    4. Adapter "iobroker.nut" - UPS Daten im iobroker
    • wendy2702
      wendy2702 last edited by
      Mal von dem einen link die Befehle abgefragt:
       cat /etc/nut/nut.conf
      MODE=netserver
       cat /etc/nut/ups.conf
      [ups]
      driver = usbhid-ups
      port = auto
      vendorid = 051d
      upsdrvctl start
      Network UPS Tools - UPS driver controller 2.6.4
      Network UPS Tools - Generic HID driver 0.37 (2.6.4)
      USB communication driver 0.32
      Using subdriver: APC HID 0.95
       cat /etc/nut/upsd.conf
      MAXAGE 15
      MAXCONN 1024
      LISTEN 127.0.0.1 3493
      Hier bei ist der einzige fehler:
      upsd
      Network UPS Tools upsd 2.6.4
      fopen /var/run/nut/upsd.pid: No such file or directory
      listening on 127.0.0.1 port 3493
      Connected to UPS [ups]: usbhid-ups-ups
       upsc ups@localhost ups.status
      OL
      root@openmediavault /opt/iobroker/node_modules/iobroker.nut/test > upsc ups@localhost
      battery.charge: 100
      battery.charge.low: 10
      battery.charge.warning: 50
      battery.date: 2001/09/25
      battery.mfr.date: 2013/11/18
      battery.runtime: 12810
      battery.runtime.low: 120
      battery.type: PbAc
      battery.voltage: 27.1
      battery.voltage.nominal: 24.0
      device.mfr: American Power Conversion
      device.model: Back-UPS RS 900G
      device.serial: 3B1329X15638
      device.type: ups
      driver.name: usbhid-ups
      driver.parameter.pollfreq: 30
      driver.parameter.pollinterval: 2
      driver.parameter.port: auto
      driver.parameter.vendorid: 051d
      driver.version: 2.6.4
      driver.version.data: APC HID 0.95
      driver.version.internal: 0.37
      input.sensitivity: medium
      input.transfer.high: 294
      input.transfer.low: 176
      input.voltage: 230.0
      input.voltage.nominal: 230
      ups.beeper.status: enabled
      ups.delay.shutdown: 20
      ups.firmware: 879.L4 .I
      ups.firmware.aux: L4
      ups.load: 5
      ups.mfr: American Power Conversion
      ups.mfr.date: 2013/07/19
      ups.model: Back-UPS RS 900G
      ups.productid: 0002
      ups.realpower.nominal: 540
      ups.serial: 3B1329X15638
      ups.status: OL
      ups.test.result: No test initiated
      ups.timer.reboot: 0
      ups.timer.shutdown: -1
      ups.vendorid: 051d
      gerade einen letzten Versuch gestartet.
      Mir war nicht bewusst das ich scheinbar:
       upsdrvctl start
      root@openmediavault /var/run/nut > upsd
      /var/run/nut is world readable
      selber starten muss.
      Ist das so richtig oder sollte das nicht eigentlich der Adapter erledigen?
      Wenn ich nach manuellem start den Adapter starte sieht es so im log aus:
      nut.0	2017-01-10 23:46:57.134	info	All Nut values set
      nut.0	2017-01-10 23:46:57.122	info	Start NUT update
      nut.0	2017-01-10 23:46:57.108	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.nut, node: v4.7.0
        apollon77 last edited by
        Hey, den UPS/NUT Prozess musst Du starten. Der Adapter verbindet sich nur da hin und liesst die Daten. Der Adapter kann ja auch den UPS/NUT-Prozess gar nicht starten weil er ja auch nicht lokal laufen kann …
        Aber jetzt scheint es ja zu tun, oder ?!
        • wendy2702
          Ja. So funktioniert es.
          Muss das jetzt später noch restart resistent machen.
          Jetzt aber schlafen.
          Gute Nacht und danke für deine Hilfe.
          • wendy2702
            Muss nochmal kurz fragen.
            Habe irgendwie auf den beiden Seiten nichts gefunden was ich machen kann/muss um dafür zu sorgen das die Prozesse nach einem restart von alleine starten.
            Ist das noch etwas notwendig oder starten die von alleine?
            Thx
              versuchs doch mal 🙂
              ansonmsten musst du die services aktivieren … je nach System ist das etwas wie
              systemctl enable nut-server.service
              oder
              update-rc.d DIENSTNAME defaults
              • wendy2702
                Versuchen…
                bin nicht zu Hause... zu Risiko reich wenn irgendetwas danach nicht mehr läuft 😛
                  darkbrain85 last edited by
                  Hi Apollon!
                  Wäre es dir möglich noch einen "Connected" Objekt in den Nut Adapter einzubauen?
                  Viele andere Pakete haben ja sowas wie "mihome-vacuum.1.info.connection".
                  Das wäre sehr hilfreich für VIS, da ich dann sofort sehe wenn keine Verbindung steht. Die Objekte bleiben ja trotzdem gefüllt, was eventuell zu falschen Annahmen führen könnte…
                  Michèl
                    Naja „connected“ ist halt nicht korrekt in dem Fall weil ja in den definierten Abständen „nur“ abgefragt wird. Und status.last_notify wird auf ERROR gesetzt wenn nicht abgefragt werden kann. Damit bekommst du es raus.
                      Hallo apollon77,
                      Danke für den Adapter.
                      Ich habe jetzt auch meine ersten APC Back UPS ES 700G.
                      Dieser hängt an einer Syno per UPS.
                      Installation lief nahezu einwandfrei, ich war nur zu doof zu erkennen, dass der ioBroker-Server dort als remote Syno eingegeben werden musste.
