    3. Entwicklung
    4. [Adapter] Neuer radar2-Adapter
    • marcuskl
      marcuskl last edited by
      Och habe mal versucht "npm i bluetooth-hci-socket"
      Das funktioniert nicht, es kommt dieser Fehler:
      root@iobroker:~# npm i bluetooth-hci-socket
      > bluetooth-hci-socket@0.5.1 install /root/node_modules/bluetooth-hci-socket                      > node-gyp rebuild
      make: Verzeichnis „/root/node_modules/bluetooth-hci-socket/build“ wird betreten
        CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o                                 ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
      ../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
       s), Nan::New("emit").ToLocalChecked(), 2, argv);                                               ^
      In file included from ../src/BluetoothHciSocket.cpp:8:0:
      ../../nan/nan.h:1045:46: note: declared here
       PRECATED inline v8::Local<v8::Value> MakeCallback(
      ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
      ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
       rorConstructor->NewInstance(1, constructorArgs);                                               ^
      In file included from /root/.node-gyp/10.16.3/include/node/node.h:63:0,
                       from /root/.node-gyp/10.16.3/include/node/node_buffer.h:25,
                       from ../src/BluetoothHciSocket.cpp:7:
      /root/.node-gyp/10.16.3/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
       ARN_UNUSED_RESULT MaybeLocal<Object> NewInstanc (
                                            ^~~~~~~~~~ /root/.node-gyp/10.16.3/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
      /root/.node-gyp/10.16.3/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
                                            ^~~~~~~~~~ /root/.node-gyp/10.16.3/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
      ../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
      ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE ’:
      ../src/BluetoothHciSocket.cpp:395:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             devId = arg0->IntegerValue();
      In file included from /root/.node-gyp/10.16.3/include/node/v8.h:26:0,
                       from /root/.node-gyp/10.16.3/include/node/node.h:63,
      /root/.node-gyp/10.16.3/include/node/v8.h:2476:46: note: declared here
       RECATED("Use maybe version", int64_t IntegerValue() const);
      /root/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATE ’
         declarator __attribute__((deprecated(message)))
      ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/BluetoothHciSocket.cpp:417:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      binding.target.mk:101: die Regel für Ziel „Release/obj.target/binding/src/BluetoothHciSocket.o“ scheiterte
      make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
      make: Verzeichnis „/root/node_modules/bluetooth-hci-socket/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.9.0-9-amd64
      gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /root/node_modules/bluetooth-hci-socket
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
      npm WARN root No description
      npm WARN root No repository field.
      npm WARN root No README data
      npm WARN root No license field.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the bluetooth-hci-socket@0.5.1 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2019-08-16T11_09_10_850Z-debug.log
      root@iobroker:~#
      • AlCalzone
        AlCalzone Developer @marcuskl last edited by
        @marcuskl sagte in [Adapter] Neuer radar2-Adapter:
        1. Falsches Paket, richtig wäre npm i @abandonware/bluetooth-hci-socket
        2. Falscher Ordner, du musst die Befehle im Adapter-Ordner /opt/iobroker/node_modules/iobroker.radar2 ausführen
        marcuskl 1 Reply Last reply Reply Quote 1
        • marcuskl
          marcuskl @AlCalzone last edited by marcuskl
          @AlCalzone sagte in [Adapter] Neuer radar2-Adapter:
          Habe ich gemacht und es ist immernoch der Fehler da
          Ich korrigiere, der warn ist jetzt anders:
          2019-08-16 15:25:10.420  - warn: radar2.0 Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 57. This version of Node.js requiresNODE_MODULE_VERSION 64. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)at Module.load (internal/modules/cjs/loader.js:653:32)at tryModuleLoad (internal/modules/cjs/loader.js:593:12)at Function.Module._load (internal/modules/cjs/loader.js:585:3)at Module.require (internal/modules/cjs/loader.js:692:17)at require (internal/modules/cjs/helpers.js:25:18)at Object.<anonymous> (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)at Module._compile (internal/modules/cjs/loader.js:778:30)at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)at Module.load (internal/modules/cjs/loader.js:653:32)
            Da steht was von verschiedenen node-Versionen.
            Was ergibt denn:
            node -v
            nodejs -v
            Enrico
            • marcuskl
              Ich habe nun unter den Verzeichnis /opt/iobroker/ nochmal
              installiert und nun geht es.
              @RappiRN sagte in [Adapter] Neuer radar2-Adapter:
              Was ergibt denn:
              node -v
              nodejs -v
              Enrico
              ergibt beides 10.16.3
                Fabian1 last edited by
                Hallo Zusammen,
                ich bin super neu dabei und habe letzte Woche meine ersten Gehversuche mit IOBroker unternommen. Was mir wirklich fehlt, ist eine gute Anwesenheitserkennung. Radar2 ist schon ziemlich nah dran, darum schreibe ich auch hier.
                Mein Telefon im WLAN zu erkennen funktioniert super, leider reicht mein WLAN viel zu weit und es triggert lange bevor ich Zuhause bin. Also für Sachen wie Türöffnung nicht zu gebrauchen. Mein Iphone Xs sendet auch kein Bluetooth Funkfeuer aus das erkannt werden könnte.
                Darum meine Idee und feature request für den Radar2 Adapter, anzeigen ob ein gekoppeltes Bluetooth Gerät verbunden ist!
