    4. [Projekt] ioGo # Smarthome to go
      e-s @Guest last edited by
      @nis
      jetzt geht das Login, aber nun kommt ein anderer Fehler im log
      iogo.0	2019-08-29 07:44:37.778	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.16.3
      host.ubuntuserver	2019-08-29 07:44:36.586	info	instance system.adapter.iogo.0 started with pid 2177
      host.ubuntuserver	2019-08-29 07:44:06.564	info	Restart adapter system.adapter.iogo.0 because enabled
      host.ubuntuserver	2019-08-29 07:44:06.564	error	instance system.adapter.iogo.0 terminated with code 0 (OK)
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: toString: [Function] }
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: name: 'FirebaseError',
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: code: 'invalid-argument',
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: at WriteBatch.set (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20702:46)
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19833:31)
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19968:25)
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20009:13)
      host.ubuntuserver	2019-08-29 07:44:06.564	error	Caught by controller[0]: at forEach (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
      host.ubuntuserver	2019-08-29 07:44:06.563	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20010:41
      host.ubuntuserver	2019-08-29 07:44:06.563	error	Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19994:29)
      host.ubuntuserver	2019-08-29 07:44:06.563	error	Caught by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20128:27)
      host.ubuntuserver	2019-08-29 07:44:06.563	error	Caught by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19781:16)
      host.ubuntuserver	2019-08-29 07:44:06.563	error	Caught by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
      host.ubuntuserver	2019-08-29 07:44:06.563	error	Caught by controller[0]: { FirebaseError: Function WriteBatch.set() called with invalid data. Unsupported field value: undefined (found in field enabled)
      iogo.0	2019-08-29 07:44:05.600	info	device xxx captured
      iogo.0	2019-08-29 07:44:05.226	info	initialize app devices
      iogo.0	2019-08-29 07:44:05.226	info	registering listener for uid:xxx
      iogo.0	2019-08-29 07:44:05.226	info	states from remote database removed
      iogo.0	2019-08-29 07:44:05.226	info	logged in as: xxx <= please keep this uid as your secret
      iogo.0	2019-08-29 07:44:05.225	info	licence key found. licence valid until 2020-08-27 20:11:57
      iogo.0	2019-08-29 07:44:04.535	info	triggered listener removed
      iogo.0	2019-08-29 07:44:04.534	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.16.3
      host.ubuntuserver	2019-08-29 07:44:03.330	info	instance system.adapter.iogo.0 started with pid 1206
        A Former User @e-s last edited by
        @e-s das sieht nach einer Instanz Objekt aus, welches nicht richtig installiert ist. Schau mal im Objektbaum nach, du kannst nach Instanzen filtern wenn du expertmode aktivierst
          @nis
          Sorry, verstehe ich nicht ganz, wonach soll ich direkt wo schauen?
          ? 2 Replies Last reply Reply Quote 0
            @e-s ich kriege es gerade nicht hin einen Screenshot hier anzuhängen vom Handy aus 😞
              e-s @Guest last edited by e-s
              @nis
              Habe den Adapter, instanz und alles was mit iogo in objekte war mal gelöscht. Aber auch danach bleibt der Fehler.
              Interessant ist, das in der App jetzt aber die meisten states zu sehen sind, schalte ich über die app ein Licht, dann bleibt es logischweise ewig auf sync. Wenn jetzt der Adapter kurz startet und auch verbunden ist, springt das Licht kurz an, beim error dann aber auch wieder aus.
                Im Tab "Objects" musst du oben den "Toggle Expert Mode" aktivieren und dann in der Ansicht auf den Type=instance filtern. Vermutlich ist dort noch eine alte Instanz, die nicht richtig installiert/deinstalliert ist.
                  @nis
                  sieht nicht danach aus
                    @e-s wie sehen denn die anderen Instanzen alle aus? Sehen alle ok aus? Es geht nicht um die iogo Instanz.
