    4. Test Adapter Nuki-extended v2.0.x
    • Zefau
      Zefau @locke987 last edited by
      @locke987 Danke für die Analyse. Probier mal die Version von Github bei aktiviertem Debug: https://github.com/Zefau/ioBroker.nuki2/tree/nuki2
        locke987 @Zefau last edited by
        @Zefau
        Ich bekomme da Fehler beim installieren:
        iobroker 2019-09-17 10:33:19.457 info exit 0
        iobroker 2019-09-17 10:33:19.417 info npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-09-17T08_33_19_401Z-debug.log
        iobroker 2019-09-17 10:33:19.416 info
        iobroker 2019-09-17 10:33:19.409 info npm ERR! 404 tarball, folder, http url, or git url.
        iobroker 2019-09-17 10:33:19.409 info npm ERR! 404 Note that you can also install from a
        iobroker 2019-09-17 10:33:19.409 info npm ERR! 404 1. name can only contain URL-friendly charactersnpm ERR! 404 2. name can no longer contain capital letters
        iobroker 2019-09-17 10:33:19.407 info 404 Your package name is not valid, because
        iobroker 2019-09-17 10:33:19.392 info npm ERR!
        iobroker 2019-09-17 10:33:19.392 info 404 npm ERR! 404 'https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/master' is not in the npm registry.
        iobroker 2019-09-17 10:33:19.390 info ERR!
        iobroker 2019-09-17 10:33:19.388 info 404 Not Found - GET https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/masternpm
        iobroker 2019-09-17 10:33:19.386 info ERR!
        iobroker 2019-09-17 10:33:19.384 info
        iobroker 2019-09-17 10:33:19.383 info npm
        iobroker 2019-09-17 10:33:19.375 info E404
        iobroker 2019-09-17 10:33:19.373 info code
        iobroker 2019-09-17 10:33:19.372 info ERR!
        iobroker 2019-09-17 10:33:19.371 info
        iobroker 2019-09-17 10:33:19.369 info npm
        iobroker 2019-09-17 10:33:11.733 info npm install https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/master --production --save --prefix "/opt/iobroker" (System call)
        iobroker 2019-09-17 10:33:10.989 info install https://github.com/Zefau/ioBroker.nuki2/tree/nuki2/tarball/master
        iobroker 2019-09-17 10:33:10.447 info url "https://github.com/Zefau/ioBroker.nuki2/tree/nuki2" --debug
        • Zefau
          @locke987 liegt wohl am Branch. Ich hab's nochmal in den Master geladen. Probier mal bitte direkt https://github.com/Zefau/ioBroker.nuki2
            locke987 @Zefau last edited by locke987
            @Zefau installieren konnte ich es, ich habe danach einen neue Instanz hinzugefügt und die alte Instanz deaktiviert, die Version ist laut iobroker noch die selbe, also 1.0.4
            Sollte der lockstate jetzt aktualisiert werden bei deaktivierten callback oder was ist jetzt anders?
            • Zefau
              @locke987 sagte in [Neuer Adapter] Nuki:
              Trag mal im Reiter der Web Api eine Refresh Zeit ein. In der Version auf Github gilt diese auch für die Bridge. Design muss ich noch ändern.
              Dann pollt er den Status regelmäßig ab.
                @Zefau ja das funktionier jetzt ...lockstate wird so jetzt auch upgedated.
                Danke Dir!
                Frage zum Webadapter:
                Was genau ist der Zweck des Webadapters? Es gibt ein paar mehr Objekte wie zum Beispiel doorstate richtig? Und wie werden diese Objekte dann upgedated? Ganz normal über die http appi und dem callback? Oder könnte man die WebApi auch alleine verwenden?
                • Zefau
                  @locke987 Die Web API liefert zusätzliche Informationen, beispielsweise Logs (damit wird auch das Interface aufgebaut, siehe https://forum.iobroker.net/assets/uploads/files/1553251416356-screenshot_2019-03-22-iobroker-nuki2.png), die gesamte Konfiguration und die berechtigten Benutzer - auch doorstate ist mit drin.
                  Die Web API hat keinen Callback. Dieser ist nur bei der Bridge API verfügbar. Die States werden über Polling geupdated.
