    4. Test Installer ioBroker Windows v1.5.14.x
    • Stabilostick
      Stabilostick @sigi234 last edited by Stabilostick
      @sigi234
      Speedy Gonzales-schnell!
      (Ich aber auch??😳 )
        sigi234 Forum Testing Most Active @Stabilostick last edited by
        @Stabilostick sagte in [Aufruf] ioBroker für Windows, Version 1.5.14:
        @sigi234
        (Ich aber auch??😳 )
        Ja ! 👍
        Aber, hat die Alte Version nicht deinstalliert, bzw wurde nicht erkannt.
        Log started 09/02/2019 at 18:31:35
        Preferred installation mode : win32
        Trying to init installer in mode win32
        Mode win32 successfully initialized
        [18:31:36] Instance list: ''
        [18:31:36] msiexec.exe version found: 5.0
        [18:31:36] Git version found: 2.21.0
        [18:31:36] Bonjour version found: 3.0.0.10
        [18:31:36] OpenSSL version found: 1.0.2.17
        Setting variable vs_buildtools_version from vswhere.exe -property installationVersion -format value -products Microsoft.VisualStudio.Product.BuildTools -utf8
        Script exit code: 0
        Script output:
         15.9.28307.557
        Script stderr:
        [18:31:36] VS_BuildTools_2017 version found: 15.9.28307.557
        Executing certutil.exe -decode "C:\Users\itservice\AppData\Local\Temp\jq.txt" "C:\Users\itservice\AppData\Local\Temp\jq.exe"
        Script exit code: 0
        Script output:
         Eingabelänge = 3728172
        Ausgabelänge = 2711358
        CertUtil: -decode-Befehl wurde erfolgreich ausgeführt.
        Script stderr:
        iobroker.json
        Executing jq.exe type "C:\ioBroker\iobroker-data\iobroker.json" | find /v /c ""
        Script exit code: 0
        Script output:
        Script stderr:
        Setting variable multihostService from jq.exe -r .multihostService.enabled "C:\ioBroker\iobroker-data\iobroker.json"
        Script exit code: 0
        Script output:
         false
        Script stderr:
        Setting variable objectstype from jq.exe -r .objects.type "C:\ioBroker\iobroker-data\iobroker.json"
        Script exit code: 0
        Script output:
         file
        Script stderr:
        Setting variable statestype from jq.exe -r .states.type "C:\ioBroker\iobroker-data\iobroker.json"
        Script exit code: 0
        Script output:
         file
        Script stderr:
        objects.json
        Executing jq.exe type "C:\ioBroker\iobroker-data\objects.json" | find /v /c ""
        Script exit code: 0
        Script output:
        Script stderr:
        states.json
        Executing jq.exe type "C:\ioBroker\iobroker-data\states.json" | find /v /c ""
        Script exit code: 0
        Script output:
        Script stderr:
        Config
        Setting variable mighostname from jq.exe -r ".|with_entries(select(.key|contains(\"system.host.\")))|.[].common.hostname | select(.==null|not)" "C:\ioBroker\iobroker-data\objects.json"
        Script exit code: 0
        Script output:
         Medion
        Script stderr:
        Setting variable port_admin from jq.exe -r .\"system.adapter.admin.0\".native.port "C:\ioBroker\iobroker-data\objects.json"
        Script exit code: 0
        Script output:
         8081
        Script stderr:
        Setting variable oldnode_version from jq.exe -r ".|with_entries(select(.key|contains(\"system.host.\")))|.[].native.process.versions.node | select(.==null|not)" "C:\ioBroker\iobroker-data\objects.json"
        Script exit code: 0
        Script output:
         10.16.0
        Script stderr:
        Setting variable winsw_id from jq.exe -r ".|with_entries(select(.key|contains(\"system.host.\")))|.[].native.process.env.WINSW_SERVICE_ID | select(.==null|not)" "C:\ioBroker\iobroker-data\objects.json"
        Script exit code: 0
        Script output:
        Script stderr:
        Setting variable port_objects from jq.exe -r .objects.port "C:\ioBroker\iobroker-data\iobroker.json"
        Script exit code: 0
        Script output:
         9001
        Script stderr:
        Setting variable port_states from jq.exe -r .states.port "C:\ioBroker\iobroker-data\iobroker.json"
        Script exit code: 0
        Script output:
         9000
        Script stderr:
        Bereite die Installation vor
        Executing powershell.exe -inputformat none -outputformat none -NonInteractive -Command "Add-MpPreference -ExclusionPath 'C:\Program Files\iobroker\SmartHome'"
        Script exit code: 0
        Script output:
        Script stderr:
        Das Verzeichnis existiert bereits: C:\Program Files\iobroker\SmartHome\setup
        [18:33:05] Die Installation wurde abgebrochen.
