    4. IRobot Roomba Adapter
    • JB_Sullivan
      JB_Sullivan last edited by
      Ich gebe mit CANVAS noch nicht auf. Offensichtlich fehlt binding.gyp (siehe unten gyp-ERR!) - aber ich checke das nicht wie ich das nachinstalliert bekomme 😞 😞
      C:\>node-gyp configure
      gyp info it worked if it ends with ok
      gyp info using node-gyp@5.0.3
      gyp info using node@10.16.0 | win32 | ia32
      gyp info find Python using Python version 2.7.15 found at "C:\Program Files\Python\python.exe"
      gyp info find VS using VS2017 (15.9.28307.812) found at:
      gyp info find VS "C:\Program Files\Microsoft Visual Studio\2017\BuildTools"
      gyp info find VS run with --verbose for detailed information
      gyp info spawn C:\Program Files\Python\python.exe
      gyp info spawn args [ 'C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'msvs',
      gyp info spawn args   '-I',
      gyp info spawn args   'C:\\build\\config.gypi',
      gyp info spawn args   'C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\node-gyp\\addon.gypi',
      gyp info spawn args   'C:\\Users\\SmartHome\\AppData\\Local\\node-gyp\\Cache\\10.16.0\\include\\node\\common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=C:\\Users\\SmartHome\\AppData\\Local\\node-gyp\\Cache\\10.16.0',
      gyp info spawn args   '-Dnode_gyp_dir=C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\node-gyp',
      gyp info spawn args   '-Dnode_lib_file=C:\\Users\\SmartHome\\AppData\\Local\\node-gyp\\Cache\\10.16.0\\<(target_arch)\\node.lib',
      gyp info spawn args   '-Dmodule_root_dir=C:\\',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'C:\\build',
      gyp info spawn args   '-Goutput_dir=.' ]
      gyp: binding.gyp not found (cwd: C:\) while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (C:\Users\SmartHome\AppData\Roaming\npm\node_modules\node-gyp\lib\configure.js:344:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Windows_NT 10.0.17763
      gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure"
      gyp ERR! cwd C:\
      gyp ERR! node -v v10.16.0
      gyp ERR! node-gyp -v v5.0.3
      gyp ERR! not ok
      • Zefau
        Zefau @JB_Sullivan last edited by
        @JB_Sullivan führe den Befehl mal im ioBroker Verzeichnis aus
          Wildbill @Zefau last edited by
          @Zefau sagte in IRobot Roomba Adapter:
          Den Fehler mit dem Docking werde ich dann ebenfalls beheben.
          kann es sein, dass das immer noch falsch ist? Bei mir ist zumindest bei meinem 966 der state docked auf false, wenn er in der Ladestation steht und geht auf true, wenn er los fährt.
          Ansonsten geiler Adapter, habe ihn gestern installiert, inklusive canvas auf Ubuntu 18.04. Es läuft ziemlich perfekt, auch eine Karte kommt per Telegram. Allerdings hatte ich heute ziemlich viel im Log. Zur Erklärung, der Roomba startet automatisch um 11 Uhr, fährt dann meist so eine Stunde, geht zum Docking, lädt so eine Stunde nach und fährt dann nochmal. Hier das Log, die Zeiten mit wesentlichen Einträgen könnten sich mit besagtem Zurückfahren und später nochmal starten decken.
          2019-09-03 10:59:59.750  - error: Caught by controller[0]: TypeError: Cannot read property 'drawImage' of undefined
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at mapMission (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:694:7)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:371:6)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at MqttClient.emit (events.js:198:13)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at Timeout.setInterval [as _onTimeout] (/opt/iobroker/node_modules/dorita980/lib/v2/local.js:39:16)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at ontimeout (timers.js:436:11)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
          2019-09-03 10:59:59.750  - error: Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
          2019-09-03 10:59:59.751  - error: host.iobroker instance system.adapter.roomba.0 terminated with code 0 (OK)
          2019-09-03 10:59:59.751  - info: host.iobroker Restart adapter system.adapter.roomba.0 because enabled
          2019-09-03 11:00:29.758  - info: host.iobroker instance system.adapter.roomba.0 started with pid 21125
          2019-09-03 11:00:30.590  - info: roomba.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.roomba, node: v10.16.3
          2019-09-03 11:00:30.640  - info: roomba.0 Connecting to Roomba (192.168.100.63)..
          2019-09-03 11:00:30.777  - info: roomba.0 Restored last mission (#4).
          2019-09-03 11:00:32.583  - info: roomba.0 Roomba online. Connection established.
          2019-09-03 11:00:33.383  - info: roomba.0 Roomba has started a new mission (#5).
          2019-09-03 12:15:43.709  - info: javascript.0 script.js.common.Roomba-Telegram: Roombi finished at  cleaning 0 sqm in 596 seconds (no errors).
          2019-09-03 12:15:43.714  - info: roomba.0 Mission #5 saved.
          2019-09-03 13:17:41.897  - error: roomba.0 uncaught exception: Cannot read property 'push' of undefined
          2019-09-03 13:17:41.898  - error: roomba.0 TypeError: Cannot read property 'push' of undefined
              at mapMission (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:757:15)
          2019-09-03 13:17:41.898  - info: roomba.0 Adapter stopped und unloaded.
