    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. MegaD 328
    MegaD 328
      MSapogov last edited by
      Вроде нашел причину…
      Как только в драйвере присутствует настройка Р14 то Р13 портится!!!
      Вот логи...
      megad-0	2015-09-18 09:49:01	info	sendTo "writeConfig" to system.adapter.admin.0 from system.adapter.megad.0: {"error":[]}
      megad-0	2015-09-18 09:49:00	info	Write config for device: http://192.168.11.206/sec/?cf=1&sip=192.168.11.3&sct=%2F0%2F
      megad-0	2015-09-18 09:48:58	info	Write config for port 15: http://192.168.11.206/sec/?pn=15&pty=2&m=0&misc=0&ecmd=ð=
      megad-0	2015-09-18 09:48:57	info	Write config for port 14: http://192.168.11.206/sec/?pn=14&pty=2&m=0&misc=0&ecmd=ð=
      megad-0	2015-09-18 09:48:56	info	Write config for port 13: http://192.168.11.206/sec/?pn=13&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:48:55	info	Write config for port 12: http://192.168.11.206/sec/?pn=12&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:48:54	info	Write config for port 11: http://192.168.11.206/sec/?pn=11&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:48:53	info	Write config for port 10: http://192.168.11.206/sec/?pn=10&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:48:52	info	Write config for port 9: http://192.168.11.206/sec/?pn=9&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:48:51	info	Write config for port 8: http://192.168.11.206/sec/?pn=8&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:48:50	info	Write config for port 7: http://192.168.11.206/sec/?pn=7&pty=0&m=0&ecmd=ð=
      megad-0	2015-09-18 09:48:49	info	Write config for port 6: http://192.168.11.206/sec/?pn=6&pty=0&m=0&ecmd=ð=
      megad-0	2015-09-18 09:48:48	info	Write config for port 5: http://192.168.11.206/sec/?pn=5&pty=0&m=0&ecmd=ð=
      megad-0	2015-09-18 09:48:46	info	Write config for port 4: http://192.168.11.206/sec/?pn=4&pty=0&m=0&ecmd=10%3A2ð=
      megad-0	2015-09-18 09:48:45	info	Write config for port 3: http://192.168.11.206/sec/?pn=3&pty=0&m=0&ecmd=9%3A3%3Bp50%3B9%3A0ð=
      megad-0	2015-09-18 09:48:44	info	Write config for port 2: http://192.168.11.206/sec/?pn=2&pty=0&m=1&ecmd=8%3A2%3Bp600%3B8%3A0ð=
      megad-0	2015-09-18 09:48:43	info	Write config for port 1: http://192.168.11.206/sec/?pn=1&pty=3&d=2&m=1&misc=undefined&ecmd=ð=
      Р13 после этого испорчен…
      Затем в драйвере выключаю порт Р14
      megad-0	2015-09-18 09:51:10	info	sendTo "writeConfig" to system.adapter.admin.0 from system.adapter.megad.0: {"error":[]}
      megad-0	2015-09-18 09:51:10	info	Write config for device: http://192.168.11.206/sec/?cf=1&sip=192.168.11.3&sct=%2F0%2F
      megad-0	2015-09-18 09:51:07	info	Write config for port 15: http://192.168.11.206/sec/?pn=15&pty=2&m=0&misc=0&ecmd=ð=
      megad-0	2015-09-18 09:51:06	info	Write config for port 14: http://192.168.11.206/sec/?pn=14&pty=255
      megad-0	2015-09-18 09:51:05	info	Write config for port 13: http://192.168.11.206/sec/?pn=13&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:51:04	info	Write config for port 12: http://192.168.11.206/sec/?pn=12&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:51:03	info	Write config for port 11: http://192.168.11.206/sec/?pn=11&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:51:02	info	Write config for port 10: http://192.168.11.206/sec/?pn=10&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:51:01	info	Write config for port 9: http://192.168.11.206/sec/?pn=9&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:51:00	info	Write config for port 8: http://192.168.11.206/sec/?pn=8&pty=1&m=0&d=0&pwm=0