        Executing iobroker.exe stop
        Script exit code:
        Script output:
        Script stderr:
        Unknown error while running iobroker.exe stop
        Executing iobroker.exe uninstall
        Script exit code:
        Script output:
        Script stderr:
        Unknown error while running iobroker.exe uninstall
        Executing netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) TCP outbound" dir=out
        Script exit code: 1
        Script output:
        Keine Regeln stimmen mit den angegebenen Kriterien berein.
        Script stderr:
         Program ended with an error exit code
        Fehler beim Ausführen netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) TCP outbound" dir=out: Program ended with an error exit code
        Executing netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) UDP outbound" dir=out
        Script exit code: 1
        Script output:
        Script stderr:
        Fehler beim Ausführen netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) UDP outbound" dir=out: Program ended with an error exit code
        Executing netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) TCP inbound" dir=in
        Script exit code: 1
        Script output:
        Script stderr:
        Fehler beim Ausführen netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) TCP inbound" dir=in: Program ended with an error exit code
        Executing netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) UDP inbound" dir=in
        Script exit code: 1
        Script output:
        Keine Regeln stimmen mit den angegebenen Kriterien überein.
        Script stderr:
        Fehler beim Ausführen netsh.exe advfirewall firewall delete rule name="ioBroker(SmartHome) UDP inbound" dir=in: Program ended with an error exit code
        Executing powershell.exe -inputformat none -outputformat none -NonInteractive -Command "Remove-MpPreference -ExclusionPath 'C:\Program Files\iobroker\SmartHome'"
        Script exit code: 0
        Script output:
        Script stderr:
          sigi234 Forum Testing Most Active @sigi234 last edited by
          @sigi234 sagte in [Aufruf] ioBroker für Windows, Version 1.5.14:
          @sigi234
          (Ich aber auch??😳 )
          Ja ! 👍
          Script exit code: 0
          Script output:
           15.9.28307.557
          Script stderr:
          Script exit code: 0
          Script output:
          Script stderr:
          iobroker.json
          Script exit code: 0
          Script output:
          Script stderr:
          Script exit code: 0
          Script output:
           false
          Script stderr:
          Script exit code: 0
          Script output:
           file
          Script stderr:
          Script exit code: 0
          Script output:
           file
          Script stderr:
          objects.json
          Script exit code: 0
          Script output:
          Script stderr:
          states.json
          Script exit code: 0
          Script output:
          Script stderr:
          Config
          Script exit code: 0
          Script output:
           Medion
          Script stderr:
          Script exit code: 0
          Script output:
           8081
          Script stderr:
          Script exit code: 0
          Script output:
           10.16.0
          Script stderr:
          Script exit code: 0
          Script output:
          Script stderr:
          Script exit code: 0
          Script output:
           9001
          Script stderr:
          Script exit code: 0
          Script output:
           9000
          Script stderr:
          Script exit code: 0
          Script output:
          Script stderr:
          Script exit code:
          Script output:
          Script stderr:
          Script exit code:
          Script output:
          Script stderr:
          Script exit code: 1
          Script output:
          Script stderr:
          Script exit code: 1
          Script output:
          Script stderr:
          Script exit code: 1
          Script output:
          Script stderr:
          Script exit code: 1
          Script output:
          Script stderr:
          Script exit code: 0
          Script output:
          Script stderr:
          Stabilostick 1 Reply Last reply Reply Quote 0
          • Stabilostick
            @sigi234
            Aus dem Log: "Das Verzeichnis existiert bereits: C:\Program Files\iobroker\SmartHome\setup [18:33:05] Die Installation wurde abgebrochen."
