    4. Adapter: ioBroker.unifi
      liv-in-sky @thewhobox last edited by
      @thewhobox also mit dem linux script ist die id richtig und wird ein und ausgeschalten -- id im linuxscript ist die selbe wie in deinem
      thewhobox 1 Reply Last reply Reply Quote 0
        @thewhobox
        09:33:56.981	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:33:57.965	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:33:57.965	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
        09:33:57.965	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
        09:33:57.965	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
        09:33:57.965	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
        09:33:58.196	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: got response: {"statusCode":200,"body":"{\"meta\":{\"rc\":\"ok\"},\"data\":[]}","headers":{"vary":"Origin","access-control-allow-credentials":"true","access-control-expose-headers":"Access-Control-Allow-Origin,Access-Control-Allow-Credentials","set-cookie":["unifises=yrsA7DInl1z2N6wr4IpLjwaR4fuKq1yc; Path=/; Secure; HttpOnly","csrf_token=X1FfCKVPvRUrXuhNffnO4sf9IbtNq5PH; Path=/; Secure"],"x-frame-options":"DENY","content-type":"application/json;charset=UTF-8","content-length":"30","date":"Wed, 28 Aug 2019 07:33:58 GMT","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.157:8443","port":"8443","hostname":"192.168.178.157","hash":null,"search":null,"query":null,"pathname":"/api/login","path":"/api/login","href":"https://192.168.178.157:8443/api/login"},"method":"POST","headers":{"Content-Type":"application/json","content-length":40}}}
        09:33:58.196	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich!
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: set_cookies:
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Cookies: ["unifises=yrsA7DInl1z2N6wr4IpLjwaR4fuKq1yc","csrf_token=X1FfCKVPvRUrXuhNffnO4sf9IbtNq5PH"]
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: resolved
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
        09:33:58.197	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
        09:33:58.210	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejected: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
        09:33:58.210	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: reject1: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
        09:33:58.210	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
        • thewhobox
          thewhobox @liv-in-sky last edited by
          @liv-in-sky Okay. Dann ersetze mal bitte die Zeile in setWifi:
          body: JSON.stringify({ enabled }),
            @thewhobox
            hier der test mit linux
            unifi enable
            {"meta":{"rc":"ok"},"data":[]}Enabling WiFi.
            {"meta":{"rc":"ok"},"data":[{"_id":"5d6512a897578401d1edd761","enabled":true,"security":"open","wep_idx":1,"wpa_mode":"wpa2","wpa_enc":"ccmp","usergroup_id":"5cadc7f73b6a3967dd7e5376","dtim_mode":"default","dtim_ng":1,"dtim_na":1,"minrate_ng_enabled":false,"minrate_ng_advertising_rates":false,"minrate_ng_data_rate_kbps":1000,"minrate_ng_cck_rates_enabled":true,"minrate_na_enabled":false,"minrate_na_advertising_rates":false,"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"mac_filter_policy":"allow","mac_filter_list":[],"bc_filter_enabled":false,"bc_filter_list":[],"group_rekey":3600,"name":"DragonRootGuest","wlangroup_id":"5cadc7f73b6a3967dd7e5377","fast_roaming_enabled":false,"schedule":[],"minrate_ng_mgmt_rate_kbps":1000,"minrate_na_mgmt_rate_kbps":6000,"minrate_ng_beacon_rate_kbps":1000,"minrate_na_beacon_rate_kbps":6000,"site_id":"5cadc7f53b6a3967dd7e5369","x_iapp_key":"cf930ad9a6750bd1d7c2f8676f775668","name_combine_enabled":true}]}root@iobroker59 09:28:00  /usr/local/bin   >
            unifi disable
            {"meta":{"rc":"ok"},"data":[]}Disabling WiFi.