                  Theoretisch kann man die Web API auch alleine verwenden, aber gerade das schicken von Aktionen macht über die Bridge API mehr Sinn.
                    @Zefau Danke für die Aufklärung!
                    • cash
                      Nachdem heute überraschend nicht nur der neue Türzylinder sondern auch das Nuki-Schloß und die Bridge angekommen sind habe ich mal den Nuki 2.0 Adapter von Zefau installiert.
                      Läuft erstmal alles so wie es soll. Deshalb an dieser Stelle eine Danke an Zefau für diesen Adapter.
                      • Zefau
                        @Sandmanyz
                        Mich würde interessieren was bei Dir passiert wenn Du zu schnell hintereinander lock/unlock Befehle über den Adapter schickst.
                        Ich habe übrigens keine Problem, nutze aber auch eine Software Bridge (bzw. Android Bridge App), siehe https://nuki.io/de/hilfe/bridge-de/android-bridge-app/android-bridge-app/.
                        Die Hardware der Nuki Bridge scheint einfach schlecht zu sein und mit vielen Abfragen nicht klarzukommen.
                        Leider unterstützt die Software Bridge den Nuki Opener nicht.
                        • Zefau
                          Zefau last edited by Zefau
                          ich entwickle gerade an einer Version v2.0.0, die verschiedene Verbesserung sowie den Support für den Nuki Opener mitbringt und suche noch Tester.
                          Installation
                          Alle Interessierten können den Adapter gerne installieren, siehe auch https://github.com/Zefau/ioBroker.nuki2/issues/18#issuecomment-533825482
                          Im Ordner /opt/iobroker:
                          npm i https://github.com/Zefau/ioBroker.nuki2.git#nuki-extended
                          danach
                          iobroker add nuki-extended
                          Features
                          • Support für den Nuki Opener
                          • Unterstützung des hashed token (siehe https://developer.nuki.io/page/nuki-bridge-http-api-190/4#heading--token)
                          • Nuki Web API wird nun als Fallback genutzt, sofern die Nuki Bridge API den Befehl nicht verarbeitet, z. B. aufgrund der Nichterreichbarkeit der Bridge (siehe https://forum.iobroker.net/post/300982 bzw. https://developer.nuki.io/t/random-http-503-unavailable/909/85?u=zefau)
                          • Sofern keine Nuki Web API genutzt wird, werden Befehle an die Bridge bei einem Fehler erneut geschickt
                          • Option für regelmäßige Synchronisierung hinzugefügt (Alternative zum Callback)
                          • Aktualisierung aller States über die Nuki Web API, wenn ein Callback über die Nuki Bridge API empfangen wurde
                          • Nuki Notifications (Benachrichtigungen) werden ausgelesen
                          Hinweise
                          Der Adapter Nuki2 wird mit dem Release v2.0.0 in nuki-extended umbenannt. Insofern wird mit der oben beschriebenen Installation ein neuer Adapter installiert. Der Nuki2 Adapter bleibt unverändert erhalten (nichts wird kaputt gemacht).
                          Die Objekte sind im Vergleich zur alten Version v1.0.4 neu strukturiert bzw. gruppiert.
                          Roadmap
                          https://github.com/Zefau/ioBroker.nuki2/projects/1
                          AntiHeld889 created this issue in Zefau/ioBroker.nuki2
                          closed Support Nuki Opener (Bridge HTTP API 1.9.0) #18
                          Neuschwansteini S 2 Replies Last reply Reply Quote 1
                          • Neuschwansteini
                            Neuschwansteini @Zefau last edited by
                            @Zefau Guten Morgen, tolle Arbeit, vielen Dank!
                            Ich benutze seit beginn den Adapter von Smaragdschlange, läuft hier einwandfrei, bzw hatte ich damals selbst ein Javascript geschrieben, das die Lockstates abfragte und als objekte in iobroker anlegte. 🙂
                            Allerdings hab ich natürlich auch das Problem, dass die Bridge ab und an mal nicht hinterher kommt .. aber recht selten.
