    5. Suchanfrage: Blockly worx Adapter
    • haselchen
      haselchen Most Active last edited by haselchen
      Ich weiss leider auch nicht , ob eine Veränderung in den Worx Datenpunkten den regulären Kalender ausser Kraft setzt. Das müsstet Du mal in dem Worx Adapter Thread erfragen.
      • dslraser
        dslraser Forum Testing Most Active @muuulle last edited by
        @muuulle
        hier mal mein Blockly (eins von zwei)
         <block type="procedures_defcustomnoreturn" id="L[J9.gWLUvGQ,)TxDIP2" x="13" y="13">
           <mutation statements="false"></mutation>
           <field name="NAME">DP_erstellen</field>
           <field name="SCRIPT">Ly9EYXRlbnB1bmt0IGVyc3RlbGxlbgpjcmVhdGVTdGF0ZSgiRWlnZW5lX0RhdGVucHVua3RlLjE2UmFzZW5t5Ghlci5aZWl0cGxhbl9hbl9hdXMiLCd0cnVlJywgewogICAgbmFtZTogJ1Jhc2VubeRoZXIgWmVpdHBsYW4gYW4gYXVzJywgCiAgICByb2xlOiAnc3dpdGNoJywKICAgIHR5cGU6ICdib29sZWFuJywgCiAgICByZWFkOiAgdHJ1ZSwgCiAgICB3cml0ZTogdHJ1ZSwKICAgICJzbWFydE5hbWUiOiB7CiAgICAiZGUiOiAiUmFzZW5t5GhlciBaZWl0cGxhbiIsCiAgICAic21hcnRUeXBlIjogIlNXSVRDSCIKfQp9KTs=</field>
         <block type="procedures_callcustomnoreturn" id="9(|Z1$;?4u5}ptr~}I0G" x="13" y="63">
           <mutation name="DP_erstellen"></mutation>
             <block type="schedule" id="P4+oP}pjNI.p:r_D9{nj">
               <field name="SCHEDULE">{"time":{"start":"09:59","end":"12:59","mode":"minutes","interval":1},"period":{"days":1,"dows":"[1,2,3,4,5]"}}</field>
                 <block type="controls_if" id="8yV?Gw.D1|MPXm^;zw72">
                     <block type="logic_operation" id="Q.LsTj5VS7g|#@+RLPg(" inline="false">
                       <field name="OP">AND</field>
                         <block type="logic_operation" id="_vn.oaH)|Te4X~+:a+I!" inline="false">
                             <block type="logic_operation" id="vVoMDH9X6Wo?X!$/;hLY" inline="false">
                                 <block type="logic_compare" id="81/z(6+cqM!`Y[Y5~jp8">
                                   <field name="OP">EQ</field>
                                     <block type="get_value" id="0M-58mN$OIs2^#`Gfsa_">
                                       <field name="OID">javascript.0.Eigene_Datenpunkte.16Rasenmäher.Zeitplan_an_aus</field>
                                     <block type="logic_boolean" id=",)]r$X]G;7rUF5k2_,,x">
                                 <block type="logic_compare" id="~hy=F%JTkEONY0}Z@AGn">
                                     <block type="get_value" id="Zf:|2MaW7u#D04|HeD1t">
                                       <field name="OID">javascript.0.Eigene_Datenpunkte.16Rasenmäher.Status</field>
                                     <block type="text" id="}63G{4x+EAq|*![Y=8!D">
                                       <field name="TEXT">zu Hause</field>
                             <block type="logic_compare" id="bBlnb*eBM6j(I*@Mt4^l">
                               <field name="OP">NEQ</field>
                                 <block type="get_value" id="Jis(F)uJJ8-*TpL=V6QR">
                                   <field name="OID">javascript.0.Eigene_Datenpunkte.16Rasenmäher.Error_Code</field>
                                 <block type="text" id="^#mOn9n5gYxN[F`P7x-F">
                                   <field name="TEXT">Regen Pause</field>
                         <block type="logic_compare" id="{|sd*gh0IBKK$Uil%nSh">
                           <field name="OP">GTE</field>
                             <block type="get_value" id="DIP*`E;aL(Q]900[I(jC">
                               <field name="OID">worx.0.xxx.mower.batteryState</field>
                             <block type="math_number" id="t`*[f15(uhtht|+dVEr/">
                               <field name="NUM">85</field>
                     <block type="control" id=";p%RJ?=xM8d`aEKosyCC">
                       <field name="OID">worx.0.xxx.mower.state</field>
                         <block type="logic_boolean" id="z=fS8esptb/Oa*=S.|Lf">
                 <block type="schedule" id="$tGG|1V:K|F|pN%GX!_2">
                   <field name="SCHEDULE">{"time":{"start":"13:01","end":"14:59","mode":"minutes","interval":10},"period":{"days":1,"dows":"[1,2,3,4,5]"}}</field>
                     <block type="controls_if" id="!0L?30~z$^1plkRDNf,o">
                         <block type="logic_operation" id="[ai1bq+OKO;Xitj*4.*R" inline="false">
                             <block type="logic_compare" id="Ndnbf(Q)8pwUndIoALtZ">
                                 <block type="get_value" id="mw(88hoi:VFZ1u/%0|,Q">
                                 <block type="logic_boolean" id="u$Jq$*1=3DS;Cgh|Zuj3">