          2019-09-03 13:17:41.935  - error: Caught by controller[0]: TypeError: Cannot read property 'push' of undefined
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at mapMission (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:757:15)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:371:6)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at MqttClient.emit (events.js:198:13)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at Timeout.setInterval [as _onTimeout] (/opt/iobroker/node_modules/dorita980/lib/v2/local.js:39:16)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at ontimeout (timers.js:436:11)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
          2019-09-03 13:17:41.935  - error: Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
          2019-09-03 13:17:41.935  - error: host.iobroker instance system.adapter.roomba.0 terminated with code 0 (OK)
          2019-09-03 13:17:41.935  - info: host.iobroker Restart adapter system.adapter.roomba.0 because enabled
          2019-09-03 13:18:11.943  - info: host.iobroker instance system.adapter.roomba.0 started with pid 22381
          2019-09-03 13:18:12.659  - info: roomba.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.roomba, node: v10.16.3
          2019-09-03 13:18:12.702  - info: roomba.0 Connecting to Roomba (192.168.100.63)..
          2019-09-03 13:18:12.880  - info: roomba.0 Restored last mission (#5).
          2019-09-03 13:18:15.687  - info: roomba.0 Roomba online. Connection established.
          2019-09-03 13:18:16.487  - warn: roomba.0 The first argument must be an object
          2019-09-03 13:18:16.488  - warn: roomba.0 TypeError: The first argument must be an object
              at mapMission (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:715:11)
          2019-09-03 13:18:17.288  - warn: roomba.0 The first argument must be an object
          2019-09-03 13:18:17.288  - warn: roomba.0 TypeError: The first argument must be an object
          2019-09-03 13:18:18.088  - warn: roomba.0 The first argument must be an object
          2019-09-03 13:18:18.088  - warn: roomba.0 TypeError: The first argument must be an object
          2019-09-03 13:18:18.888  - warn: roomba.0 The first argument must be an object
          Wiederholt sich so im Sekundentakt
          2019-09-03 13:29:51.403  - warn: roomba.0 The first argument must be an object
          2019-09-03 13:29:51.403  - warn: roomba.0 TypeError: The first argument must be an object
          2019-09-03 13:29:52.204  - warn: roomba.0 The first argument must be an object
          2019-09-03 13:29:52.204  - warn: roomba.0 TypeError: The first argument must be an object
          2019-09-03 13:30:15.693  - warn: roomba.0 Connection lost! Roomba offline.
          2019-09-03 13:30:15.694  - info: roomba.0 Roomba Connection closed.
          2019-09-03 13:30:19.922  - info: roomba.0 Roomba online. Connection established.
          Könnte es damit zusammenhängen, dass er momentan noch Zugriff aufs Internet hat? App ist auf dem Android gestoppt und sollte nicht parallel gelaufen sein. Beim späteren Öffnen habe ich aber auch dort ganz normal die Karte und den Bericht über die Reinigung, ohne Fehler.
          Sollte der Internetzugriff generell verboten sein, wenn man den Adapter in Gebrauch hat, oder sollte sich das nicht beissen, solange man die App nicht öffnet, während der Roomba gerade arbeitet?
          Gruss, Jürgen
          Zefau 2 Replies Last reply Reply Quote 0
          • JB_Sullivan
            Leider auch nicht erfolgreich, da immer noch nicht erkannt und wieder ein Pfund voll Fehlermeldungen angezeigt wurden.
            C:\ioBroker>npm install canvas@2.6.0 --unsafe-perm=true
            unix-dgram@0.2.3 install C:\ioBroker\node_modules\unix-dgram
            node-gyp rebuild
            C:\ioBroker\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
            Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
            unix_dgram.cc
            win_delay_load_hook.cc
            c:\iobroker\node_modules\unix-dgram\node_modules\nan\nan_maybe_43_inl.h(88): error C2039: "ForceSet": Ist kein Element
            von "v8::Object" (Quelldatei wird kompiliert ..\src\unix_dgram.cc) [C:\ioBroker\node_modules\unix-dgram\build\unix_dgra
            m.vcxproj]
            c:\users\smarthome.node-gyp\10.16.0\include\node\v8.h(3243): note: Siehe Deklaration von "v8::Object" (Quelldatei wi
            c:\iobroker\node_modules\unix-dgram\node_modules\nan\nan.h(816): warning C4996: 'node::MakeCallback': wurde als veralte