      megad-0	2015-09-18 09:50:59	info	Write config for port 7: http://192.168.11.206/sec/?pn=7&pty=0&m=0&ecmd=ð=
      megad-0	2015-09-18 09:50:58	info	Write config for port 6: http://192.168.11.206/sec/?pn=6&pty=0&m=0&ecmd=ð=
      megad-0	2015-09-18 09:50:57	info	Write config for port 5: http://192.168.11.206/sec/?pn=5&pty=0&m=0&ecmd=ð=
      megad-0	2015-09-18 09:50:56	info	Write config for port 4: http://192.168.11.206/sec/?pn=4&pty=0&m=0&ecmd=10%3A2ð=
      megad-0	2015-09-18 09:50:54	info	Write config for port 3: http://192.168.11.206/sec/?pn=3&pty=0&m=0&ecmd=9%3A3%3Bp50%3B9%3A0ð=
      megad-0	2015-09-18 09:50:53	info	Write config for port 2: http://192.168.11.206/sec/?pn=2&pty=0&m=1&ecmd=8%3A2%3Bp600%3B8%3A0ð=
      megad-0	2015-09-18 09:50:52	info	Write config for port 1: http://192.168.11.206/sec/?pn=1&pty=3&d=2&m=1&misc=undefined&ecmd=ð=
      megad-0	2015-09-18 09:50:51	info	Write config for port 0: http://192.168.11.206/sec/?pn=0&pty=3&d=3&m=1&misc=33&ecmd=12%3A4ð=
      После этого Р13 работает как миленький!!!
      Что самое интересное Р15 не трогаю.
      Небольшие замечания (как должно быть)
      Р14 и Р15 - присутствуют ВСЕГДА в устройстве и ВСЕГДА они ADC.
      если порт цифровой DHT11 или DHT22, то он только отображает значения. Комманд он выполнять никаких не может. Так как там 2 значения передаются.
      PS: Если после того как Р13 испорчен, подать комманду http://192.168.11.206/sec/?pn=14&pty=255, то его можно спокойно конфигурировать как хочется и он становится работающим.
      • Bluefox
        Bluefox last edited by
        Первое.
        Не пойму откуда берётся "ecmd=ð="
        Второе.
        То есть порты Р14 и Р15 всегда либо ADC Input, NC или Digital Sensor? Или только ADC и NC.
        А команды они могут выполнять?
        А строка без pty=2
        http://192.168.11.206/sec/?pn=14&m=0&misc=0&ecmd=
        Воспринимается нормально?
        Третье.
        Если порты DHT11 или DHT22, то комманды невозможны. А как же скрин?
        Там выставлен 1Wire и команды можно задать. При выборе DHT11 поля исчезают?
        Я могу убрать команды для DHT11 или DHT22 и могу сделать P14 и P15 только ADC. Но мне нужно знать, как правильно.
        Кто ещё пользуется megad подтвердите/объясните. 😉
          Andrei34 last edited by
          @Bluefox:
          Первое.
          Не пойму откуда берётся "ecmd=ð=" `
          @Bluefox:
          Второе.
          А строка без pty=2
          Воспринимается нормально? `
          Порты Р14 и Р15 всегда ADC Input. И называются они A6 и A7 как в ардуино .
          @Bluefox:
          Третье.
          filename="screencapture-192-168-1-14-sec-1440449943300.png" index="3">~~
          Кто ещё пользуется megad подтвердите/объясните. 😉 `
          Команды возможны , но они по уровню в поле Val и можно выбрать (Norm , < , > , <> )
          • Bluefox
            @Andrei34:
            @Bluefox:
            Первое.
            Не пойму откуда берётся "ecmd=ð=" ??????
            В конце строки у MSapogov
            Осталось выяснить выживет ли mega при записи:
            Речь шла о DHT11(22). Вопрос остаётся открытым.
            • V
              vtec last edited by
              DHT 11 и 22 это цифровые датчики и к данным портам (A6(14) и А7(15)) не могут быть подключены, только аналоговые. Поэтому там нет их в списке.