                             <block type="logic_compare" id="6N/1B|3I2E`sZGbjc3)e">
                                 <block type="get_value" id="i8Y)tw;|7`9Z7:3`qfEN">
                                 <block type="text" id="VG`q^ze?GDO1DXDohz/=">
                         <block type="control" id="^t?,K_B)e#[Zx|Q*?myg">
                             <block type="logic_boolean" id=";$*b-yA{z(s{QgZ2`%M{">
                     <block type="schedule" id="?B%}}]}fSPGJtZPiog0e">
                       <field name="SCHEDULE">{"time":{"start":"15:00","end":"18:00","mode":"minutes","interval":1},"period":{"days":1,"dows":"[1,2,3,4,5]"}}</field>
                         <block type="controls_if" id="5rQp$eToZZy}YrO])~sD">
                             <block type="logic_operation" id="_yL{AaYTn-wFL)XKk?^g" inline="false">
                                 <block type="logic_operation" id="~9~-wWDnCUC~2B9{oU9y" inline="false">
                                     <block type="logic_operation" id="YHx+Av,QUj$(:ox~!{bD" inline="false">
                                         <block type="logic_compare" id="ELhsHE)._-nu)aXgm!s5">
                                             <block type="get_value" id="j0|mbbS9~M@K:N[(xN9f">
                                             <block type="logic_boolean" id="={%JpqGoRzgbP$2t(nP#">
                                         <block type="logic_compare" id="ZldCEP0*}K3;jor(Z-iq">
                                             <block type="get_value" id="d/Zcoazj:TiW@8WBp#~b">
                                             <block type="text" id="Q3K8SvO52F#,=6!*)`O-">
                                     <block type="logic_compare" id="])qko5Je[{tz{d]^i/Fx">
                                         <block type="get_value" id="M^%5kp_wuhb2DhO7HoHZ">
                                         <block type="text" id="wcNU[H{#/hORudaN-nt%">
                                 <block type="logic_compare" id="61o]CRFKsnbh$MNHU~LN">
                                     <block type="get_value" id="[XQu@Xvv(xDcXc6I~P@[">
                                     <block type="math_number" id="0]q@:{S7q5B64UAgs^PO">
                             <block type="control" id="ueCf!qC#)H(`^]+^2O-R">
                                 <block type="logic_boolean" id="N@}kbc#)f3M]YMawd`FC">
                         <block type="schedule" id="SOym^V7{^`V*,7a{8B%5">
                           <field name="SCHEDULE">{"time":{"start":"18:01","end":"19:00","mode":"minutes","interval":10},"period":{"days":1,"dows":"[1,2,3,4,5]"}}</field>
                             <block type="controls_if" id="yO)6ycnbnN/8]MF8l:Sw">
                                 <block type="logic_operation" id="}nhlQ1zex]/08(5-JJwj" inline="false">
                                     <block type="logic_compare" id="iD^gPv.Ip.r*F:f-T$}W">
                                         <block type="get_value" id="f|_HtHA0UfOWk3SFiYxl">
                                         <block type="logic_boolean" id="*VF,_qx$Z7yH^k5t.6It">
                                     <block type="logic_compare" id="efK]SZl|m4wVsxOliitV">
                                         <block type="get_value" id="A(?A:T[$TZ|N^/:,wn)I">
                                         <block type="text" id="OThx}XjuSXv7*dY#9G=W">
                                 <block type="control" id=".cIGZ4wg(+:q4TEg1UkT">
                                     <block type="logic_boolean" id="kAUUL,M.s13Y8|=S,}%:">
        • dslraser
          dslraser Forum Testing Most Active @muuulle last edited by dslraser
          @muuulle
          Blockly zwei
          Bitte die Textdatei mit speichern unter bzw. runter laden auf den eigenen Rechner speichern und dort öffnen und den Inhalt kopieren und importieren. Nicht im Browser die Textdatei öffnen und von dort den Inhalt kopieren, dann kommt es beim Import zu Umlautefehlern.
          Export als Textdatei, da 50.000 Zeichen Limit vom Forum überschritten.
          Rasenmaeher_Status und Error.txt
          M 2 Replies Last reply Reply Quote 1
          • dslraser
            dslraser Forum Testing Most Active @haselchen last edited by
            @haselchen sagte in Suchanfrage: Blockly worx Adapter:
            Wenn ich mich nicht falsch erinnere, musste mindestens 1 Tag in der App angeben.
            ich habe in der App keinen Mähplan an (auch nicht einen einzelnen Tag)
            Ich habe das nur über das obere Blockly laufen weil ich in der App jeden Tag nur Zeiten von bis angeben kann, also ohne z.B. eine "Mittagspause". Zwei Mähzeiten an einem Tag habe ich da nicht gefunden.
