    4. ioBroker.upnp - please test
    • Jey Cee
      Jey Cee Developer @crunchip last edited by
      @crunchip und da haben wir das problem, warum die nicht erkannt werden. Der Zugriff auf die XML ist notwendig um die Geräte an zu legen.
        crunchip Forum Testing Most Active @Jey Cee last edited by
        @Jey-Cee so sehen nun meine Fehler aus
        einzigste ist, das nun nicht mehr jeden Tag, die Fehlermeldungen kommen
        2019-07-15 07:54:51.629 - error: upnp.0 uncaught exception: Cannot read property 'LastChange' of undefined
        2019-07-15 07:54:51.630 - error: upnp.0 TypeError: Cannot read property 'LastChange' of undefined
        at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1384:70)
        at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
        at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
        at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
        at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
        at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
        at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        2019-07-15 07:54:52.664 - error: Caught by controller[0]: TypeError: Cannot read property 'LastChange' of undefined
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1384:70)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
        2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        2019-07-15 07:54:52.666 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        2019-07-15 07:54:52.666 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
        2019-07-15 07:54:52.666 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
        2019-07-15 07:54:52.666 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        2019-07-15 07:54:52.666 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
        2019-07-15 07:54:52.666 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
        2019-07-15 07:55:22.691 - info: host.IoBroker instance system.adapter.upnp.0 started with pid 30593
        2019-07-15 07:55:24.266 - info: upnp.0 starting. Version 1.0.13 in /opt/iobroker/node_modules/iobroker.upnp, node: v10.16.0
        2019-07-15 07:55:24.300 - info: upnp.0 Auto discover: false
        Bluefox 1 Reply Last reply Reply Quote 0
          Andre R. last edited by
          kann ich die Geräte die ich nicht brauche unter Objekte eigentlich löschen?
          • SBorg
            Ich sag mal Jein. Löschen an sich stellt kein Problem dar, nur wenn das entsprechende Gerät selbst UPnP macht, werden sie erneut angelegt 😉
              sigi234 Forum Testing Most Active @Andre R. last edited by
              @Andre-R sagte in ioBroker.upnp - please test:
              Ja, aber beim Adapter die automatische Erkennung ausschalten..........
                Andre R. @sigi234 last edited by
                @sigi234
                hab ich eh abgeschalten
                • Bluefox
                  Bluefox @crunchip last edited by
                  @crunchip Fehler gefixt
                  crunchip 1 Reply Last reply Reply Quote 1
                    crunchip Forum Testing Most Active @Bluefox last edited by
                    @Bluefox dann test ich mal
                    • Jey Cee
                      Auf github liegt die Version 1.0.15 zum Testen bereit.
                      Ich hab einen Fehler gefixt der verhindert hat das Befehle mit Parametern ausgeführt werden.
                      • Asgothian
                        Asgothian Developer @Jey Cee last edited by
                        Test läuft.
                        A.
                        31.7k
                        79.8k
                        adapter test
                        18
                        196
                        19451