                      @nis
                      sieht alles gut aus, alle instanzen nur mit .0, keine weiteren pro adapter.
                      Alle aktiven sind auch true im alive.
                        @e-s Eine deiner Instanzen wird im RAW kein Attribut common.enabled haben. Das sagt der Fehler im Log bei dir. Vielleicht ist es auch einer der Adapter. Poste mal bitte eine Sicht auf alle Instanzen.
                          @nis reicht das so, oder alle nochaufgeklappt?
                            @e-s Das reicht so, ich hatte vermutet es gibt eine Instanz, die gar nicht aufklappbar ist. Dann wäre das die verdächtige Instanz gewesen.
                              @nis
                              es gab nicht aufklappbar noch vis und rickshaw, die beiden Adapter hatte ich dann aber nochmal komplett gelöscht. Das hat aber auch nicht geholfen.
                                @e-s Ist beim Starten der iogo Instanz denn jetzt immer noch der selbe Fehler? Oder vielleicht etwas anderes?
                                  @nis immer noch der selbe:
                                  host.ubuntuserver	2019-08-29 21:22:34.508	info	Restart adapter system.adapter.iogo.0 because enabled
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	instance system.adapter.iogo.0 terminated with code 0 (OK)
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: toString: [Function] }
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: name: 'FirebaseError',
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: code: 'invalid-argument',
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: at WriteBatch.set (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20702:46)
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19833:31)
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19968:25)
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20009:13)
                                  host.ubuntuserver	2019-08-29 21:22:34.508	error	Caught by controller[0]: at forEach (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                                  host.ubuntuserver	2019-08-29 21:22:34.507	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20010:41
                                  host.ubuntuserver	2019-08-29 21:22:34.507	error	Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19994:29)
                                  host.ubuntuserver	2019-08-29 21:22:34.507	error	Caught by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:20128:27)
                                  host.ubuntuserver	2019-08-29 21:22:34.507	error	Caught by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:19781:16)
                                  host.ubuntuserver	2019-08-29 21:22:34.507	error	Caught by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/iobroker.iogo/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                                  host.ubuntuserver	2019-08-29 21:22:34.507	error	Caught by controller[0]: { FirebaseError: Function WriteBatch.set() called with invalid data. Unsupported field value: undefined (found in field enabled)
                                  iogo.0	2019-08-29 21:22:33.147	info	initialize app devices
                                  iogo.0	2019-08-29 21:22:33.147	info	registering listener for uid:xxx
                                  iogo.0	2019-08-29 21:22:33.147	info	states from remote database removed
                                  iogo.0	2019-08-29 21:22:33.146	info	logged in as: xxx <= please keep this uid as your secret
                                  iogo.0	2019-08-29 21:22:33.146	info	licence key found. licence valid until 2020-08-27 20:11:57
                                  iogo.0	2019-08-29 21:22:32.418	info	triggered listener removed
                                  iogo.0	2019-08-29 21:22:32.417	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.16.3
                                  host.ubuntuserver	2019-08-29 21:22:31.230	info	instance system.adapter.iogo.0 started with pid 7082
                                    @e-s Kannst du dir dann bitte mal die Mühe machen und bei allen Instanzen zu schauen ob im RAW ein Attribut common.enabled ist mit Wert true oder false
                                      @nis
                                      wenn ich mich nicht vertan habe, ist es in allen Adaptern vorhanden. Habe auch mal alle außer admin deaktiviert, nur beim Start von iogo kommt der fehler, bei allen anderen passiert nichts falsches im log
                                        @e-s sagte in [Projekt] ioGo # Native Android App:
                                        Bei allen Adaptern? Oder Instanzen?
                                          @nis
                                          sorry, instancen
                                            @e-s OK, dann prüfe zur Sicherheit nochmal ob auch bei den Adaptern das Attribut vorhanden ist
                                            android app iogo
                                            61
                                            1140
                                            359306
