    4. Adapter: ioBroker.unifi
      liv-in-sky @thewhobox last edited by
      @thewhobox
      hier der test mit linux
      unifi enable
      {"meta":{"rc":"ok"},"data":[]}Enabling WiFi.
      {"meta":{"rc":"ok"},"data":[{"_id":"5d6512a897578401d1edd761","enabled":true,"security":"open","wep_idx":1,"wpa_mode":"wpa2","wpa_enc":"ccmp","usergroup_id":"5cadc7f73b6a3967dd7e5376","dtim_mode":"default","dtim_ng":1,"dtim_na":1,"minrate_ng_enabled":false,"minrate_ng_advertising_rates":false,"minrate_ng_data_rate_kbps":1000,"minrate_ng_cck_rates_enabled":true,"minrate_na_enabled":false,"minrate_na_advertising_rates":false,"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"mac_filter_policy":"allow","mac_filter_list":[],"bc_filter_enabled":false,"bc_filter_list":[],"group_rekey":3600,"name":"DragonRootGuest","wlangroup_id":"5cadc7f73b6a3967dd7e5377","fast_roaming_enabled":false,"schedule":[],"minrate_ng_mgmt_rate_kbps":1000,"minrate_na_mgmt_rate_kbps":6000,"minrate_ng_beacon_rate_kbps":1000,"minrate_na_beacon_rate_kbps":6000,"site_id":"5cadc7f53b6a3967dd7e5369","x_iapp_key":"cf930ad9a6750bd1d7c2f8676f775668","name_combine_enabled":true}]}root@iobroker59 09:28:00  /usr/local/bin   >
      unifi disable
      {"meta":{"rc":"ok"},"data":[]}Disabling WiFi.
      {"meta":{"rc":"ok"},"data":[{"_id":"5d6512a897578401d1edd761","enabled":false,"security":"open","wep_idx":1,"wpa_mode":"wpa2","wpa_enc":"ccmp","usergroup_id":"5cadc7f73b6a3967dd7e5376","dtim_mode":"default","dtim_ng":1,"dtim_na":1,"minrate_ng_enabled":false,"minrate_ng_advertising_rates":false,"minrate_ng_data_rate_kbps":1000,"minrate_ng_cck_rates_enabled":true,"minrate_na_enabled":false,"minrate_na_advertising_rates":false,"minrate_na_data_rate_kbps":6000,"mac_filter_enabled":false,"mac_filter_policy":"allow","mac_filter_list":[],"bc_filter_enabled":false,"bc_filter_list":[],"group_rekey":3600,"name":"DragonRootGuest","wlangroup_id":"5cadc7f73b6a3967dd7e5377","fast_roaming_enabled":false,"schedule":[],"minrate_ng_mgmt_rate_kbps":1000,"minrate_na_mgmt_rate_kbps":6000,"minrate_ng_beacon_rate_kbps":1000,"minrate_na_beacon_rate_kbps":6000,"site_id":"5cadc7f53b6a3967dd7e5369","x_iapp_key":"cf930ad9a6750bd1d7c2f8676f775668","name_combine_enabled":true}]}root@iobroker59 09:29:23  /usr/local/bin   >
        @thewhobox sagte in Adapter: ioBroker.unifi:
        body: JSON.stringify({ enabled }),
        jetzt weiß ich wieder, warum ich mit json auf kriegsfuß stehe 😞
        09:36:40.055	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
        09:36:40.065	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:36:40.065	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:36:40.069	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:36:40.080	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
        09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
        09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
        09:36:40.081	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
        09:36:40.311	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: got response: {"statusCode":200,"body":"{\"meta\":{\"rc\":\"ok\"},\"data\":[]}","headers":{"vary":"Origin","access-control-allow-credentials":"true","access-control-expose-headers":"Access-Control-Allow-Origin,Access-Control-Allow-Credentials","set-cookie":["unifises=4lIovxEqmKXvAF8JehI733XXQ6fSh1Se; Path=/; Secure; HttpOnly","csrf_token=4D3RfUt1GtDD4k6JXdNUcunJw5O0jqvu; Path=/; Secure"],"x-frame-options":"DENY","content-type":"application/json;charset=UTF-8","content-length":"30","date":"Wed, 28 Aug 2019 07:36:40 GMT","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.157:8443","port":"8443","hostname":"192.168.178.157","hash":null,"search":null,"query":null,"pathname":"/api/login","path":"/api/login","href":"https://192.168.178.157:8443/api/login"},"method":"POST","headers":{"Content-Type":"application/json","content-length":40}}}
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich!
