    4. Projekt WetterView von sigi234
      sigi234 Forum Testing Most Active @Seadon last edited by sigi234
      @Seadon
      Stell das Widget rein das ich alle DP sehen kann.
        Seadon @sigi234 last edited by
        @sigi234
        [{"tpl":"tplValueStringRaw","data":{"oid":"javascript.0.UWZ.UWZDE10115.warning.0.HTMLShort","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":">=","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Wetter/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Wetter/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Wetter/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"javascript.0.UWZ.UWZAT00810.warning.0.uwzLevel","name":"warning.0.uwzLevel","comment":"UWZ","filterkey":"Warnung"},"style":{"left":"830px","top":"840px","width":"549px","height":"87px","z-index":"3","color":"#000000","text-align":"center","font-size":"small","background":"","background-color":""},"widgetSet":"basic"}]
          @Seadon
          Du musst ALLE DP an deine anpassen!
          Beispiel:
          Da steht noch mein DP drinnen.
            @sigi234 Das war es, Danke .. wieder etwas gelernt ... (Sichtbarkeit) ^^
              @Seadon sagte in Projekt WetterView von sigi234:
              Bitte benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
              • O
                Oli last edited by Oli
                ich habe mir für jeden Tag eine Detailansicht erstellt und mir dafür Bilder für die Nacht gebastelt.
                Kann ich mir, wenn im Forecast um 2:00 Uhr "Sonne" steht, einen Alternativtext anzeigen lassen?
                Sieht doof aus, wenn ein Mond abgebildet ist und darüber steht Sonne 😁
                Gruß Oliver
                  sigi234 Forum Testing Most Active @Oli last edited by sigi234
                  @Oli
                  Ja, geht mit Sichtbarkeit im Widget. Einfach ein 2.Widget darüber legen. Also das Widget wo Sonne steht kopieren.
                  O 2 Replies Last reply Reply Quote 0
                  • O
                    Oli @sigi234 last edited by
                    @sigi234
                    Danke, manchmal sieht man den Wald vor lauter Bäumen nicht.
                    • O
                      @sigi234
                      weist du zufällig, ob ich eine Sichtbarkeit auch mit 2 Bedingungen einstellen kann?
                      Beispiel:
                      Sichtbar wenn Sonnenuntergang < 20:00 Uhr und Forecast = Sonne
                        @Oli sagte in Projekt WetterView von sigi234:
                        @sigi234
                        Beispiel:
                        Ev. Blockly
                        O sigi234 2 Replies Last reply Reply Quote 0
                        • O
                          @sigi234
                          das verstehe ich jetzt nicht, wie du das meinst
                            @sigi234
                            Da kenne ich mich nicht so gut aus (Blockly) , vielleicht kann noch wer helfen. Könnte aber auch mit bindig gehen.
                              sigi234 Forum Testing Most Active @sigi234 last edited by sigi234
                              @sigi234 sagte in Projekt WetterView von sigi234:
                              Widget Standard da kam man nur eine variable Abfragen
                              Alternative währe ein Objekt zu erstellen was nur true ist wen beide Bedingungen erfüllt sind und das per Script zu füllen
                              • MathiasJ
                                MathiasJ last edited by
                                also, endlich bin ich auch mal dazu gekommen, das Projekt in Angriff zu nehmen.Nun habe ich ein neues Projekt erstellt mit dem namen Wetter.
                                Nun stellt sich aber wie frage, wie ich den Hauptview in mein produktives Projekt bekomme, wo auch die Einkaufsliste, die Zimmer usw sind.
                                ganz rechts, das Float bekomme ich nur noch nicht hin.
                                das liegt aber daran, weil mein rock64 mir erzählen will, dass es am USB-Stick liegt......
                                Gruß,
                                Mathias
                                  sigi234 Forum Testing Most Active @MathiasJ last edited by sigi234
                                  @MathiasJ sagte in Projekt WetterView von sigi234:
                                  Ein Ganzes Projekt das geht nicht. 2 mal den Vis Editor aufmachen, also eines mit deinen Wetter Projekt und eines von deinen Prod. Projekt.
                                  Dann die Views von Wetter in das prod. Projekt importieren.
                                  MathiasJ 1 Reply Last reply Reply Quote 0
                                    Das ist Flot,
                                    Setze folgendes davor: Bei Allgemein Quelle:
                                    http://192.168.178.20:8082
                                    IP ist dein Host
                                    Ändere index auf edit, dann kannst du es bearbeiten und deine ID ändern. Speichern , kopieren und in die Quelle einfügen.
                                    • MathiasJ
                                      MathiasJ @sigi234 last edited by MathiasJ
                                      @sigi234
                                      ahhhh ok, danke!
                                      werde ich dann versuchen........
                                      Edit
                                      Ich habe von vorne begonnen und lt Doc die komplette zip-Datei als neues Projekt importiert.
                                      Wenn ich das neue Projekt aufrufe, sehe ich jedoch nur die Demoview.
                                      Muß ich jetzt die Views jetzt einzeln importieren?
                                      Im Dokument steht dazu nichts.
                                      Gruß,
                                      Mathias
                                      • MathiasJ
                                        @sigi234
                                        Wo soll ich die Symbole eingeben?
                                        Ich sehe da nichts.....
                                        Gruß,
                                        Mathias
                                          Nein, entpacken und dort ist dam das Projekt drinnen (als Zip)
                                            @sigi234
                                            Gruß,
                                            Mathias
                                            Sollten zu sehen sein.
                                            wetter wetterview sigi234
                                            60
                                            497
                                            134846