            Das passiert, wenn z.B. noch ein CMD-Fenster im Ordner C:\Program Files\iobroker\SmartHome... oder irgendein Datei-Handle bei der Deinstallation offen war. In dem Fall lösche den Ordner "C:\Program Files\iobroker\SmartHome" vor der Installation per Hand (nachdem Du sichergestellt hast, dass da nichts wertvolles mehr enthalten ist).
              @sigi234
              Das passiert, wenn z.B. noch ein CMD-Fenster im Ordner C:\Program Files\iobroker\SmartHome... oder irgendein Datei-Handle bei der Deinstallation offen ist. In dem Fall lösche den Ordner C:\Program Files\iobroker\SmartHome vor der Installation per Hand (nachdem Du sichergestellt hast, dass da nichts wertvolles mehr enthalten ist).
              Ok, in der Reg. auch?
              • Stabilostick
                @sigi234
                Da sollte nichts sein.
                  sigi234 Forum Testing Most Active last edited by sigi234
                  Bericht 2
                  Installation hat geklappt, ein Fehler. Wurde aber abgeschlossen.
                  ioBroker gestartet, Adapter werden anscheidend jetzt alle nachinstalliert. Warte noch ab.
                  Migration abgeschlossen, er wurde alles nachinstalliert ( Dauer 1,5 h). Natürlich nicht die von Github, die habe ich manuell installiert.
                  Läuft, TOP!
                  • Stabilostick
                    @sigi234
                    Hmm, das ist ein Fehler im autonom ablaufenden Installer von Git. Bei Git sollte z.B. eine eventuelle git-bash Kommandozeile vor dem ioBroker-Setup geschlossen werden.
                      michihorn last edited by
                      Habe die neue Windows Installation Iobroker 1.5.14b nun auf meinem Rechner. Die Installation hat unter Berücksichtigung meines alten iobroker-data Ordners hervorragend geklappt. Iobroker ist nun mit allen Adaptern auf dem neusten Stand. Sollte allerdings ein Adapter über die "Katze" auf einem PreRelease Stand installiert worden sein, wird der Installer den z.Zt. aktuellen Adapter Stand installieren. Alle in allem, tolle Arbeit. Ich bin begeistert. Danke Stabilostick
                      • Stabilostick
                        Stabilostick @michihorn last edited by
                        @michihorn sagte in [Aufruf] ioBroker für Windows, Version 1.5.14:
                        Nicht ganz. In diesem Fall muss man aktuell noch den Adapter von Hand nachinstallieren. Mit js-controller 2.x wird automatisch versucht, ihn von der ursprünglichen URL zu laden.
                          Cool, wann kommt er?
                          • Feuersturm
                            Feuersturm last edited by
                            Habe gerade eine frische Instanz mit der Version iobroker-1.5.14.b-windows-installer.exe aufgesetzt. Installation verlief ohne Probleme und Fehlermeldungen.
                            • Q
                              Qlink last edited by
                              installiert er bei einem Upgrade von allen Adaptern die neueste Version, oder die Version, die vorher installiert war ?
                              Bei mir macht nämlich z.B. die neueste SQL Adapter Version Probleme und ich kann nur die Vorgängerversion ohne Fehler einsetzen ...
                              • Stabilostick
                                Stabilostick @Qlink last edited by
                                @Qlink
                                Die Adapter werden bei der Migration/Update/Reparatur in der Version installiert, in der sie vorher installiert waren.
