    4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
      Moskito last edited by
      Hallo!
      Nachdem Version 2 nicht mehr funktioniert habe ich die Version 3 getestet.
      Leider bekomme ich folgende Meldungen:
      2019-09-11 17:33:31.787  - info: host.iobroker object change system.adapter.tuya.0
      2019-09-11 17:33:31.787  - info: host.iobroker stopInstance system.adapter.tuya.0
      2019-09-11 17:33:31.788  - info: host.iobroker stopInstance system.adapter.tuya.0 killing pid 6912
      2019-09-11 17:33:34.311  - info: host.iobroker instance system.adapter.tuya.0 started with pid 14822
      2019-09-11 17:33:34.840  - info: host.iobroker instance system.adapter.tuya.0 terminated with code 156 ()
      2019-09-11 17:33:35.718  - info: tuya.0 starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3
      2019-09-11 17:33:35.793  - info: tuya.0 Existing devices initialized
      2019-09-11 17:33:35.812  - info: tuya.0 Listen for local Tuya devices on port 6666
      2019-09-11 17:33:35.812  - info: tuya.0 Listen for encrypted local Tuya devices on port 6667
      2019-09-11 17:34:44.382  - info: tuya.0 SSL-Proxy ready to receive requests
      2019-09-11 17:34:59.725  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:34:59.727  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:00.798  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:00.801  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:00.802  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:00.803  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:00.808  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:00.808  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:01.006  - error: tuya.0 SSL-Proxy ERROR: Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      2019-09-11 17:35:01.006  - error: tuya.0 Error: 140287171663680:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
      Ich habe dies mehrfach ausprobiert, aber leider immer das gleich Ergebnis bekommen.😞
        benziman last edited by benziman
        Hi Zusammen,
        ich nutze den Tuyaadapter 2.0.4 mit sechs Rolladenschaltern (Gen. 3) und habe diese in einem Blocklyscript eigebunden.
        Das Script funktioniert auch wunderbar, allerdings tritt hier bisher ein mal am Tag der Fehler auf, dass bei allen Schaltern die Stopptaste blinkt und die Schalter dann nicht mehr bedient werden können. Erst ein beenden und Starten des Scripts bringt abhilfe.
        Das Log sieht dann so aus:
        (Fehler erscheint dann im Sekundentakt!)
        Gerne poste ich auch das Script hier (relativ Umfangreich) wenn das helfen solte. (Bild oder als Textformat?)
          Moskito @Moskito last edited by
          @Moskito sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
          Hallo!
          Kommando zurück!
          Ich habe es mit der Version 3 hinbekommen.
          Hatte nochmal alles von vorne abgearbeitet und das Zertifikat bei "VPN und Apps" und bei "WLAN" installiert.
          Bin mir nicht sicher ob es daran lag und ich es vielleicht vorher nicht so gemacht hatte....
          Jedenfalls sind die Objekte jetzt vorhanden.
            apollon77 last edited by
            Für alle geschädigten der Fehler bitte mal die 3.0.1 vom GitHub versuchen. Ich hab mal ein paar Dinge versucht ... Wenn es nicht tut bitte zusammen mit Eurer nodejs Version reporten. (Auch wenns tut )
              A.J. @apollon77 last edited by A.J.
              @apollon77 hmm, es will und will einfach nicht bei mir laufen.
              habs jetzt mit der 3.0.1 Version auch versucht. Problem ist nach wie vor die Sync. über Proxy.
              Vorgehensweise:
              -Adapter über git installiert
              • Proxy gestartet
              • QR-Code wird angezeigt, mit ein App eingescant und auf die Seite mit Zertifikat die Datei auf Tablet geladen.
              • Zertifikat installiert
              • unter Wlan-Einstellung Proxy Daten eingetragen (Raspberry IP und port 8888)
              • SmartLife App gestartet.
