    4. Test Adapter fb-checkpresence v0.1.x
    • afuerhoff
      afuerhoff Developer @sigi234 last edited by
      @sigi234 sagte in [Neuer Adapter] iobroker.fb-checkpresence:
      Seit 15 Minuten keine Aktualisierung.
      Hallo, das deutet darauf hin, dass zur Fritzbox keine Verbindung besteht. Kannst Du mal einen Log Auszug posten.
        sigi234 Forum Testing Most Active @afuerhoff last edited by
        @afuerhoff sagte in [Neuer Adapter] iobroker.fb-checkpresence:
        2019-09-06 21:48:26.426  - info: host.Medion object change system.adapter.fb-checkpresence.0
        2019-09-06 21:48:26.426  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0
        2019-09-06 21:48:26.427  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0 killing pid 12400
        2019-09-06 21:48:26.474  - warn: host.Medion instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
        2019-09-06 21:48:26.474  - info: host.Medion instance system.adapter.fb-checkpresence.0 terminated with code null ()
        2019-09-06 21:48:29.001  - info: host.Medion instance system.adapter.fb-checkpresence.0 started with pid 2188
        2019-09-06 21:48:29.370  - debug: fb-checkpresence.0 objectDB connected
        2019-09-06 21:48:29.378  - debug: fb-checkpresence.0 statesDB connected
        2019-09-06 21:48:29.387  - info: fb-checkpresence.0 starting. Version 0.0.1 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.16.0
        2019-09-06 21:48:29.398  - info: fb-checkpresence.0 start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 30 (*/30 * * * *)
        2019-09-06 21:48:29.465  - info: email.0 Send email: {"text":"iobroker - System Adapter laufen fehlerfrei","from":"xxxxxxxxxx@xxxxxxxxxx","to":"xxxxxxxxxx@gmail.com","subject":"ioBroker"}
        2019-09-06 21:48:29.518  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:48:29.530  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799309528}
        2019-09-06 21:48:29.530  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        2019-09-06 21:48:29.581  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:48:29.591  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        2019-09-06 21:48:29.591  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799309589}
        2019-09-06 21:48:29.626  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:48:29.637  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799309636}
        2019-09-06 21:48:29.637  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        2019-09-06 21:48:30.630  - info: email.0 sent to xxxxxxxxxx@gmail.com
        2019-09-06 21:48:52.472  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
        2019-09-06 21:49:18.232  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
        2019-09-06 21:51:23.794  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
        2019-09-06 21:53:15.098  - info: host.Medion object change system.adapter.fb-checkpresence.0
        2019-09-06 21:53:15.098  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0
        2019-09-06 21:53:15.098  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0 killing pid 2188
        2019-09-06 21:53:15.125  - warn: host.Medion instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
        2019-09-06 21:53:15.125  - info: host.Medion instance system.adapter.fb-checkpresence.0 terminated with code null ()
        2019-09-06 21:53:15.141  - info: email.0 Send email: {"text":"iobroker - System Adapter meldet Probleme fb-checkpresence.0 alive","from":"xxxxxxxxxx@xxxxxxxxxx","to":"xxxxxxxxxx@gmail.com","subject":"ioBroker"}
        2019-09-06 21:53:16.392  - info: email.0 sent to xxxxxxxxxx@gmail.com
        2019-09-06 21:53:17.660  - info: host.Medion instance system.adapter.fb-checkpresence.0 started with pid 11812
        2019-09-06 21:53:18.120  - debug: fb-checkpresence.0 objectDB connected
        2019-09-06 21:53:18.128  - debug: fb-checkpresence.0 statesDB connected
        2019-09-06 21:53:18.135  - info: fb-checkpresence.0 starting. Version 0.0.1 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.16.0
        2019-09-06 21:53:18.144  - info: fb-checkpresence.0 start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 30 (*/30 * * * *)
        2019-09-06 21:53:18.217  - info: email.0 Send email: {"text":"iobroker - System Adapter laufen fehlerfrei","from":"xxxxxxxxxx@xxxxxxxxxx","to":"xxxxxxxxxx@gmail.com","subject":"ioBroker"}
        2019-09-06 21:53:18.268  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:53:18.272  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799598271}
        2019-09-06 21:53:18.272  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        2019-09-06 21:53:18.341  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:53:18.341  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799598340}
        2019-09-06 21:53:18.341  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        2019-09-06 21:53:18.399  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:53:18.400  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        2019-09-06 21:53:20.564  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
        2019-09-06 21:53:26.987  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
        2019-09-06 21:54:17.438  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
        2019-09-06 21:57:01.382  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
        2019-09-06 21:57:34.664  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
        2019-09-06 21:57:46.674  - info: host.Medion object change system.adapter.fb-checkpresence.0
        2019-09-06 21:57:46.674  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0
        2019-09-06 21:57:46.674  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0 killing pid 11812
        2019-09-06 21:57:46.696  - warn: host.Medion instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
        2019-09-06 21:57:46.696  - info: host.Medion instance system.adapter.fb-checkpresence.0 terminated with code null ()
        2019-09-06 21:57:49.232  - info: host.Medion instance system.adapter.fb-checkpresence.0 started with pid 7736
        2019-09-06 21:57:49.789  - debug: fb-checkpresence.0 objectDB connected
        2019-09-06 21:57:49.798  - debug: fb-checkpresence.0 statesDB connected
        2019-09-06 21:57:49.811  - info: fb-checkpresence.0 starting. Version 0.0.1 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.16.0
        2019-09-06 21:57:49.824  - info: fb-checkpresence.0 start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 10 (*/10 * * * *)
        2019-09-06 21:57:49.962  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:57:50.032  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:57:50.090  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        2019-09-06 21:57:50.091  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          @sigi234
          Das sieht so aus, als ob dein Polling Intervall auf 30 Minuten eingestellt ist.