            {"meta":{"rc":"ok"},"data":[{"_id":"5d6512a897578401d1edd761","enabled":false,"security":"open","wep_idx":1,"wpa_mode":"wpa2","wpa_enc":"ccmp","usergroup_id":"5cadc7f73b6a3967dd7e5376","dtim_mode":"default","dtim_ng":1,"dtim_na":1,"minrate_ng_enabled":false,"minrate_ng_advertising_rates":false,"minrate_ng_data_rate_kbps":1000,"minrate_ng_cck_rates_enabled":true,"minrate_na_enabled":false,"minrate_na_advertising_rates":false,"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"mac_filter_policy":"allow","mac_filter_list":[],"bc_filter_enabled":false,"bc_filter_list":[],"group_rekey":3600,"name":"DragonRootGuest","wlangroup_id":"5cadc7f73b6a3967dd7e5377","fast_roaming_enabled":false,"schedule":[],"minrate_ng_mgmt_rate_kbps":1000,"minrate_na_mgmt_rate_kbps":6000,"minrate_ng_beacon_rate_kbps":1000,"minrate_na_beacon_rate_kbps":6000,"site_id":"5cadc7f53b6a3967dd7e5369","x_iapp_key":"cf930ad9a6750bd1d7c2f8676f775668","name_combine_enabled":true}]}root@iobroker59 09:29:23  /usr/local/bin   >
              @thewhobox sagte in Adapter: ioBroker.unifi:
              jetzt weiß ich wieder, warum ich mit json auf kriegsfuß stehe 😞
              09:36:40.055	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
              09:36:40.065	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:36:40.065	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:36:40.069	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:36:40.080	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
              09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
              09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
              09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
              09:36:40.311	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: got response: {"statusCode":200,"body":"{\"meta\":{\"rc\":\"ok\"},\"data\":[]}","headers":{"vary":"Origin","access-control-allow-credentials":"true","access-control-expose-headers":"Access-Control-Allow-Origin,Access-Control-Allow-Credentials","set-cookie":["unifises=4lIovxEqmKXvAF8JehI733XXQ6fSh1Se; Path=/; Secure; HttpOnly","csrf_token=4D3RfUt1GtDD4k6JXdNUcunJw5O0jqvu; Path=/; Secure"],"x-frame-options":"DENY","content-type":"application/json;charset=UTF-8","content-length":"30","date":"Wed, 28 Aug 2019 07:36:40 GMT","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.157:8443","port":"8443","hostname":"192.168.178.157","hash":null,"search":null,"query":null,"pathname":"/api/login","path":"/api/login","href":"https://192.168.178.157:8443/api/login"},"method":"POST","headers":{"Content-Type":"application/json","content-length":40}}}
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich!
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: set_cookies:
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Cookies: ["unifises=4lIovxEqmKXvAF8JehI733XXQ6fSh1Se","csrf_token=4D3RfUt1GtDD4k6JXdNUcunJw5O0jqvu"]
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: resolved
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
              09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
              09:36:40.322	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejected: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
              09:36:40.322	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: reject1: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
              09:36:40.322	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
              09:36:42.072	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
              09:36:42.095	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:36:42.117	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:36:42.117	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
              09:36:42.118	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
              09:36:42.118	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
              09:36:42.118	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: got response: {"statusCode":200,"body":"{\"meta\":{\"rc\":\"ok\"},\"data\":[]}","headers":{"vary":"Origin","access-control-allow-credentials":"true","access-control-expose-headers":"Access-Control-Allow-Origin,Access-Control-Allow-Credentials","set-cookie":["unifises=EnoMzZ5FyglDTNPrZYGa2hvP16jewWiU; Path=/; Secure; HttpOnly","csrf_token=fAjfJm99u8hTqyKjEBfv7IRA4lZMILYO; Path=/; Secure"],"x-frame-options":"DENY","content-type":"application/json;charset=UTF-8","content-length":"30","date":"Wed, 28 Aug 2019 07:36:42 GMT","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.157:8443","port":"8443","hostname":"192.168.178.157","hash":null,"search":null,"query":null,"pathname":"/api/login","path":"/api/login","href":"https://192.168.178.157:8443/api/login"},"method":"POST","headers":{"Content-Type":"application/json","content-length":40}}}
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich!
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: set_cookies:
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Cookies: ["unifises=EnoMzZ5FyglDTNPrZYGa2hvP16jewWiU","csrf_token=fAjfJm99u8hTqyKjEBfv7IRA4lZMILYO"]
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: resolved
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
              09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
              09:36:42.429	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejected: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
              09:36:42.429	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: reject1: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
              09:36:42.429	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
              • thewhobox
                @liv-in-sky Okay, zu dem Fehler finde ich leider auch nix im Netz. Hab es jetzt mal so angepasst wie in deinem verlinkten Skript.