              Aber da läuft scheinbar wieder etwas schief. Bin jetzt extra mit ein Andriod Tab (HUAWEI, Android 9) unterwegs
              2019-09-12 06:48:05.939 - info: iobroker host.raspberrypi create instance tuya
              2019-09-12 06:48:05.953 - info: iobroker host.raspberrypi object tuya.0.info.connection created
              2019-09-12 06:48:05.984 - info: iobroker host.raspberrypi object tuya.0.info created
              2019-09-12 06:48:06.020 - info: iobroker host.raspberrypi object system.adapter.tuya.0.outputCount created
              2019-09-12 06:48:06.053 - info: iobroker host.raspberrypi object system.adapter.tuya.0.inputCount created
              2019-09-12 06:48:06.087 - info: iobroker host.raspberrypi object system.adapter.tuya.0.uptime created
              2019-09-12 06:48:06.122 - info: iobroker host.raspberrypi object system.adapter.tuya.0.memRss created
              2019-09-12 06:48:06.155 - info: iobroker host.raspberrypi object system.adapter.tuya.0.memHeapTotal created
              2019-09-12 06:48:06.189 - info: iobroker host.raspberrypi object system.adapter.tuya.0.memHeapUsed created
              2019-09-12 06:48:06.225 - info: iobroker host.raspberrypi object system.adapter.tuya.0.cputime created
              2019-09-12 06:48:06.257 - info: iobroker host.raspberrypi object system.adapter.tuya.0.cpu created
              2019-09-12 06:48:06.291 - info: iobroker host.raspberrypi object system.adapter.tuya.0.connected created
              2019-09-12 06:48:06.323 - info: iobroker host.raspberrypi object system.adapter.tuya.0.alive created
              2019-09-12 06:48:06.374 - info: host.raspberrypi object change system.adapter.tuya.0
              2019-09-12 06:48:06.387 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 19367
              2019-09-12 06:48:06.400 - info: iobroker host.raspberrypi object system.adapter.tuya.0 created
              2019-09-12 06:48:06.419 - info: iobroker exit 0
              2019-09-12 06:48:08.332 - info: tuya.0 starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3
              2019-09-12 06:48:08.428 - info: tuya.0 Existing devices initialized
              2019-09-12 06:48:08.450 - info: tuya.0 Listen for local Tuya devices on port 6666
              2019-09-12 06:48:08.451 - info: tuya.0 Listen for encrypted local Tuya devices on port 6667
              2019-09-12 06:48:08.560 - info: tuya.0 3050061084f3eb745219 Init with IP=192.168.178.89, Key=undefined, Version=3.1
              2019-09-12 06:48:08.566 - info: tuya.0 3050061084f3eb745219: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 06:48:08.609 - info: tuya.0 3050061084f3eb745219: No schema exists, init basic states ...
              2019-09-12 06:48:08.858 - info: tuya.0 05110774cc50e3490fe1 Init with IP=192.168.178.77, Key=undefined, Version=3.1
              2019-09-12 06:48:08.859 - info: tuya.0 05110774cc50e3490fe1: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 06:48:08.878 - info: tuya.0 05110774cc50e3490fe1: No schema exists, init basic states ...
              2019-09-12 06:48:10.123 - info: tuya.0 36822714807d3a3f2518 Init with IP=192.168.178.78, Key=undefined, Version=3.1
              2019-09-12 06:48:10.125 - info: tuya.0 36822714807d3a3f2518: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 06:48:11.273 - info: tuya.0 36822714807d3a3f271d Init with IP=192.168.178.76, Key=undefined, Version=3.1
              2019-09-12 06:48:11.274 - info: tuya.0 36822714807d3a3f271d: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 06:48:11.285 - info: tuya.0 36822714807d3a3f2741 Init with IP=192.168.178.75, Key=undefined, Version=3.1
              2019-09-12 06:48:11.286 - info: tuya.0 36822714807d3a3f2741: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 06:48:11.438 - info: tuya.0 01530667807d3a1e2e98 Init with IP=192.168.178.29, Key=undefined, Version=3.1
              2019-09-12 06:48:11.439 - info: tuya.0 01530667807d3a1e2e98: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 06:48:11.463 - info: tuya.0 01530667807d3a1e2e98: No schema exists, init basic states ...
              2019-09-12 06:55:41.467 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:00:55.143 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:02:00.149 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:07:51.465 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:08:56.470 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:13:57.313 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:15:29.266 - info: info.0 Popup-News readed...