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: set_cookies:
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Cookies: ["unifises=4lIovxEqmKXvAF8JehI733XXQ6fSh1Se","csrf_token=4D3RfUt1GtDD4k6JXdNUcunJw5O0jqvu"]
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: resolved
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
        09:36:40.312	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
        09:36:40.322	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejected: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
        09:36:40.322	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: reject1: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
        09:36:40.322	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
        09:36:42.072	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
        09:36:42.095	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:36:42.117	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
        09:36:42.117	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
        09:36:42.118	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
        09:36:42.118	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
        09:36:42.118	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: got response: {"statusCode":200,"body":"{\"meta\":{\"rc\":\"ok\"},\"data\":[]}","headers":{"vary":"Origin","access-control-allow-credentials":"true","access-control-expose-headers":"Access-Control-Allow-Origin,Access-Control-Allow-Credentials","set-cookie":["unifises=EnoMzZ5FyglDTNPrZYGa2hvP16jewWiU; Path=/; Secure; HttpOnly","csrf_token=fAjfJm99u8hTqyKjEBfv7IRA4lZMILYO; Path=/; Secure"],"x-frame-options":"DENY","content-type":"application/json;charset=UTF-8","content-length":"30","date":"Wed, 28 Aug 2019 07:36:42 GMT","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.157:8443","port":"8443","hostname":"192.168.178.157","hash":null,"search":null,"query":null,"pathname":"/api/login","path":"/api/login","href":"https://192.168.178.157:8443/api/login"},"method":"POST","headers":{"Content-Type":"application/json","content-length":40}}}
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich!
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: set_cookies:
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Cookies: ["unifises=EnoMzZ5FyglDTNPrZYGa2hvP16jewWiU","csrf_token=fAjfJm99u8hTqyKjEBfv7IRA4lZMILYO"]
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: resolved
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
        09:36:42.421	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
        09:36:42.429	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejected: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
        09:36:42.429	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: reject1: StatusCodeError: 400 - "{\"meta\":{\"rc\":\"error\",\"msg\":\"api.err.IdInvalid\"},\"data\":[]}"
        09:36:42.429	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
        thewhobox 1 Reply Last reply Reply Quote 0
        • thewhobox
          thewhobox @liv-in-sky last edited by
          @liv-in-sky Okay, zu dem Fehler finde ich leider auch nix im Netz. Hab es jetzt mal so angepasst wie in deinem verlinkten Skript.
          Was mich wundert, dass nach "getting status" nix mehr kommt...
          const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
          const unifi_username = "user";
          const unifi_password = "pass";
          const unifi_controller = "https://192.168.x.xx:xxxx";
          const wifi_id = "dsa4fsda6g46fdsg984";
          let cookies = [];
          let loggedIn = false;
          async function login() {
             return new Promise(async (resolve, reject) => {
                 let resp = await request.post({
                     resolveWithFullResponse: true,
                     url: unifi_controller + "/api/login",
                     body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                     headers: { 'Content-Type': 'application/json' }
                 }).catch((e) => { console.log("login: reject"), reject(e) });
                 if(resp != null) {
                     console.log("login: Login war erfolgreich! " + ((resp.headers && resp.headers.hasOwnProperty("set-cookie")) ? "Mit Cookies":"Ohne Cookies"));
                     if(resp.headers && resp.headers.hasOwnProperty("set-cookie")) {
                         let set_cookies = resp.headers["set-cookie"];
                         for(i = 0; i < set_cookies.length; i++) {
                             let cookie = set_cookies[i];
                             cookie = cookie.split(";")[0];
                             cookies.push(cookie);
                     } else {
                         console.log("login: no cookies to set!")
