    4. [GELÖST] Homepilot Umweltsensor mit Javascript auslesen
      paul53 @meicker last edited by paul53
      @meicker sagte:
      Ich würde mich sehr freuen wenn Du mir da eventuell weiter helfen könntest ..
      Ohne zu wissen, was sich geändert hat, kann ich nicht helfen.
      Ändere mal Zeile 42 in
      var temp = parseFloat(data[37].value);
        Hi Paul,
        danke schon mal für die Rückmeldung. Habe ich geändert, ist aber glaube ich nicht richtig. Das heißt ja nicht mehr Data, das war bei dem alten JSON noch richtig.
        Schau mal in meinem ersten Post, da habe ich die neue JSON abgebildet und hier im Spoiler eingefügt.
        {"error_description":"OK","error_code":0,"payload":{"device":{"capabilities":[{"name":"TEMPERATURE_THRESH4_ENV_NAMES_CFG","value":"Temperatur 10° Winter","timestamp":-1},{"name":"WIND_THRESH1_VALUE_CFG","value":"6","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054423},{"name":"SUN_THRESH5_ENV_NAMES_CFG","value":"-","timestamp":-1},{"name":"PROD_CODE_DEVICE_LOC","value":"32000064_S","timestamp":-1},{"name":"REACHABILITY_EVT","value":"true","timestamp":1568067423},{"name":"SUN_THRESH3_TEMPERATURE_VALUE_CFG","value":"21","min_value":"-5","max_value":"26","step_size":"1","timestamp":1568054418},{"name":"TEMPERATURE_THRESH5_VALUE_CFG","value":"-10","min_value":"-40","max_value":"80","step_size":"1","timestamp":1568054423},{"name":"DUSK_THRESH3_VALUE_CFG","value":"50","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"NAME_DEVICE_LOC","value":"Sensor UWS","timestamp":-1},{"name":"DAWN_THRESH1_ENV_NAMES_CFG","value":"Licht 20 Lux","timestamp":-1},{"name":"DUSK_THRESH2_ENV_NAMES_CFG","value":"Licht 25 Lux","timestamp":-1},{"name":"DCF_MODE_CFG","value":"true","timestamp":1568067423},{"name":"DAWN_THRESH4_VALUE_CFG","value":"80","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"SUN_THRESH3_TIME_2_RELEASE_CFG","value":"30","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054418},{"name":"INTF_ID_DEVICE_LOC","value":"3","timestamp":-1},{"name":"TEMPERATURE_THRESH1_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"DAWN_ENABLE_THRESH4_CFG","value":"true","timestamp":1568054415},{"name":"TEMPERATURE_THRESH4_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"SUN_DIRECTION_MEA","value":"333.0","min_value":"0.0","max_value":"360.0","timestamp":1568067423},{"name":"SUN_DETECTION_MEA","value":"false","timestamp":1485440904},{"name":"WIND_SPEED_EVT","value":"0.0","min_value":"0.0","max_value":"70.0","step_size":"0.1","timestamp":1568067423},{"name":"SUN_THRESH4_ENABLE_CFG","value":"true","timestamp":1568054418},{"name":"SUN_THRESH4_TEMPERATURE_VALUE_CFG","value":"0","min_value":"-5","max_value":"26","step_size":"1","timestamp":1568054418},{"name":"WIND_SPEED_MS_MEA","value":"0.0","min_value":"0.0","max_value":"70.0","timestamp":1568067423},{"name":"WIND_THRESH3_ENV_NAMES_CFG","value":"Markise 11","timestamp":-1},{"name":"SUN_THRESH1_ELEVATION_RANGE_CFG","value":"0","min_value":"0","max_value":"52","step_size":"26","timestamp":1568054417},{"name":"DUSK_EVT","value":"5","min_value":"1","max_value":"5","step_size":"1","timestamp":1568052149},{"name":"SUN_THRESH4_VALUE_CFG","value":"20","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054418},{"name":"SUN_THRESH2_TEMPERATURE_ENABLE_CFG","value":"true","timestamp":1568054417},{"name":"WIND_DETECT_FACTOR_CFG","value":"180","min_value":"1","max_value":"255","step_size":"1","