    • dslraser
      dslraser Forum Testing Most Active @s.bormann last edited by
      @s-bormann sagte in [Neuer Adapter] Visualisierung iQontrol:
      @dslraser Wie ist der RAW von CONTROL_MODE?
       "from": "system.adapter.hm-rpc.2",
       "user": "system.user.admin",
       "ts": 1568583351760,
       "common": {
         "name": "Heizung Wohnzimmer INT0000001:1.CONTROL_MODE",
         "type": "number",
         "role": "indicator",
         "def": 0,
         "min": 0,
         "max": 3,
         "read": false,
         "write": true,
         "custom": {
           "iqontrol.0": {
             "enabled": true,
             "readonly": false,
             "invert": false,
             "confirm": false,
             "unit": "",
             "unit_zero": "",
             "unit_one": "",
             "min": 0,
             "max": 3,
             "step": "",
             "type": "number",
             "role": "",
             "targetValueId": "",
             "states": {
               "0": "automatik",
               "1": "manuell"
       "native": {
         "ID": "CONTROL_MODE",
         "TYPE": "INTEGER",
         "CONTROL": "HEATING_CONTROL_HMIP.CONTROL_MODE",
         "MIN": 0,
         "OPERATIONS": 2,
         "MAX": 3,
         "FLAGS": 1,
         "DEFAULT": 0
       "acl": {
         "object": 1636,
         "owner": "system.user.admin",
         "state": 1636
       "_id": "hm-rpc.2.INT0000001.1.CONTROL_MODE",
       "type": "state"
       "type": "state",
       "common": {
         "def": false,
         "type": "boolean",
         "read": false,
         "write": true,
         "role": "switch.boost",
         "name": "Heizung Wohnzimmer INT0000001:1.BOOST_MODE"
       "native": {
         "MIN": false,
         "OPERATIONS": 6,
         "MAX": true,
         "FLAGS": 1,
         "ID": "BOOST_MODE",
         "TYPE": "BOOL",
         "DEFAULT": false,
         "CONTROL": "HEATING_CONTROL_HMIP.BOOST_MODE"
       "ts": 1568583351763,
       "_id": "hm-rpc.2.INT0000001.1.BOOST_MODE",
       "acl": {
         "object": 1636,
         "state": 1636,
       "type": "state",
       "common": {
         "def": 0,
         "type": "number",
         "read": true,
         "write": false,
         "min": 0,
         "max": 2048,
         "name": "Heizung Wohnzimmer INT0000001:1.BOOST_TIME"
       "native": {
         "MIN": 0,
         "OPERATIONS": 5,
         "MAX": 2048,
         "FLAGS": 1,
         "ID": "BOOST_TIME",
         "TYPE": "INTEGER",
         "DEFAULT": 0
       "ts": 1568583351761,
       "_id": "hm-rpc.2.INT0000001.1.BOOST_TIME",
       "acl": {
         "object": 1636,
         "state": 1636,
      CONTOL_MODE funktioniert bei mir. BOOST funktioniert nicht.
      • s.bormann
        @dslraser sagte in [Neuer Adapter] Visualisierung iQontrol:
         "common": {
           "type": "number",
           "def": 0,
           "min": 0,
           "max": 3,
           "read": false,
           "write": true,
           "custom": {
             "iqontrol.0": {
               "enabled": true,
               "readonly": false,
               "invert": false,
               "confirm": false,
               "unit": "",
               "unit_zero": "",
               "unit_one": "",
               "min": 0,
               "max": 3,
               "step": "",
               "type": "number",
               "role": "",
               "states": {
                 "0": "automatik",
                 "1": "manuell"
         "native": {
           "TYPE": "INTEGER",
           "MIN": 0,
           "OPERATIONS": 2,
           "MAX": 3,
           "FLAGS": 1,
           "DEFAULT": 0
         "acl": {
           "object": 1636,
           "state": 1636
         "type": "state"
         "type": "state",
         "common": {
           "def": false,
           "type": "boolean",
           "read": false,
           "write": true,
         "native": {
           "MIN": false,
           "OPERATIONS": 6,
           "MAX": true,
           "FLAGS": 1,
           "ID": "BOOST_MODE",
           "TYPE": "BOOL",
           "DEFAULT": false,
         "acl": {
           "object": 1636,
           "state": 1636,
         "type": "state",
         "common": {
           "def": 0,
           "type": "number",
           "read": true,
           "write": false,
           "min": 0,
           "max": 2048,
         "native": {
           "MIN": 0,
           "OPERATIONS": 5,
           "MAX": 2048,
           "FLAGS": 1,
           "ID": "BOOST_TIME",
           "TYPE": "INTEGER",
           "DEFAULT": 0
         "acl": {
           "object": 1636,
           "state": 1636,
        Hi, sag noch mal, was genau bei Boost nicht klappt.