                      Jetzt habe ich hunderte von Daten.
                      Bevor die Verbindung stand, war als einziges das Unterverzeichnis Status verfügbar.
                      Mit diesem scheint etwas nicht zu stimmen.
                      da wird u.a. sowohl bei charge als auch bei discharge ein true angezeigt.
                      Weiterhin würde ich gerne den Beeper disablen. Aber alle Beeper-Buttons haben anscheinend keine function, der Beeper-Status unter ups bleibt auf enabled und so ist es auch.
                      Rainer
                        @Homoran:
                        Jetzt habe ich hunderte von Daten. `
                        @Homoran:
                        Weiterhin würde ich gerne den Beeper disablen. Aber alle Beeper-Buttons haben anscheinend keine function, der Beeper-Status unter ups bleibt auf enabled und so ist es auch. `
                        Schick mal den aufgeklappten Objektbaum als Screenshot. Kann mir gerade nicht vorstellen was du meinst
                          @apollon77:
                          war metaphorisch gemeint 😉
                          @apollon77:
                          Schick mal den aufgeklappten Objektbaum als Screenshot. Kann mir gerade nicht vorstellen was du meinst `
                          Gerne:
                          Rainer
                            zu den Status:
                            Die einzelnen Werte werden aus dem berichteten "ups.status" geparst. Dein Screenshot zeigt nicht was da drin steht … Aktuell stet da bestimmt CHRG. Und Du hast nen Bug gefunden :-))
                            1.1.2 auf Github hat den Fix.
                            Commands: Kann ich Dir nicht sagen. Keine Ahnung ob die Synology die Kommandos erlaubt! Wenn man nut selbst auf Linux aufsetzt dann muss man Kommandos explizit freischalten in der nut Konfig. Daher tippe ich das die Synology die Kommandos nicht durchlässt.
                            Daher wäre es nur möglich das zu machen wenn Du die USV direkt an einen Linux Rechner anschliesst, dort nut konfigurierst und Kommandos erlaubst.
                              @apollon77:
                              Die einzelnen Werte werden aus dem berichteten "ups.status" geparst `
                              ok, muss ich aber nicht verstehen, warum es dann noch diese einzelnen Punkte gibt?
                              und ja, im ups-Status stand discharge und steht jetzt wieder charge.
                              @apollon77:
                              Daher wäre es nur möglich das zu machen wenn Du die USV direkt an einen Linux Rechner anschliesst, dort nut konfigurierst und Kommandos erlaubst. `
                              jetzt hast du mich wieder kalt erwischt.
                              wenn ich da einen Raspi o.ä hinstelle und dort iobroker mit einem nut Adapter installiere, würde ich noch zusätzlich einen nut server benötigen?
                              Wenn ja woher bekomme ich den?
                              Rainer
                              • wendy2702
                                Hi Rainer,
                                Das mit dem NUT Server hatte ich auch.
                                Schau mal eine Seite vorher, vielleicht hilft es dir.
                                Mirko
                                  @Homoran:
                                  @apollon77:
                                  Die einzelnen Werte werden aus dem berichteten "ups.status" geparst ok, muss ich aber nicht verstehen, warum es dann noch diese einzelnen Punkte gibt?
                                  Weil das andere ein "kryptischer text" ist wo auch mehrere der Status drin sein können mit Leerzeichen getrennt, also sowas wie "OL CHRG FSD". Wüstest Du was das heisst? :-))
                                  Daher nimmt der Adapter dir das netterweise auseinander sodass Du auf die einzelnen Stati trigger setzen kannst und nicht jeder diesen String parsen muss. Gesamte Liste: https://github.com/Apollon77/ioBroker.n … ut.js#L326
                                  @Homoran:
                                  @apollon77:
                                  Wenn ja woher bekomme ich den? `
                                  Siehe Post von wendy2702 … am Ende "apt-get install nut" 🙂
                                  https://wiki.ubuntuusers.de/USV/NUT/
                                  Am Ende kannst Du mit einem "nut client" auf deinem Host auch einstellen wie der z.B. automatisch runterfahren soll wenn der Strom weg ist und all sowas. Und mit einem "nut server" kannst Du die Werte abfragen (wie bei der Syno), aber ggf die Kommandos auch aktivieren ...
                                  Am Ende ist auf der Syno nichts anderes drauf als ein Nut-client/server 🙂 Nur die Konfiguration ist halt durch die Syno-Oberfläche begrenzt oder du gehst per SSH hin und tust zusätzlich Dinge.
                                  • wendy2702
                                    @apollon77:
                                    1.1.2 auf Github hat den Fix. `
                                    Moin Ingo,
                                    wollte mir gerade mal das Update ansehen und dabei ist mir im Admin nach drücken des "?" folgendes aufgefallen–>
                                    Hier gibt es keine Info und oben rechts einen mini Scrollbalken:
                                    Hier fehlen einige Versionen:
                                    Ist das ein Admin 3.3.5 Fehler oder ein Problem von deinem Adapter?
                                    Mirko
                                      Admin 🙂 Mein Adapter hat ganz andere Changelog … Da ist irgendwas ganz falsch
                                      • wendy2702
                                        Sieht das denn nur bei mir so aus oder hat das sonst noch wer?
                                        • eric2905
                                          eric2905 last edited by
                                          Ist bei mir (Safari auf Mac) auch so.
                                          Gruß,
                                          Eric
                                          Von unterwegs getippert
                                          • wendy2702
                                            Dann mache ich ein GitHub Issue auf.
                                            31.7k
                                            79.8k
                                            83
                                            14868
