    4. [Projekt] ioGo # Smarthome to go
      e-s last edited by
      @nis
      auf beta12 und 0.4.5 sind alle instances Probleme bei mir weg. Dabei ist zwar die Startseite wieder leer, aber dafür sind die Anzahl von States, instances und Adapter scheinbar alle jetzt richtig, waren vorher alle viel zu viel.
        @nis
        hatte heute Nacht, direkt 0.00Uhr ein mehr oder weniger grosses Problem, so daß mein Iobroker nicht mehr erreichbar war. Konnte nur mit einem Backup das Problem lösen.
        2019-09-13 00:00:00.364 - error: iogo.0 uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
        2019-09-13 00:00:00.364 - error: iogo.0 FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
        at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
        at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19832:16)
        at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20179:27)
        at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20045:29)
        at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20061:41
        at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
        at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20060:13)
        at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20019:25)
        at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19884:31)
        at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20829:45)
        2019-09-13 00:00:00.365 - info: iogo.0 cleaned everything up...
        2019-09-13 00:00:00.365 - info: iogo.0 triggered listener removed
        2019-09-13 00:00:00.369 - info: iogo.0 listener removed
        2019-09-13 00:00:00.375 - info: iogo.0 signed out
        2019-09-13 00:00:00.392 - info: iogo.0 triggered listener removed
        2019-09-13 00:00:00.392 - info: iogo.0 listener removed
        2019-09-13 00:00:00.099 - info: host.IoBroker instance system.adapter.dwd.0 started with pid 24147
        2019-09-13 00:00:00.379 - info: javascript.0 script.js.Visualisierung.Wegezeit_Arbeit_Landstraße: Anzahl Wegepunkte: 28
        2019-09-13 00:00:00.445 - info: javascript.0 script.js.Visualisierung.Wegezeit_Arbeit_Autobahn: Anzahl Wegepunkte: 19
        2019-09-13 00:00:00.284 - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 24155
        2019-09-13 00:00:00.500 - info: sourceanalytix.0 Updated SourceAnalytix configuration for : wiffi-wz.0.root.192_168_178_33.w_counter_1
        2019-09-13 00:00:00.503 - info: sourceanalytix.0 Setting start value Day for device : wiffi-wz.0.root.192_168_178_33.w_counter_2 succeeded with value + 2591.14
        2019-09-13 00:00:00.512 - info: influxdb.0 enabled logging of wiffi-wz.0.root.192_168_178_33.w_counter_1, Alias=false
        2019-09-13 00:00:00.515 - warn: iogo.0 You are not logged in
        2019-09-13 00:00:00.362 - info: host.IoBroker instance system.adapter.ical.0 started with pid 24157
        2019-09-13 00:00:00.494 - info: host.IoBroker instance system.adapter.feiertage.0 started with pid 24169
        2019-09-13 00:00:00.535 - info: iogo.0 terminating
        2019-09-13 00:00:00.544 - info: sourceanalytix.0 Setting start value Day for device : wiffi-wz.0.root.192_168_178_33.w_counter_1 succeeded with value + 112242.41
        2019-09-13 00:00:00.966 - error: Caught by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
        2019-09-13 00:00:02.143 - info: javascript.0 script.js.common.System.Logfiles2: Start new Tail process. File path to current log: [/opt/iobroker/log/iobroker.2019-09-13.log]
        2019-09-13 00:00:00.967 - error: Caught by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
        2019-09-13 00:00:00.967 - error: Caught by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19832:16)
        2019-09-13 00:00:00.967 - error: Caught by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20179:27)
        2019-09-13 00:00:00.967 - error: Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20045:29)
        2019-09-13 00:00:00.967 - error: Caught by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20061:41
        2019-09-13 00:00:00.967 - error: Caught by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20060:13)
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20019:25)
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19884:31)
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20829:45)
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: code: 'invalid-argument',
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: name: 'FirebaseError',
        2019-09-13 00:00:01.012 - error: Caught by controller[0]: toString: [Function] }
        2019-09-13 00:00:01.012 - error: host.IoBroker instance system.adapter.iogo.0 terminated with code 0 (OK)
          e-s @crunchip last edited by
          @crunchip
          Mach mal nen eigenen Thread dafür auf, Aber ich würde auch tippen das deine Festplatte, sd Karte oder was auch immer voll ist.
            crunchip Forum Testing Most Active @e-s last edited by
            @e-s läuft auf einer VM in Proxmox, Diskgröße 15G, IoBroker belegt 6,75G, Arbeitsspeicher in gebrauch 2,5G von 4,5G, also kann da schon mal nichts voll sein
              backup zurückgespielt, Adapter gelöscht und neu installiert, lies sich anschließend fehlerfrei installieren.
                e-s last edited by
                @nis
                Irgendwas passt wieder nicht, nutze 0.4.5 und beta14.
                Habe einen Adapter installiert und wieder deinstalliert. Anschließend 5 weitere states in Räumen und Funktionen hinzugefügt.
                Anzahl im log bei Adapterneustart scheint zu passen.
                Anzahl in der App bleibt unverändert.
                In Räumen und Funtionen passt die Anzahl, aber wenn ich dann auf den Raum/Funktion selber klicke, dann stehen da nur die alten States drin. Also steht unter Raum/Bad 4 States zugeordnet, aber es ist unter Bad nur ein Funktion vorhanden.