        • dslraser
          dslraser Forum Testing Most Active @s.bormann last edited by dslraser
          Diese Konstellation hatte ich vorher noch nicht - habe aber mal eine Anpassung der Zeile in diese Richtung vorgenommen.
          Wenn das so ist, dann wird der Fehler aber auch an anderer Stelle auftreten, denn Zeilen mit exakt diesem Aufbau gibt es in iQontrol haufenweise...
          genau das in einer anderen Zeilennummer. (die habe ich aber nicht mehr parat, da ich diese Kachel dann nicht mehr bearbeiten konnte, ging nur noch zu löschen und neu anlegen)
          Hat aber immer noch so ausgesehen, also kein Boost zu sehen.
          • s.bormann
            @dslraser Versuch mal die Value-List mit dem Schraubenschlüssel so anzupassen, dass Du als 3. Eintrag "BOOST-MODE" hast, min = 0, max = 2. Geht es dann?
            dslraser liv-in-sky 2 Replies Last reply Reply Quote 0
            • dslraser
              Wenn . ich das so mache, also die Value-List von Control_MODE von 0-2, dann wird BOOST angezeigt.
              Aber es wird dann in den Objekten einfach bei CONTOL_MODE auf 2 geschaltet, was aber nichts auslöst.
              Es müßte für BOOST aber BOOST_Mode auf true gesetzt werden.
              Ich dachte auch, das dafür eigentlich der BOOST_STATE verantwortlich ist ?
              Für BOOST_TIME gibt es ja auch einen Datenpunkt, der wird automatisch gestartet, wenn BOOST_MODE auf true gesetzt wird. Dieser wird aber bisher auch nicht angezeigt.
              sigi234 s.bormann 2 Replies Last reply Reply Quote 0
                sigi234 Forum Testing Most Active @dslraser last edited by
                @dslraser
                Hallo, ist aber nur bei HMIP so, oder?
                • dslraser
                  dslraser Forum Testing Most Active @sigi234 last edited by
                  @sigi234 sagte in [Neuer Adapter] Visualisierung iQontrol:
                  @dslraser
                  keine Ahnung, ich habe nur HMIP. Aber da sind wir je gerade dabei die Unterschiede raus zu arbeiten.
                    @dslraser
                    Ich habe nur HM Geräte, bei mir geht es. Wenn ich testen soll, einfach sagen.
                      luder last edited by
                      Ich teste gerade meine Firtzdect Thermostate einzubinden.
                      Wie bekommt ihr denn die Parameter MANUAL - AUTO - BOOST nebeneinader zur direkten Auswahl?
                      bei mir stehen die Untereinander
                        liv-in-sky @s.bormann last edited by liv-in-sky
                        @s-bormann
                        ich hätte da mal ein problem - bzw - verständnis frage
                        ich probiere mit iqontrol mit einem datenpunkt-werteliste zu arbeiten, also etwas auswählen und im script wird dann das gewählte verarbeitet, irgend wie verwirrt mich die definition
                        die werteliste, die du auf github beschreibst ist etwas anders aufgebaut als der offizielle werteliste-datenpunkt
                        wie kommen die beiden richtig zusammen - eigentlich sollte der wertelisten-datenpunkt vom type number sein - du verwendest aber strings
                        mein datenpunkt sieht so aus - der type ist hier string - habe aber auch number probiert (dann steht statt CODE01 nur 1 usw):
                          "common": {
                            "name": "Unifi Wifi Vouchers_ValueCodeList",
                            "role": "state",
                            "type": "string",
                            "states": "CODE01:5d7fa5ab97578401a0612f6e;CODE02:5d7fa5ab97578401a0612f6b;",
                            "read": true,
                            "write": true
                          "native": {},
                          "type": "state",
                          "from": "system.adapter.javascript.2",
                          "ts": 1568645584287,
                          "_id": "javascript.2.WLANUnifi.Wifi_Vouchers_ValueCodeList",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        wie müssen die states genau aussehen, damit eine werteliste in iqontrol kommt (meistens zeigt er nur einen wert an und es kommt keine valueliste) - hatte auch mal kurz erfolg, aber jetzt bekomme ich es nicht mehr hin
                        die states sind bei mir flexibel - ein script beschreibt die (obj.common.states = ...) - es können also auch mal 5 codes drinstehen oder weniger - wird das dann ge-updatet in iqontrol ?