                     loggedIn = true;
                     resolve();
                 } else {
                     console.log("login: rejected")
                     reject("resp = null");
          async function getStatus() {
                 console.log("nur mal so");
                 if(!loggedIn) await login().catch((e) => reject(e));
                 let resp = await request.get({
                     url: unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id,
                     headers: { Cookie: cookies.join("; ") }
                 }).catch((e) => { console.log("getStatus reject " + e); reject(e) });
                 console.log("got response " + JSON.stringify(resp));
                 if(resp != null && resp.statusCode == 200) {
                     console.log("Status erfolgreich geholt!");
                     console.log(resp);
                     let status = JSON.parse(resp);
                     let wlanOn = status.data[0].enabled;
                     console.log("WLAN ist: " + (wlanOn ? "an" : "aus"));
                     resolve(wlanOn);
                 } else {
                     reject(JSON.parse(resp.body).meta.msg);
          async function logout() {
                     url: unifi_controller + "/logout",
                 }).catch((e) => reject(e));
                 if(resp != null) {
                     console.log("Du bist nun ausgeloggt.");
                     console.log(resp);
                     resolve();
                 } else {
          async function setWifi(enabled) {
                 console.log("setWifi: start set wifi");
                 if(!loggedIn) { console.log("need to login"); await login().catch((e) => reject(e)); }
                 console.log("setWifi: now setting wifi");
                 let resp = request.post({
                     url: unifi_controller + "/api/s/default/upd/wlanconf/" + wifi_id,
                     headers: { 'Content-Type': 'application/json', Cookie: cookies.join("; ") }
                 }).catch((e) => { console.log("setWifi: rejected: " + e); reject(e) });
                 console.log("setWifi: got response")
                     console.log("setWifi: Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                     console.log(resp);
                     resolve();
                 } else {
                     console.log("setWifi: rejetced")
                     console.log("resp: " + JSON.stringify(resp));
                     reject("msg: " + JSON.parse(resp.body).meta.msg);
          async function test() {
             console.log("starting test");
             await setWifi(true).catch((e) => console.log("reject1: " + e));
             console.log("getting status");
             let wlan = await getStatus().catch((e) => console.log("reject2: " + e));
             console.log("fin")
             console.log(wlan);
          test()
            @thewhobox moment noch - jetzt ist was passiert
              @thewhobox
              jeah -
              scheint zu klappen - kann es ein und ausschalten
              09:55:42.324	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
              09:55:42.331	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:55:42.337	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:55:42.341	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:55:42.352	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
              09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
              09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
              09:55:42.353	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
              09:55:42.672	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
              09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
              09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
              09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
              09:55:42.673	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
              09:55:44.342	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
              09:55:44.360	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:55:44.408	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
              09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
              09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
              09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
              09:55:44.408	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
              09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
              09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
              09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
              09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: rejetced
              09:55:44.730	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: resp: {}
              • dslraser
                dslraser Forum Testing Most Active @liv-in-sky last edited by
                @liv-in-sky
                @thewhobox
                moin, schon alle wieder fleißig...
                Welches ist jetzt das komplette Script ?
                  liv-in-sky @dslraser last edited by
                  @dslraser 3 posts weiter oben
                  • thewhobox
                    So hier nochmal mit Console Ausgaben nur wenn debug true ist.
                    @dslraser bringt er bei dir auch was nach "getting status"?
                    let cookies = [];
                    let debug = false;
                    function log(message) {
                       if(debug)
                           console.log(message);
                           }).catch((e) => { log("login: reject"), reject(e) });
                           if(resp != null) {
                               } else {
                               loggedIn = true;
                               resolve();
                           } else {
                           log("nur mal so");
                           }).catch((e) => { log("getStatus reject " + e); reject(e) });
                               log(resp);
                               resolve(wlanOn);
                           } else {
                           if(resp != null) {
                               log(resp);
                               resolve();
                           } else {
                           if(!loggedIn) { log("need to login"); await login().catch((e) => reject(e)); }
                           }).catch((e) => { log("setWifi: rejected: " + e); reject(e) });
                           if(resp != null) {
                               log(resp);
                               resolve();
                           } else {
                       await setWifi(true).catch((e) => log("reject1: " + e));
                       let wlan = await getStatus().catch((e) => log("reject2: " + e));
                       console.log("fin")
                       console.log(wlan);
                    test()
                    dslraser liv-in-sky 2 Replies Last reply Reply Quote 0
                      was aber nervt - nicht script - es werden immer alle netzwerke aus und eingeschaltet - ist beim linux script auch - das scheint etwas mit unifi selbst zu tun zu haben
                      • dslraser
                        dslraser Forum Testing Most Active @thewhobox last edited by
                        @thewhobox
                        ich bin irgendwo nicht mit gekommen...?
