    4. KNX Adapter überholt
    • Merlin123
      Merlin123 last edited by
      Hab gestern auf die neue Version aktualisiert und bekomme jetzt folgende Meldung:
      knx.0	2019-09-08 10:18:55.792	error	TypeError: Cannot read property 'read' of undefined at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:3891) at Object.change (/opt/iobroker/node_modules/iobroker.js-cont
      knx.0	2019-09-08 10:18:55.791	error	message knx.0.Beleuchtung.Licht_Hue_Status.LichtHue_Flur_EG_Status [object Object] Cannot read property 'read' of undefined
      knx.0	2019-09-08 10:17:36.156	error	TypeError: Cannot read property 'read' of undefined at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:3891) at Object.change (/opt/iobroker/node_modules/iobroker.js-cont
      knx.0	2019-09-08 10:17:36.156	error	message knx.0.Beleuchtung.Licht_Hue_Status.LichtHue_Flur_EG_Status [object Object] Cannot read property 'read' of undefined
      knx.0	2019-09-08 10:01:45.829	error	TypeError: Cannot read property 'read' of undefined at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:3891) at Object.change (/opt/iobroker/node_modules/iobroker.js-cont
      knx.0	2019-09-08 10:01:45.828	error	message knx.0.Beleuchtung.Licht_Hue_Status.LichtHue_Flur_EG_Status [object Object] Cannot read property 'read' of undefined
      knx.0	2019-09-08 10:01:35.604	error	TypeError: Cannot read property 'read' of undefined at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:3891) at Object.change (/opt/iobroker/node_modules/iobroker.js-cont
      knx.0	2019-09-08 10:01:35.604	error	message knx.0.Beleuchtung.Licht_Hue_Status.LichtHue_Flur_OG_Status [object Object] Cannot read property 'read' of undefined
      knx.0	2019-09-08 09:58:34.039	error	TypeError: Cannot read property 'read' of undefined at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:3891) at Object.change (/opt/iobroker/node_modules/iobroker.js-cont
      knx.0	2019-09-08 09:58:34.038	error	message knx.0.Beleuchtung.Licht_Hue_Status.LichtHue_Flur_EG_Status [object Object] Cannot read property 'read' of undefined
      knx.0	2019-09-08 09:50:59.855	error	TypeError: Cannot read property 'read' of undefined at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:3891) at Object.change (/opt/iobroker/node_modules/iobroker.js-cont
      knx.0	2019-09-08 09:50:59.854	error	message knx.0.Beleuchtung.Licht_Hue_Status.LichtHue_Flur_EG_Status [object Object] Cannot read property 'read' of undefined
      knx.0	2019-09-08 09:50:56.614	debug	system.adapter.admin.0: logging true
      knx.0	2019-09-07 20:25:40.177	info	Connected! with 153 datapoints of 329 Datapoints over all.
      knx.0	2019-09-07 20:25:40.176	info	Connected - local UDP Server listening on 0.0.0.0:54307
      knx.0	2019-09-07 20:25:40.176	info	Event : UDP - listening
      knx.0	2019-09-07 20:25:40.176	info	Debuglevel: 1 2
      knx.0	2019-09-07 20:25:40.176	info	Connecting to knx GW: 192.168.0.112:3671 with phy. Adr: 15.15.241
      knx.0	2019-09-07 20:25:40.175	info	knx license is OK.
      knx.0	2019-09-07 20:25:39.620	info	starting. Version 1.0.32 in /opt/iobroker/node_modules/iobroker.knx, node: v10.15.2
      Hat jemand eine Idee was das sein könnte? Hatte ich bisher nicht.
      • chefkoch009
        chefkoch009 Developer last edited by
        Ich habe eine Idee. Ist im nächsten Update mit drin.
        VG
        chefkoch009
        • Merlin123
          Merlin123 @chefkoch009 last edited by Merlin123
          @chefkoch009 sagte in KNX Adapter überholt:
          Klingt gut! Schon ne Idee, wann das kommen wird?
          Muss das heute nochmal beobachten, aber ein Script hatte gestern abend und heute morgen auch Probleme, was auf dem Bus zu schalten (Tag/Nachtschaltung). Falls das weiter nicht geht würde ich sonst wieder eine Version zurückgehen, wenn das Update noch etwas länger dauert.
          EDIT:
          Nachdem ich wieder auf die 1.0.31 zurück bin, geht die Tag/Nacht Umschaltung wieder. in der 32er ist irgendwie ein kleiner Wurm drin
          • chefkoch009
            nur kurze Zwischenmeldung: ich denke(hoffe), das das Update morgen Abend kommt.
            Da war ich wohl beim letzten "Code aufräumen" etwas übereifrig.🙄
            VG
            chefkoch009
            • Merlin123
              Ok. Perfekt.
