    4. KNX Adapter überholt
      peer69 Forum Testing last edited by
      1.0.33 gibt mir leider genau wie 1.0.32 disconnects alle paar Minuten. 1.0.31 läuft fehlerfrei.
      chefkoch009 1 Reply Last reply Reply Quote 0
      • chefkoch009
        chefkoch009 Developer @peer69 last edited by
        @peer69 kannst du mir mal den „Most-log“ -13 Sekunden zukommen lassen?
        VG
        chefkoch009
          peer69 Forum Testing @chefkoch009 last edited by
          @chefkoch009 Ist per PN raus.
          • dQeLse
            dQeLse last edited by
            @chefkoch009 vielen Dank für die neue Version, bei mir lüppt wieder alles.
            VG
            Marcus
            • Merlin123
              Merlin123 last edited by
              Hab leider auch permanente Restarts mit der 33er 😞
              host.beelink	2019-09-14 16:50:09.812	info	Restart adapter system.adapter.knx.0 because enabled
              host.beelink	2019-09-14 16:50:09.812	error	instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
              host.beelink	2019-09-14 16:50:06.782	info	instance system.adapter.knx.0 started with pid 2249
              host.beelink	2019-09-14 16:49:36.772	info	Restart adapter system.adapter.knx.0 because enabled
              host.beelink	2019-09-14 16:49:36.771	error	instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
              host.beelink	2019-09-14 16:49:33.738	info	instance system.adapter.knx.0 started with pid 1520
              host.beelink	2019-09-14 16:49:03.691	info	Restart adapter system.adapter.knx.0 because enabled
              host.beelink	2019-09-14 16:49:03.690	error	instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
              host.beelink	2019-09-14 16:49:00.673	info	instance system.adapter.knx.0 started with pid 599
              knx.0	2019-09-14 16:48:32.447	debug	system.adapter.admin.0: logging true
              host.beelink	2019-09-14 16:48:30.632	info	Restart adapter system.adapter.knx.0 because enabled
              host.beelink	2019-09-14 16:48:30.632	error	instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
              knx.0	2019-09-14 16:48:30.586	error	already running
              knx.0	2019-09-14 16:48:30.564	debug	statesDB connected
              knx.0	2019-09-14 16:48:30.518	debug	objectDB connected
                ecki945 last edited by
                Kann die Neustarts bestätigen. Bei mir so alle 10 Minuten.
                @chefkoch009: Frage zu den Einheiten der Datenpunkte bei der neuen Version:
                Verstehst du darunter die Übernahme von: "dpt": "DPT5.001" in den Datenpunkt?
                Ich fände es schön wenn der Adapter beim Import des Projetfiles auf grund der DPT Codierung auch gleich den Unit EIntrag im Datenpunkt macht. Z.B. DPT9.004 "unit" "lux", wenn das technisch möglich ist. Den Unit Eintrag unten habe ich nachgerüstet, würde nicht automatisch gemacht.
                  "from": "system.adapter.knx.0",
                  "user": "system.user.admin",
                  "ts": 1568439233977,
                  "common": {
                    "name": "Esszimmer Licht 1 Deckenbeleuchtung Wert",
                    "type": "number",
                    "role": "level.dimmer",
                    "min": 0,
                    "max": 100,
                    "unit": "%",
                    "read": false,
                    "write": true,
                    "custom": {
                      "lovelace.0": {
                        "enabled": true,
                        "entity": "light",
                        "name": "EsszimmerLichtDecke1"
                  "native": {
                    "dpt": "DPT5.001",
                    "address": "1/1/52",
                    "addressRefId": "P-0372-0_GA-626",
                    "statusGARefId": "",
                    "actGARefId": ""
                  "acl": {
                    "object": 1636,
                    "owner": "system.user.admin",
                    "state": 1636
                  "_id": "knx.0.Beleuchtung.02_EG.Esszimmer_Licht_1_Deckenbeleuchtung_Wert",
                  "type": "state"
                • dQeLse
                  habt ihr in den Einstellungen die IP und das Interface festgepinned?
                  Ich kann die Restarts hier nicht nachvollziehen
                    peer69 Forum Testing @Merlin123 last edited by
                    @Merlin123 das sieht aber eher so aus als würde der alte Prozess nach dem Update noch laufen. Alte PID killen oder System mal rebooten sollte das lösen. Der Fehler bei mir stellt sich leider etwas anders dar.
                      peer69 Forum Testing @dQeLse last edited by
                      @dQeLse Jup. Habe ich. Ansonsten auch keine Besonderheiten und mit der „alten“ Version läuft tatsächlich alles einwandfrei.
                      • Merlin123
                        Merlin123 @peer69 last edited by
                        @peer69 sagte in KNX Adapter überholt:
                        Danke für den Hinweis. Hab nochmal installiert und iobroker restartet. Sieht jetzt gut aus 🙂
                        • Merlin123
                          Ich habe eben das im Log entdeckt. Hat jemand eine Idee, was mir das sagen soll?