                        das passiert beim letzten Script
                        javascript.0	2019-08-28 10:07:00.672	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                        javascript.0	2019-08-28 10:07:00.672	error	at script.js.Heiko.Unifi.unifi_wifi:1:1
                        javascript.0	2019-08-28 10:07:00.672	error	SyntaxError: Identifier 'log' has already been declared
                        javascript.0	2019-08-28 10:07:00.672	error	^
                        javascript.0	2019-08-28 10:07:00.672	error	const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                        javascript.0	2019-08-28 10:07:00.672	error	script.js.Heiko.Unifi.unifi_wifi: script.js.Heiko.Unifi.unifi_wifi:1
                          @thewhobox
                          muss leider nochmal fragen - wenn ich nur getStatus() anstatt test() aufrufe, sollte das funktionieren - es kommt kein WLAN ist an oder aus
                          10:05:22.860	info	js2fs.0 Script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 modified in ioBroker, write to file
                          10:05:22.864	info	javascript.1 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                          10:05:22.865	info	javascript.0 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                          10:05:22.874	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                          10:05:22.886	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                          10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
                          10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
                          10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
                          10:05:22.886	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
                          10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
                          10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
                          10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
                          10:05:23.174	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: Wifi wurde erfolgreich eingeschaltet
                          10:05:23.175	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: {}
                          10:05:23.175	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
                          10:05:23.175	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: nur mal so
                          10:05:23.183	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d6512a897578401d1edd761\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5cadc7f73b6a3967dd7e5376\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"DragonRootGuest\",\"wlangroup_id\":\"5cadc7f73b6a3967dd7e5377\",\"fast_roaming_enabled\":false,\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5cadc7f53b6a3967dd7e5369\",\"x_iapp_key\":\"cf930ad9a6750bd1d7c2f8676f775668\",\"name_combine_enabled\":true}]}"
                          10:05:24.876	info	js2fs.0 Script file script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2 changed, also update in ioBroker
                          10:05:24.895	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                          10:05:24.919	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2
                          10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: starting test
                          10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: start set wifi
                          10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: need to login
                          10:05:24.919	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: registered 0 subscriptions and 0 schedules
                          10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: login: Login war erfolgreich! Mit Cookies
                          10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: now setting wifi
                          10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: got response
                          10:05:25.205	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: setWifi: Wifi wurde erfolgreich eingeschaltet
                          10:05:25.206	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: {}
                          10:05:25.206	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: getting status
                          10:05:25.206	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: nur mal so
                          10:05:25.214	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN2: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d6512a897578401d1edd761\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5cadc7f73b6a3967dd7e5376\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"DragonRootGuest\",\"wlangroup_id\":\"5cadc7f73b6a3967dd7e5377\",\"fast_roaming_enabled\":false,\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5cadc7f53b6a3967dd7e5369\",\"x_iapp_key\":\"cf930ad9a6750bd1d7c2f8676f775668\",\"name_combine_enabled\":true}]}"
                          • thewhobox
                            thewhobox @dslraser last edited by
                            @dslraser Nein war mein Fehler gerade, jetzt nochmal:
                            @liv-in-sky laut Log hast du aber test aufgerufen? Hätte aber trotzdem nicht funktioniert, sollte jetzt aber gefixt sein.
                            let cookies = [];
                            let debug = true;
                            function dlog(message) {
                               if(debug)
                                   }).catch((e) => { dlog("login: reject"), reject(e) });
                                   if(resp != null) {
                                       dlog("login: login war erfolgreich! " + ((resp.headers && resp.headers.hasOwnProperty("set-cookie")) ? "Mit Cookies":"Ohne Cookies"));
                                       } else {
                                           dlog("login: no cookies to set!")
