ausschalten - dass funktioniert aber nicht
                              es wird nicht geschalten obwohl die meldung es sagt
                              oder mach ich was falsch ?
                              • thewhobox
                                @liv-in-sky Ah okay. Nein liegt nicht an dir. ich hab vergessen, dass das alles ja gar nicht synchron abläuft.
                                Ich hab den Code oben angepasst.
                                Achtung! Jetzt wird das Modul request-promise-native benötigt.
                                Beachte! Die Funktionen sind nun asynchron! Heißt um danach den Status abfragen zu können musst du es in eine ebenfalls asynchrone Funktion machen und mit await auf die beendigung warten.
                                asynch function test() {
                                    await setWifi(true);
                                  @thewhobox da stimmt was nicht mit dem upgedaten file
                                  • thewhobox
                                    @liv-in-sky Habs korrigiert.
                                      @thewhobox compiler fehler bei der
                                      sollte woh async heißen
                                        liv-in-sky @liv-in-sky last edited by
                                        @liv-in-sky wenn ich test() aufrufe passiert nix
                                        • thewhobox
                                          @liv-in-sky Jap, das liegt daran, dass ich zuwenig geschlafen habe^^
                                          Ich korrigiere das gleich.
                                            @thewhobox mach dir keinen stress @dslraser und ich sind froh, dass du dich darum kümmerst - wir testen solange, bis es läuft
                                            unifi
                                            171
                                            1010
                                            386378
