    4. [Vorlage] Variable Zeitsteuerung mit VIS Editor
      GiuseppeS @sigi234 last edited by
      @sigi234
      Existiert bei dir die Aufzählung namens "timerconditions"? Evtl hast Du vergessen den Namen anzupassen?
        sigi234 Forum Testing Most Active @GiuseppeS last edited by sigi234
        @GiuseppeS sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
        @sigi234
        Aha, habe ich das überlesen. An was anpassen?
        Edit:
        So?
        var deviceCond = "enum.functions.Licht";
        00:05:54.993	info	javascript.0 Stop script script.js.Sigi.Timer_1
        00:05:55.010	info	javascript.0 Start javascript script.js.Sigi.Timer_1
        00:05:55.010	info	javascript.0 script.js.Sigi.Timer_1: registered 15 subscriptions and 3 schedules
        00:05:56.685	error	javascript.0 at buildJson (script.js.Sigi.Timer_1:1010:35)
        00:05:56.685	error	javascript.0 at tableMain (script.js.Sigi.Timer_1:1101:74)
        00:05:56.685	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:1123:5)
        00:05:56.686	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:647:8)
        00:05:56.687	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:649:8)
        00:05:56.688	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:650:8)
        00:05:56.689	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:651:8)
        00:05:56.690	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:652:8)
        00:05:56.691	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:653:8)
        00:05:56.692	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:662:80)
        00:05:56.692	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:647:8)
        00:05:56.700	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:650:8)
        00:05:56.701	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:651:8)
        00:05:56.701	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:652:8)
        00:05:56.702	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:653:8)
        00:05:56.703	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:662:80)
        00:05:56.703	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:647:8)
        00:05:56.706	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:651:8)
        00:05:56.708	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:652:8)
        00:05:56.708	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:653:8)
        00:05:56.709	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:662:80)
        00:05:56.709	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:647:8)
        00:05:56.709	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:652:8)
        00:05:56.710	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:653:8)
        00:05:56.711	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:662:80)
        00:05:56.711	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:647:8)
        00:05:56.712	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:653:8)
        00:05:56.713	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:662:80)
        00:05:56.715	warn	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:647:8)
        00:05:56.716	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:662:80)
        00:05:56.717	warn	javascript.0 at createConditionsJSON (script.js.Sigi.Timer_1:156:39)
        00:05:56.717	warn	javascript.0 at Object.main (script.js.Sigi.Timer_1:932:5)
        00:05:56.718	warn	javascript.0 at createConditionsJSON (script.js.Sigi.Timer_1:156:39)
        00:05:56.718	warn	javascript.0 at Object.main (script.js.Sigi.Timer_1:932:5)
        00:05:56.718	error	javascript.0 at compareCond (script.js.Sigi.Timer_1:170:30)
        00:05:56.718	error	javascript.0 at Object.main (script.js.Sigi.Timer_1:933:5)
        00:06:06.434	info	javascript.0 Stop script script.js.Sigi.Timer_1
        00:06:06.454	info	javascript.0 Start javascript script.js.Sigi.Timer_1
        00:06:06.454	info	javascript.0 script.js.Sigi.Timer_1: registered 15 subscriptions and 3 schedules
        00:06:06.961	warn	javascript.0 at createConditionsJSON (script.js.Sigi.Timer_1:156:39)
        00:06:06.961	warn	javascript.0 at Object.main (script.js.Sigi.Timer_1:932:5)
        00:06:06.962	warn	javascript.0 at createConditionsJSON (script.js.Sigi.Timer_1:156:39)
        00:06:06.962	warn	javascript.0 at Object.main (script.js.Sigi.Timer_1:932:5)
        00:06:06.962	warn	javascript.0 at script.js.Sigi.Timer_1:173:39
        00:06:06.962	warn	javascript.0 at compareCond (script.js.Sigi.Timer_1:172:32)
        00:06:06.962	warn	javascript.0 at Object.main (script.js.Sigi.Timer_1:933:5)
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: States werden neu erstellt! Script bitte erneut starten!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Licht_Vorraum:1 #1" (1) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Licht_Vorraum:1 #2" (2) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Steckdose Terrasse #1" (21) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Steckdose Terrasse #2" (22) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Philips_hue #1" (41) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Philips_hue #2" (42) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Stehlampe Wohnzimmer #1" (61) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.962	info	javascript.0 script.js.Sigi.Timer_1: Schedule für "Stehlampe Wohnzimmer #2" (62) nicht vorhanden! Kein Löschen notwendig!
        00:06:06.967	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:503:40)
        00:06:06.968	error	javascript.0 at Object.<anonymous> (script.js.Sigi.Timer_1:503:40)
        00:06:06.979	warn	javascript.0 at tableMain (script.js.Sigi.Timer_1:1118:9)
          GiuseppeS @GiuseppeS last edited by GiuseppeS
          @sigi234
          Für alle Timer können individuell über die VIS Bedingungen angegeben werden. So werden Timer nur gesetzt, wenn die hinterlegten Bedingungen erfüllt sind. Die States, die als Bedingungen gewählt werden sollen, müssen über eine Aufzählung integriert werden, z.B. "enum.functions.timerconditions":
          // Eine Aufzählung für States der Bedingungen:
          var deviceCond = "enum.functions.timerconditions";
          Wenn die Aufzählung für die Bedingungen verändert wird (States werden gelöscht oder hinzugefügt), dann muss nur das Skript neu gestartet werden. Die Auswahl-Liste wird dann neu erstellt.