              Danke für Deine Mühe! Das ist für mich der wichtigste Adapter überhaupt.
                tipitopi last edited by
                Ich stehe mit iobroker noch ziehmlich am Anfang, nachdem ich mich aber mit openhab beschäftigt hatte finde ich den KNX Adapter für den iobroker natürlich eine ziehmlich feine Sache da man das KNX Projekt einfach importieren kann.
                Ich hätte eine Frage bezüglich der Rückmeldungen bei Dimmbaren Lampen.
                Ich bin mir nicht sicher ob er bei Dimmbaren Lampen automatisch die Adresse absolut mit Status verbinden sollte damit man an einem Slider nur ein Objekt benötigt oder ob ich das selber über ein Skript selber lösen muß.
                Bei einfachen Lampen holt er sich den Status über das Schalten Objekt.
                Ich habe die Version 1.0.20 installiert
                Danke schonmal für eure Hilfe 😊
                  tombox @tipitopi last edited by
                  @tipitopi Wenn du die Gruppenadresse korrekt benennst dann wird der Status automatisch an die Adresse gebunden:
                  einheitliche Beschriftung der GA-Namen (z.B "EG Wohnen Decke Licht schalten" und "EG Wohnen Decke Licht schalten status"
                    Das habe ich ja bei den nur Schalten Adressen aber bei dimmen absolut und dimmwert status nicht, dadurch habe ich keine Rückmeldung an einem Slider. Frage ist ja ob der import das hier genauso erkannt haben müsste? Ich habe ein paar Themen gefunden wo das dann mit einem script gelöst wurde, nur ist das noch immer so oder müsste das in dem aktuellen Versionen vom KNX Adapter verknüpft werden?
                      @tipitopi Wenn die beiden Objekte "EG Dimmen absolut" und "EG Dimmen absolut status" heißen dann erkennt der Adapter beim Import die beiden Sachen und du kannst sie einfach im Slider benutzen.
                        schmid_no1 last edited by
                        @chefkoch009 Hallo Chefkoch
                        Ich nutze den Adapter schon seit mehreren Jahren und bin bis auf ein paar kleinere Änderungen die ich an den Objekten machen musste sehr zufrieden. Aktuell nutze ich die Version 1.0.19 (stable). Weil ich diesem threat aufmerksam folge, habe ich natürlich die neueren Versionen alle schon min. 1 mal versucht zum laufen zu bringen dies aber nicht geschafft. Meine Frage dazu wäre ; Überall in den Beschreibungen wird von einer sauberen ets-Programmierung geschprochen, doch was ist sauber? Ich habe das Projekt von meinem Elektriker bekommen und musste nach ca. 1 Jahr doch noch mit ets5 selber Hand anlegen. Leider musste ich feststellen dass ich mich in der ets5 Programmierung jetzt besser auskenne wie er, was im umkerschluss heißt ich programmiere mein Projekt nach besten Wissen selber. Könntest du dir mein Projekt mal anschauen ob dieses für deinen Adapter überhaupt geeignet ist.
                        Danke für deine Mühe
                          @tombox ich hatte meine Adressen
                          ...Dimmwert Absolut
                          und
                          ...Dimmen Status
                          genannt, deswegen hatte das nicht geklappt.
                          Nach umbenennen in
                          ...Dimmen
                          und
                          ...Dimmen Status
                          hats dann funktioniert, hinterher ist immer alles einfach 😀
                            ecki945 last edited by ecki945
                            Ich habe mich beim Anlegen der Gruppenadressen an das Buch vom KNX-Papst EIB-Meier gehalten:
                            Vorlage für Schalt / Dimm
                            	Adresse	Name	Beschreibung	Zentralfunktion	Durch Linienkoppler lassen	Datentyp	Länge	Anzahl der Verknüpfungen	Letzter Wert
                            	9/0/0	Kopiervorlage Schalt /Dimm Deckenbeleuchtung E/A		Nein	Nein	Schalten
                            	9/0/1	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Dim		Nein	Nein
                            	9/0/2	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Wert		Nein	Nein	Prozent (0..100%)
                            	9/0/3	Kopiervorlage Schalt /Dimm Deckenbeleuchtung RM E/A		Nein	Nein	Status
                            	9/0/4	Kopiervorlage Schalt /Dimm Deckenbeleuchtung RM Wert		Nein	Nein	Prozent (0..100%)
                            	9/0/5	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Reserve 1		Nein	Nein
                            	9/0/6	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Reserve 2		Nein	Nein
                            	9/0/7	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Reserve 3		Nein	Nein
                            	9/0/8	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Reserve 4		Nein	Nein
                            	9/0/9	Kopiervorlage Schalt /Dimm Deckenbeleuchtung Reserve 5		Nein	Nein
                            Vorlage für Rolladen / Jalousie
                            	9/1/0	Kopiervorlage Rolladen Behang Auf-Ab fahren (Auto)		Nein	Nein	Schalten
                            	9/1/1	Kopiervorlage Rolladen Stopp Auf-Ab (Tippbetrieb)		Nein	Nein	Schalten
                            	9/1/2	Kopiervorlage Rolladen Pos. Höhe anfahren 0…255		Nein	Nein	Zählimpulse (0..255)
                            	9/1/3	Kopiervorlage Rolladen Status Höhe 0…255		Nein	Nein	Prozent (0..100%)
                            	9/1/4	Kopiervorlage Rolladen Status Endlage oben		Nein	Nein	Status
                            	9/1/5	Kopiervorlage Rolladen Status Endlage unten		Nein	Nein	Status
                            	9/1/6	Kopiervorlage Rolladen Reserve 1		Nein	Nein
                            	9/1/7	Kopiervorlage Rolladen Reserve 2		Nein	Nein
                            	9/1/8	Kopiervorlage Rolladen Reserve 3		Nein	Nein
                            	9/1/9	Kopiervorlage Rolladen Reserve 4		Nein	Nein
                            Kann mein Projekt zur Analyse auch gerne zur Verfügung stellen.
