    4. [Projekt] ioGo # Smarthome to go
      crunchip Forum Testing Most Active @crunchip last edited by
      @crunchip @nis nach langem suchen und keinen Fehler gefunden, hab ich den Adapter neu gestartet, bzw die neue version 0.4.5 drauf.
      Meine drei state´s werden jetzt wieder aktualisiert, sind jedoch aus den Favoriten am Handy wieder verschwunden.
      hast du ne Idee was da noch falsch ist bei mir
      iogo.0	2019-09-13 20:35:58.255	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:58.249	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:58.245	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:58.234	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:48.074	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:48.071	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:48.068	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:48.057	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"71"}
      iogo.0	2019-09-13 20:35:37.851	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:37.849	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:37.847	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:37.828	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:27.650	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:27.647	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:27.642	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:27.627	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:17.410	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:17.408	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:17.404	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:17.392	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:07.209	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:07.206	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:07.200	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:35:07.189	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:57.034	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:57.031	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:57.028	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:57.021	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:46.894	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:46.891	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:46.882	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:46.865	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:36.693	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:36.691	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:36.689	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:36.678	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:26.505	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:26.503	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:26.499	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:26.485	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"70"}
      iogo.0	2019-09-13 20:34:16.325	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:16.318	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:16.316	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:16.304	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:06.141	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:06.139	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:06.133	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:34:06.119	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:55.949	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:55.946	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:55.936	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:55.922	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:45.760	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:45.757	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:45.754	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:45.744	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:35.579	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:35.577	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:35.574	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:35.564	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:28.451	info	Object iogo.0.f4Oce5GiBFM.token created
      iogo.0	2019-09-13 20:33:28.449	info	Object iogo.0.f4Oce5GiBFM.token created
      iogo.0	2019-09-13 20:33:28.448	info	Object iogo.0.f4Oce5GiBFM.token created
      iogo.0	2019-09-13 20:33:28.441	warn	setObject iogo.0.f4Oce5GiBFM.token (type=state) property native missing!
      iogo.0	2019-09-13 20:33:28.422	warn	setObject iogo.0.f4Oce5GiBFM.token (type=state) property native missing!
      iogo.0	2019-09-13 20:33:28.417	warn	setObject iogo.0.f4Oce5GiBFM.token (type=state) property native missing!
      iogo.0	2019-09-13 20:33:28.409	warn	setObject iogo.0.f4Oce5GiBFM.token (type=state) property native missing!
      iogo.0	2019-09-13 20:33:25.397	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:25.394	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:25.389	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:25.379	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:15.211	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:15.208	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:15.205	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:15.195	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:05.626	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:05.624	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:05.621	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      iogo.0	2019-09-13 20:33:05.603	info	state update received: {"ack":false,"id":"iogo.0.f4Oce5GiBFM.akku","lc":0,"q":0,"ts":0,"val":"69"}
      socketio.0	2019-09-13 20:33:05.469	info	==>Connected system.user.admin from ::ffff:192.168.178.111
        e-s last edited by
        @nis
        auf beta12 und 0.4.5 sind alle instances Probleme bei mir weg. Dabei ist zwar die Startseite wieder leer, aber dafür sind die Anzahl von States, instances und Adapter scheinbar alle jetzt richtig, waren vorher alle viel zu viel.
          @nis
          hatte heute Nacht, direkt 0.00Uhr ein mehr oder weniger grosses Problem, so daß mein Iobroker nicht mehr erreichbar war. Konnte nur mit einem Backup das Problem lösen.
          2019-09-13 00:00:00.364 - error: iogo.0 uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
          2019-09-13 00:00:00.364 - error: iogo.0 FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
          at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
          at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19832:16)
          at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20179:27)
          at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20045:29)
          at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20061:41
          at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
          at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20060:13)
          at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20019:25)
          at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19884:31)
          at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20829:45)
          2019-09-13 00:00:00.365 - info: iogo.0 cleaned everything up...