            t deklariert (Quelldatei wird kompiliert ..\src\unix_dgram.cc) [C:\ioBroker\node_modules\unix-dgram\build\unix_dgram.vc
            xproj]
            c:\users\smarthome.node-gyp\10.16.0\include\node\node.h(176): note: Siehe Deklaration von "node::MakeCallback" (Quel
            c:\iobroker\node_modules\unix-dgram\node_modules\nan\nan.h(830): warning C4996: 'node::MakeCallback': wurde als veralte
            xproj]
            c:\users\smarthome.node-gyp\10.16.0\include\node\node.h(169): note: Siehe Deklaration von "node::MakeCallback" (Quel
            c:\iobroker\node_modules\unix-dgram\node_modules\nan\nan.h(844): warning C4996: 'node::MakeCallback': wurde als veralte
            xproj]
            c:\users\smarthome.node-gyp\10.16.0\include\node\node.h(162): note: Siehe Deklaration von "node::MakeCallback" (Quel
            c:\iobroker\node_modules\unix-dgram\node_modules\nan\nan.h(1457): warning C4996: 'node::MakeCallback': wurde als veralt
            et deklariert (Quelldatei wird kompiliert ..\src\unix_dgram.cc) [C:\ioBroker\node_modules\unix-dgram\build\unix_dgram.v
            cxproj]
            c:\iobroker\node_modules\unix-dgram\src\unix_dgram.cc(9): fatal error C1083: Datei (Include) kann nicht geöffnet werden
            : "unistd.h": No such file or directory [C:\ioBroker\node_modules\unix-dgram\build\unix_dgram.vcxproj]
            gyp ERR! build error
            gyp ERR! stack Error: C:\Program Files\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
            gyp ERR! stack at ChildProcess.onExit (C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
            gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
            gyp ERR! cwd C:\ioBroker\node_modules\unix-dgram
            gyp ERR! node-gyp -v v3.8.0
            gyp ERR! not ok
            canvas@2.6.0 install C:\ioBroker\node_modules\canvas
            node-pre-gyp install --fallback-to-build
            node-pre-gyp WARN Using request for node-pre-gyp https download
            node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-win32-unknown-ia32.tar.gz
            node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.0 and node@10.16.0 (node-v64 ABI, unknown) (falling back to source compile with node-gyp)
            Warning: Missing input files:
            C:\GTK\bin\libfreetype-6.dll
            C:\GTK\bin\libintl-8.dll
            Copying C:/libjpeg-turbo/bin/jpeg62.dll to C:\ioBroker\node_modules\canvas\build\Release\jpeg62.dll
            1 Datei(en) kopiert.
            Backend.cc
            ImageBackend.cc
            PdfBackend.cc
            SvgBackend.cc
            BMPParser.cc
            Backends.cc
            c:\iobroker\node_modules\canvas\src\bmp\bmpparser.cc(189): warning C4018: ">": Konflikt zwischen "signed" und "unsigned
            " [C:\ioBroker\node_modules\canvas\build\canvas.vcxproj]
            c:\iobroker\node_modules\canvas\src\bmp\bmpparser.cc(204): warning C4018: ">": Konflikt zwischen "signed" und "unsigned
            Canvas.cc
            CanvasGradient.cc
            CanvasPattern.cc
            CanvasRenderingContext2d.cc
            closure.cc
            color.cc
            Image.cc
            ImageData.cc
            init.cc
            register_font.cc
            Bibliothek "C:\ioBroker\node_modules\canvas\build\Release\canvas.lib" und Objekt "C:\ioBroker\node_modules\canvas
            build\Release\canvas.exp" werden erstellt.
            Code wird generiert.
            All 2104 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
            Codegenerierung ist abgeschlossen.
            canvas.vcxproj -> C:\ioBroker\node_modules\canvas\build\Release\canvas.node
            Copying C:/GTK/bin/libpangoft2-1.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libpangoft2-1.0-0.dll
            Copying C:/GTK/bin/libgthread-2.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libgthread-2.0-0.dll
            Copying C:/GTK/bin/libpangowin32-1.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libpangowin32-1.0-0.dll
            Copying C:/GTK/bin/libglib-2.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libglib-2.0-0.dll
            Copying C:/GTK/bin/libcairo-2.dll to C:\ioBroker\node_modules\canvas\build\Release\libcairo-2.dll
            Copying C:/GTK/bin/libpango-1.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libpango-1.0-0.dll
            Copying C:/GTK/bin/libfontconfig-1.dll to C:\ioBroker\node_modules\canvas\build\Release\libfontconfig-1.dll
            Copying C:/GTK/bin/libintl-8.dll to C:\ioBroker\node_modules\canvas\build\Release\libintl-8.dll
            Das System kann die angegebene Datei nicht finden.