                            • chefkoch009
                              es ist mal wieder so weit. Die neue Version 1.0.33 ist raus.
                              @ecki945 : Bei der neuen Version werden beim Import nun die Units (so die DPT's richtig vergeben sind) mit übergeben.
                              @schmid_no1 : "ob das Projekt .....überhaupt geeignet ist" : Grundsätzlich sollte es jedes Projekt sein. Je "aufgeräumter" ein Projekt ist, desto besser ist das Importergebniss. Aber ich kann gern mal drüberschauen dazu bitte per PN.
                              Über reges testen und feedback würde ich mich wieder freuen.
                              VG
                              chefkoch009
                              • Garfonso
                                Garfonso Developer last edited by
                                @chefkoch009
                                Ich habe mal noch eine Verständnisfrage: Es gibt ja beim Import den Haken "Nur neue Objekt hinzufügen". Was genau macht der? Die Situation ist bei mir meist, dass ich die Objekte in knx.0.* nicht lösche, z.B. auch weil dann die Einstellungen für iot weg sind.
                                Daher die Frage: Wenn ich etwas an einer bestimmten GA im ETS ändere und ich möchte diese Änderung im knx Adapter haben (also z.B. anderer DTP oder Flags waren falsch oder so, Name bleibt aber identisch), was macht der Adapter, wenn ich den Haken dahin mache und was macht er, wenn der Haken nicht da ist?
                                Konkrete Frage 1: Ersetzt er, wenn der Haken nicht da ist alle Objekte mit denen, die er neu aus dem Import generiert? Konkrete Frage 2: Ignoriert er Änderungen an GAs beim Import, wenn er dafür schon ein Objekt hat?
                                Bisher ist mein Vorgehen meist so, dass ich zu den GA(s) an denen ich etwas ändere die Objekte lösche und dann den Haken setze. Irgendwie sehe ich aber keinen wirklichen Unterschied, ob ich den Haken setze, oder nicht. Daher hier mal die Frage, was dabei tatsächlich im Hintergrund abläuft. 🙂
                                Noch eine zweite, kleinere Frage (da ich bei ETS/KNX noch immer neues Entdecke): Die Datentype der GAs sind wichtig, das habe ich verstanden. Aber man kann ja auch in einer GA bei den Objekten Datentypen setzen (und zum Teil sind die bei mir anders als die von der GA oder gar nicht gesetzt). Ist das für den Adapter wichtig? Oder werden die ignoriert? Was passiert, wenn ein Konflikt zwischen dem GA Datentyp ist und dem Objekt Datentyp?
                                • N
                                  Neledo last edited by
                                  Ich habe seit kurzer Zeit das Problem, dass keine ETS Sicherung mehr im ioBroker zu importieren ist.
                                  Kann jemand in seinem Testsystem das mal Probieren oder mir nen Tipp geben wie ein eventuelles Projekt in ETS "Reparieren" kann?
                                  • Glasfaser
                                    Glasfaser @Neledo last edited by
                                    @Neledo
                                    Welche ETS Version hattest du , bei der Erstellung der Sicherungsdatei.
                                    • N
                                      Neledo @Glasfaser last edited by
                                      @Glasfaser 5.7.2 Build 743
                                      • Glasfaser
                                        Glasfaser @Neledo last edited by Glasfaser
                                        @Neledo
                                        Ok … die aktuelle !
                                        Kannst du Sie mir senden , dann kann ich Sie bei mir Testen
                                        Welche Adapter Version hast Du !
                                        • N
                                          @Glasfaser heute auf 1.0.33 geupdatet
                                            peer69 Forum Testing last edited by
                                            1.0.33 gibt mir leider genau wie 1.0.32 disconnects alle paar Minuten. 1.0.31 läuft fehlerfrei.
                                            chefkoch009 1 Reply Last reply Reply Quote 0
                                            1043
                                            342911