                            Habe jetzt den nuki-extended installiert, hatte beim holen von git aber probleme mit den rechten von npm unter meinem normalen account, da meine iobroker installation schon sehr alt ist.. wurde durch die alten Versionen die Rechte vermurkst.. auch der Fixer hilft da nicht immer.. und auch ein
                            sudo chown -R 1000:1000 /home/ilovegym/.npm
                            half nicht..
                            Dafür der Adapter aber einwandfrei, bis jetzt, verwende darin die WebApi und die Bridge. Ich habe noch das allererste Nuki. Türkontakte etc mach ich alles über xiaomi.
                            iobroker läuft auf Linux Mint 18.3 in ner VM unter Proxmox. JS-Controller 1.5.14, Node 10.16.3, NPM 6.11.2.
                            ps: hab auch mal auf den PP Button gedrückt, gibts Dich auch bei Patreon.com ? 🙂
                              Sandmanyz @Zefau last edited by
                              @Zefau
                              Ich habe gerade mal mein Glück versucht. So richtig erfolgreich war ich nicht. Was durchaus an mir liegen kann. Es taucht kein neuer Adapter auf.
                              npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                              npm notice created a lockfile as package-lock.json. You should commit this file.
                              npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                              npm WARN root No description
                              npm WARN root No repository field.
                              npm WARN root No README data
                              npm WARN root No license field.
                              + iobroker.nuki-extended@2.0.0
                              added 109 packages from 137 contributors and audited 541 packages in 17.291s
                              found 0 vulnerabilities
                              host.raspberrypi Unknown packetName nuki-extended
                              • Zefau
                                Zefau @Sandmanyz last edited by
                                @Sandmanyz sorry, bitte im Ordner von ioBroker ausführen (/opt/iobroker).
                                • cash
                                  Muss ich auch testen sofern ich den Opener installiert kriege (sollte Montag kommen).
                                  Aber mal zwei anderen Fragen zu dem alten Adapter. Zum einen habe ich heute einen neuen Benutzer eingerichtet der auch schon einmal erfolgreich die Tür geöffnet habe. Das ganze kann ich auch auf der Adapter Webseite (Protokoll) sehen. Aber der Benutzer taucht nicht in den Objekten auf? Für mich und meine Frau gibt es extra Punkte unter den Objekt users. Wo könnte das Problem liegen. Synronisation steht auf 60 Sekunden. Callback ist auch eingerichtet?
                                  Die andere Frage: Wie kann ich mittels Script ermitteln welcher Benutzer die Tür geöffnet hat? Ich würde gerne das wenn der heute angelegte Benutzer die Tür öffnet das ich dann ein paar bestimmte Lampen einschalte, Alarmanlage ausgeschaltet wird usw. Der Benutzer ist unser Haussitter wenn wir im Urlaub sind...
                                  • cash
                                    Habe nun doch mal eben den nuki-extended Adapter installiert. Aber auch hier taucht der Benutzer nicht bei den Usern auf? Nur meine Frau, ich und nuki_web...
                                    • cash
                                      cash Most Active last edited by cash
                                      Im Log erscheint bei mir immer:
                                      	getWebApi(): Error retrieving smartlocks: Cannot read property 'replace' of null
                                      Habe den gleichen Token wie beim alten Adapter eingetragen. Der alte Adapter ist deaktiviert.
                                      • Zefau
                                        Zefau @cash last edited by
                                        @cash sagte in [Neuer Adapter] Nuki:
                                        Erscheint der Benutzer auf der Nuki Web Seite unter https://web.nuki.io/de/#/admin/users ?
                                        cash 1 Reply Last reply Reply Quote 0
                                        • cash
                                          cash Most Active @Zefau last edited by
                                          @Zefau Komisch. Dort ist er auch nicht. Habe dem Benutzer nicht erlaubt aus der Ferne zu öffen. In der App ist er aber unter Benutzer zu finden.
                                          • Zefau
                                            Der Callback selbst liefert diese Daten nicht. Mit der Nuki Web API bekommst du aber alle Events in den log State geschrieben. Den kannst du per Skript auswerten.
                                            31.7k
                                            79.8k
                                            nuki nuki-extended adapter
                                            65
                                            599
                                            110375