                Was mich wundert, dass nach "getting status" nix mehr kommt...
                const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                const unifi_username = "user";
                const unifi_password = "pass";
                const unifi_controller = "https://192.168.x.xx:xxxx";
                const wifi_id = "dsa4fsda6g46fdsg984";
                let cookies = [];
                let loggedIn = false;
                async function login() {
                   return new Promise(async (resolve, reject) => {
                       let resp = await request.post({
                           resolveWithFullResponse: true,
                           url: unifi_controller + "/api/login",
                           body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                           headers: { 'Content-Type': 'application/json' }
                       }).catch((e) => { console.log("login: reject"), reject(e) });
                       if(resp != null) {
                           console.log("login: Login war erfolgreich! " + ((resp.headers && resp.headers.hasOwnProperty("set-cookie")) ? "Mit Cookies":"Ohne Cookies"));
                           if(resp.headers && resp.headers.hasOwnProperty("set-cookie")) {
                               let set_cookies = resp.headers["set-cookie"];
                               for(i = 0; i < set_cookies.length; i++) {
                                   let cookie = set_cookies[i];
                                   cookie = cookie.split(";")[0];
                                   cookies.push(cookie);
                           } else {
                               console.log("login: no cookies to set!")
                           loggedIn = true;
                           resolve();
                       } else {
                           console.log("login: rejected")
                           reject("resp = null");
                async function getStatus() {
                       console.log("nur mal so");
                       if(!loggedIn) await login().catch((e) => reject(e));
                       let resp = await request.get({
                           url: unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id,
                           headers: { Cookie: cookies.join("; ") }
                       }).catch((e) => { console.log("getStatus reject " + e); reject(e) });
                       console.log("got response " + JSON.stringify(resp));
                       if(resp != null && resp.statusCode == 200) {
                           console.log("Status erfolgreich geholt!");
                           console.log(resp);
                           let status = JSON.parse(resp);
                           let wlanOn = status.data[0].enabled;
                           console.log("WLAN ist: " + (wlanOn ? "an" : "aus"));
                           resolve(wlanOn);
                       } else {
                           reject(JSON.parse(resp.body).meta.msg);
                async function logout() {
                           url: unifi_controller + "/logout",
                       }).catch((e) => reject(e));
                       if(resp != null) {
                           console.log("Du bist nun ausgeloggt.");
                           console.log(resp);
                           resolve();
                       } else {
                async function setWifi(enabled) {
                       console.log("setWifi: start set wifi");
                       if(!loggedIn) { console.log("need to login"); await login().catch((e) => reject(e)); }
                       console.log("setWifi: now setting wifi");
                       let resp = request.post({
                           url: unifi_controller + "/api/s/default/upd/wlanconf/" + wifi_id,
                           headers: { 'Content-Type': 'application/json', Cookie: cookies.join("; ") }
                       }).catch((e) => { console.log("setWifi: rejected: " + e); reject(e) });
                       console.log("setWifi: got response")
                           console.log("setWifi: Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                           console.log(resp);
                           resolve();
                       } else {
                           console.log("setWifi: rejetced")
                           console.log("resp: " + JSON.stringify(resp));
                           reject("msg: " + JSON.parse(resp.body).meta.msg);
                async function test() {
                   console.log("starting test");
                   await setWifi(true).catch((e) => console.log("reject1: " + e));
                   console.log("getting status");
                   let wlan = await getStatus().catch((e) => console.log("reject2: " + e));
                   console.log("fin")
                   console.log(wlan);
                test()
                  @thewhobox moment noch - jetzt ist was passiert
                    @thewhobox
                    jeah -
                    scheint zu klappen - kann es ein und ausschalten
                    09:55:42.324	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
                    09:55:42.331	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                    09:55:42.337	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                    09:55:42.341	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                    09:55:42.352	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                    09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
                    09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
                    09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
                    09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
                    09:55:42.672	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
                    09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
                    09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
                    09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
                    09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
                    09:55:44.342	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
                    09:55:44.360	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                    09:55:44.408	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                    09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
                    09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
                    09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
                    09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
                    09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
                    09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
                    09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
                    09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
                    09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
                    • dslraser
                      dslraser Forum Testing Most Active @liv-in-sky last edited by
                      @liv-in-sky
                      @thewhobox
                      moin, schon alle wieder fleißig...
                      Welches ist jetzt das komplette Script ?
                        liv-in-sky @dslraser last edited by
                        @dslraser 3 posts weiter oben
                        • thewhobox
                          So hier nochmal mit Console Ausgaben nur wenn debug true ist.
                          @dslraser bringt er bei dir auch was nach "getting status"?