            Copying C:/GTK/bin/libfreetype-6.dll to C:\ioBroker\node_modules\canvas\build\Release\libfreetype-6.dll
            Copying C:/GTK/bin/libgmodule-2.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libgmodule-2.0-0.dll
            Copying C:/GTK/bin/libpangocairo-1.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libpangocairo-1.0-0.dll
            Copying C:/GTK/bin/libgobject-2.0-0.dll to C:\ioBroker\node_modules\canvas\build\Release\libgobject-2.0-0.dll
            Copying C:/GTK/bin/libpng14-14.dll to C:\ioBroker\node_modules\canvas\build\Release\libpng14-14.dll
            Copying C:/GTK/bin/zlib1.dll to C:\ioBroker\node_modules\canvas\build\Release\zlib1.dll
            Copying C:/GTK/bin/libexpat-1.dll to C:\ioBroker\node_modules\canvas\build\Release\libexpat-1.dll
            All 1 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
            canvas-postbuild.vcxproj -> C:\ioBroker\node_modules\canvas\build\Release\canvas-postbuild.node
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules\iobroker.rflink\node_modules\avrgirl-arduino\node_modules\browser-serialport):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: Error while executing:
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: undefined ls-remote -h -t git://github.com/noopkat/browser-serialport.git
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: spawn git ENOENT
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules\iobroker.rflink\node_modules\avrgirl-arduino\node_modules\stk500):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: undefined ls-remote -h -t git://github.com/noopkat/js-stk500v1.git
            npm WARN enoent ENOENT: no such file or directory, open 'C:\ioBroker\node_modules\avrgirl-arduino\package.json'
            npm WARN enoent ENOENT: no such file or directory, open 'C:\ioBroker\node_modules\build\package.json'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules\iobroker.js-controller\node_modules\diskusage):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Error: EPERM: operation not permitted, unlink 'C:\ioBroker\node_modules\iobroker.js-controller\node_modules.diskusage.DELETE\build\Release\diskusage.node'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules\xpc-connection):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"ia32"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules\osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"ia32"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules\fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"ia32"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
            • canvas@2.6.0
              added 11 packages from 3 contributors, removed 49 packages, updated 2 packages, moved 29 packages and audited 20651 packages in 187.896s
              found 40 vulnerabilities (29 low, 11 high)
              run npm audit fix to fix them, or npm audit for details
            C:\ioBroker>
            • Zefau
              @JB_Sullivan Du musst zwischen WARN und ERROR unterscheiden. WARN ist nicht unbedingt schlimm, wie jetzt in deinem Fall ist alles erfolgreich durchgelaufen. Du hast aber (wieder) canvas im falschem Ordner installiert. Du musst canvas im ioBroker.roomba Ordner installieren. Das sind wir oben schon durchgegangen.
              • JB_Sullivan
                JB_Sullivan @Zefau last edited by JB_Sullivan
                @Zefau
                Nein, du hast geschrieben - "führe den Befehl mal im ioBroker Verzeichnis aus" - das ist für mich "C:/ioBroker" das ist das ioBroker Verzeichnis - ich dachte das wäre Absicht, darum habe ich es so versanden.
                Die male davor habe ich es in C:/ioBroker/node_modules/iobroker.roomba installiert ....... und da liegt Canvas auch.
                Es sind alle Canvas Dateien genau dort und trotzdem meckert der Adapter das er sie nicht finden kann.
                Aber ich mache es gerne noch einmal unter C:/ioBroker/node_modules/iobroker.roomba
                • JB_Sullivan
                  So ich habe jetzt Canavas nochmal in den iobroker.roomba Ordner installiert.
                  Hier das Ergebnis:
                  C:\ioBroker\node_modules\iobroker.roomba>npm install canvas@2.6.0 --unsafe-perm=true
                  canvas@2.6.0 install C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                  Copying C:/libjpeg-turbo/bin/jpeg62.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                  \jpeg62.dll
                  Backend.cc
                  ImageBackend.cc
                  PdfBackend.cc
                  SvgBackend.cc
                  BMPParser.cc
                  Backends.cc
                  c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(189): warning C4018: ">": Konflikt zw
                  ischen "signed" und "unsigned" [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                  c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(204): warning C4018: ">": Konflikt zw
                  Canvas.cc
                  CanvasGradient.cc
                  CanvasPattern.cc
                  closure.cc
                  color.cc
                  Image.cc
                  ImageData.cc
                  init.cc
                  register_font.cc
                  Bibliothek "C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.lib" und Objekt "C:
                  ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.exp" werden erstellt.
                  canvas.vcxproj -> C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node
                  Copying C:/GTK/bin/libpangoft2-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Releas
                  Copying C:/GTK/bin/libgthread-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                  Copying C:/GTK/bin/libpangowin32-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Rele
                  Copying C:/GTK/bin/libglib-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\l
                  ibglib-2.0-0.dll
                  Copying C:/GTK/bin/libcairo-2.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\libc
                  airo-2.dll
                  Copying C:/GTK/bin/libpango-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\
                  libpango-1.0-0.dll
                  Copying C:/GTK/bin/libfontconfig-1.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                  Copying C:/GTK/bin/libintl-8.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\libin
                  tl-8.dll
                  Copying C:/GTK/bin/libfreetype-6.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\l
                  ibfreetype-6.dll
                  Copying C:/GTK/bin/libgmodule-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                  Copying C:/GTK/bin/libpangocairo-1.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Rele
                  Copying C:/GTK/bin/libgobject-2.0-0.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release
                  Copying C:/GTK/bin/libpng14-14.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\lib
                  png14-14.dll
                  Copying C:/GTK/bin/zlib1.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\zlib1.dll
                  Copying C:/GTK/bin/libexpat-1.dll to C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\libe
                  xpat-1.dll
                  canvas-postbuild.vcxproj -> C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas-postbu
                  ild.node
                  • canvas@2.6.0
                    added 381 packages from 1033 contributors, removed 2 packages, updated 14 packages and audited 7482 packages in 50.36s
                    found 0 vulnerabilities
                  Ich habe den Adapter gestoppt und wieder gestartet, den Robbi laufen lassen und anschließend wieder zur Basis geschickt.
                  Das Ergebnis ist das gleiche wie immer - kann keine Karte geladen werden.
