    4. Projekt WetterView von sigi234
      sigi234 Forum Testing Most Active @Seadon last edited by
      @Seadon sagte in Projekt WetterView von sigi234:
      Objekt in IObroker
      Zeig sie mal.
        Seadon @sigi234 last edited by
        @sigi234
          @sigi234
          mit den Temperaturen ist ein Problem mit das wetter und der Api denk ich, das versuch ich selber zu klären. Auf der Webseite zeigt er für Berlin 31 Grad und in der View 24 Grad.
            sigi234 Forum Testing Most Active @Seadon last edited by sigi234
            @Seadon
            Stell das Widget rein das ich alle DP sehen kann.
              @sigi234
              [{"tpl":"tplValueStringRaw","data":{"oid":"javascript.0.UWZ.UWZDE10115.warning.0.HTMLShort","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":">=","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Wetter/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Wetter/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Wetter/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"javascript.0.UWZ.UWZAT00810.warning.0.uwzLevel","name":"warning.0.uwzLevel","comment":"UWZ","filterkey":"Warnung"},"style":{"left":"830px","top":"840px","width":"549px","height":"87px","z-index":"3","color":"#000000","text-align":"center","font-size":"small","background":"","background-color":""},"widgetSet":"basic"}]
                @Seadon
                Du musst ALLE DP an deine anpassen!
                Beispiel:
                Da steht noch mein DP drinnen.
                  @sigi234 Das war es, Danke .. wieder etwas gelernt ... (Sichtbarkeit) ^^
                    Bitte benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
                    • O
                      Oli last edited by Oli
                      ich habe mir für jeden Tag eine Detailansicht erstellt und mir dafür Bilder für die Nacht gebastelt.
                      Kann ich mir, wenn im Forecast um 2:00 Uhr "Sonne" steht, einen Alternativtext anzeigen lassen?
                      Sieht doof aus, wenn ein Mond abgebildet ist und darüber steht Sonne 😁
                      Gruß Oliver
                        sigi234 Forum Testing Most Active @Oli last edited by sigi234
                        @Oli
                        Ja, geht mit Sichtbarkeit im Widget. Einfach ein 2.Widget darüber legen. Also das Widget wo Sonne steht kopieren.
                        O 2 Replies Last reply Reply Quote 0
                        • O
                          Oli @sigi234 last edited by
                          @sigi234
                          Danke, manchmal sieht man den Wald vor lauter Bäumen nicht.
                          • O
                            @sigi234
                            weist du zufällig, ob ich eine Sichtbarkeit auch mit 2 Bedingungen einstellen kann?
                            Beispiel:
                            Sichtbar wenn Sonnenuntergang < 20:00 Uhr und Forecast = Sonne
                              @Oli sagte in Projekt WetterView von sigi234:
                              @sigi234
                              Beispiel:
                              Ev. Blockly
                              O sigi234 2 Replies Last reply Reply Quote 0
                              • O
                                @sigi234
                                das verstehe ich jetzt nicht, wie du das meinst
                                  @sigi234
                                  Da kenne ich mich nicht so gut aus (Blockly) , vielleicht kann noch wer helfen. Könnte aber auch mit bindig gehen.
                                    sigi234 Forum Testing Most Active @sigi234 last edited by sigi234
                                    @sigi234 sagte in Projekt WetterView von sigi234:
                                    Widget Standard da kam man nur eine variable Abfragen
                                    Alternative währe ein Objekt zu erstellen was nur true ist wen beide Bedingungen erfüllt sind und das per Script zu füllen
                                    • MathiasJ
                                      MathiasJ last edited by
                                      also, endlich bin ich auch mal dazu gekommen, das Projekt in Angriff zu nehmen.Nun habe ich ein neues Projekt erstellt mit dem namen Wetter.
                                      Nun stellt sich aber wie frage, wie ich den Hauptview in mein produktives Projekt bekomme, wo auch die Einkaufsliste, die Zimmer usw sind.
                                      ganz rechts, das Float bekomme ich nur noch nicht hin.
                                      das liegt aber daran, weil mein rock64 mir erzählen will, dass es am USB-Stick liegt......
                                      Gruß,
                                      Mathias
                                        sigi234 Forum Testing Most Active @MathiasJ last edited by sigi234
                                        @MathiasJ sagte in Projekt WetterView von sigi234:
                                        Ein Ganzes Projekt das geht nicht. 2 mal den Vis Editor aufmachen, also eines mit deinen Wetter Projekt und eines von deinen Prod. Projekt.
                                        Dann die Views von Wetter in das prod. Projekt importieren.
                                        MathiasJ 1 Reply Last reply Reply Quote 0
                                          Das ist Flot,
                                          Setze folgendes davor: Bei Allgemein Quelle:
                                          http://192.168.178.20:8082
                                          IP ist dein Host
                                          Ändere index auf edit, dann kannst du es bearbeiten und deine ID ändern. Speichern , kopieren und in die Quelle einfügen.
                                          • MathiasJ
                                            MathiasJ @sigi234 last edited by MathiasJ
                                            @sigi234
                                            ahhhh ok, danke!
                                            werde ich dann versuchen........
                                            Edit
                                            Ich habe von vorne begonnen und lt Doc die komplette zip-Datei als neues Projekt importiert.
                                            Wenn ich das neue Projekt aufrufe, sehe ich jedoch nur die Demoview.
                                            Muß ich jetzt die Views jetzt einzeln importieren?
                                            Im Dokument steht dazu nichts.
                                            Gruß,
                                            Mathias
                                            wetter wetterview sigi234
                                            60
                                            497
                                            134846