          2019-09-13 00:00:00.365 - info: iogo.0 triggered listener removed
          2019-09-13 00:00:00.369 - info: iogo.0 listener removed
          2019-09-13 00:00:00.375 - info: iogo.0 signed out
          2019-09-13 00:00:00.392 - info: iogo.0 triggered listener removed
          2019-09-13 00:00:00.392 - info: iogo.0 listener removed
          2019-09-13 00:00:00.099 - info: host.IoBroker instance system.adapter.dwd.0 started with pid 24147
          2019-09-13 00:00:00.379 - info: javascript.0 script.js.Visualisierung.Wegezeit_Arbeit_Landstraße: Anzahl Wegepunkte: 28
          2019-09-13 00:00:00.445 - info: javascript.0 script.js.Visualisierung.Wegezeit_Arbeit_Autobahn: Anzahl Wegepunkte: 19
          2019-09-13 00:00:00.284 - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 24155
          2019-09-13 00:00:00.500 - info: sourceanalytix.0 Updated SourceAnalytix configuration for : wiffi-wz.0.root.192_168_178_33.w_counter_1
          2019-09-13 00:00:00.503 - info: sourceanalytix.0 Setting start value Day for device : wiffi-wz.0.root.192_168_178_33.w_counter_2 succeeded with value + 2591.14
          2019-09-13 00:00:00.512 - info: influxdb.0 enabled logging of wiffi-wz.0.root.192_168_178_33.w_counter_1, Alias=false
          2019-09-13 00:00:00.515 - warn: iogo.0 You are not logged in
          2019-09-13 00:00:00.362 - info: host.IoBroker instance system.adapter.ical.0 started with pid 24157
          2019-09-13 00:00:00.494 - info: host.IoBroker instance system.adapter.feiertage.0 started with pid 24169
          2019-09-13 00:00:00.535 - info: iogo.0 terminating
          2019-09-13 00:00:00.544 - info: sourceanalytix.0 Setting start value Day for device : wiffi-wz.0.root.192_168_178_33.w_counter_1 succeeded with value + 112242.41
          2019-09-13 00:00:00.966 - error: Caught by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
          2019-09-13 00:00:02.143 - info: javascript.0 script.js.common.System.Logfiles2: Start new Tail process. File path to current log: [/opt/iobroker/log/iobroker.2019-09-13.log]
          2019-09-13 00:00:00.967 - error: Caught by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
          2019-09-13 00:00:00.967 - error: Caught by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19832:16)
          2019-09-13 00:00:00.967 - error: Caught by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20179:27)
          2019-09-13 00:00:00.967 - error: Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20045:29)
          2019-09-13 00:00:00.967 - error: Caught by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20061:41
          2019-09-13 00:00:00.967 - error: Caught by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20060:13)
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20019:25)
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19884:31)
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20829:45)
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: code: 'invalid-argument',
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: name: 'FirebaseError',
          2019-09-13 00:00:01.012 - error: Caught by controller[0]: toString: [Function] }
          2019-09-13 00:00:01.012 - error: host.IoBroker instance system.adapter.iogo.0 terminated with code 0 (OK)
            e-s @crunchip last edited by
            @crunchip
            Mach mal nen eigenen Thread dafür auf, Aber ich würde auch tippen das deine Festplatte, sd Karte oder was auch immer voll ist.
              crunchip Forum Testing Most Active @e-s last edited by
              @e-s läuft auf einer VM in Proxmox, Diskgröße 15G, IoBroker belegt 6,75G, Arbeitsspeicher in gebrauch 2,5G von 4,5G, also kann da schon mal nichts voll sein
                backup zurückgespielt, Adapter gelöscht und neu installiert, lies sich anschließend fehlerfrei installieren.
                  e-s last edited by
                  @nis
                  Irgendwas passt wieder nicht, nutze 0.4.5 und beta14.
                  Habe einen Adapter installiert und wieder deinstalliert. Anschließend 5 weitere states in Räumen und Funktionen hinzugefügt.
                  Anzahl im log bei Adapterneustart scheint zu passen.
                  Anzahl in der App bleibt unverändert.
                  In Räumen und Funtionen passt die Anzahl, aber wenn ich dann auf den Raum/Funktion selber klicke, dann stehen da nur die alten States drin. Also steht unter Raum/Bad 4 States zugeordnet, aber es ist unter Bad nur ein Funktion vorhanden.
                  Nach häufigen Neustarten vom Adapter und sync der App war auch wieder die Startseite leer.