timestamp":1568054425},{"name":"SUN_THRESH1_ENABLE_CFG","value":"true","timestamp":1568054417},{"name":"DAWN_THRESH3_VALUE_CFG","value":"60","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"DAWN_EVT","min_value":"1","max_value":"5","step_size":"1","timestamp":-1},{"name":"TEMPERATURE_START_EVT","value":"5","min_value":"1","max_value":"5","step_size":"1","timestamp":1534954010},{"name":"SUN_THRESH2_TEMPERATURE_VALUE_CFG","value":"21","min_value":"-5","max_value":"26","step_size":"1","timestamp":1568054417},{"name":"WIND_THRESH2_VALUE_CFG","value":"25","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054423},{"name":"WIND_THRESH5_ENABLE_CFG","value":"false","timestamp":1568054423},{"name":"TEMP_CURR_DEG_MEA","value":"12.1","min_value":"-40.0","max_value":"80.0","timestamp":1568067423},{"name":"TEMPERATURE_THRESH4_VALUE_CFG","value":"10","min_value":"-40","max_value":"80","step_size":"1","timestamp":1568054423},{"name":"SUN_THRESH4_USE_AZIMUTH_CFG","value":"true","timestamp":1568054418},{"name":"SENS_STATUS_INTERVAL_CFG","value":"1","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054425},{"name":"SUN_THRESH1_USE_AZIMUTH_CFG","value":"true","timestamp":1568054417},{"name":"TEMPERATURE_THRESH1_ENV_NAMES_CFG","value":"Temperatur 35° FREI","timestamp":-1},{"name":"DEGREE_LATITUDE_CFG","value":"51","min_value":"-90","max_value":"90","step_size":"1","timestamp":1568054425},{"name":"SUN_THRESH5_TARGET_ELEVATION_CFG","value":"13","min_value":"13","max_value":"78","step_size":"13","timestamp":1568054420},{"name":"SUN_THRESH2_ELEVATION_RANGE_CFG","value":"0","min_value":"0","max_value":"52","step_size":"26","timestamp":1568054417},{"name":"DUSK_THRESH2_VALUE_CFG","value":"25","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"SUN_THRESH1_TEMPERATURE_VALUE_CFG","value":"21","min_value":"-5","max_value":"26","step_size":"1","timestamp":1568054417},{"name":"SUN_THRESH3_TEMPERATURE_ENABLE_CFG","value":"true","timestamp":1568054418},{"name":"SUN_THRESH4_TIME_2_RELEASE_CFG","value":"20","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054418},{"name":"TEMPERATURE_THRESH3_VALUE_CFG","value":"18","min_value":"-40","max_value":"80","step_size":"1","timestamp":1568054423},{"name":"TEMPERATURE_INT_CFG","value":"12.1","min_value":"-40.0","max_value":"80.0","step_size":"0.1","timestamp":1568067423},{"name":"DAWN_THRESH2_VALUE_CFG","value":"40","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"VERSION_CFG","value":"0.3","timestamp":1568067125},{"name":"DUSK_ENABLE_THRESH3_CFG","value":"true","timestamp":1568054415},{"name":"DEGREE_LONGITUDE_CFG","value":"7","min_value":"0","max_value":"360","step_size":"1","timestamp":1568054425},{"name":"DATE_TIME_CFG","value":"1568060671","timestamp":1568061932},{"name":"SUN_THRESH3_ENABLE_CFG","value":"true","timestamp":1568054418},{"name":"DAWN_THRESH3_ENV_NAMES_CFG","value":"Licht 60 Lux","timestamp":-1},{"name":"WIND_THRESH1_ENV_NAMES_CFG","value":"Markise 5","timestamp":-1},{"name":"SUN_THRESH2_TIME_2_RELEASE_CFG","value":"20","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054417},{"name":"ICONSET_LOC","value":"iconset25","timestamp":-1},{"name":"DAWN_THRESH4_ENV_NAMES_CFG","value":"Licht 80 Lux","timestamp":-1},{"name":"SUN_START_EVT","min_value":"1","max_value":"5","step_size":"1","timestamp":-1},{"name":"DEVICE_TYPE_LOC","value":"3","timestamp":-1},{"name":"DUSK_ENABLE_THRESH1_CFG","value":"true","timestamp":1568054415},{"name":"DUSK_THRESH4_ENV_NAMES_CFG","value":"Licht 