                          let cookies = [];
                          let debug = false;
                          function log(message) {
                             if(debug)
                                 console.log(message);
                                 }).catch((e) => { log("login: reject"), reject(e) });
                                 if(resp != null) {
                                     } else {
                                     loggedIn = true;
                                     resolve();
                                 } else {
                                 log("nur mal so");
                                 }).catch((e) => { log("getStatus reject " + e); reject(e) });
                                     log(resp);
                                     resolve(wlanOn);
                                 } else {
                                 if(resp != null) {
                                     log(resp);
                                     resolve();
                                 } else {
                                 if(!loggedIn) { log("need to login"); await login().catch((e) => reject(e)); }
                                 }).catch((e) => { log("setWifi: rejected: " + e); reject(e) });
                                 if(resp != null) {
                                     log(resp);
                                     resolve();
                                 } else {
                             await setWifi(true).catch((e) => log("reject1: " + e));
                             let wlan = await getStatus().catch((e) => log("reject2: " + e));
                             console.log("fin")
                             console.log(wlan);
                          test()
                          dslraser liv-in-sky 2 Replies Last reply Reply Quote 0
                            was aber nervt - nicht script - es werden immer alle netzwerke aus und eingeschaltet - ist beim linux script auch - das scheint etwas mit unifi selbst zu tun zu haben
                            • dslraser
                              dslraser Forum Testing Most Active @thewhobox last edited by
                              @thewhobox
                              ich bin irgendwo nicht mit gekommen...?
                              das passiert beim letzten Script
                              javascript.0	2019-08-28 10:07:00.672	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                              javascript.0	2019-08-28 10:07:00.672	error	at script.js.Heiko.Unifi.unifi_wifi:1:1
                              javascript.0	2019-08-28 10:07:00.672	error	SyntaxError: Identifier 'log' has already been declared
                              javascript.0	2019-08-28 10:07:00.672	error	^
                              javascript.0	2019-08-28 10:07:00.672	error	const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                              javascript.0	2019-08-28 10:07:00.672	error	script.js.Heiko.Unifi.unifi_wifi: script.js.Heiko.Unifi.unifi_wifi:1
                                @thewhobox
                                muss leider nochmal fragen - wenn ich nur getStatus() anstatt test() aufrufe, sollte das funktionieren - es kommt kein WLAN ist an oder aus
                                10:05:22.860	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
                                10:05:22.864	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                                10:05:22.865	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                                10:05:22.874	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                                10:05:22.886	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                                10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
                                10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
                                10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
                                10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
                                10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
                                10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
                                10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
                                10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: Wifi wurde erfolgreich eingeschaltet
                                10:05:23.175	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: {}
                                10:05:23.175	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
                                10:05:23.175	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: nur mal so
                                10:05:23.183	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d6512a897578401d1edd761\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5cadc7f73b6a3967dd7e5376\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"DragonRootGuest\",\"wlangroup_id\":\"5cadc7f73b6a3967dd7e5377\",\"fast_roaming_enabled\":false,\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5cadc7f53b6a3967dd7e5369\",\"x_iapp_key\":\"cf930ad9a6750bd1d7c2f8676f775668\",\"name_combine_enabled\":true}]}"
                                10:05:24.876	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
                                10:05:24.895	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                                10:05:24.919	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                                10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
                                10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
                                10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
                                10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
                                10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
                                10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
                                10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
                                10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: Wifi wurde erfolgreich eingeschaltet
                                10:05:25.206	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: {}
                                10:05:25.206	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
                                10:05:25.206	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: nur mal so
                                10:05:25.214	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d6512a897578401d1edd761\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5cadc7f73b6a3967dd7e5376\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"DragonRootGuest\",\"wlangroup_id\":\"5cadc7f73b6a3967dd7e5377\",\"fast_roaming_enabled\":false,\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5cadc7f53b6a3967dd7e5369\",\"x_iapp_key\":\"cf930ad9a6750bd1d7c2f8676f775668\",\"name_combine_enabled\":true}]}"
                                • thewhobox
                                  thewhobox @dslraser last edited by
                                  @dslraser Nein war mein Fehler gerade, jetzt nochmal:
                                  @liv-in-sky laut Log hast du aber test aufgerufen? Hätte aber trotzdem nicht funktioniert, sollte jetzt aber gefixt sein.