              • V
                vtec last edited by
                @Bluefox:
                megad-0 2015-09-18 09:51:07 info Write config for port 15: http://192.168.11.206/sec/?pn=15&pty=2& … =0&ecmd=ð= `
                Может это мега что то на конце отправляет?
                  Вот это дисскуссия! Истинна где-то рядом 🙂
                  1. Логи просто обрезаются наверное, но если подвести мышку к нужной строке но можно увидеть полную комманду. Вот пример скриншота…
                  2. Для Р14 и Р15 режим только ADC с возможностью выбора режима Mode и Action.
                  Комманда http://192.168.11.206/sec/?pn=14&m=0&misc=0&ecmd=
                  Воспринимается нормально. (Back. MegaD is restarted)
                  3. Для цифровых датчиков Поле Action и Mode может быть только у 1W!
                  PS: Нашел что убивает Р13. Это комманда http://192.168.11.206/sec/?pn=14&pty=2& … 1%3A4&eth= - из скриншота
                  Если подать комманду без pty, то порт не оживает.
                  Но если подать комманду http://192.168.11.206/sec/?pn=14&pty=25 ... 1%3A4&eth= - То все оживает
                  Такое ощущение что для портов Р14 и Р15 комманда pty=2 Вообще не нужна. Или Нужна комманда pty=255.
                    @Bluefox:
                    Речь шла о DHT11(22). Вопрос остаётся открытым. `
                    Нет в DHT11(22) менять ничего нельзя .
                    • Bluefox
                      Отлично. У меня есть вся инфа. Спасибо
                        @Bluefox:
                        Отлично. У меня есть вся инфа. Спасибо `
                        Ждем версию драйвера 0.2.6 с этими исправлениями.
                        А при нажатии "Find devices" у меня ничего не находит…
                        Но когда из линукса набираю
                        php megad-cfg.php --scan --local-ip 192.168.11.1
                        Обязательно с параметром --local-ip 192.168.11.1
                        192.168.11.1 - адресс компьютера с которого зпускаю комманду, то в ответ
                        Радостно прилетает 192.168.11.206
                        root@router:/var/www/desk# php megad-cfg.php --scan --local-ip 192.168.11.1
                        192.168.11.206
                        Может у Вас не хватает параметра –local-ip ?
                        PS: Программатор в шкаф пока не убираю 🙂
                          После обновления перестал ШИМ работать 😞
                          • Bluefox
                            @Andrei34:
                            После обновления перестал ШИМ работать 😞 `
                            Что говорит debug?
                              @Bluefox:
                              @Andrei34:
                              После обновления перестал ШИМ работать 😞 Что говорит debug?
                              Вчера ещё всё работало 😞 . Как бы откатится ?
                              • megad-0 2015-09-19 09:49:07 debug Response "Done"
                              megad-0 2015-09-19 09:49:07 debug Send command "cmd=13:NaN" to 192.168.10.11
                              megad-0 2015-09-19 09:49:07 info try to control megad.0.p13_P13 with 0.78
                              megad-0 2015-09-19 09:49:06 debug Response "Done"
                              megad-0 2015-09-19 09:49:06 debug Send command "cmd=13:NaN" to 192.168.10.11
                              megad-0 2015-09-19 09:49:06 info try to control megad.0.p13_P13 with 0
                              megad-0 2015-09-19 09:49:05 debug Response "Done"
                              megad-0 2015-09-19 09:49:05 debug Send command "cmd=13:NaN" to 192.168.10.11
                              megad-0 2015-09-19 09:49:05 info try to control megad.0.p13_P13 with 0.54
                              megad-0 2015-09-19 09:49:04 debug Response "Done"
                              megad-0 2015-09-19 09:49:04 debug Send command "cmd=13:NaN" to 192.168.10.11
                              megad-0 2015-09-19 09:49:04 info try to control megad.0.p13_P13 with 0
                              megad-0 2015-09-19 09:49:04 debug detected new value on port [15]: 427, calc state 427
                              megad-0 2015-09-19 09:49:04 debug detected new value on port [14]: 204, calc state 204
                              megad-0 2015-09-19 09:49:04 debug Response for 192.168.10.11[all]: OFF;OFF/16;temp:23/hum:48;OFF;OFF;OFF/16;ON/219;ON/165;OFF/8;OFF;0;OFF;OFF;0;204;427
                              • Bluefox
                                Не надо откатыватся. Есть 0.2.7
                                  @Bluefox:
                                  Не надо откатыватся. Есть 0.2.7 `
                                  Мало что изменилось 😞 Команды вроде посылаются но на меге ничего не меняется .