75 Lux","timestamp":-1},{"name":"ICONSET_INV_LOC","value":"false","timestamp":-1},{"name":"SUN_THRESH4_TARGET_ELEVATION_CFG","value":"13","min_value":"13","max_value":"78","step_size":"13","timestamp":1568054418},{"name":"DCF_VALID_EVT","value":"false","timestamp":1568067423},{"name":"DUSK_THRESH1_VALUE_CFG","value":"10","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"RESET_FULL_CMD","timestamp":-1},{"name":"SUN_THRESH1_TIME_2_DETECT_CFG","value":"15","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054417},{"name":"PAIRING_CONFIRMED_LOC","value":"true","timestamp":-1},{"name":"DUSK_ENABLE_THRESH5_CFG","value":"true","timestamp":1568054417},{"name":"SUN_THRESH2_VALUE_CFG","value":"30","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054417},{"name":"REQ_DATE_TIME_CMD","timestamp":-1},{"name":"DAWN_THRESH5_VALUE_CFG","value":"100","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054417},{"name":"SUN_THRESH5_ENABLE_CFG","value":"true","timestamp":1568054420},{"name":"DAWN_ENABLE_THRESH2_CFG","value":"true","timestamp":1568054415},{"name":"DUSK_THRESH4_VALUE_CFG","value":"75","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"DAWN_THRESH5_ENV_NAMES_CFG","value":"Licht 100 Lux","timestamp":-1},{"name":"CURR_BRIGHTN_CFG","value":"0","min_value":"0","max_value":"150000","step_size":"1","timestamp":1568067423},{"name":"WIND_THRESH3_VALUE_CFG","value":"12","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054423},{"name":"SUN_THRESH1_AZIMUTH_RANGE_CFG","value":"90.0","min_value":"0.0","max_value":"180.0","step_size":"45.0","timestamp":1568054417},{"name":"SUN_THRESH4_USE_ELEVATION_CFG","value":"false","timestamp":1568054418},{"name":"SUN_THRESH5_VALUE_CFG","value":"100","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054420},{"name":"DUSK_THRESH5_ENV_NAMES_CFG","value":"Licht 100 Lux","timestamp":-1},{"name":"RAIN_START_EVT","timestamp":-1},{"name":"SUN_THRESH3_TARGET_ELEVATION_CFG","value":"39","min_value":"13","max_value":"78","step_size":"13","timestamp":1568054418},{"name":"SUN_THRESH1_TEMPERATURE_ENABLE_CFG","value":"true","timestamp":1568054417},{"name":"SUN_STOP_EVT","value":"5","min_value":"1","max_value":"5","step_size":"1","timestamp":1485440904},{"name":"SUN_THRESH5_AZIMUTH_RANGE_CFG","value":"0.0","min_value":"0.0","max_value":"180.0","step_size":"45.0","timestamp":1568054420},{"name":"TIME_ZONE_CFG","value":"1","min_value":"-11","max_value":"13","step_size":"1","timestamp":1568054425},{"name":"SUN_THRESH1_VALUE_CFG","value":"30","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054417},{"name":"SUN_THRESH1_TIME_2_RELEASE_CFG","value":"30","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054417},{"name":"SUN_THRESH3_TIME_2_DETECT_CFG","value":"10","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054418},{"name":"SUN_THRESH3_USE_ELEVATION_CFG","value":"false","timestamp":1568054418},{"name":"SUN_THRESH5_TIME_2_RELEASE_CFG","value":"20","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054420},{"name":"SUN_THRESH2_USE_ELEVATION_CFG","value":"false","timestamp":1568054417},{"name":"SUN_THRESH3_USE_AZIMUTH_CFG","value":"true","timestamp":1568054418},{"name":"WIND_THRESH4_ENABLE_CFG","value":"false","timestamp":1568054423},{"name":"DAWN_THRESH1_VALUE_CFG","value":"20","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054415},{"name":"SUN_THRESH2_TARGET_ELEVATION_CFG","value