                                  let cookies = [];
                                  let debug = true;
                                  function dlog(message) {
                                     if(debug)
                                         }).catch((e) => { dlog("login: reject"), reject(e) });
                                         if(resp != null) {
                                             dlog("login: login war erfolgreich! " + ((resp.headers && resp.headers.hasOwnProperty("set-cookie")) ? "Mit Cookies":"Ohne Cookies"));
                                             } else {
                                                 dlog("login: no cookies to set!")
                                             loggedIn = true;
                                             resolve();
                                         } else {
                                             dlog("login: rejected")
                                         dlog("nur mal so");
                                         }).catch((e) => { dlog("getStatus reject " + e); reject(e) });
                                         dlog("got response " + JSON.stringify(resp));
                                         if(resp != null && resp.meta.rc == "ok") {
                                             dlog("Status erfolgreich geholt!");
                                             dlog(resp);
                                             let wlanOn = resp.data[0].enabled;
                                             dlog("WLAN ist: " + (wlanOn ? "an" : "aus"));
                                             resolve(wlanOn);
                                         } else {
                                             reject(JSON.stringify(resp));
                                  async function dlogout() {
                                             url: unifi_controller + "/dlogout",
                                         if(resp != null) {
                                             dlog("Du bist nun ausgedloggt.");
                                             dlog(resp);
                                             resolve();
                                         } else {
                                         dlog("setWifi: start set wifi");
                                         if(!loggedIn) { dlog("need to login"); await login().catch((e) => reject(e)); }
                                         dlog("setWifi: now setting wifi");
                                         }).catch((e) => { dlog("setWifi: rejected: " + e); reject(e) });
                                         dlog("setWifi: got response")
                                         if(resp != null) {
                                             dlog("setWifi: Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                                             dlog(resp);
                                             resolve();
                                         } else {
                                             dlog("setWifi: rejetced")
                                             dlog("resp: " + JSON.stringify(resp));
                                     dlog("starting test");
                                     await setWifi(true).catch((e) => dlog("reject1: " + e));
                                     dlog("getting status");
                                     let wlan = await getStatus().catch((e) => dlog("reject2: " + e));
                                     console.log("fin")
                                     console.log(wlan);
                                  test()
                                  liv-in-sky dslraser 2 Replies Last reply Reply Quote 0
                                    @thewhobox sorry falsches log
                                    • thewhobox
                                      @liv-in-sky Ah okay. Wie gesagt, das hätte auch nicht klappen können^^
                                      Versuch es mal mit dem neuen Skript von eins oben drüber.
                                        @thewhobox war das neuste script
                                        • dslraser
                                          @thewhobox
                                          in dem Log steht nun auch der Netzwerkname und auch das Passwort
                                          28.8.2019, 10:18:18.764	[info ]: javascript.0 Stop script script.js.Heiko.Unifi.unifi_wifi
                                          28.8.2019, 10:18:18.784	[info ]: javascript.0 Start javascript script.js.Heiko.Unifi.unifi_wifi
                                          28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: starting test
                                          28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: start set wifi
                                          28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: need to login
                                          28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: registered 0 subscriptions and 0 schedules
                                          28.8.2019, 10:18:19.083	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: login: login war erfolgreich! Mit Cookies
                                          28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: now setting wifi
                                          28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: got response
                                          28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: Wifi wurde erfolgreich eingeschaltet
                                          28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: {}
                                          28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: getting status
                                          28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: nur mal so
                                          28.8.2019, 10:18:19.123	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d3c5be0bc96040011365fe5\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5d3b2323bc9604001132d2c5\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"xxx Gäste\",\"is_guest\":true,\"x_passphrase\":\"xxx\",\"wlangroup_id\":\"5d3b2323bc9604001132d2c6\",\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5d3b231abc9604001132d2b8\",\"x_iapp_key\":\"0613db2263d118bc9e21936a202a964e\",\"fast_roaming_enabled\":false,\"no2ghz_oui\":true}]}"
                                          • thewhobox
                                            @liv-in-sky Hmm okay, da fehlt mir das get resonse wie bei @dslraser
                                            Ersetz mal die getStatus funktion
                                                    dlog("nur mal so");
                                                    if(resp != null && resp.meta && resp.meta.rc == "ok") {
                                                        dlog(resp);
                                                        resolve(wlanOn);
                                                    } else {
                                                        dlog("nicht ok...")
                                            liv-in-sky dslraser 3 Replies Last reply Reply Quote 0
                                            unifi
                                            171
                                            1010
                                            386857
