    4. [Projekt] ioGo # Smarthome to go
      crunchip Forum Testing Most Active @Guest last edited by
      @nis gerade probiert
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: (node:12186) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process wit
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: (node:12186) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecti
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at /opt/iobroker/node_modules/grpc/src/client_interceptors.js:1123:18
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at InterceptingListener.onReceiveStatus (/opt/iobroker/node_modules/grpc/src/client_interceptors.js:618:8)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at InterceptingListener._callNext (/opt/iobroker/node_modules/grpc/src/client_interceptors.js:568:42)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at Object.onReceiveStatus (/opt/iobroker/node_modules/grpc/src/client_interceptors.js:1306:15)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at ClientDuplexStream._receiveStatus (/opt/iobroker/node_modules/grpc/src/client.js:211:8)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at ClientDuplexStream._emitStatusIfDone (/opt/iobroker/node_modules/grpc/src/client.js:234:12)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at ClientDuplexStream.emit (events.js:198:13)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at ClientDuplexStream.<anonymous> (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:22177:19)
      Caught	2019-09-02 21:34:08.947	error	by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
      Caught	2019-09-02 21:34:08.946	error	by controller[0]: (node:12186) UnhandledPromiseRejectionWarning: FirebaseError: 3 INVALID_ARGUMENT: maximum 500 writes allowed per request
      iogo.0	2019-09-02 21:34:08.896	info	listener removed
      iogo.0	2019-09-02 21:34:08.895	info	triggered listener removed
      iogo.0	2019-09-02 21:34:08.893	info	signed out
      iogo.0	2019-09-02 21:34:08.887	info	listener removed
      iogo.0	2019-09-02 21:34:08.875	info	triggered listener removed
      host.IoBroker	2019-09-02 21:34:08.872	info	stopInstance system.adapter.iogo.0 killing pid 12186
      iogo.0	2019-09-02 21:34:08.874	info	cleaned everything up...
        A Former User @crunchip last edited by
        @crunchip tritt der Fehler beim Stoppen der Instanz auf? Bitte etwas mehr Details was du gemacht hast
          crunchip Forum Testing Most Active @Guest last edited by crunchip
          @nis ja, das kommt, wenn ich den Adapter stoppe, genau das selbe wie vorhin schon gepostet
          hab nur den Adapter gestartet, kurz gewartet und dann wieder beendet
            @crunchip Und viel wichtiger, wie sieht es beim Start aus?
              @nis
              2019-09-02 21:33:36.135 - info: host.IoBroker object change system.adapter.iogo.0
              2019-09-02 21:33:36.156 - info: host.IoBroker instance system.adapter.iogo.0 started with pid 12186
              2019-09-02 21:33:37.805 - info: iogo.0 starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.16.0
              2019-09-02 21:33:37.920 - info: iogo.0 triggered listener removed
              2019-09-02 21:33:38.592 - info: iogo.0 licence key found. licence valid until 2020-08-27 20:38:10
              2019-09-02 21:33:38.593 - info: iogo.0 logged in as: qwertz <= please keep this uid as your secret
              2019-09-02 21:33:38.605 - info: iogo.0 states from remote database removed
              2019-09-02 21:33:38.624 - info: iogo.0 initialize app devices
              2019-09-02 21:33:43.183 - info: iogo.0 database initialized with 1 hosts
              2019-09-02 21:33:43.607 - info: iogo.0 database initialized with 106 instances
              2019-09-02 21:33:43.760 - info: iogo.0 database initialized with 23 enums
              2019-09-02 21:33:44.848 - info: iogo.0 database initialized with 102 adapters
                @crunchip bitte erneut die aktuelle Version von GitHub installieren und nochmal Restart des Adapters
                  @nis adapter gestartet, noch nicht beendet
                  iogo.0	2019-09-02 22:05:18.796	info	database initialized with 23 enums
                  iogo.0	2019-09-02 22:05:18.655	info	database initialized with 106 instances
                  iogo.0	2019-09-02 22:05:18.311	info	database initialized with 1 hosts
                  iogo.0	2019-09-02 22:05:17.985	info	database initialized with 822 states
                  iogo.0	2019-09-02 22:05:12.783	info	initialize app devices
                  iogo.0	2019-09-02 22:05:12.765	info	states from remote database removed
                  iogo.0	2019-09-02 22:05:12.755	info	logged in as: qwertz <= please keep this uid as your secret
                  iogo.0	2019-09-02 22:05:12.754	info	licence key found. licence valid until 2020-08-27 20:38:10
                  iogo.0	2019-09-02 22:05:11.948	info	triggered listener removed
                  iogo.0	2019-09-02 22:05:11.824	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.16.0
                  host.IoBroker	2019-09-02 22:05:10.322	info	instance system.adapter.iogo.0 started with pid 13700
                  host.IoBroker	2019-09-02 22:05:10.303	info	object change system.adapter.iogo.0
                  zwischen drin alle state.system.adapter...has wrong type
                  iogo.0	2019-09-02 22:05:22.623	info	database initialized with 805 state values
                  iogo.0	2019-09-02 22:07:20.826	info	database initialized with 102 adapters
                  adapter gestoppt
                  host.IoBroker	2019-09-02 22:10:29.063	info	instance system.adapter.iogo.0 terminated with code 156 ()
                  iogo.0	2019-09-02 22:10:29.018	info	listener removed
                  iogo.0	2019-09-02 22:10:29.017	info	triggered listener removed
                  iogo.0	2019-09-02 22:10:29.015	info	signed out
                  iogo.0	2019-09-02 22:10:29.009	info	listener removed
                  iogo.0	2019-09-02 22:10:29.001	info	triggered listener removed
                  iogo.0	2019-09-02 22:10:29.000	info	cleaned everything up...