":"13","min_value":"13","max_value":"78","step_size":"13","timestamp":1568054417},{"name":"DAWN_ENABLE_THRESH5_CFG","value":"true","timestamp":1568054417},{"name":"TEMPERATURE_THRESH2_VALUE_CFG","value":"25","min_value":"-40","max_value":"80","step_size":"1","timestamp":1568054423},{"name":"WIND_THRESH4_VALUE_CFG","value":"2","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054423},{"name":"SUN_THRESH2_TIME_2_DETECT_CFG","value":"10","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054417},{"name":"DAWN_THRESH2_ENV_NAMES_CFG","value":"Licht 40 Lux","timestamp":-1},{"name":"LIGHT_VAL_LUX_MEA","value":"0","min_value":"0","max_value":"150000","timestamp":1568067423},{"name":"ID_DEVICE_LOC","value":"1010005","timestamp":-1},{"name":"PROTOCOL_ID_CFG","value":"690732","timestamp":-1},{"name":"SUN_THRESH4_ENV_NAMES_CFG","value":"Sonne O - SW / 20Klux Winter","timestamp":-1},{"name":"SUN_HEIGHT_EVT","value":"-29","min_value":"-90","max_value":"90","step_size":"1","timestamp":1568067423},{"name":"SUN_THRESH1_USE_ELEVATION_CFG","value":"false","timestamp":1568054417},{"name":"SUN_THRESH4_TIME_2_DETECT_CFG","value":"5","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054418},{"name":"SUN_THRESH3_AZIMUTH_RANGE_CFG","value":"90.0","min_value":"0.0","max_value":"180.0","step_size":"45.0","timestamp":1568054418},{"name":"TEMPERATURE_THRESH3_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"SUN_THRESH1_ENV_NAMES_CFG","value":"Sonne O - S / 30 KLux Sommer","timestamp":-1},{"name":"RAIN_STOP_EVT","timestamp":1568016601},{"name":"TEMPERATURE_THRESH5_ENV_NAMES_CFG","value":"Temperatur -10° FREI","timestamp":-1},{"name":"RAIN_DETECTION_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"DUSK_THRESH3_ENV_NAMES_CFG","value":"Licht 50 Lux","timestamp":-1},{"name":"SUN_THRESH4_AZIMUTH_RANGE_CFG","value":"135.0","min_value":"0.0","max_value":"180.0","step_size":"45.0","timestamp":1568054418},{"name":"WIND_THRESH5_VALUE_CFG","value":"2","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054423},{"name":"VIS_DEVICE_LOC","value":"true","timestamp":-1},{"name":"SUN_THRESH1_TARGET_ELEVATION_CFG","value":"13","min_value":"13","max_value":"78","step_size":"13","timestamp":1568054417},{"name":"WIND_THRESH2_ENV_NAMES_CFG","value":"Rolläden","timestamp":-1},{"name":"REQ_SENS_INFO_CMD","timestamp":-1},{"name":"TEMPERATURE_THRESH2_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"TEMPERATURE_THRESH1_VALUE_CFG","value":"35","min_value":"-40","max_value":"80","step_size":"1","timestamp":1568054423},{"name":"SUN_THRESH2_ENABLE_CFG","value":"true","timestamp":1568054417},{"name":"DESCR_DEVICE_LOC","value":"Balkon","timestamp":-1},{"name":"RAIN_DETECTION_MEA","value":"false","timestamp":1568067423},{"name":"SUN_THRESH2_USE_AZIMUTH_CFG","value":"true","timestamp":1568054417},{"name":"DUSK_THRESH5_VALUE_CFG","value":"100","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054417},{"name":"SUN_THRESH2_AZIMUTH_RANGE_CFG","value":"135.0","min_value":"0.0","max_value":"180.0","step_size":"45.0","timestamp":1568054417},{"name":"TEMPERATURE_THRESH5_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"SUN_THRESH5_USE_ELEVATION_CFG","value":"false","timestamp":1568054420},{"name":"DUSK_ENABLE_THRESH2_CFG","value":"true","timestamp":1568054415},{"name":"SUN_THRESH3_VALUE_CFG","value":"30","min_value":"1","max_value":"100","step_size":"1","timestamp":1568054418},{"name":"RESET_WO_PAIR_CMD","timestamp":-1},{"name":"SUN_THRESH3_ENV_NAMES_CFG","value":"Sonne