          Also selbst eine Aufzählung erstellen und deine States einpflegen, die du zukünftig in den Timern verwenden willst.
          Zum Beispiel eignen sich hier Türsensoren, wichtige States wie AtHome (was jeder iwie verwendet) usw.
          • Glasfaser
            Glasfaser @GiuseppeS last edited by
            @GiuseppeS
            • Glasfaser
              @Glasfaser
              So schaut es bei mir aus...
              und so bei mir " Firefox "
              (Sorry ging nicht besser )
              VID_20190901_001136.mp4
                sigi234 Forum Testing Most Active @Glasfaser last edited by
                @GiuseppeS
                So bei mir...
                Glasfaser G 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @sigi234 last edited by Glasfaser
                  @sigi234
                  Ändere mal das :
                  sigi234 G 2 Replies Last reply Reply Quote 0
                    @sigi234
                    Solange du einen Haufen Fehler im Log hast, ist deine Darstellung wohl nicht "ausschlaggebend"...
                    @Glasfaser
                    Sorry, da muss ich genauer suchen, wo der Fehler überhaupt herkommen kann...
                    Im 30s-Rithmus ändert sich eigentlich nichts.
                      Im aktuellen zip habe ich übrigens die CSS von Uhula eingesetzt. Damit passen die Darstellungen auf Anhieb.
                        @Glasfaser sagte in [Vorlage] Variable Zeitsteuerung mit VIS Editor:
                        @sigi234
                        Ändere mal das :
                        Danke, Besser:
                        • Glasfaser
                          Glasfaser @GiuseppeS last edited by Glasfaser
                          @GiuseppeS
                          Ich habe deinen Schedule Wert mal geändert
                          // Darstellung zukünftiger Timer
                          schedule('30 * * * * *', nextTimer);
                          auf … und der Wechsel mit den Werten ist weg
                          schedule('*/15 * * * * *', nextTimer);
                          Edit : Fehler wieder da , dafür jetzt alle 15 Sekunden ….
                            @sigi234
                            Neue Aufzählung anklicken:
                            Dabei wählst Du einfach "Benutzerdefinierte Gruppe" und gibst einen Namen deiner Wahl ein.
                              GiuseppeS @Glasfaser last edited by GiuseppeS
                              @Glasfaser
                              Starte bitte den iobroker-docker oder zumindest die Javascript-Instanz neu, falls noch nicht geschehen. Die Darstellung ist zumindest für mich absolut nicht nachvollziehbar. Kannst du diesen Switch der Darstellung auch direkt bei den Objekten sehen?
                              EDIT:
                              Soeben extra Firefox genutzt, auch wieder nicht möglich die seltsame Darstellung zu reproduzieren.
                              • Glasfaser
                                @GiuseppeS
                                OK … werde alles neu starten !
                                  @sigi234
                                    @sigi234
                                    Indem Du oben auf das zunächst blaue Symbol klickst, kannst Du weitere States zu deinen Aufzählungen hinzufügen:
                                    Daraufhin geht rechts ein Fenster mit allen Objekten auf. Hierbei kannst Du per Drag&Drop States von Rechts nach Links in eine Aufzählung schieben.
                                    Bitte nur einzelne States rein schieben, keine Objekte, die Unter-Objekte besitzen.
                                    Glasfaser 1 Reply Last reply Reply Quote 1
                                    • Glasfaser
                                      @GiuseppeS
                                      So ... Neustart durchgeführt.
                                      Die Logik muss keiner verstehen , die Anzeigenwerten bleiben jetzt , es kommt nur der Refresh den man sieht .
                                        @sigi234
                                        Freut mich, dass es nun verständlich wird mit den Aufzählungen und Co...
                                        @Glasfaser
                                        Ausnahmsweise wird bei der Darstellung ein JSON genutzt, der rein virtuell als Variable besteht, also nicht in States zurückgeschrieben wird o.ä.
                                        Vielleicht war iwas im RAM so durcheinander, dass es diesen Switch der Darstellungen gab oder ioBroker hatte was in der Javascript-Instanz durcheinander gebracht. Seltsam ist es jedenfalls... und leider nicht nachvollziehbar.
                                        Melde mich für heute dann mal ab 🙂
                                        EDIT:
                                        @Glasfaser
                                        Mir ist gerade eingefallen, dass ich einmal ein Skript gelöscht hatte, aber in iobroker dieses Skript nicht beendet wurde. Es lief weiter obwohl davon nichts mehr sichtbar vorhanden war. Konnte das an Änderungen von States nachvollziehen. Nach einem Neustart war alles ok. Ist hier bestimmt der gleiche Fall. Eine alte Version lief noch irgendwie im Hintergrund.
                                        sigi234 Glasfaser 2 Replies Last reply Reply Quote 0
                                          @sigi234
                                          Warum ich sie doppelt und dreifach habe weis ich noch nicht.
                                          Glasfaser G 3 Replies Last reply Reply Quote 0
                                          • Glasfaser
                                            @GiuseppeS
                                            Ich stelle mal lieber hier die Daten von meinem System ein :
                                            vielleicht hat der ein oder andere den gleichen Fehler !
                                            template vis
                                            47
                                            919
                                            275093