                                       loggedIn = true;
                                       resolve();
                                   } else {
                                       dlog("login: rejected")
                                   dlog("nur mal so");
                                   }).catch((e) => { dlog("getStatus reject " + e); reject(e) });
                                   dlog("got response " + JSON.stringify(resp));
                                   if(resp != null && resp.meta.rc == "ok") {
                                       dlog("Status erfolgreich geholt!");
                                       dlog(resp);
                                       let wlanOn = resp.data[0].enabled;
                                       dlog("WLAN ist: " + (wlanOn ? "an" : "aus"));
                                       resolve(wlanOn);
                                   } else {
                                       reject(JSON.stringify(resp));
                            async function dlogout() {
                                       url: unifi_controller + "/dlogout",
                                   if(resp != null) {
                                       dlog("Du bist nun ausgedloggt.");
                                       dlog(resp);
                                       resolve();
                                   } else {
                                   dlog("setWifi: start set wifi");
                                   if(!loggedIn) { dlog("need to login"); await login().catch((e) => reject(e)); }
                                   dlog("setWifi: now setting wifi");
                                   }).catch((e) => { dlog("setWifi: rejected: " + e); reject(e) });
                                   dlog("setWifi: got response")
                                   if(resp != null) {
                                       dlog("setWifi: Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                                       dlog(resp);
                                       resolve();
                                   } else {
                                       dlog("setWifi: rejetced")
                                       dlog("resp: " + JSON.stringify(resp));
                               dlog("starting test");
                               await setWifi(true).catch((e) => dlog("reject1: " + e));
                               dlog("getting status");
                               let wlan = await getStatus().catch((e) => dlog("reject2: " + e));
                               console.log("fin")
                               console.log(wlan);
                            test()
                            liv-in-sky dslraser 2 Replies Last reply Reply Quote 0
                              @thewhobox sorry falsches log
                              • thewhobox
                                @liv-in-sky Ah okay. Wie gesagt, das hätte auch nicht klappen können^^
                                Versuch es mal mit dem neuen Skript von eins oben drüber.
                                  @thewhobox war das neuste script
                                  • dslraser
                                    @thewhobox
                                    in dem Log steht nun auch der Netzwerkname und auch das Passwort
                                    28.8.2019, 10:18:18.764	[info ]: javascript.0 Stop script script.js.Heiko.Unifi.unifi_wifi
                                    28.8.2019, 10:18:18.784	[info ]: javascript.0 Start javascript script.js.Heiko.Unifi.unifi_wifi
                                    28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: starting test
                                    28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: start set wifi
                                    28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: need to login
                                    28.8.2019, 10:18:18.785	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: registered 0 subscriptions and 0 schedules
                                    28.8.2019, 10:18:19.083	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: login: login war erfolgreich! Mit Cookies
                                    28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: now setting wifi
                                    28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: got response
                                    28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: Wifi wurde erfolgreich eingeschaltet
                                    28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: {}
                                    28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: getting status
                                    28.8.2019, 10:18:19.084	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: nur mal so
                                    28.8.2019, 10:18:19.123	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d3c5be0bc96040011365fe5\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5d3b2323bc9604001132d2c5\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"xxx Gäste\",\"is_guest\":true,\"x_passphrase\":\"xxx\",\"wlangroup_id\":\"5d3b2323bc9604001132d2c6\",\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5d3b231abc9604001132d2b8\",\"x_iapp_key\":\"0613db2263d118bc9e21936a202a964e\",\"fast_roaming_enabled\":false,\"no2ghz_oui\":true}]}"
                                    • thewhobox
                                      @liv-in-sky Hmm okay, da fehlt mir das get resonse wie bei @dslraser
                                      Ersetz mal die getStatus funktion
                                              dlog("nur mal so");
                                              if(resp != null && resp.meta && resp.meta.rc == "ok") {
                                                  dlog(resp);
                                                  resolve(wlanOn);
                                              } else {
                                                  dlog("nicht ok...")
