    4. Nach Update ADMIN auf 3.6-5 Probleme mit Alexa.20
    SOLVED Nach Update ADMIN auf 3.6-5 Probleme mit Alexa.20
    • sissiwup
      sissiwup last edited by
      nach Update vom Admin-Adapter kommt folgende Fehlermeldung:
      host.zotac	2019-09-18 22:42:56.772	info	Restart adapter system.adapter.alexa2.0 because enabled
      host.zotac	2019-09-18 22:42:56.772	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:63:19)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at endReadableNT (_stream_readable.js:1125:12)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at IncomingMessage.emit (events.js:194:15)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at alexa.querySmarthomeDevices (/opt/iobroker/node_modules/iobroker.alexa2/main.js:607:13)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobroker.alexa2/main.js:792:46)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[2]: 2019-09-18 22:42:56.748 - alexa2.0 TypeError: native.valueMap.indexOf is not a function
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[1]: 2019-09-18 22:42:56.748 - alexa2.0 uncaught exception: native.valueMap.indexOf is not a function
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1125:12)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at IncomingMessage.emit (events.js:194:15)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at alexa.querySmarthomeDevices (/opt/iobroker/node_modules/iobroker.alexa2/main.js:607:13)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobroker.alexa2/main.js:792:46)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37)
      host.zotac	2019-09-18 22:42:56.772	error	Caught by controller[0]: TypeError: native.valueMap.indexOf is not a function
      alexa2.0	2019-09-18 22:42:56.753	error	TypeError: native.valueMap.indexOf is not a function at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37) at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobr
      alexa2.0	2019-09-18 22:42:56.753	error	uncaught exception: native.valueMap.indexOf is not a function
      alexa2.0	2019-09-18 22:42:56.753	warn	Exception: TypeError: native.valueMap.indexOf is not a function
      alexa2.0	2019-09-18 22:42:46.802	info	Alexa-Push-Connection established. Disable Polling
      alexa2.0	2019-09-18 22:42:41.231	info	starting. Version 2.6.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v10.15.3
      sissiwup 1 Reply Last reply Reply Quote 0
      • sissiwup
        sissiwup @sissiwup last edited by
        @sissiwup
        Hab den fix von dklinger (Thx) eingesetzt. Jetzt läuft es wieder.
        GIT
        Damit geht es wieder. Hoffe das ist in nächsten Alexa-Adapter enthalten.
        Anzupassen in:
        • sissiwup
          @sissiwup
          GIT
          Anzupassen in:
          • Negalein
            Negalein Global Moderator @sissiwup last edited by
            @sissiwup sagte in Nach Update ADMIN auf 3.6-5 Probleme mit Alexa.20:
            @sissiwup
            Perfekt!
            Wenn ein Thema gelöst wurde bitte den Beitrag der die Lösung beinhaltet als gelöst markieren.
            -> 3 Punkte Menü rechts unten am Beitrag -> Mark this post as the correct answer
              Springreiter last edited by
              Bei mir weiterhin die selbe Fehlermeldung-trotz Aänderung
                Springreiter @Springreiter last edited by Negalein
                2019-11-05 11:32:37.441 - error: host.ioBroker-RasPi Caught by controller[0]: TypeError: native.valueMap.indexOf is not a function
                2019-11-05 11:32:37.443 - error: host.ioBroker-RasPi Caught by controller[0]: at handleObject (/opt/iobroker/node_modules/iobroker.alexa2/main.js:748:37)
                2019-11-05 11:32:37.443 - error: host.ioBroker-RasPi Caught by controller[0]: at updateSmarthomeDeviceStates (/opt/iobroker/node_modules/iobroker.alexa2/main.js:792:46)
                2019-11-05 11:32:37.443 - error: host.ioBroker-RasPi Caught by controller[0]: at alexa.querySmarthomeDevices (/opt/iobroker/node_modules/iobroker.alexa2/main.js:607:13)
                2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:752:58)
                2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at emitNone (events.js:111:20)
                2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at IncomingMessage.emit (events.js:208:7)
                2019-11-05 11:32:37.444 - error: host.ioBroker-RasPi Caught by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
                2019-11-05 11:32:37.445 - error: host.ioBroker-RasPi Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
                2019-11-05 11:32:37.445 - error: host.ioBroker-RasPi Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
                  Nehme alles zurück- habe es hinbekommen - Danke
                  adapater admin fehler