              2019-09-12 07:20:51.476 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:21:56.481 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:28:25.414 - info: tuya.0 01530667807d3a1e2e98 Init with IP=192.168.178.29, Key=undefined, Version=3.1
              2019-09-12 07:28:25.416 - info: tuya.0 01530667807d3a1e2e98: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
              2019-09-12 07:30:15.825 - info: tuya.0 SSL-Proxy ready to receive requests
              2019-09-12 07:32:20.418 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:20.418 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:21.177 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:21.178 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:22.644 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:22.644 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:25.471 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:32:25.659 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:25.659 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:29.186 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:29.187 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:35.608 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:35.609 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:46.346 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:32:46.347 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:33:02.654 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:33:02.654 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:33:30.474 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
              2019-09-12 07:33:33.532 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:33:33.533 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:01.370 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:01.370 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:01.445 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:01.445 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:02.784 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:02.785 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:05.102 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:05.102 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:09.961 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:09.962 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:15.574 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:15.575 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:19.886 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:19.887 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:21.208 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:21.209 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:27.549 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:27.550 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:43.101 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:34:43.101 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:35:19.074 - error: tuya.0 SSL-Proxy ERROR: Error: getaddrinfo ENOTFOUND ksckichr ksckichr:80
              2019-09-12 07:35:19.075 - error: tuya.0 Error: getaddrinfo ENOTFOUND ksckichr ksckichr:80
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:56:26)
              2019-09-12 07:35:19.076 - error: tuya.0 SSL-Proxy ERROR: Error: getaddrinfo ENOTFOUND bmwtumghdz bmwtumghdz:80
              2019-09-12 07:35:19.077 - error: tuya.0 Error: getaddrinfo ENOTFOUND bmwtumghdz bmwtumghdz:80
              2019-09-12 07:35:19.078 - error: tuya.0 SSL-Proxy ERROR: Error: getaddrinfo ENOTFOUND vhdudyjdwcp vhdudyjdwcp:80
              2019-09-12 07:35:19.078 - error: tuya.0 Error: getaddrinfo ENOTFOUND vhdudyjdwcp vhdudyjdwcp:80
              2019-09-12 07:35:38.251 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:35:38.251 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:36:02.161 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:36:02.162 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:36:06.555 - error: tuya.0 SSL-Proxy ERROR: Error: socket hang up
              2019-09-12 07:36:06.556 - error: tuya.0 Error: socket hang up
              at TLSSocket.onSocketClose (_tls_wrap.js:764:23)
              at TLSSocket.emit (events.js:203:15)
              at _handle.close (net.js:606:12)
              at Socket.done (_tls_wrap.js:388:7)
              at Object.onceWrapper (events.js:286:20)
              at Socket.emit (events.js:198:13)
              at TCP._handle.close (net.js:606:12)
              2019-09-12 07:36:19.244 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:36:19.245 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:36:19.296 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
              2019-09-12 07:36:19.297 - error: tuya.0 Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
              2019-09-12 07:36:52.111 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
              2019-09-12 07:36:52.111 - error: tuya.0 Error: 1995598288:error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol:../deps/openssl/openssl/ssl/statem/statem_srvr.c:1667:
              2019-09-12 07:37:11.317 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              2019-09-12 07:37:11.318 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
              node: v10.16.3
              nodejs: v10.16.3
              npm: v6.11.3
                Moskito @A.J. last edited by
                @A-J sagte in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
                Installier das Zertifikat auch mal unter "VPN und Apps".
                Ich habe auch ein HUAWEI und danach hat es bei mir funktioniert....
                  A.J. @Moskito last edited by
                  @Moskito Wie meinst du das? Wenn ich das Zertifikat Downloade, installiere ich das doch inter VPN und Apps oder habe ich da was falsch verstanden?
                    @A-J Installier es unter "VPN und APPS" UND unter WLAN. Also Zertifikat zweimal installieren.