W - NW / 30 KLux Sommer","timestamp":-1},{"name":"PROT_ID_DEVICE_LOC","value":"690732_S_1","timestamp":-1},{"name":"WIND_THRESH3_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"SUN_THRESH3_ELEVATION_RANGE_CFG","value":"0","min_value":"0","max_value":"52","step_size":"26","timestamp":1568054418},{"name":"WIND_DETECT_TIME_CFG","value":"1","min_value":"1","max_value":"255","step_size":"1","timestamp":1568054425},{"name":"DAWN_ENABLE_THRESH1_CFG","value":"true","timestamp":1568054415},{"name":"TEMPERATURE_STOP_EVT","value":"3","min_value":"1","max_value":"5","step_size":"1","timestamp":1568038009},{"name":"SUN_THRESH2_ENV_NAMES_CFG","value":"Sonne S - W / 30 KLux Sommer","timestamp":-1},{"name":"WIND_START_EVT","min_value":"1","max_value":"5","step_size":"1","timestamp":-1},{"name":"SUN_THRESH1_TARGET_AZIMUTH_CFG","value":"135.0","min_value":"22.5","max_value":"315.0","step_size":"22.5","timestamp":1568054417},{"name":"SUN_HEIGHT_DEG_MEA","value":"-29","min_value":"-90","max_value":"90","timestamp":1568067423},{"name":"TEMPERATURE_THRESH2_ENV_NAMES_CFG","value":"Temperatur 25° Sonne","timestamp":-1},{"name":"AUTOMATIC_SOMMERTIME_CFG","value":"false","timestamp":1568061932},{"name":"RMT_STOP_PAIR_CMD","timestamp":-1},{"name":"REQ_SENS_CFG_CMD","timestamp":-1},{"name":"SUN_THRESH5_TIME_2_DETECT_CFG","value":"1","min_value":"1","max_value":"32","step_size":"1","timestamp":1568054420},{"name":"SENS_STATUS_MODE_CFG","value":"true","timestamp":1568054425},{"name":"SUN_THRESH4_TEMPERATURE_ENABLE_CFG","value":"false","timestamp":1568054418},{"name":"WIND_THRESH5_ENV_NAMES_CFG","value":"Mein Reaktionswert 5","timestamp":-1},{"name":"SUN_THRESH5_TARGET_AZIMUTH_CFG","value":"22.5","min_value":"22.5","max_value":"315.0","step_size":"22.5","timestamp":1568054420},{"name":"SUN_THRESH4_ELEVATION_RANGE_CFG","value":"0","min_value":"0","max_value":"52","step_size":"26","timestamp":1568054418},{"name":"TEMPERATURE_THRESH3_ENV_NAMES_CFG","value":"Temperatur 18° Ventilator","timestamp":-1},{"name":"SUN_THRESH5_TEMPERATURE_VALUE_CFG","value":"0","min_value":"-5","max_value":"26","step_size":"1","timestamp":1568054420},{"name":"WIND_STOP_EVT","value":"5","min_value":"1","max_value":"5","step_size":"1","timestamp":1568067121},{"name":"RAIN_DETECTED_EVT","value":"false","timestamp":1568067423},{"name":"RMT_START_PAIR_CMD","timestamp":-1},{"name":"SUN_THRESH4_TARGET_AZIMUTH_CFG","value":"157.5","min_value":"22.5","max_value":"315.0","step_size":"22.5","timestamp":1568054418},{"name":"SUN_THRESH3_TARGET_AZIMUTH_CFG","value":"292.5","min_value":"22.5","max_value":"315.0","step_size":"22.5","timestamp":1568054418},{"name":"SUN_THRESH2_TARGET_AZIMUTH_CFG","value":"157.5","min_value":"22.5","max_value":"315.0","step_size":"22.5","timestamp":1568054417},{"name":"DUSK_THRESH1_ENV_NAMES_CFG","value":"Licht 10 Lux","timestamp":-1},{"name":"WIND_THRESH1_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"WIND_THRESH2_ENABLE_CFG","value":"true","timestamp":1568054423},{"name":"USE_SECURE_WIND_FCT_CFG","value":"true","timestamp":1568054425},{"name":"SUN_DIRECTION_EVT","value":"333.0","min_value":"0.0","max_value":"360.0","step_size":"1.5","timestamp":1568067423},{"name":"SUN_THRESH5_TEMPERATURE_ENABLE_CFG","value":"false","timestamp":1568054420},{"name":"RMT_START_UNPAIR_CMD","timestamp":-1},{"name":"SUN_THRESH5_USE_AZIMUTH_CFG","value":"false","timestamp":1568054420},{"name":"DUSK_ENABLE_THRESH4_CFG","value":"true","timestamp":1568054415},{"name":"SUN_THRESH5_ELEVATION_RANGE_CFG","value":"0","min_value":"0","max_value":"52","step_size":"26","timestamp":1568054420},{"name":"DAWN_ENABLE_THRESH3_CFG","value":"true","timestamp":1568054415},{"name":"WIND_THRESH4_ENV_NAMES_CFG","value":"Mein Reaktionswert 4","timestamp":-1}],"scenes":[]}}}