                Das koppeln mit dem Raspi Bluetooth Adapter ist ja super einfach und man könnte dann das Iphone auf automatisch verbinden stellen und hätte eine super Anwesenheitserkennung mit kleiner Reichweite.
                  Kuddel last edited by Kuddel
                  ich habe den Adapter gerade in einer frischen iobroker Installation auf Ubuntu 18.04 installiert.
                  Mein Handy wird über WLAN erkannt, allerdings fehlt das Datenobjekte Handy.here wie beim Radar 1.
                  Über dieses Datenobjekt steure ich Anwesenheit...
                  EDIT: Aktuelle Version von GIT installiert. jetzt ist das Datenobjekt da
                  • tigertim08
                    tigertim08 last edited by tigertim08
                    ich bekomme den adapter einfach nicht zu laufen... ich habe ioBroker in einer VM (Proxmox) auf Debian Basis laufen. Allerdings bekomme ich den Adapter einfach nicht grün... Das weiterleiten des USB Bluetooth dongle zur VM schein zu funktionieren.
                    Allerdings bekomme ich beim starten des Adapters immer folgende Fehlermeldung:
                    Hat jemand das Problem auch gehabt und kann helfen?
                    Vielen Dank
                    Tim
                    • marcuskl
                      marcuskl @toki1973 last edited by
                      @toki1973 sagte in [Adapter] Neuer radar2-Adapter:
                      @frankjoke said in [Adapter] Neuer radar2-Adapter:
                      @marcuskl
                      Wenn du etwas änderst im ioBroker (Nodejs oder ioBroker neu installierst u.s.w.) dann bitte immer vor installation/update vom adapter
                      sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
                      ausführen. Das sollte die eingeschränkten Standardbewilligungen wieder aufheben.
                      Super Danke! Das war auch das Problem bei mir - nun gelöst
                      @tigertim08
                      Führe diese Befehle mal aus, dann müsste es klappen.
                      Steht aber alles im Readme vom Adapter
                      tigertim08 1 Reply Last reply Reply Quote 0
                      • tigertim08
                        tigertim08 @marcuskl last edited by
                        @marcuskl said in [Adapter] Neuer radar2-Adapter:
                        which arp-scan)
                        Hatte ich versucht... !
                        gibt bei mir aber auch eine fehlermeldung aus
                          A Former User @tigertim08 last edited by
                          @tigertim08 du hast noble nicht installiert..
                          • tigertim08
                            tigertim08 @Guest last edited by
                            @ilovegym Guten Morgen, dachte eigentlich das ich das damals gemacht hatte. Habe gerade versucht das ganze nochmal zu machen. Bekomme jetzt aber folgende Fehlermeldung....
                            Kann jemand damti was anfangen?
                            • AlCalzone
                              AlCalzone Developer @tigertim08 last edited by
                              @tigertim08 Ja, du kannst npm audit fix nicht ausführen. Ist aber vollkommen egal, dieser Befehl macht IMO nur Unsinn.
                              Und die Installation von noble musst du im Adapter-Ordner ausführen, nicht in deinem Home-Verzeichnis!
                              • tigertim08
                                tigertim08 @AlCalzone last edited by
                                @AlCalzone Du meinst im "/home/iobroker/.npm"?
                                • Diginix
                                  Diginix last edited by Diginix
                                  @tigertim08 Nein
                                  • tigertim08
                                    tigertim08 @Diginix last edited by
                                    @Diginix Habe ich gemacht, jetzt wird der Adapter zumindest wieder grün. Allerdings funktioniert Bluetooth immer noch nicht... Schein immer noch ein Problem mit Noble zu haben
                                    • Diginix
                                      Diginix @tigertim08 last edited by
                                      @tigertim08
                                      Gibt es denn nun im node_modules Ordner bei dir ein @abandonware Ordner in dem dann "noble" liegt?
                                      • tigertim08
                                        @Diginix Den Ordner gibt es nur liegt dort nichts drin
                                        • Diginix
                                          @tigertim08
                                          Dann wurde noble auch nicht korrekt installiert und deswegen funktioniert BT im radar2 noch nicht.
                                          Was genau da nun hilft, kann ich von hier schlecht sagen.
                                          Ich habe in der Vergangenheit auch schon hässliche Kämpfe mit node modules geführt. Das ist nicht immer von einem System zum anderen übertragbar.
                                          • MathiasJ
                                            MathiasJ last edited by MathiasJ
                                            Hat jemand eine Idee, woran das liegen kann?
                                            Ich habe mir auf einem Raspberry PI4/4GB piVCCU installiert und Radar nach der Anleitung in Post1 installiert.
                                            Nun Radar ist grün, aber es werden keine Bluetoth-Geräte gescannt.
                                            Alle Geräte im Netzwerk werden hingegen erkannt.
                                            BLE hingegen arbeitet fehlerfrei, nachdem ich Radar2 abgeschaltet habe. Ich habe BLE nur installiert, um zu sehen, ob überhaupt ein BLE-Sinal durchkommt.
                                            ich denke, an Noble kann es da nicht liegen, da BLE ja seine Arbeit tut. Im Log finde ich da überhaupt nichts, nur daß keine Ubt's zu finden sind.
                                            Gruß,
                                            Mathias
                                            adapter radar2 adapter
                                            80
                                            840
                                            231146