                  Hier der LOG aus dem ioBroker Admin.
                  roomba.0	2019-09-03 20:43:53.630	debug	system.adapter.admin.0: logging true
                  roomba.0	2019-09-03 20:43:41.297	info	Triggered action -dock- on Roomba.
                  roomba.0	2019-09-03 20:43:41.063	info	Roomba online. Connection established.
                  roomba.0	2019-09-03 20:43:37.872	debug	{"code":"EPIPE"}
                  roomba.0	2019-09-03 20:43:37.872	info	Roomba Connection closed.
                  roomba.0	2019-09-03 20:43:37.872	warn	Connection lost! Roomba offline.
                  roomba.0	2019-09-03 20:43:37.872	info	Triggered action -dock- on Roomba.
                  roomba.0	2019-09-03 20:43:34.281	info	Triggered action -dock- on Roomba.
                  roomba.0	2019-09-03 20:43:31.682	info	Triggered action -stop- on Roomba.
                  roomba.0	2019-09-03 20:40:07.186	info	Triggered action -start- on Roomba.
                  roomba.0	2019-09-03 20:39:54.384	debug	Subscribed to states commands.dock.
                  roomba.0	2019-09-03 20:39:54.384	debug	Subscribed to states commands.resume.
                  roomba.0	2019-09-03 20:39:54.384	debug	Subscribed to states commands.pause.
                  roomba.0	2019-09-03 20:39:54.384	debug	Subscribed to states commands.stop.
                  roomba.0	2019-09-03 20:39:54.384	debug	Subscribed to states commands.start.
                  web.0	2019-09-03 20:39:50.354	info	==>Connected system.user.admin from ::ffff:10.122.60.28
                  roomba.0	2019-09-03 20:39:46.728	info	Roomba online. Connection established.
                  roomba.0	2019-09-03 20:39:44.525	info	Connecting to Roomba (10.122.60.10)..
                  roomba.0	2019-09-03 20:39:44.525	debug	\\?\C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node
                  roomba.0	2019-09-03 20:39:44.525	debug	Das angegebene Modul wurde nicht gefunden.
                  roomba.0	2019-09-03 20:39:44.525	warn	Canvas not installed! Thus, no map drawings are possible.
                  roomba.0	2019-09-03 20:39:44.353	info	starting. Version 1.0.6 in C:/ioBroker/node_modules/iobroker.roomba, node: v10.16.0
                  roomba.0	2019-09-03 20:39:44.259	debug	statesDB connected
                  roomba.0	2019-09-03 20:39:44.244	debug	objectDB connected
                  Das Problem ist das gleiche wie immer - er meckert, das er canvas.node nicht finden kann, obwohl es GENAU dort liegt.
                  Zefau Stabilostick 2 Replies Last reply Reply Quote 0
                  • Zefau
                    @JB_Sullivan Ich bin leider ratlos. Er müsste nach der Installation von canvas (die bei dir ja auch erfolgreich durchläuft) eigl. auf C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas zugreifen und nicht auf \\?\C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node.
                    • JB_Sullivan
                      Gibt es irgend eine Config Datei wo der Pfad drin steht? Vielleicht kann man das händisch ändern?
                      • Zefau
                        @JB_Sullivan C:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\binding.gyp
                        Mein Inhalt der Datei:
                          'conditions': [
                            ['OS=="win"', {
                              'variables': {
                                'GTK_Root%': 'C:/GTK',  # Set the location of GTK all-in-one bundle
                                'with_jpeg%': 'false',
                                'with_gif%': 'false',
                                'with_rsvg%': 'false',
                                'variables': { # Nest jpeg_root to evaluate it before with_jpeg
                                  'jpeg_root%': '<!(node ./util/win_jpeg_lookup)'
                                'jpeg_root%': '<(jpeg_root)', # Take value of nested variable
                                'conditions': [
                                  ['jpeg_root==""', {
                                    'with_jpeg%': 'true'
                            }, {  # 'OS!="win"'
                              'variables': {
                                'with_jpeg%': '<!(node ./util/has_lib.js jpeg)',
                                'with_gif%': '<!(node ./util/has_lib.js gif)',
                                'with_rsvg%': '<!(node ./util/has_lib.js rsvg)'
                          'targets': [
                              'target_name': 'canvas-postbuild',
                              'dependencies': ['canvas'],
                              'conditions': [
                                ['OS=="win"', {
                                  'copies': [{
                                    'destination': '<(PRODUCT_DIR)',
                                    'files': [
                                      '<(GTK_Root)/bin/zlib1.dll',
                                      '<(GTK_Root)/bin/libintl-8.dll',
                                      '<(GTK_Root)/bin/libpng14-14.dll',
                                      '<(GTK_Root)/bin/libpangocairo-1.0-0.dll',
                                      '<(GTK_Root)/bin/libpango-1.0-0.dll',
                                      '<(GTK_Root)/bin/libpangoft2-1.0-0.dll',
                                      '<(GTK_Root)/bin/libpangowin32-1.0-0.dll',
                                      '<(GTK_Root)/bin/libcairo-2.dll',
                                      '<(GTK_Root)/bin/libfontconfig-1.dll',
                                      '<(GTK_Root)/bin/libfreetype-6.dll',
                                      '<(GTK_Root)/bin/libglib-2.0-0.dll',
                                      '<(GTK_Root)/bin/libgobject-2.0-0.dll',
                                      '<(GTK_Root)/bin/libgmodule-2.0-0.dll',
                                      '<(GTK_Root)/bin/libgthread-2.0-0.dll',
                                      '<(GTK_Root)/bin/libexpat-1.dll'
                              'target_name': 'canvas',
                              'include_dirs': ["<!(node -e \"require('nan')\")"],
                              'sources': [
                                'src/backend/Backend.cc',
                                'src/backend/ImageBackend.cc',
                                'src/backend/PdfBackend.cc',
                                'src/backend/SvgBackend.cc',
                                'src/bmp/BMPParser.cc',