                        könntest du mir bitte einen tipp gehen, was da bei meinem beispiel drinstehen muss (unter states) und ob diese bei veränderung auch in iqontrol verändert werden
                        nachtrag 17.9.19: konnte problem lösen - frage hat sich erledigt
                        • einfach standard werte für datenpunkt werteliste nutzen - dann funktioniert es - mußte beim erstellen des datenpunktes im script alle werte des datenpunktes mitangeben und auch die states gleich mit "dummy-values" besetzen
                        createState(dpPrefix + "WLANUnifi.Wifi_Vouchers_ValueCodeList", { name: 'Unifi Wifi Vouchers_ValueCodeList', desc:"ValueCodeList", role: "", type:'number', states: "1:please wait ...;2:refresh webpage", def:1, min: 0, max: 20,  read:  true,  write: true,});
                        • Z
                          zahnheinrich @liv-in-sky last edited by
                          @s-bormann
                          Ich habe einen kleinen Bug gefunden:
                          Ich habe eine zweite Instanz von iqontrol installiert, um diese mit identischen Kacheln zu betreiben, jedoch in anderer Sprache zu beschriften.
                          In den Einstellungen mit dem Schraubenschlüssel kann ich auch für die zweite Instanz neue Bezeichnungen eingeben, jedoch werden in der Kachel immer die Bezeichnungen der ersten Instanz gezeigt.
                          Könntest Du das ändern?
                          Vielen Dank für diesen tollen Adapter!!!
                          • Z
                            zahnheinrich @zahnheinrich last edited by zahnheinrich
                            @s-bormann
                            Das Problem ist sogar etwas umfangreicher:
                            Sobald eine zweite Instanz von iqontrol läuft, kann ich die Value List in den Eigenschaften BEIDER Instanzen ncht mehr ändern.
                            Das geht erst wieder, nachdem ich die zweite Instanz gelöscht habe.
                            iqontrol Vers. 0.2.4
                            node 8.16
                            • s.bormann
                              Hi, zur Info: bin ein paar Tage ohne PC. Melde mich, sobald ich wieder online bin.
                                RichieXX last edited by
                                Hallo.
                                Ab Version 0.2.2 werden bei meinen Devolo Z-wave Thermostaten keine Temparaturwerte mehr angezeigt und man kann auch keinen Setpoint setzen. Bis V 0.2.1 alles OK. Bin wieder zurück zur 0.2.1 und alles OK.
                                • Z
                                  zahnheinrich @s.bormann last edited by
                                  @s-bormann
                                  Danke für die Info.
                                  Keinen Stress!
                                    mucki last edited by
                                    @s-bormann
                                    Könntest du vielleicht bei Gelegenheit mal schauen, ob du das Nuki Schloss einpflegen könntest?
