    4. Iot error read ECONNRESET !!!
    SOLVED Iot error read ECONNRESET !!!
    • marcuskl
      marcuskl @Bluefox last edited by
      @Bluefox sagte in Iot error read ECONNRESET !!!:
      @marcuskl https://github.com/aws/aws-iot-device-sdk-js/issues/280#issuecomment-529990098
      Der error kommt seitdem ich es abgeändert habe
      2019-09-10 17:53:08.200  - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iot/main.js:777
      2019-09-10 17:53:08.209  - error: Caught by controller[0]: 		keepalive: 60,
      2019-09-10 17:53:08.209  - error: Caught by controller[0]: 		^^^^^^^^^
      2019-09-10 17:53:08.209  - error: Caught by controller[0]: SyntaxError: Unexpected identifier
      2019-09-10 17:53:08.209  - error: Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
      2019-09-10 17:53:08.209  - error: Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      2019-09-10 17:53:08.209  - error: Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
      2019-09-10 17:53:08.209  - error: Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      2019-09-10 17:53:08.209  - error: Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      2019-09-10 17:53:08.210  - error: Caught by controller[0]:     at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
      2019-09-10 17:53:08.210  - error: Caught by controller[0]:     at startup (internal/bootstrap/node.js:283:19)
      2019-09-10 17:53:08.210  - error: Caught by controller[0]:     at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
      2019-09-10 17:53:08.210  - error: host.iobroker instance system.adapter.iot.0 terminated with code 1 ()
      2019-09-10 17:53:08.210  - info: host.iobroker Do not restart adapter system.adapter.iot.0 because disabled or deleted
      2019-09-10 17:53:08.469  - info: javascript.0 received all states
        apollon77 last edited by
        An alle weiteren betroffenen bitte auch mal die Änderung aus https://github.com/aws/aws-iot-device-sdk-js/issues/280#issuecomment-529990098 versuchen und zurückmelden!!
        Der Fehler kommt eher aus der 1.0.8 ... am besten nimm mal die 1.0.7 vom npm als basis oder versuchen die 1.1.0 vom Github
        klotzma created this issue in aws/aws-iot-device-sdk-js
        closed Connection lost every 2-3 Minutes by some users #280
        marcuskl 1 Reply Last reply Reply Quote 0
        • marcuskl
          marcuskl last edited by
          2019-09-10 17:51:07.137  - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iot/main.js:777
          2019-09-10 17:51:07.138  - error: Caught by controller[0]: 		keepalive: 60,
          2019-09-10 17:51:07.138  - error: Caught by controller[0]: 		^^^^^^^^^
          2019-09-10 17:51:07.138  - error: Caught by controller[0]: SyntaxError: Unexpected identifier
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at startup (internal/bootstrap/node.js:283:19)
          2019-09-10 17:51:07.139  - error: Caught by controller[0]:     at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
          2019-09-10 17:51:07.139  - error: host.iobroker instance system.adapter.iot.0 terminated with code 1 ()
          2019-09-10 17:51:07.139  - info: host.iobroker Restart adapter system.adapter.iot.0 because enabled
          2019-09-10 17:51:37.153  - info: host.iobroker instance system.adapter.iot.0 started with pid 18328
          M apollon77 2 Replies Last reply Reply Quote 0
            Megawaldi @marcuskl last edited by
            @marcuskl
            Da fehlt ein Komma nach den 5000
              apollon77 @marcuskl last edited by
              @marcuskl exakt ... zeile davor ein komma ans ende
              • marcuskl
                Anscheinend hat "Keepalive", das Problem behoben.
                Bis jetzt gab es kein Verbindungsabbruch mehr, nur heute morgen hat der Iot Adapter sich neu gestartet und hat ein Error ausgespuckt:
                2019-09-11 03:12:35.240  - error: iot.0 uncaught exception: Cannot read property 'message' of undefined
                2019-09-11 03:12:35.241  - error: iot.0 TypeError: Cannot read property 'message' of undefined
                2019-09-11 03:12:35.279  - error: Caught by controller[0]: TypeError: Cannot read property 'message' of undefined
                2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1713:102)
                2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.emit (events.js:198:13)
                2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
                2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
                2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at Object.onceWrapper (events.js:286:20)
                2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at IncomingMessage.emit (events.js:203:15)
                2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at endReadableNT (_stream_readable.js:1145:12)
                2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
                2019-09-11 03:12:35.281  - error: host.iobroker instance system.adapter.iot.0 terminated with code 0 (OK)
                2019-09-11 03:12:35.281  - info: host.iobroker Restart adapter system.adapter.iot.0 because enabled
                2019-09-11 03:13:05.297  - info: host.iobroker instance system.adapter.iot.0 started with pid 28192
                2019-09-11 03:13:06.646  - info: iot.0 starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
                2019-09-11 03:13:06.681  - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                2019-09-11 03:13:07.229  - info: iot.0 shelly.0.SHSW-1#12C27E#1.Relay0.Switch is auto added with type  light.
                2019-09-11 03:13:07.236  - info: iot.0 shelly.0.SHSW-1#94147C#1.Relay0.Switch is auto added with type  light.
                2019-09-11 03:13:07.241  - info: iot.0 sonoff.0.Nachtlicht Benchy.POWER is auto added with type  light.
                2019-09-11 03:13:07.246  - info: iot.0 sonoff.0.Nachtlicht Liah.POWER is auto added with type  light.
                2019-09-11 03:13:07.250  - info: iot.0 sonoff.0.Nachtlicht Marcus.POWER is auto added with type  light.