                                      liv-in-sky dslraser 3 Replies Last reply Reply Quote 0
                                        @thewhobox
                                          @thewhobox sorry - hab beim kopieren das let cokkies... übersehen
                                          so sieht es aus:
                                          • dslraser
                                            @thewhobox
                                            28.8.2019, 10:32:04.140	[info ]: javascript.0 Stop script script.js.Heiko.Unifi.unifi_wifi
                                            28.8.2019, 10:32:04.168	[info ]: javascript.0 Start javascript script.js.Heiko.Unifi.unifi_wifi
                                            28.8.2019, 10:32:04.168	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: starting test
                                            28.8.2019, 10:32:04.168	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: start set wifi
                                            28.8.2019, 10:32:04.168	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: need to login
                                            28.8.2019, 10:32:04.168	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: nur mal so
                                            28.8.2019, 10:32:04.168	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: registered 0 subscriptions and 0 schedules
                                            28.8.2019, 10:32:04.530	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: login: login war erfolgreich! Mit Cookies
                                            28.8.2019, 10:32:04.552	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: login: login war erfolgreich! Mit Cookies
                                            28.8.2019, 10:32:04.552	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: now setting wifi
                                            28.8.2019, 10:32:04.552	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: got response
                                            28.8.2019, 10:32:04.552	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: setWifi: Wifi wurde erfolgreich eingeschaltet
                                            28.8.2019, 10:32:04.553	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: {}
                                            28.8.2019, 10:32:04.553	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: getting status
                                            28.8.2019, 10:32:04.553	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: nur mal so
                                            28.8.2019, 10:32:04.582	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d3c5be0bc96040011365fe5\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5d3b2323bc9604001132d2c5\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"xxx Gäste\",\"is_guest\":true,\"x_passphrase\":\"xxx\",\"wlangroup_id\":\"5d3b2323bc9604001132d2c6\",\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5d3b231abc9604001132d2b8\",\"x_iapp_key\":\"0613db2263d118bc9e21936a202a964e\",\"fast_roaming_enabled\":false,\"no2ghz_oui\":true}]}"
                                            28.8.2019, 10:32:04.582	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: nicht ok...
                                            28.8.2019, 10:32:04.599	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: got response "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d3c5be0bc96040011365fe5\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5d3b2323bc9604001132d2c5\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"xxx Gäste\",\"is_guest\":true,\"x_passphrase\":\"xxx\",\"wlangroup_id\":\"5d3b2323bc9604001132d2c6\",\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5d3b231abc9604001132d2b8\",\"x_iapp_key\":\"0613db2263d118bc9e21936a202a964e\",\"fast_roaming_enabled\":false,\"no2ghz_oui\":true}]}"
                                            28.8.2019, 10:32:04.599	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: nicht ok...
                                            28.8.2019, 10:32:04.599	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: reject2: "{\"meta\":{\"rc\":\"ok\"},\"data\":[{\"_id\":\"5d3c5be0bc96040011365fe5\",\"enabled\":true,\"security\":\"open\",\"wep_idx\":1,\"wpa_mode\":\"wpa2\",\"wpa_enc\":\"ccmp\",\"usergroup_id\":\"5d3b2323bc9604001132d2c5\",\"dtim_mode\":\"default\",\"dtim_ng\":1,\"dtim_na\":1,\"minrate_ng_enabled\":false,\"minrate_ng_advertising_rates\":false,\"minrate_ng_data_rate_kbps\":1000,\"minrate_ng_cck_rates_enabled\":true,\"minrate_na_enabled\":false,\"minrate_na_advertising_rates\":false,\"minrate_na_data_rate_kbps\":6000,\"mac_filter_enabled\":false,\"mac_filter_policy\":\"allow\",\"mac_filter_list\":[],\"bc_filter_enabled\":false,\"bc_filter_list\":[],\"group_rekey\":3600,\"name\":\"xxx Gäste\",\"is_guest\":true,\"x_passphrase\":\"xxx\",\"wlangroup_id\":\"5d3b2323bc9604001132d2c6\",\"schedule\":[],\"minrate_ng_mgmt_rate_kbps\":1000,\"minrate_na_mgmt_rate_kbps\":6000,\"minrate_ng_beacon_rate_kbps\":1000,\"minrate_na_beacon_rate_kbps\":6000,\"site_id\":\"5d3b231abc9604001132d2b8\",\"x_iapp_key\":\"0613db2263d118bc9e21936a202a964e\",\"fast_roaming_enabled\":false,\"no2ghz_oui\":true}]}"
                                            28.8.2019, 10:32:04.599	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: fin
                                            28.8.2019, 10:32:04.599	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: undefined
                                            unifi
                                            171
                                            1010
                                            386870