                  host.IoBroker	2019-09-02 22:10:28.999	info	stopInstance system.adapter.iogo.0 killing pid 13700
                  host.IoBroker	2019-09-02 22:10:28.999	info	object change system.adapter.iogo.0
                    @crunchip sieht recht gut aus, ist auch alles in der App sichtbar?
                      @crunchip sagte in [Projekt] ioGo # Native Android App:
                      @nis das hab ich auch gelesen, is eher die frage, warum so viele.
                      1. hab ich nichts geändert
                      2. sind das nur ein paar Lichtschalter, Steckdosen, Xiaomi Sensoren, Strom/Gas Werte und Spritkosten
                        sind da die state´s von der gesamten Iobroker Installation gemeint?
                      Die vielen zusätzlichen States kommen durch die Synchronisation der Instanzen. In der App soll demnächst auch Speicher und CPU Verbrauch angezeigt werden jeder einzelnen Instanz
                        @nis soweit ich sehen konnte ja, werd ich mir heute nachmittag nochmal genauer anschauen
                          mpenno @Guest last edited by
                          @nis Danke. Ich habe den Übeltäter gefunden. 🙂
                          Bzgl. den Einheiten: In der aktuellen Beta werden mir auch keine Einheiten mehr angezeigt. Egal, ob "°C", "kWh" oder "%".
                          PS: Ich nutze ausschließlich den Web-Adapter.
                          • N
                            NightWatcher @Guest last edited by
                            @nis Daran liegt es nicht. Dieses Objekt ist nur beispielhaft für ungefähr 20 ähnlicher Objekte, wo es nicht geht. Manche mit, manche ohne Leerzeichen. Ich denke das ist eher ein grundsätzliches Problem mit unit?
                              A Former User last edited by
                              @NightWatcher @mpenno stehen irgendwelche Fehler im Log der App in Bezug auf die Probleme bei der Anzeige von "unit"?
                                @nis Nein, im Log (verbose) steht gar nichts auffälliges.
                                190903-verbose.log
                                Hast Du übrigens noch Lust einen besseren Status als "true" für das Schloss zu hinterlegen?
                                Als Rolle habe ich "sensor.lock" angegeben.
                                Danke fürs debuggen!
                                  crunchip Forum Testing Most Active last edited by crunchip
                                  @nis soweit so gut, hab mal ein bisschen rumgespielt, funktioniert soweit.
                                  was mir noch fehlt sind die units, hatte ich aber ein paar zeilen weiter oben schon gefragt, mit raw beispiel.
                                  Was nicht mehr funktioniert, ist die Admin-Seite, beim öffnen des Host, Adapter oder Instanzen, bleibt die liste leer.
                                  Was auch noch nicht funktioniert
                                  Nach einer Synchronisation, ist die zuvor eingerichtete Homeseite wieder leer.
                                    MGK last edited by
                                    @nis Gelöschte Funktionen werden in der App leider nicht gelöscht und demzufolge weiter angezeigt, siehe Bild.
                                      A Former User @mpenno last edited by
                                      @mpenno sagte in [Projekt] ioGo # Native Android App:
                                      Klar gerne. Wie soll sensor.lock denn angezeigt werden in deutsch und englisch? Vorschläge?
                                      Gerne kann ich auch noch mehr Rollen aus der Gruppe sensor.* übersetzen.
                                        e-s @Guest last edited by
                                        @nis sagte in [Projekt] ioGo # Native Android App:
                                        @e-s Einzelne Issues auf Github wäre schön, Danke
                                        habe gerade mal in github geschaut, da finde ich nur die alte App und dern iobroker Adapter, da wären die meisten issues aber falsch.
                                          A Former User @e-s last edited by
                                          @e-s hier bitte Issues zur App erfassen: GitHub
                                            Es sind wieder ein paar Fehler behoben und Verbesserungen eingebaut.
                                            Damit ist nun eine weitere Version unterwegs: 2.0.0-beta5
                                            Diese benötigt den Adapter in der neuesten Version: 0.4.4
                                            Anpassungen:
                                            • Passwörter nicht im Klartext anzeigen
                                            • Objekte beim Sync nicht mehr löschen, damit bleiben Sortierung und "starred" Einstellungen erhalten
                                            • Automatisches Löschen von Objekten in der App sobald diese in ioBroker entfernt wurden (Instanzen, Adapter, Enums, States)
                                            • Anzeige der aktuellen Anzahl von Adapter, Instanz, Host im Info View ergänzt
                                            • Anzeige der Instanz ergänzt um aktuellen Speicherverbrauch: MemRSS, MemHeapTotal, MemHeapUsed
                                            crunchip E 2 Replies Last reply Reply Quote 1
                                            android app iogo
                                            61
                                            1140
                                            359772