                      @Moskito Achso, das meinst du. Ja hab das auch schon probiert gehabt und eben noch einmal aber es ändert sich nichts. Weiterhin erscheint das im Log, sobald ich die App starte:
                      undefined2019-09-12 09:20:55.391 - info: tuya.0 SSL-Proxy ready to receive requests
                      2019-09-12 09:21:43.804 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                      2019-09-12 09:22:48.810 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                      2019-09-12 09:22:51.317 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:51.318 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:51.772 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:51.772 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:53.517 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:53.518 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:56.832 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:22:56.832 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:00.708 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:00.708 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:07.094 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:07.094 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:16.670 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:16.671 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:30.338 - error: tuya.0 SSL-Proxy ERROR: Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:30.339 - error: tuya.0 Error: 1995598288:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                      2019-09-12 09:23:53.813 - error: tuya.0 01530667807d3a1e2e98: Error: connection timed out
                        mich wundern diese komischen ENOTFOUND domainnamen im oberen Log ...
                        A 2 Replies Last reply Reply Quote 0
                          @apollon77 hmm, da bin ich leider auch überfragt. Ich wiederhole den Vorgang, mal sehen, ob ich die gleiche Fehlermeldung bekomme.
                            @apollon77 ich weiß jetzt was das war, ich hatte nachdem das einmal nicht funktioniert hatte, die Seite heide.de aufgerufen um zu sehen, ob die Seite über Proxy überhaupt aufgeht oder nicht. Die Seite ging auf (also verbindung zu internet ist da) und das sind wohl irgend welche Ad-Server die heise eingebunden hat. Ähnliche ENOTFOUND habe ich angezeigt bekommen, als ich den vorgang genau so wie vorhin probiert habe.
                            letzte versuch war jetzt ohne Aufruf von irgendwelche Seiten. siehe log:
                            tuya.0	2019-09-12 10:55:17.830	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:17.830	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:15.783	error	01530667807d3a1e2e98: Error: connection timed out
                            tuya.0	2019-09-12 10:55:10.068	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:10.067	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:05.728	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:05.728	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:03.205	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:03.204	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:01.501	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:01.501	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:01.006	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:01.006	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:01.003	error	Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:55:01.003	error	SSL-Proxy ERROR: Error: 1996188112:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1536:SSL alert number 46
                            tuya.0	2019-09-12 10:54:10.778	error	01530667807d3a1e2e98: Error: connection timed out
                            tuya.0	2019-09-12 10:53:05.774	error	01530667807d3a1e2e98: Error: connection timed out
                            tuya.0	2019-09-12 10:52:21.400	info	SSL-Proxy ready to receive requests
                            tuya.0	2019-09-12 10:52:00.770	error	01530667807d3a1e2e98: Error: connection timed out
                            tuya.0	2019-09-12 10:49:51.022	info	05110774cc50e3490fe1: No schema exists, init basic states ...
                            tuya.0	2019-09-12 10:49:50.840	info	05110774cc50e3490fe1: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2019-09-12 10:49:50.839	info	05110774cc50e3490fe1 Init with IP=192.168.178.77, Key=undefined, Version=3.1
                            tuya.0	2019-09-12 10:49:50.785	info	01530667807d3a1e2e98: No schema exists, init basic states ...
                            tuya.0	2019-09-12 10:49:50.743	info	01530667807d3a1e2e98: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2019-09-12 10:49:50.743	info	01530667807d3a1e2e98 Init with IP=192.168.178.29, Key=undefined, Version=3.1
                            tuya.0	2019-09-12 10:49:50.487	info	3050061084f3eb745219: No schema exists, init basic states ...
                            tuya.0	2019-09-12 10:49:50.472	info	3050061084f3eb745219: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2019-09-12 10:49:50.471	info	3050061084f3eb745219 Init with IP=192.168.178.89, Key=undefined, Version=3.1
                            tuya.0	2019-09-12 10:49:50.181	info	36822714807d3a3f271d: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2019-09-12 10:49:50.180	info	36822714807d3a3f271d Init with IP=192.168.178.76, Key=undefined, Version=3.1
                            tuya.0	2019-09-12 10:49:50.093	info	36822714807d3a3f2741: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2019-09-12 10:49:50.091	info	36822714807d3a3f2741 Init with IP=192.168.178.75, Key=undefined, Version=3.1
                            tuya.0	2019-09-12 10:49:49.218	info	36822714807d3a3f2518: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
                            tuya.0	2019-09-12 10:49:49.212	info	36822714807d3a3f2518 Init with IP=192.168.178.78, Key=undefined, Version=3.1
                            tuya.0	2019-09-12 10:49:48.406	info	Listen for encrypted local Tuya devices on port 6667
                            tuya.0	2019-09-12 10:49:48.405	info	Listen for local Tuya devices on port 6666
                            tuya.0	2019-09-12 10:49:48.377	info	Existing devices initialized
                            tuya.0	2019-09-12 10:49:48.281	info	starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.tuya, node: v10.16.3```
                              heisst generell tut der proxy weil "heise.de" tut, nur die Tuya App macht nix? Oder bei elchem Aufruf kommen diese SSL Fehler?