                                'src/Backends.cc',
                                'src/Canvas.cc',
                                'src/CanvasGradient.cc',
                                'src/CanvasPattern.cc',
                                'src/CanvasRenderingContext2d.cc',
                                'src/closure.cc',
                                'src/color.cc',
                                'src/Image.cc',
                                'src/ImageData.cc',
                                'src/init.cc',
                                'src/register_font.cc'
                              'conditions': [
                                ['OS=="win"', {
                                  'libraries': [
                                    '-l<(GTK_Root)/lib/cairo.lib',
                                    '-l<(GTK_Root)/lib/libpng.lib',
                                    '-l<(GTK_Root)/lib/pangocairo-1.0.lib',
                                    '-l<(GTK_Root)/lib/pango-1.0.lib',
                                    '-l<(GTK_Root)/lib/freetype.lib',
                                    '-l<(GTK_Root)/lib/glib-2.0.lib',
                                    '-l<(GTK_Root)/lib/gobject-2.0.lib'
                                  'include_dirs': [
                                    '<(GTK_Root)/include',
                                    '<(GTK_Root)/include/cairo',
                                    '<(GTK_Root)/include/pango-1.0',
                                    '<(GTK_Root)/include/glib-2.0',
                                    '<(GTK_Root)/include/freetype2',
                                    '<(GTK_Root)/lib/glib-2.0/include'
                                  'defines': [
                                    '_USE_MATH_DEFINES'  # for M_PI
                                  'configurations': {
                                    'Debug': {
                                      'msvs_settings': {
                                        'VCCLCompilerTool': {
                                          'WarningLevel': 4,
                                          'ExceptionHandling': 1,
                                          'DisableSpecificWarnings': [
                                            4100, 4611
                                    'Release': {
                                      'msvs_settings': {
                                          'WarningLevel': 4,
                                            4100, 4611
                                }, {  # 'OS!="win"'
                                  'libraries': [
                                    '<!@(pkg-config pixman-1 --libs)',
                                    '<!@(pkg-config cairo --libs)',
                                    '<!@(pkg-config libpng --libs)',
                                    '<!@(pkg-config pangocairo --libs)',
                                    '<!@(pkg-config freetype2 --libs)'
                                  'include_dirs': [
                                    '<!@(pkg-config cairo --cflags-only-I | sed s/-I//g)',
                                    '<!@(pkg-config libpng --cflags-only-I | sed s/-I//g)',
                                    '<!@(pkg-config pangocairo --cflags-only-I | sed s/-I//g)',
                                    '<!@(pkg-config freetype2 --cflags-only-I | sed s/-I//g)'
                                  'cflags!': ['-fno-exceptions'],
                                  'cflags_cc!': ['-fno-exceptions']
                                ['OS=="mac"', {
                                  'xcode_settings': {
                                    'GCC_ENABLE_CPP_EXCEPTIONS': 'YES'
                                ['with_jpeg=="true"', {
                                  'defines': [
                                    'HAVE_JPEG'
                                  'conditions': [
                                    ['OS=="win"', {
                                      'copies': [{
                                        'files': [
                                          '<(jpeg_root)/bin/jpeg62.dll',
                                      'include_dirs': [
                                        '<(jpeg_root)/include'
                                      'libraries': [
                                        '-l<(jpeg_root)/lib/jpeg.lib',
                                      'libraries': [
                                        '-ljpeg'
                                ['with_gif=="true"', {
                                  'defines': [
                                    'HAVE_GIF'
                                  'conditions': [
                                    ['OS=="win"', {
                                      'libraries': [
                                        '-l<(GTK_Root)/lib/gif.lib'
                                      'libraries': [
                                        '-lgif'
                                ['with_rsvg=="true"', {
                                  'defines': [
                                    'HAVE_RSVG'
                                  'conditions': [
                                    ['OS=="win"', {
                                      'copies': [{
                                        'files': [
                                          '<(GTK_Root)/bin/librsvg-2-2.dll',
                                          '<(GTK_Root)/bin/libgdk_pixbuf-2.0-0.dll',
                                          '<(GTK_Root)/bin/libgio-2.0-0.dll',
                                          '<(GTK_Root)/bin/libcroco-0.6-3.dll',
                                          '<(GTK_Root)/bin/libgsf-1-114.dll',
                                          '<(GTK_Root)/bin/libxml2-2.dll'
                                      'libraries': [
                                        '-l<(GTK_Root)/lib/librsvg-2-2.lib'
                                      'include_dirs': [
                                        '<!@(pkg-config librsvg-2.0 --cflags-only-I | sed s/-I//g)'
                                      'libraries': [
                                        '<!@(pkg-config librsvg-2.0 --libs)'
                        • Zefau
                          Zefau @JB_Sullivan last edited by Zefau
                          @JB_Sullivan ggf. die C:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\package.json?