        Wichtig ist doch jetzt erst einmal der Weg zu den Daten. Wenn ich das richtig sehe ist das Zeile 26 Die habe ich geändert von
        var data = JSON.parse(body).data; in
        var data = JSON.parse(body).payload.device.capabilities;
        um es an die neue JSON anzupassen
        In Zeile 42/43 soll dann auf [37] zugegriffen werden und die Daten übertragen werden.
        Kannst Du damit jetzt mehr anfangen ? Das Script ist hier im Spoiler noch mal drin
        const request = require('request');
        const link = 'http://192.168.1.180/devices/1010005';
        //const linkfsupunten = 'http://192.168.1.180/deviceajax.do?meter=1010009';
        //const linkfsupoben = 'http://192.168.1.180/deviceajax.do?meter=1010008';
        // Datenpunkte erzeugen
        createState('Homepilot.Sonnenrichtung', 0, {type: 'number', unit: '°'});
        createState('Homepilot.Sonnenhöhe', 0, {type: 'number', unit: '°'});
        createState('Homepilot.Lichtwert', 0, {type: 'number', unit: 'lux'});
        createState('Homepilot.Windgeschwindigkeit', 0, {type: 'number', unit: 'm/s'});
        createState('Homepilot.Temperatur', 0, {type: 'number', unit: '°C'});
        createState('Homepilot.Regen', 0, {type: 'boolean', unit: ''});
        createState('Homepilot.Aktualisiert', 0, {type: 'string', unit: ''});
        createState('Homepilot.balkontüreoben', 0, {type: 'boolean', unit: ''});
        createState('Homepilot.balkontüreobenaktualisiert', 0, {type: 'string', unit: ''});
        createState('Homepilot.balkontüreunten', 0, {type: 'boolean', unit: ''});
        createState('Homepilot.balkontüreuntenaktualisiert', 0, {type: 'string', unit: ''});
        function sensordaten() {
        request(link, function(error,response, body) {
        if(error) log('Fehler request: ' + error, 'error');
        else {
                var dir = data[5].Sonnenrichtung;
                //log(dir);
                dir = parseFloat(dir.substr(dir.indexOf('(') + 1));
                setState('Homepilot.Sonnenrichtung', dir, true);
                var ele = parseFloat(data[4].Sonnenhöhe);
                setState('Homepilot.Sonnenhöhe', ele, true);
                var lux = parseFloat(data[0].Lichtwert);
                setState('Homepilot.Lichtwert', lux, true);
                var wind = parseFloat(data[1]['Windgeschw.']);
                setState('Homepilot.Windgeschwindigkeit', wind, true);
                setState('Homepilot.Temperatur', temp, true);
                var regen = data[3].Regen; // Das ist ein String !
                    if(regen == 'Nicht erkannt') setState('Homepilot.Regen', false, true);
                    else setState('Homepilot.Regen', true, true);
                var aktualisiert = data[6].Aktualisiert; // Das ist ein String !
                setState('Homepilot.Aktualisiert', aktualisiert, true);
        function balkontuere() {
        request(linkfsupunten, function(error,response, body) {
        else {
        var schliesserunten = data[0].Schließer; // Das ist ein String !
