    4. Error delete file…
    SOLVED Error delete file…
      AndyUM61 last edited by
      bei mir kann ioBroker die backup-Files nicht löschen.
      Ist da irgend ein Fehler drin?
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_18-12_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_16-11_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_15-22_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_13-34_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_11-34_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_09-33_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_07-33_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_05-33_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_03-33_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-12_01-33_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-11_23-33_states.json.gz: {}
      Cannot	2018-08-14 18:17:52.330	error	delete file "C:/Program Files/ioBroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2018-08-11_21-33_states.json.gz: {}
      • David McNeill
        David McNeill @Merlin123 last edited by
        root cause is explained by user voretsen ... here
        Die Ursache wird vom Benutzer voretsen erklärt ... hier
          paul53 last edited by
          Nodejs 10.x ? Dann https://forum.iobroker.net/viewtopic.php?f=17&t=15083&p=157659#p157659 (node.exe austauschen).
          • Merlin123
            Ich habe den Fehler auch. Habe node.js 8.11.4 installiert.
            Was könnte das noch sein?
            David McNeill 1 Reply Last reply Reply Quote 0
            • David McNeill