                Nach häufigen Neustarten vom Adapter und sync der App war auch wieder die Startseite leer.
                  @nis
                  nachdem ich ja zuvor das Problem mit dem angeblich "zuwenig speicher" Problem, den Adapter de/installiert habe, bekomme ich bei einem Neustart des Iobroker´s folgende Meldung
                  host.IoBroker	2019-09-15 15:02:18.068	error	instance system.adapter.iogo.0 terminated with code 0 (OK)
                  Caught	2019-09-15 15:02:18.068	error	by controller[1]: toString: [Function] }
                  Caught	2019-09-15 15:02:18.068	error	by controller[1]: name: 'FirebaseError',
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: code: 'invalid-argument',
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20938:45)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19961:31)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20096:25)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20137:13)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20138:41
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20122:29)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20256:27)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19909:16)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                  Caught	2019-09-15 15:02:18.067	error	by controller[1]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                  Caught	2019-09-15 15:02:18.067	error	by controller[0]: toString: [Function] }
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: name: 'FirebaseError',
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: code: 'invalid-argument',
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20938:45)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19961:31)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20096:25)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20137:13)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20138:41
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20122:29)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20256:27)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19909:16)
                  Caught	2019-09-15 15:02:18.066	error	by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                  Caught	2019-09-15 15:02:18.065	error	by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                  iogo.0	2019-09-15 15:02:17.985	error	uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                  host.IoBroker	2019-09-15 15:03:08.617	error	instance system.adapter.iogo.0 terminated with code 0 (OK)
                  Caught	2019-09-15 15:03:08.617	error	by controller[0]: toString: [Function] }
                  Caught	2019-09-15 15:03:08.617	error	by controller[0]: name: 'FirebaseError',
                  Caught	2019-09-15 15:03:08.617	error	by controller[0]: code: 'invalid-argument',
                  Caught	2019-09-15 15:03:08.617	error	by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20938:45)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19961:31)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20096:25)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20137:13)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20138:41
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20122:29)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20256:27)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19909:16)
                  Caught	2019-09-15 15:03:08.616	error	by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
                  Caught	2019-09-15 15:03:08.615	error	by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                  iogo.0	2019-09-15 15:03:08.553	error	uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
                    A Former User @crunchip last edited by
                    @crunchip ich konnte deinen Fehler nachstellen, Bugfix kommt asap
                      A Former User last edited by
                      Neuer Version des Adapters v0.4.6 behebt die Fehler "Unsupported field value: undefined ..."
                      Dazu kommt auch eine neue Beta der App v2.0.0-beta15 da auch die Übertragung der Smartphonewerte angepasst wurde.
                      Es werden nun folgende Werte zuverlässig vom Smartphone übertragen:
                      • battery-level
                      • battery-charging
                      • alive (ist die App geöffnet)
                        crunchip Forum Testing Most Active @Guest last edited by
                        @nis bin grad erst dazu gekommen, ein update zu machen, nachdem 0.00 Uhr verstrichen war und die error firebase Meldung auftauchte. Hab nun v0.4.7. Was gibt´s da neues?
                        ? 2 Replies Last reply Reply Quote 0
                          @crunchip 0.4.7 hat nur einen Bugfix
                            @crunchip Sind die Fehler "unsupported field value... " bei dir behoben?
                              @nis ein neu laden, bzw Adapter stoppen und starten verursacht schon mal keinen Fehler mehr
                                Neue Version des Adapters ist online:
                                • Es wurde der Traffic reduziert für die States der Hosts und Instanzen
                                  ChrisXY last edited by ChrisXY
                                  Gibt es auch Widgets?
                                  Bzw. gehen auch https Urls für den "web" zugriff welche kein gültiges Zertifikat haben ? Komme nicht drauf von Extern.
                                    A Former User @ChrisXY last edited by
                                    @ChrisXY sagte in [Projekt] ioGo # Native Android App:
                                    Nein
                                    Nein, https geht bei web nicht
                                      ChrisXY @Guest last edited by
                                      @nis Okay Danke für die Info. Ist das den in Zukunft mal geplant ? Vor allem mit den Widget ist Intressant
                                        @ChrisXY Erstmal nicht. Mach gerne einen detaillierten Feature request in GitHub auf. Bitte gut beschreiben den Sinn und Zweck und wie das Layout und Verhalten sein soll...
                                          Es sind wieder neue Version unterwegs.
                                          Adapterversion: 0.4.9
                                          Appversion: 2.0.0-beta17
                                          Anpassung bezieht sich hauptsächlich auf die Reduzierung von Netzwerktraffic.
                                          Dazu wurde eine Checksum für jedes Objekt errechnet als Workaround für die nicht verlässliche Angabe von obj.ts (mehr dazu in diesem Thread: https://forum.iobroker.net/topic/25174/obj-ts-wird-nicht-erneuert-bei-änderungen)
                                          Wenn die Massnahme funktioniert und sich der Traffic deutlich reduziert, wird die Version 2.0.0 demnächst beta Status verlassen produktiv gehen.
                                          Hat Jemand mit der Beta noch Probleme, die auf jeden Fall gelöst werden sollen vorher?!?
                                          crunchip E 2 Replies Last reply Reply Quote 0
                                            @nis sagte in [Projekt] ioGo # Native Android App:
                                            scheint zu laufen, bisher nichts negatives aufgefallen
                                            android app iogo
                                            61
                                            1140
                                            327628