                                • Q
                                  Kurze Rückmeldung:
                                  Ich hätte soeben versucht mit 1.5.14b ein Upgrade meiner bestehenden iobroker Installation durchzuführen.
                                  Das Setup lief ganz normal durch nachdem ich den iobroker Dienst manuell gestoppt habe (es kam eine FM, dass der Admin Port aktuell benutzt wird)
                                  Hier wäre es toll, wenn die Setup Routine den Dienst automatisch stoppen würde, damit kein manuelles Eingreifen notwendig ist.
                                  Nach dem die Installation durchgelaufen ist, ist iobroker ganz normal gestartet.
                                  Leider waren aber keine Bestände in iobroker admin mehr sichtbar.
                                  Nur der admin, info und discovery adapter waren unter instanzen zu finden.
                                  Wie eine komplette Neuinstallation.
                                  Restore von Backups nicht möglich, weder über die backitup adapter (lässt sich nicht starten) noch über cmd iobroker restore 0
                                  Mir ist aufgefallen dass er den alten data ordner eine Ebene zu tief angelegt hat, nämlich unter: C:\ioBroker\iobroker01\iobroker-data\iobroker-data
                                  Zur Info: mein bestehendes iobroker war unter c:\iobroker und die neue instanz hätte unter c:\iobroker\iobroker01 installiert und migriert werden sollen...
                                  Ich hätte auch versucht das iobroker-data verzeichnis manuell nach C:\ioBroker\iobroker01\iobroker-data\ zu kopieren.
                                  Hier waren dann auch wieder sämtliche daten, instanzen und adapter vorhanden, aber es startete kein einziger adapter. Das Log hat permanent Fehlermeldungen ausgespuckt weil anscheinend die Pfade alle noch auf C:\iobroker\ verwiesen haben und nicht auf C:\ioBroker\iobroker01\
                                  Fazit: 3h vergeblich versucht auf eine neue Version zu migrieren 😞 -> Hyper-V Snapshot restored und zurück zum alten System ...
                                  sigi234 Stabilostick 2 Replies Last reply Reply Quote 0
                                    sigi234 Forum Testing Most Active @Qlink last edited by
                                    @Qlink sagte in [Aufruf] ioBroker für Windows, Version 1.5.14:
                                    Das war bei mir auch so, aber die Adapter wurden nach und nach installiert! Das dauerte 1,5 Stunden.
                                    • Q
                                      Gab es dazu irgendwelche Anzeichen ?
                                      Ich habe 30min gewartet und hätte damit gerechnet zumindest irgendwo einen Fortschrittsbalken zu sehen, oder nach und nach mehr Adapter in Instanzen zu finden, oder zumindest Einträge im log.
                                      Es ist in den 30min aber gar nichts passiert, daher hätte ich mich dann an den o.g. restores versucht ...
                                        Ja, im Log
                                        • Stabilostick
                                          Da würde mich interessieren, was da passiert ist. Hast Du noch die Logdateien aus dem „c:\iobroker<Instanz>\setup“-Ordner?
                                          Das System hättest Du nicht unbedingt komplett rücksetzen müssen. Die alte Installation ist unangetastet und die neue Instanz kannst Du mit dem Installer löschen. (Sicherheitshalber vorher Kopie vom c:\iobroker-Ordner machen) 😉
                                          • Q
                                            Sorry, gibt keine log files mehr ...
                                            Ich werde eine neue Server 2019 VM erstellen und iobroker frisch installieren.
                                            Auf welchem Weg ich allerdings am besten meine bestehenden Daten, Instanzen und Adapter in die neue VM migriere weiß ich allerdings nach wie vor nicht.
                                            iobroker-data ordner rüberkopieren und gut is, funzt ja scheinbar auch nicht, falls sich pfade, hostnames oder instance names ändern oder ?
                                            Hast du hier einen möglichst problemlosen weg für mich ?
                                            installation iobroker installation node node npm windows npm windows windows 10
                                            23
                                            236
                                            32390