                                @apollon77 Also die letzte Log oben hat mit Heise nichts zutun. da habe ich einfach nur die App aufgerufen, nachdem ich proxy gestartet habe, das zertifikat installiert und proxy einstellung in wlan eingefügt habe.
                                Bei irgend eine Version (ich glaube das war noch mit AnyProxy auf ios) hatte ich mal das Problem, dass die App immer internetprobleme angezeigt hat. Da hatte ich dann versucht über Browser eine Seite aufzurufen und das ging gar nicht. Deshalb hatte ich vorhin kurz auch das getestet. wollte nur wissen, ob trotz der proxy das netz überhaupt funktioniert oder nicht.
                                Im gegensatz zu der Version mit AnyProxy funktioniert das netz, will heißen, ich komme über Browser auf andere Seiten rauf. nur gibt es im log dann diesen komischen ENOTFOUND, was sich dann auf die Ad-Server wohl bezieht.
                                  mpchen last edited by
                                  Hallo in die Runde,
                                  habe mir bei Action die von den LSC Smarthome Birnen welche besorgt und nun testweise einen GU/10 Strahler eingebaut. Der wurde mit Proxy der neusten VErsion und der LSC Smart Connect App auch in Iobroker erkannt. Wirklich was mit dem daraus resultierenden Objekt anfangen kann ich aber nicht. Nachfolgend der Log/Auszug:
                                  2019-09-12 22:26:54.046  - ^[[32minfo^[[39m: tuya.0 new Shema added for product type mzdqe6ectfdaarqr. Please send next line from logfile on disk to developer!
                                  2019-09-12 22:26:54.046  - ^[[32minfo^[[39m: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"led_switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":2,\"type\":\"obj\",\"desc\":\"white:白光模式;colour:彩光模式
                                  ;scene:场景模式;scene1-4:不同场景模式切换;可根据产品实际功能更改。\"},{\"mode\":\"rw\",\"code\":\"bright_value\",\"name\":\"亮度\",\"property\":{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_sun\",\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"temp_value\",\"name\":\"冷暖\",\"property\":{\"unit\":\"\",\"min\":0,\"max\":255,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-dp_half\",\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光模式数\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_light2\",\"id\":5,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"情景模式数\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_direction\",\"id\":6,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_1\",\"name\":\"柔光模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_flower\",\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_2\",\"name\":\"缤纷模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_dust\",\"id\":8,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_3\",\"name\":\"炫彩模式\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_puzzle\",\"id\":9,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"flash_scene_4\",\"name\":\"斑斓模式
                                  \",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_smile\",\"id\":10,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"remote_switch\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\",\"desc\":\"用于wifi遥控器开关\"}]","schemaExt":"[{\"id\":1,\"inputStyle\":\"\",\"inputType\":\"\"},{\"id\":2,\"inputStyle\":\"\",\"inputType\":\"\"},{\"id\":3,\"inputStyle\":\"bright\",\"inputType\":\"percent1\"},{\"id\":4,\"inputStyle\":\"temp\",\"inputType\":\"percent\"},{\"id\":101,\"inputStyle\":\"\",\"inputType\":\"\"}]"}
                                  Muss dieses Schema noch angelegt werden oder ist meinerseits jetzt was zu tun? Bevor ich jetzt alle Birnen auspacke und rumprobiere wollte ich sichergehen, dass die Sachen schlussendlich auch kompatibel sind. Habe noch E14 RGBW sowie den RGBW LED Strip und eine Steckdose.