                          knx.0	2019-09-16 20:03:44.907	debug	system.adapter.admin.0: logging true
                          knx.0	2019-09-16 20:03:07.067	info	Connected - local UDP Server listening on 0.0.0.0:60335
                          knx.0	2019-09-16 20:03:07.065	info	Event : UDP - listening
                          knx.0	2019-09-16 20:03:07.061	info	Using UDP with local IP: 0.0.0.0
                          knx.0	2019-09-16 20:03:05.074	info	STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_RESPONSE(16) to STATE_NOT_CONNECTED(0).
                          knx.0	2019-09-16 20:03:05.070	info	STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
                          knx.0	2019-09-16 20:03:05.067	info	STATE_NOT_CONNECTED : Stop connection : STATE_READY(7) to STATE_NOT_CONNECTED(0).
                          knx.0	2019-09-16 20:03:05.063	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
                          knx.0	2019-09-16 20:03:05.060	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECTION_STATE_RESPONSE(6) to STATE_NOT_CONNECTED(0).
                            @Merlin123 das ist der Fehler, den ich meinte. Tritt bei mir seit 1.0.32 alle 2-4 Minuten auf.
                            • Merlin123
                              Ich hab das jetzt einmal drin gehabt mit der 33er
                              • chefkoch009
                                chefkoch009 Developer @Merlin123 last edited by
                                Dieses Verhalten tritt auf, wenn 2-4 Minuten lang(abhängig vom GW) kein Paket zwischen Adapter und GW gewechselt wird. Dann beendet das GW die Verbindung und der Adapter baut sie wieder auf.
                                Nun ist es so, das 10Sek nach dem letzten Paket ein conn-State-request gesendet wird und somit die Verbindung geöffnet bleibt.
                                An dieser Stelle ein Dankeschön an peer69.
                                Neue Version ist raus (1.0.35)
                                VG
                                chefkoch009
                                  cyberax last edited by cyberax
                                  Hallo Chefkoch,
                                  erstmal danke für deine grossartige Arbeit an dem KNX Adapter!
                                  Leider habe ich mit ETS5.7.2 und dem Adapter 1.0.35 das Problem, dass der Import des knxproj Files ewig dauert und kein Ergebnis bringt.
                                  Im Log taucht folgendes auf:
                                  knx.0	2019-09-19 08:40:53.913	error	TypeError: Cannot read property 'split' of undefined at _0x5ea473 (/opt/iobroker/node_modules/iobroker.knx/knx.js:44:9278) at _0x3e4883 (/opt/iobroker/node_modules/iobroker.knx/knx.js:44:15128
                                  knx.0	2019-09-19 08:40:53.913	error	message messagebox.system.adapter.knx.0 [object Object] Cannot read property 'split' of undefined
                                  knx.0	2019-09-19 08:40:53.912	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
                                  knx.0	2019-09-19 08:40:53.912	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3680:34)
                                  knx.0	2019-09-19 08:40:53.912	error	at Adapter.emit (events.js:211:7)
                                  knx.0	2019-09-19 08:40:53.912	error	at emitOne (events.js:116:13)
                                  knx.0	2019-09-19 08:40:53.912	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:7324)
                                  knx.0	2019-09-19 08:40:53.912	error	at _0x3e1e1e (/opt/iobroker/node_modules/iobroker.knx/knx.js:80:8688)
                                  knx.0	2019-09-19 08:40:53.912	error	at Object.getGAS (/opt/iobroker/node_modules/iobroker.knx/knx.js:72:13449)
                                  knx.0	2019-09-19 08:40:53.912	error	at Object._0xfdb812 [as convertAll] (/opt/iobroker/node_modules/iobroker.knx/knx.js:44:39668)
                                  knx.0	2019-09-19 08:40:53.912	error	at _0x3e4883 (/opt/iobroker/node_modules/iobroker.knx/knx.js:44:15128)
                                  knx.0	2019-09-19 08:40:53.912	error	at _0x5ea473 (/opt/iobroker/node_modules/iobroker.knx/knx.js:44:9278)
                                  Hast du eine Idee warum der Import nicht klappt?
                                  Bei früheren ETS Versionen war das kein Problem.
                                  VG
                                    AndreasK last edited by AndreasK
                                    ich bin gerade dabei, mich in den Adapter etwas einzuarbeiten.
                                    Aktuell möchte ich eine RTR umsetzen.
                                    Ich habe aber das Problem, dass ich den Sollwert nicht verändern kann.
                                    Datentyp des Sollwerts ist 9.001 (Temperatur). Wird auch unter Objekte sauber anzeigt. Soll bedeuten, wenn ich über den RTR im Raum die Solltemperatur verändere wird Veränderung auch sauber angezeigt.
                                    Nur wenn ich diesen in Objekte händisch verändere, wird nichts auf den Bus gesendet.
                                    Im Gruppenmonitor wird folgendes angezeigt:
                                    Unter Objekte habe ich als Rolle "level" ausgewählt.
                                    Woran könnte das liegen?