                                    Anbei mal das RAW von nuki2.0.door__garage.action:
                                      "from": "system.adapter.nuki2.0",
                                      "ts": XXXXXXXXXXXXXXX,
                                      "common": {
                                        "name": "Trigger an action on Garage",
                                        "role": "value",
                                        "type": "number",
                                        "nukiId": XXXXXXXXX,
                                        "write": true,
                                        "states": {
                                          "0": "NO_ACTION",
                                          "1": "UNLOCK",
                                          "2": "LOCK",
                                          "3": "UNLATCH",
                                          "4": "LOCK_N_GO",
                                          "5": "LOCK_N_GO_WITH_UNLATCH"
                                        "custom": {
                                          "iqontrol.0": {
                                            "enabled": true,
                                            "readonly": false,
                                            "invert": false,
                                            "confirm": false,
                                            "unit": "",
                                            "unit_zero": "",
                                            "unit_one": "",
                                            "min": "",
                                            "max": "",
                                            "step": "",
                                            "type": "number",
                                            "role": "state",
                                            "states": {
                                              "0": "NO_ACTION",
                                              "1": "UNLOCK",
                                              "2": "LOCK",
                                              "3": "UNLATCH",
                                              "4": "LOCK_N_GO",
                                      "native": {},
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636
                                      "_id": "nuki2.0.door__garage.action",
                                      "type": "state"
                                    Bluefox s.bormann 2 Replies Last reply Reply Quote 0
                                    • Bluefox
                                      Bluefox @mucki last edited by
                                      @mucki Ich sehe jetzt schon, dass nuki falsch implementiert ist.
                                      nukiId darf nicht in common drin sein
                                      • s.bormann
                                        s.bormann Most Active @mucki last edited by
                                        @mucki sagte in [Neuer Adapter] Visualisierung iQontrol:
                                        @s-bormann
                                          "common": {
                                            "role": "value",
                                            "type": "number",
                                            "write": true,
                                            "states": {
                                              "0": "NO_ACTION",
                                              "1": "UNLOCK",
                                              "2": "LOCK",
                                              "3": "UNLATCH",
                                              "4": "LOCK_N_GO",
                                            "custom": {
                                              "iqontrol.0": {
                                                "enabled": true,
                                                "readonly": false,
                                                "invert": false,
                                                "confirm": false,
                                                "unit": "",
                                                "unit_zero": "",
                                                "unit_one": "",
                                                "min": "",
                                                "max": "",
                                                "step": "",
                                                "type": "number",
                                                "role": "state",
                                                "states": {
                                                  "0": "NO_ACTION",
                                                  "1": "UNLOCK",
                                                  "2": "LOCK",
                                                  "3": "UNLATCH",
                                                  "4": "LOCK_N_GO",
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636
                                          "type": "state"
                                        @DocGame hat mir mal folgenden RAW zu Nuki geschickt:
                                          "common": {
                                            "name": "Current door-state of the Nuki",
                                            "role": "value",
                                            "type": "number",
                                            "write": false,
                                            "states": {
                                              "0": "UNAVAILABLE",
                                              "1": "DEACTIVATED",
                                              "2": "DOOR_CLOSED",
                                              "3": "DOOR_OPENED",
                                              "4": "DOOR_STATE_UNKNOWN",
                                              "5": "CALIBRATING"
                                          "type": "state",
                                          "native": {},
                                          "ts": 1563554429834,
                                          "_id": "nuki2.0.door__haustür.status.doorState",
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                        Sehe ich es richtig, dass NUKI zwei unterschiedliche Datenpunkte für den aktuellen Zustand und Befehle verwendet?
                                        VG
                                        • s.bormann
                                          s.bormann Most Active @RichieXX last edited by
                                          @RichieXX sagte in [Neuer Adapter] Visualisierung iQontrol:
                                          Hallo.
                                          bitte mit F12 Entwicklerkonsole im Browser starten und mir posten, was im Fenster "Console" angzeigt wird, wenn der Fehler entsteht.
                                          Danke und VG!
                                          • s.bormann
                                            s.bormann Most Active @zahnheinrich last edited by
                                            @zahnheinrich sagte in [Neuer Adapter] Visualisierung iQontrol:
                                            @s-bormann
                                            node 8.16
                                            bitte schick mal den RAW den Datenpunktes. Habe es bei mir gerade versucht und konnte den Fehler nicht reproduzieren. Kommt wohl nur in bestimmten Konstellationen vor.
                                            Was ich noch nicht ganz verstanden habe: Ist der Fehler schon auf der Schraubenschlüssel-Seite (also kannst Du gar nichts einstellen? - dann bitte die Seite mit geöffneter Entwicklerkonsole öffnen (F12) und hier die Meldungen posten) oder erst im Frontend? (Dann bitte hier ebenfalls die Fehler der Entwicklerkonsole posten).
                                            VG!
                                            1.2k
                                            296
                                            7637
                                            6977372