                2019-09-11 03:13:07.255  - info: iot.0 sonoff.0.Stehlampe.POWER is auto added with type  light.
                2019-09-11 03:13:07.259  - info: iot.0 shelly.0.SHSW-1#943F39#1.Relay0.Switch is auto added with type  light.
                2019-09-11 03:13:07.288  - info: iot.0 shelly.0.SHRGBW2#5A38A7#1.color is auto added with type  rgb.
                2019-09-11 03:13:07.294  - info: iot.0 sonoff.0.Schreibtischlampe.POWER is auto added with type  light.
                2019-09-11 03:13:07.298  - info: iot.0 sonoff.0.Küchenlicht.POWER is auto added with type  light.
                2019-09-11 03:13:07.303  - info: iot.0 sonoff.0.TV Steckdose.POWER is auto added with type  socket.
                2019-09-11 03:13:07.310  - info: iot.0 tuya.0.17014830b4e62d5a02cc.1 is auto added with type  socket.
                2019-09-11 03:13:07.313  - info: iot.0 javascript.0.scriptEnabled.Steckdosen.Schreibtischsteckdosen_Automatik is auto added with type  socket.
                2019-09-11 03:13:07.322  - info: iot.0 Cannot auto convert chromecast.0.Küche.status.volume. Type volume is not available, yet. If you need the state please add him manually
                2019-09-11 03:13:07.326  - info: iot.0 Cannot auto convert chromecast.0.Schlafzimmer.status.volume. Type volume is not available, yet. If you need the state please add him manually
                2019-09-11 03:13:07.330  - info: iot.0 Cannot auto convert chromecast.0.WohnzimmerJBL.status.volume. Type volume is not available, yet. If you need the state please add him manually
                2019-09-11 03:13:07.715  - info: iot.0 Connection changed: connect
                Ich glaube das hat aber nichts damit zu tun oder ?
                  • marcuskl
                    marcuskl @apollon77 last edited by
                    @apollon77 sagte in Iot error read ECONNRESET !!!:
                    Ich habe gesehen Bluefox hat in der Version 1.1.4 den keepalive Value hinzugefügt, man kann ja dann einfach die neuste Version von Github laden oder ?
                      apollon77 @marcuskl last edited by apollon77
                      @marcuskl Ja, das ist noch viel einfacher! 🙂 Und die Version sollte auch schon im Latest Repo sein
                      • marcuskl
                        marcuskl last edited by marcuskl
                        Endlich ist das Problem gelöst 👏
                        Großes danke an alle 🙂
                        • marcuskl
                          @apollon77 Eine frage, zum Verständnis: Was hat das keepalive jetzt eigentlich geändert zu vorher ?
                            @marcuskl Ich denke es werden öfter "ping-pong" nachrichten ausgetauscht um die Verbindung am leben zu halten. Scheinbar hat der "Standard" 5 Minuten nicht gereicht und deswegen ist es immer wieder gekillt worden.
                            • marcuskl
                              Seit neusten bekomme ich diese Fehlermeldung im Log:
                              2019-09-11 11:53:18.343  - error: iot.0 uncaught exception: Cannot read property 'message' of undefined
                              2019-09-11 11:53:18.377  - error: Caught by controller[0]: TypeError: Cannot read property 'message' of undefined
                              2019-09-11 11:53:18.377  - error: Caught by controller[0]:     at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1713:102)
                              2019-09-11 11:53:18.377  - error: Caught by controller[0]:     at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at Request.emit (events.js:198:13)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at Object.onceWrapper (events.js:286:20)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at IncomingMessage.emit (events.js:203:15)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at endReadableNT (_stream_readable.js:1145:12)
                              2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
                              2019-09-11 11:53:18.378  - error: host.iobroker instance system.adapter.iot.0 terminated with code 0 (OK)
                              2019-09-11 11:53:18.378  - info: host.iobroker Restart adapter system.adapter.iot.0 because enabled
                              2019-09-11 11:53:48.396  - info: host.iobroker instance system.adapter.iot.0 started with pid 7265
                              2019-09-11 11:53:49.834  - info: iot.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
                              2019-09-11 11:53:49.873  - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                              Was hat das zu bedeuten ?
                                Das da leider ein Bug ist. Bitte GitHub Version versuchen
                                • marcuskl
                                  marcuskl @apollon77 last edited by marcuskl
                                  Ich habe die Github Version geladen.
                                  Oder muss ich das was ich Manuell in die js reingeschrieben (keepalive: 60) habe wieder rückgängig machen ?
                                  apollon77 Bluefox 2 Replies Last reply Reply Quote 0
                                    @marcuskl ne das sollte eh überschrieben wordenr sein., iot einmal neu starten nach GitHub Update
                                    • Bluefox
                                      Bluefox @marcuskl last edited by
                                      @marcuskl Kannst du dein iobroker.pro login an info@iobroker.net mailen?
                                      Ich will was testen
                                      • marcuskl
                                        Ich will was testen
                                        Was heißt Login ? Passwort und Email, Freischaltcode?
                                        Bluefox 1 Reply Last reply Reply Quote 0
                                        • Bluefox
                                          @marcuskl
                                          Nur email in iobroker.pro.
                                          Bitte kein Passwort
                                          • marcuskl
                                            @marcuskl
                                            Bitte kein Passwort
                                            Habe ich getan. 🙂
                                            • Bluefox
                                              Bluefox @marcuskl last edited by Bluefox
                                              @marcuskl Man muss die Version von iot updaten. 1.1.7
                                              marcuskl 1 Reply Last reply Reply Quote 1
                                              econnreset error iot iot adapter verbindungsprobleme
                                              7793