                                    Andreas
                                    • chefkoch009
                                      chefkoch009 Developer @AndreasK last edited by
                                      @AndreasK im Adapter muss dann das writeflag gesetzt sein UND das readflag MUSS reaktiv sein. Bitte daran denken, wenn Objekte geändert wurden, muss der Adapter neu gestartet werden.
                                      VG
                                      chefkoch009
                                        cyberopi last edited by cyberopi
                                        Ich möchte alle im Forum begrüßen und habe auch gleich ein Problem
                                        Habe heute meinen iobroker und KNX Adapter installiert
                                        Node.js 10.16.3 Raspberry4 mit 4 GB NPM: v6.9.0
                                        Welche Version des Adapters weiß ich nicht wo ich das sehe.
                                        folgender Fehler erscheint immer wieder Und KNX adapter startet immer wieder neu.
                                        Was kann ich tun um den Fehler wegzubekommen.
                                        Entschuldigung wegen Doppelpost. Ein Mitglied hat mir dazu geraten mein Anliegen hier zu posten.
                                        Viele Grüße
                                        host.raspberrypi	2019-09-20 22:13:25.829	info	Restart adapter system.adapter.knx.0 because enabled
                                        host.raspberrypi	2019-09-20 22:13:25.829	error	instance system.adapter.knx.0 terminated with code 6 (uncaught exception)
                                        host.raspberrypi	2019-09-20 22:13:25.829	error	Caught by controller[1]: at Object.onceWrapper (events.js:286:20)
                                        host.raspberrypi	2019-09-20 22:13:25.829	error	Caught by controller[1]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5341:21)
                                        host.raspberrypi	2019-09-20 22:13:25.829	error	Caught by controller[1]: at Object.unload (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:11067)
                                        host.raspberrypi	2019-09-20 22:13:25.829	error	Caught by controller[1]: at fsm.FSM.Disconnect (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/Connection.js:252:8)
                                        host.raspberrypi	2019-09-20 22:13:25.829	error	Caught by controller[1]: at fsm.Fsm.(anonymous function) [as transition] (/opt/iobroker/node_modules/machina/lib/machina.js:466:63)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[1]: at fsm.transition (/opt/iobroker/node_modules/machina/lib/machina.js:653:28)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[1]: at fsm._onEnter (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:118:14)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[1]: at fsm.FSM.send (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/Connection.js:186:15)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[1]: at Socket.send (dgram.js:399:3)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[1]: at healthCheck (dgram.js:605:11)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[1]: Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[0]: at fsm.transition (/opt/iobroker/node_modules/machina/lib/machina.js:653:28)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[0]: at fsm._onEnter (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:286:12)
                                        host.raspberrypi	2019-09-20 22:13:25.828	error	Caught by controller[0]: at fsm.emitEvent (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:312:10)
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at fsm.emit (/opt/iobroker/node_modules/machina/lib/machina.js:111:8)
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at Function.<anonymous> (/opt/iobroker/node_modules/machina/node_modules/lodash/index.js:3346:13)
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at /opt/iobroker/node_modules/machina/node_modules/lodash/index.js:3049:15
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at /opt/iobroker/node_modules/machina/node_modules/lodash/index.js:2874:23
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at fsm.<anonymous> (/opt/iobroker/node_modules/machina/lib/machina.js:113:17)
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at fsm.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/Datapoint.js:51:28)
                                        host.raspberrypi	2019-09-20 22:13:25.827	error	Caught by controller[0]: at Object.dpts.fromBuffer (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/dptlib/index.js:175:54)
                                        host.raspberrypi	2019-09-20 22:13:25.826	error	Caught by controller[0]: TypeError: Cannot read property 'hasOwnProperty' of undefined
                                        knx.0	2019-09-20 22:13:24.830	error	Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running at healthCheck (dgram.js:605:11) at Socket.send (dgram.js:399:3) at fsm.FSM.send (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/
                                        knx.0	2019-09-20 22:13:24.830	error	uncaught exception: Not running
                                        knx.0	2019-09-20 22:13:24.830	info	terminating
                                        knx.0	2019-09-20 22:13:24.829	error	TypeError: Cannot read property 'hasOwnProperty' of undefined at Object.dpts.fromBuffer (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/dptlib/index.js:175:54) at fsm.<anonymous> (/op
                                        knx.0	2019-09-20 22:13:24.827	error	uncaught exception: Cannot read property 'hasOwnProperty' of undefined
                                        • chefkoch009
                                          chefkoch009 Developer last edited by
                                          Hallo cyberopi,
                                          welche knx-adapter Version hast Du? Ich schätze mal nicht die aktuelle. Der von Dir angezeigte Fehler deutet auf eine Version kleiner 1.x.x hin. Wie hast Du den Adapter installiert?
                                          VG
                                          chefkoch009
                                            AndreasK @chefkoch009 last edited by AndreasK
                                            @chefkoch009 said in KNX Adapter überholt:
                                            Also so:
                                            Sollte ich die Flags in der ETS auch anpassen? Aktuell stehen die auf KLS. Nicht das bei einem neu einlesen die Einstellungen im Adapter überschrieben werden
                                            Andreas
                                            1043
                                            339692