                    @nis
                    nachdem ich ja zuvor das Problem mit dem angeblich "zuwenig speicher" Problem, den Adapter de/installiert habe, bekomme ich bei einem Neustart des Iobroker´s folgende Meldung
                    host.IoBroker	2019-09-15 15:02:18.068	error	instance system.adapter.iogo.0 terminated with code 0 (OK)
                    Caught	2019-09-15 15:02:18.068	error	by controller[1]: toString: [Function] }
                    Caught	2019-09-15 15:02:18.068	error	by controller[1]: name: 'FirebaseError',
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: code: 'invalid-argument',
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20938:45)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19961:31)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20096:25)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20137:13)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20138:41
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20122:29)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20256:27)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19909:16)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                    Caught	2019-09-15 15:02:18.067	error	by controller[1]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                    Caught	2019-09-15 15:02:18.067	error	by controller[0]: toString: [Function] }
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: name: 'FirebaseError',
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: code: 'invalid-argument',
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20938:45)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19961:31)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20096:25)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20137:13)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20138:41
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20122:29)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20256:27)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19909:16)
                    Caught	2019-09-15 15:02:18.066	error	by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                    Caught	2019-09-15 15:02:18.065	error	by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                    iogo.0	2019-09-15 15:02:17.985	error	uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                    host.IoBroker	2019-09-15 15:03:08.617	error	instance system.adapter.iogo.0 terminated with code 0 (OK)
                    Caught	2019-09-15 15:03:08.617	error	by controller[0]: toString: [Function] }
                    Caught	2019-09-15 15:03:08.617	error	by controller[0]: name: 'FirebaseError',
                    Caught	2019-09-15 15:03:08.617	error	by controller[0]: code: 'invalid-argument',
                    Caught	2019-09-15 15:03:08.617	error	by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20938:45)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19961:31)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20096:25)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20137:13)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20138:41
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20122:29)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20256:27)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19909:16)
                    Caught	2019-09-15 15:03:08.616	error	by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                    Caught	2019-09-15 15:03:08.615	error	by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                    iogo.0	2019-09-15 15:03:08.553	error	uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                      A Former User @crunchip last edited by
                      @crunchip ich konnte deinen Fehler nachstellen, Bugfix kommt asap
                        A Former User last edited by
                        Neuer Version des Adapters v0.4.6 behebt die Fehler "Unsupported field value: undefined ..."
                        Dazu kommt auch eine neue Beta der App v2.0.0-beta15 da auch die Übertragung der Smartphonewerte angepasst wurde.
                        Es werden nun folgende Werte zuverlässig vom Smartphone übertragen:
                        • battery-level
                        • battery-charging
                        • alive (ist die App geöffnet)
                          crunchip Forum Testing Most Active @Guest last edited by
                          @nis bin grad erst dazu gekommen, ein update zu machen, nachdem 0.00 Uhr verstrichen war und die error firebase Meldung auftauchte. Hab nun v0.4.7. Was gibt´s da neues?
                          ? 2 Replies Last reply Reply Quote 0
                            @crunchip 0.4.7 hat nur einen Bugfix
                              @crunchip Sind die Fehler "unsupported field value... " bei dir behoben?
                                @nis ein neu laden, bzw Adapter stoppen und starten verursacht schon mal keinen Fehler mehr
                                  Neue Version des Adapters ist online:
                                  • Es wurde der Traffic reduziert für die States der Hosts und Instanzen
                                    ChrisXY last edited by ChrisXY
                                    Gibt es auch Widgets?
                                    Bzw. gehen auch https Urls für den "web" zugriff welche kein gültiges Zertifikat haben ? Komme nicht drauf von Extern.
                                      A Former User @ChrisXY last edited by
                                      @ChrisXY sagte in [Projekt] ioGo # Native Android App:
                                      Nein
                                      Nein, https geht bei web nicht
                                        ChrisXY @Guest last edited by
                                        @nis Okay Danke für die Info. Ist das den in Zukunft mal geplant ? Vor allem mit den Widget ist Intressant
                                          @ChrisXY Erstmal nicht. Mach gerne einen detaillierten Feature request in GitHub auf. Bitte gut beschreiben den Sinn und Zweck und wie das Layout und Verhalten sein soll...
                                            Es sind wieder neue Version unterwegs.
                                            Adapterversion: 0.4.9
                                            Appversion: 2.0.0-beta17
                                            Anpassung bezieht sich hauptsächlich auf die Reduzierung von Netzwerktraffic.
                                            Dazu wurde eine Checksum für jedes Objekt errechnet als Workaround für die nicht verlässliche Angabe von obj.ts (mehr dazu in diesem Thread: https://forum.iobroker.net/topic/25174/obj-ts-wird-nicht-erneuert-bei-änderungen)
                                            Wenn die Massnahme funktioniert und sich der Traffic deutlich reduziert, wird die Version 2.0.0 demnächst beta Status verlassen produktiv gehen.
                                            Hat Jemand mit der Beta noch Probleme, die auf jeden Fall gelöst werden sollen vorher?!?
                                            crunchip E 2 Replies Last reply Reply Quote 0
                                            android app iogo
                                            61
                                            1140
                                            359791