          • Negalein
            @afuerhoff
            Wäre es möglich, die Daten von fb-checkpresence.0.xxxx.history als Tabelle anzuzeigen?
            Derzeit gibt der DP leider nichts ansehbares raus.
              sigi234 Forum Testing Most Active @afuerhoff last edited by sigi234
              @sigi234
              Jupp........🙄
              Dachte es sind Sekunden.
              • afuerhoff
                @Negalein sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                <span style="color:yellow">{fb-checkpresence.0.Lisi.history}
                Danke!
                Ist das normal, dass die Daten so komisch (schiach) angezeigt werden?
                Tabelle ist mit diesem DP nicht möglich?
                Ja leider, da wäre ein DP Table nötig.
                Vielleicht kann das @afuerhoff einbauen?
                Ist auf der ToDo Liste
                • afuerhoff
                  afuerhoff Developer @bommel_030 last edited by
                  @bommel_030 sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                  @afuerhoff
                  Ich nutze aktuell HM Pdetect auf der CCU.
                  Wunsch wäre quasi das analog auf dem iobroker nachzubilden.
                  Schaue ich mir an.
                  • O
                    onkel-ede last edited by
                    Der Adapter macht eigentlich genau das, was ich brauch. Nur gelegentlich merkt er nicht, dass ich das Haus verlassen habe. Woran kann das liegen? Abrufintervall (steht auf 1 ändern)? Ich nutze ein iphone. Bei den Androiden habe ich dies noch beobachtet.
                    • afuerhoff
                      afuerhoff Developer @onkel-ede last edited by
                      @onkel-ede
                      es dauert bis zu 10 Minuten bis die Fritzbox den Status auf false setzt. Kann es daran liegen?
                        kommt er bald in den Beta Status?
                        • afuerhoff
                          @sigi234
                          Es ist noch einiges zu tun. Ist ja auch einer meiner ersten Adapter und Javascript ist auch neu für mich. Ich kann demnächst mal wieder eine Version freischalten.
                          • opossum
                            opossum last edited by
                            ich habe den Adapter auf meinem Testsystem installiert. Er funktioniert. Die Datenpunkte sind angelegt und werden auch aktualisiert. Genutzt werden in unserem Haushalt Huawei-Telefone. Wenn ich bei mir das History-Logging deaktiviere und das SQL-Logging aktiviere, erhalte ich im Log den Fehler:
                            ERROR:TypeError: Cannot read property 'enabled' of undefined
                            Leider nutze ich den History-Adapter nicht, bei mir läuft eine SQL-Datenbank, die alle Datensammlungen aufnimmt. Wirst Du da in absehbarer Zeit eine Erweiterung vornehmen?
                            @sigi234 Würdest Du mir Deine o.g. Ansicht als Export zur Verfügung stellen? Gern auch per PN?
                            Egbert
                            sigi234 afuerhoff 2 Replies Last reply Reply Quote 0
                              sigi234 Forum Testing Most Active @opossum last edited by
                              @opossum sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                              Bitte sehr:
                              Widget_Checkpresence_2.zip
                              Negalein opossum 2 Replies Last reply Reply Quote 0
                              • Negalein
                                Negalein Global Moderator @sigi234 last edited by
                                Ist das eine neue Version?
                                Ist mit Passwort gesichert! 😞
                                  sigi234 Forum Testing Most Active @Negalein last edited by
                                  Nein keine neue Version
                                  • O
                                    onkel-ede @afuerhoff last edited by
                                    @onkel-ede
                                    Nein, daran liegt es nicht. Ich war ca. 3 Stunden unterwegs und in der Historie des Datenpunktes steht davon nix.
                                    In der FritzBox unter Netzwerkverbindungen stehen die iphone dann allerdings auch noch drin, jedoch ohne "verbunden mit:".
                                    • opossum
                                      opossum @sigi234 last edited by
                                      @sigi234
                                      Bitte sehr:
                                      Vielen Dank, hat alles funktioniert.
                                      • afuerhoff
                                        afuerhoff Developer @opossum last edited by
                                        Hallo, SQL ist schon in Arbeit.
                                        • afuerhoff
                                          @onkel-ede sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                                          @onkel-ede
                                          Hallo, kannst Du mal den Log vom Adapter posten.
                                          • Ralla66
                                            Ralla66 Most Active last edited by Ralla66
                                            Adapter bleibt bei mir Gelb.
                                            TR-064 verbindet sich mit der Fritte, ist aber deaktiviert.
                                            Scheint so als wenn der Adapter sich nicht mit der Fritte verbindet.
                                            Denkfehler von mir ?
                                            Log sagt immer invalid status code <500> ?
                                            Wäre ja 500 Internal Server Error Dies ist ein „Sammel-Statuscode“ für unerwartete Serverfehler.
                                            Muß was in der Fritte freigegeben werden ?
                                            31.7k
                                            79.8k
                                            fb-checkpresence adapter
                                            30
                                            346
                                            44206