                          Mein Inhalt:
                           "_from": "canvas@^2.6.0",
                           "_id": "canvas@2.6.0",
                           "_inBundle": false,
                           "_integrity": "sha512-bEO9f1ThmbknLPxCa8Es7obPlN9W3stB1bo7njlhOFKIdUTldeTqXCh9YclCPAi2pSQs84XA0jq/QEZXSzgyMw==",
                           "_location": "/iobroker.roomba/canvas",
                           "_phantomChildren": {},
                           "_requested": {
                             "type": "range",
                             "registry": true,
                             "raw": "canvas@^2.6.0",
                             "name": "canvas",
                             "escapedName": "canvas",
                             "rawSpec": "^2.6.0",
                             "saveSpec": null,
                             "fetchSpec": "^2.6.0"
                           "_requiredBy": [
                             "/iobroker.roomba"
                           "_resolved": "https://registry.npmjs.org/canvas/-/canvas-2.6.0.tgz",
                           "_shasum": "7a8f87b6148845d97e6ee30947fba1508bed4941",
                           "_spec": "canvas@^2.6.0",
                           "_where": "C:\\Users\\Zefau\\iobroker\\node_modules\\iobroker.roomba",
                           "author": {
                             "name": "TJ Holowaychuk",
                             "email": "tj@learnboost.com"
                           "binary": {
                             "module_name": "canvas",
                             "module_path": "build/Release",
                             "host": "https://github.com/node-gfx/node-canvas-prebuilt/releases/download/",
                             "remote_path": "v{version}",
                             "package_name": "{module_name}-v{version}-{node_abi}-{platform}-{libc}-{arch}.tar.gz"
                           "browser": "browser.js",
                           "bugs": {
                             "url": "https://github.com/Automattic/node-canvas/issues"
                           "bundleDependencies": false,
                           "contributors": [
                               "name": "Nathan Rajlich",
                               "email": "nathan@tootallnate.net"
                               "name": "Rod Vagg",
                               "email": "r@va.gg"
                               "name": "Juriy Zaytsev",
                               "email": "kangax@gmail.com"
                           "dependencies": {
                             "nan": "^2.14.0",
                             "node-pre-gyp": "^0.11.0",
                             "simple-get": "^3.0.3"
                           "deprecated": false,
                           "description": "Canvas graphics API backed by Cairo",
                           "devDependencies": {
                             "@types/node": "^10.12.18",
                             "assert-rejects": "^1.0.0",
                             "dtslint": "^0.5.3",
                             "express": "^4.16.3",
                             "mocha": "^5.2.0",
                             "pixelmatch": "^4.0.2",
                             "standard": "^12.0.1"
                           "engines": {
                             "node": ">=6"
                           "files": [
                             "binding.gyp",
                             "lib/",
                             "src/",
                             "util/",
                             "types/index.d.ts"
                           "homepage": "https://github.com/Automattic/node-canvas",
                           "keywords": [
                             "canvas",
                             "graphic",
                             "graphics",
                             "pixman",
                             "cairo",
                             "image",
                             "images",
                             "pdf"
                           "license": "MIT",
                           "main": "index.js",
                           "name": "canvas",
                           "repository": {
                             "type": "git",
                             "url": "git://github.com/Automattic/node-canvas.git"
                           "scripts": {
                             "benchmark": "node benchmarks/run.js",
                             "dtslint": "dtslint types",
                             "install": "node-pre-gyp install --fallback-to-build",
                             "prebenchmark": "node-gyp build",
                             "pretest": "standard examples/*.js test/server.js test/public/*.js benchmarks/run.js lib/context2d.js util/has_lib.js browser.js index.js && node-gyp build",
                             "pretest-server": "node-gyp build",
                             "test": "mocha test/*.test.js",
                             "test-server": "node test/server.js"
                           "types": "types/index.d.ts",
                           "version": "2.6.0"
                          Sind darin insbesondere die Pfade identisch zu deiner Variante?
                          • Zefau
                            Zefau @Wildbill last edited by
                            @Wildbill sagte in IRobot Roomba Adapter:
                            Bin aktuell nicht Zuhause und werde das nochmal prüfen, wenn ich wieder da bin.
                            • JB_Sullivan
                              OK - hier mein binding.gyp und package.json - liegt im selben Dateipfad wie bei dir. Ich werde mal alles vergleichen.