                                  • megad-0 2015-09-19 10:50:25 debug Response "Done"
                                  megad-0 2015-09-19 10:50:25 debug Send command "cmd=13:NaN" to 192.168.10.11
                                  megad-0 2015-09-19 10:50:25 info try to control megad.0.p13_P13 with 1
                                  megad-0 2015-09-19 10:50:24 debug getPortState [http://192.168.10.11/mar/?cmd=all](http://192.168.10.11/mar/?cmd=all)
                                  megad-0 2015-09-19 10:50:24 debug Response "Done"
                                  megad-0 2015-09-19 10:50:24 debug Send command "cmd=13:NaN" to 192.168.10.11
                                  megad-0 2015-09-19 10:50:24 info try to control megad.0.p13_P13 with 0.32999999999999996
                                  megad-0 2015-09-19 10:50:23 debug Response "Done"
                                  megad-0 2015-09-19 10:50:23 debug Send command "cmd=13:NaN" to 192.168.10.11
                                  megad-0 2015-09-19 10:50:23 info try to control megad.0.p13_P13 with 0.57
                                  • Bluefox
                                    @Andrei34:
                                    @Bluefox:
                                    megad-0 2015-09-19 10:50:23 info try to control megad.0.p13_P13 with 0.57 `
                                    А ты перезапустил драйвер? Выглядит как будто старая версия.
                                    А почему ты пишешь 0.57? разве там не целочисленные значения от 0 до 255?
                                      @Bluefox:
                                      А почему ты пишешь 0.57? разве там не целочисленные значения от 0 до 255? `
                                      Да перезапустил 😞 Вроде .25 было от 0 до 1 ?
                                      • megad-0 2015-09-19 11:40:44 debug Response "Done"
                                      megad-0 2015-09-19 11:40:44 debug Send command "cmd=13:NaN" to 192.168.10.11
                                      megad-0 2015-09-19 11:40:44 info try to control megad.0.p13_P13 with 207
                                      megad-0 2015-09-19 11:40:43 debug getPortState [http://192.168.10.11/mar/?cmd=all](http://192.168.10.11/mar/?cmd=all)
                                      megad-0 2015-09-19 11:40:42 debug Response "Done"
                                      megad-0 2015-09-19 11:40:42 debug Send command "cmd=13:NaN" to 192.168.10.11
                                      megad-0 2015-09-19 11:40:42 info try to control megad.0.p13_P13 with 132
                                      • Bluefox
                                        Ничего не пойму.
                                        Не буду пока версию делать можешь выполнить в консоли:
                                        cd /opt/iobroker
                                        iobroker stop megad.0
                                        npm install https://github.com/ioBroker/ioBroker.megad/tarball/master
                                        iobroker start megad.0
                                          @Bluefox:
                                          Ничего не пойму.
                                          cd /opt/iobroker
                                          Спасибо ОГРОМНЕЙШЕЕ всё опять заработало 😄 😄 😄
                                            Что-то у меня голова не соображает, куда нужно что прописать, чтобы об нажатии кнопки, выключателя или изменении выхода - IoBroker об этом получал информацию.
                                            У меня после записи конфига в устройство, автоматом прописалось только поле SRV - 192.168.11.3:80 и Script - /0/
                                            Может нужно в настройках порта в поле Net тоже что-то указывать?
                                            Научите правильному 🙂
                                            430
                                            127058