                                  PS: Liegt die irgendwie merkwuerdige Formatierung meines Logs moeglicherweise am englischsprachigen Chromebook? Kann das sonst morgen gerne nochmal via PC posten. Dann sieht's vielleicht normaler aus.
                                  Gruss
                                  Jan
                                    apollon77 @mpchen last edited by
                                    @mpchen Also ich an Deiner Stelle würde einfach mal in den ioBroker-Objekten des tuya Adapters schauen ... Da ist alles da und sollte tun. Die Meldung bedeutet nur das der Adapter genau dieses Schema noch nicht kennt und : "Please send the next line from logfile on disk to developer" ... Bitte ein GitHub-Issue anlegen. Das ist für dich am Ende egal, hilft später aber anderen Usern die die gleichen Geräte haben.
                                      benziman @benziman last edited by
                                      @benziman said in [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere):
                                      Hi Zusammen,
                                      Keiner eine Idee?
                                        Restarte mal die Geräte 8Strom weg/hin. Die sind nicht erreichbar bzw Antworten nicht
                                        • V
                                          varg last edited by varg
                                          @apollon77
                                          wollte kurz Rückmeldung geben dass es mit der 3.0.2 jetzt geklappt hat.
                                          Vielen Dank !
                                            Also, 3.0.2 funktioniert.
                                            Was mir aber aufgefallen ist, der Tuya Adapter wird nicht gestoppt bei einem restart oder beim stoppen. Ich mußte nach mehrmaligem hin- und her den Prozess des Adapters unter Linux killen und erst dann ließ er sich wieder starten.
                                            Möglicherweise hängt das mit einem unbekannten Gerät zusammen.
                                            Hier das Log beim starte/restarten:
                                            2019-09-13 23:00:12.514  - info: host.iobroker object change system.adapter.tuya.0
                                            2019-09-13 23:00:12.567  - info: host.iobroker instance system.adapter.tuya.0 started with pid 21958
                                            2019-09-13 23:00:15.021  - error: host.iobroker instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                                            2019-09-13 23:00:15.022  - info: host.iobroker Restart adapter system.adapter.tuya.0 because enabled
                                            2019-09-13 23:00:45.049  - info: host.iobroker instance system.adapter.tuya.0 started with pid 22151
                                            2019-09-13 23:00:46.421  - error: host.iobroker instance system.adapter.tuya.0 terminated with code 7 (Adapter already running)
                                            2019-09-13 23:00:46.421  - info: host.iobroker Restart adapter system.adapter.tuya.0 because enabled
                                            Hier das unbekannte Gerät:
                                            2019-09-13 23:05:53.831  - info: tuya.0 new Shema added for product type xaogr3mrapdrlydm. Please send next line from logfile on disk to developer!
                                            2019-09-13 23:05:53.832  - info: tuya.0 {"schema":"[{\"mode\":\"rw\",\"code\":\"switch_1\",\"name\":\"åŒå³1\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":1,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_2\",\"name\":\"åŒå³2\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":2,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_3\",\"name\":\"åŒå³3\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":3,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_4\",\"name\":\"åŒå³4\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power2\",\"id\":4,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"switch_usb1\",\"name\":\"USBåŒå³1\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":7,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown1\",\"name\":\"åŒå³1å计æ¶\",\"property\":{\"unit\":\"ç§\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":101,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown2\",\"name\":\"åŒå³2å计æ¶\",\"property\":{\"unit\":\"ç§\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":102,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown3\",\"name\":\"åŒå³3å计æ¶\",\"property\":{\"unit\":\"ç§\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":103,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown4\",\"name\":\"åŒå³4å计æ¶\",\"property\":{\"unit\":\"ç§\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":104,\"type\":\"obj\",\"desc\":\"\"},{\"mode\":\"rw\",\"code\":\"countdown_usb1\",\"name\":\"USB1å计æ¶\",\"property\":{\"unit\":\"ç§\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":105,\"type\":\"obj\",\"desc\":\"\"}]","schemaExt":"[]"}
                                            Ich habe zu dem unbekannten Gerät bereits auf github ein issue auf gemacht.
                                            547
                                            151166