            Da ich aber einen sensiblen Nachbarn habe, habe ich jetzt Zeiten von Mo-Fr von 10-13 Uhr und 15-18 Uhr. Manuell geht dann trotzdem über einen zusätzlichen Datenpunkt (Zeitplan an/aus)
            Ich nutze zur Steuerung den iQontrol Adapter, oder Alexa über Sprachbefehle mit dem iot Adapter.
            • haselchen
              haselchen Most Active @dslraser last edited by
              @dslraser
              Kann es leider jetzt nicht testen, aber sagt die App nicht , wenn Du alle Tage löschst, dass Du mindestens 1 Tag konfigurieren musst?
              • dslraser
                @haselchen Nein, bei mir nicht.
                • dslraser
                  @haselchen
                  soweit ich weiß ist das bei Gardena so, das Du mindestens einen Tag brauchst.
                  Bei Worx anscheinend nicht.
                    muuulle @dslraser last edited by
                    @dslraser
                    Vielen Dank!
                    Werde ich nachher mal importieren!
                      @dslraser
                      Was wird mit „Rasenmäher Zeitplan an aus“ abgefragt und warum muss der Wert wahr sein?
                      Steht das in Bezug zu deinem iQontrol Adapter? Kann man hier das ebenfalls exportieren? Das wäre wirklich großartig.
                      Wie steuerst du den Kantenschnitt?
                      Vielen, vielen Dank für deine Unterstützung!
                      • dslraser
                        @muuulle sagte in Suchanfrage: Blockly worx Adapter:
                        @dslraser
                        das Script läuft nur wenn der DP Zeitplan wahr ist bzw. nur dann wird geschaltet. Ja, das steht in Bezug zum iQontrol Adapter, aber zu finden ist der Datenpunkt unter javascript.0.Eigene_Datenpunkte.16Rasenmäher.Zeitplan_an_aus
                        Der DP wird im Blockly erstellt
                        iQontrol kann ich nix exportieren bzw. nur komplett, aber das hilft Dir dann nicht.
                        Der Kantenschnitt ist im worx Adapter möglich.
                        Adaptereinstellung bei mir
                        Datenpunkt edgecut
                          @dslraser
                          So, jetzt habe ich auch iQontrol nachgebaut. Klappt alles toll. Vielen Dank dafür.
                          Muss ich den Kantenschnitt statt des Start/Stop ansteuern? Hast du den Kantenschnitt regelmäßig im Mähplan berücksichtigt oder machst du das nur punktuell und manuell mittels Schalter im iQontrol?
                          Kannst du mich nochmal anschieben? 😌
                          • dslraser
                            @muuulle
                            den Kantenschnitt mache ich bisher manuell. Könnte man aber auch im Blockly mit einbauen.
                            • dslraser
                              @dslraser
                              Also für den Kantenschnitt habe ich in iQontrol nur einen Button genommen.
                                muuulle @dslraser last edited by muuulle
                                @dslraser
                                So müsste es funktionieren, oder? Dann ist Dienstag und Freitag Abend zunächst Kantenschnitt und später gemäht.
                                Edit.
                                Es muss ODER sein 😵
                                • dslraser
                                  @muuulle
                                  nein, kann eigentlich nicht gehen. In Deinem Blockly ist die Bedingung das Dienstag und Freitag gleichzeitig ist ...😁
                                  mach mal oder draus
                                    @dslraser
                                    Geändert. Danke!
                                    • dslraser
                                      @muuulle
                                      ich mache gerade was anderes, aber ich glaube so geht es noch nicht wirklich...Ich schaue mir das später mal an.
                                      Ist es jetzt nicht so, das er jetzt Dienstags und Freitags ständig die Kante mäht und sonst nix anderes macht ? (müßte man noch einen Zähler einbauen)
                                        @dslraser
                                        Ich probiere es morgen mal aus 😊
                                        Edit.
                                        Ich habe jetzt noch einen Timeout reingenommen:
                                        • dslraser
                                          @muuulle
                                          aber dann mäht er ja trotzdem Dienstags und Freitags ständig die Kante und zum normalen mähen wird es kaum kommen, weil, wenn er in der Ladestation ist, direkt wieder los geschickt wird und dann wieder die Kante mäht....
                                          • dslraser
                                            @muuulle
                                            ich habe es jetzt mal mit einem Tag (heute) probiert, heute morgen hat es funktioniert. Also morgens den Zähler auf 1 setzen, damit einmal der Kantenschnitt gemacht wird, dann soll die Variable auf eins bleiben.
                                            Abends, nach dem letzten Mähvorgang soll dann die Variable wieder auf 0 gesetzt werden, so das dann der Kantenschnitt für den/die Tage (sollte auch mit mehreren Tagen gehen---über eine oder Verknüpfung) wieder auf null steht....
                                            Ich probiere das mal so aus.
                                            2260