        if(schliesserunten == 'Geöffnet') setState('Homepilot.balkontüreunten', false, true);
        else setState('Homepilot.balkontüreunten', true, true);
        var aktualisiert = data[1].Aktualisiert; // Das ist ein String !
        setState('Homepilot.balkontüreuntenaktualisiert', aktualisiert, true);
        request(linkfsupoben, function(error,response, body) {
        else {
        var schliesseroben = data[0].Schließer; // Das ist ein String !
        if(schliesseroben == 'Geöffnet') setState('Homepilot.balkontüreoben', false, true);
        else setState('Homepilot.balkontüreoben', true, true);
        setState('Homepilot.balkontüreobenaktualisiert', aktualisiert, true);
        /*function controme() {
        request(linkcontrome1, function(error,response, body) {
        else {
        var data = JSON.parse(body).sensoren;
        var id = parseFloat(data[0].id);
        setState('Controme.id', id, true);
        function alledaten() {
        sensordaten();
        balkontuere();
        //controme();
        schedule('*/30 * * * * *', alledaten); // alle 30 Sekunden
        Vielen dank nochmal und viele Grüße,
        Marc
          @meicker sagte:
          Ist doch richtig, denn die Variable data enthält das Array, an dessen Index 37 das Objekt mit der Temperatur enthalten ist.
            jetzt hab ich es verstanden 🙂 Es funktioniert. Ich war mir nicht sicher. Ich dachte halt ich habe das total falsch angefangen ... Danke für den Hinweis !
            Ich versuche gleich mal die anderen einfachen Dinge ... aber da waren auch noch kompliziertere Datenpunkte drin wo was umgewandelt wurde. Ich versuche es erstmal und wenn ich nicht klar komme darfst Du mir gerne wieder einen denkanstoß geben 🙂
            Danke DIR !
            vg
            Marc
              klappt soweit, komme gut weiter ...
              Ich bekomme bei einem datenpunkt ein 'warn' - er funktioniert, aktuell ist er 'true'
              var regen = data[133].value;
              setState('Homepilot.Regen', regen, true);
              und die Logmeldung ist:
              javascript.0 at Request._callback (script.js.Homepilot.Sensordaten1:46:13)
              Zeile 46 ist -> setState('Homepilot.Regen', regen, true);
              Hast Du eine Idee ?
              vg
              Marc
                @meicker sagte:
                Es wird ein String geliefert, deshalb ändere es:
                var regen = false;
                if(data[133].value == 'true') regen = true;
                  SUPER 🙂 Klappt natürlich ... DANKE !!!
                  Und jetzt hab ich noch eine Kleinigkeit ... wie wandle ich den Timestamp in ein Datum mit Zeit um ? Was ich im Netz gefunden habe war alles ellenlanger code ...
                  var aktualisiert = data[37].timestamp;
                  Geht das überhaupt einfach ?
                    @meicker sagte:
                    Ja, mit formatDate(). Der Datenpunkt muss vom Typ "string" sein.
                    var aktualisiert = formatDate(data[37].timestamp, 'DD.MM.YY hh:mm:ss');
                      @paul53 said in [GELÖST] Homepilot Umweltsensor mit Javascript auslesen:
                      Ganz herzlichen Dank Paul !!!
                        slkschlumpf last edited by
                        gibt es für mein Schalten der Aktoren auch schon eine Lösung ?
                        die Kommandos
                        command_on: curl "http://192.168.2.2/deviceajax.do?cid=10&did=1010022&command=1"
                        command_off: curl "http://192.168.2.2/deviceajax.do?cid=11&did=1010022&command=1"
                        funktionieren nicht mehr.
                          @slkschlumpf
                          soweit ich aktuell weiß noch nicht ... aber ich frage mal eben jemanden ...
                          Das Problem ist das es noch nicht genügend Leute gibt die Informationen bekommen haben ... Rademacher sagt zwar auf Youtube das die Schnittstelle extra überarbeitet wurde um das Zusammenspiel zu vereinfachen, auf der anderen Seite habe ich 'noch' keine Informationen dazu bekommen können ...
                          Ich weiß das wenigstens einer an einem Adapter arbeitet. Dort habe ich gerade gefragt. Wenn ich was höre gebe ich Bescheid ...
                          vg
                          Marc
                          79.9k
                          2771