                              'conditions': [
                              ['OS=="win"', {
                              'variables': {
                              'conditions': [
                              ['jpeg_root==""', {
                              }, { # 'OS!="win"'
                              'variables': {
                              'targets': [
                              'conditions': [
                              ['OS=="win"', {
                              'copies': [{
                              'files': [
                              'include_dirs': ["<!(node -e "require('nan')")"],
                              'sources': [
                              'src/Backends.cc',
                              'src/Canvas.cc',
                              'src/closure.cc',
                              'src/color.cc',
                              'src/Image.cc',
                              'src/ImageData.cc',
                              'src/init.cc',
                              'conditions': [
                              ['OS=="win"', {
                              'libraries': [
                              'include_dirs': [
                              'defines': [
                              'configurations': {
                              'Debug': {
                              'msvs_settings': {
                              'WarningLevel': 4,
                              4100, 4611
                              'Release': {
                              'msvs_settings': {
                              'WarningLevel': 4,
                              4100, 4611
                              }, { # 'OS!="win"'
                              'libraries': [
                              'include_dirs': [
                              ['OS=="mac"', {
                              'xcode_settings': {
                              'defines': [
                              'HAVE_JPEG'
                              'conditions': [
                              ['OS=="win"', {
                              'copies': [{
                              'files': [
                              'include_dirs': [
                              'libraries': [
                              'libraries': [
                              '-ljpeg'
                              'defines': [
                              'HAVE_GIF'
                              'conditions': [
                              ['OS=="win"', {
                              'libraries': [
                              'libraries': [
                              '-lgif'
                              'defines': [
                              'HAVE_RSVG'
                              'conditions': [
                              ['OS=="win"', {
                              'copies': [{
                              'files': [
                              'libraries': [
                              'include_dirs': [
                              'libraries': [
                              .... und package.json
                              "_from": "canvas@2.6.0",
                              "_inBundle": false,
                              "_location": "/canvas",
                              "_requested": {
                              "type": "version",
                              "registry": true,
                              "raw": "canvas@2.6.0",
                              "name": "canvas",
                              "rawSpec": "2.6.0",
                              "saveSpec": null,
                              "fetchSpec": "2.6.0"
                              "_requiredBy": [
                              "#USER",
                              "_spec": "canvas@2.6.0",
                              "_where": "C:\ioBroker\node_modules\iobroker.roomba",
                              "author": {
                              "binary": {
                              "bugs": {
                              "contributors": [
                              "name": "Rod Vagg",
                              "email": "r@va.gg"
                              "dependencies": {
                              "nan": "^2.14.0",
                              "mocha": "^5.2.0",
                              "engines": {
                              "node": ">=6"
                              "files": [
                              "binding.gyp",
                              "lib/",
                              "src/",
                              "util/",
                              "types/index.d.ts"
                              "keywords": [
                              "canvas",
                              "graphic",
                              "graphics",
                              "pixman",
                              "cairo",
                              "image",
                              "images",
                              "pdf"
                              "license": "MIT",
                              "main": "index.js",
                              "name": "canvas",
                              "repository": {
                              "type": "git",
                              "scripts": {
                              "pretest": "standard examples/.js test/server.js test/public/.js benchmarks/run.js lib/context2d.js util/has_lib.js browser.js index.js && node-gyp build",
                              "version": "2.6.0"
                              • Zefau
                                @JB_Sullivan in der package.json sind ein paar Sachen, den die Unterschied machen könnten. Einfach mal rumprobieren.
                                • JB_Sullivan
                                  Werde ich mal machen, auch wenn ich keine Ahnung davon habe, was von "Kriegs entscheidender" Relevanz ist.
                                  • Zefau
                                    @JB_Sullivan kann ich auch nur raten, aber _location würde ich probieren und _requiredBy und ggf. nochmal _where.
                                    • Zefau
                                      Sind alles Fehler im Adapter. Bitte installiere dir die aktuelle Version v1.0.7 von Github. Diese sollte die Fehler beheben.
                                      Danke dir für's Testen.
                                        eben von 1.0.6 auf 1.0.7 upgedated. Bin gespannt und werde morgen berichten. Danke schonmal.
                                        Gruss, Jürgen
                                        • kobi wan
                                          kobi wan last edited by
                                          Habe auch das Problem mit dem Docked-Status, wobei er bei mir immer auf true steht. Eben auf 1.07 upgegradet, aber keine Änderung. Habe übrigens den iRobot 695.
                                          • Stabilostick
                                            Stabilostick @JB_Sullivan last edited by Stabilostick
                                            @JB_Sullivan
                                            Ich habe mal ein ganz verrückte Idee. Installiere doch einmal eine weitere ioBroker-Instanz mit dem neuen Windows Installer auf Deinen Rechner. An der bestehenden Installation unter c:\Windows wird nichts verändert, so dass Du jederzeit zurück gehen kannst.
                                            Der neue Installer hat eine Funktion zur Migration und Reparatur. Dabei werden all Deine Daten, Skripte, Adaptereinstellunge usw. übernommen. Dazu musst Du den bestehenden iobroker-data-Ordner Deiner bestehenden Installation als Referenz angeben. Alle Adapter (außer die manuell von GitHub installierten) werden in den vorher installierten Versionen mit den referenzierten node_modules-Dateien neu installiert.
                                            Bitte stoppe den alten iobroker-Dienst manuell vor der Migration. Er bleibt bestehen, so dass Du ihn ggf. später bei einem Rücksprung wieder aktivieren kannst, wenn Du mit dem Migrationsergebnis nicht zufrieden bist.
                                            https://forum.iobroker.net/post/293701
                                            81.1k
                                            851
                                            300260
