    4. Test js-controller v2.0.x (GitHub)
      e-s @apollon77 last edited by
      @apollon77
      Install vor ein paar Tagen lief ohne Probleme, auch npm Update.
      Wollte jetzt von 2.0.3 auf 2.0.5
      santa@ubuntuserver:~$ npm install ioBroker/ioBroker.js-controller
      > iobroker.js-controller@2.0.5 preinstall /media/HDD/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.11.3
      > unix-dgram@2.0.3 install /media/HDD/node_modules/unix-dgram
      > node-gyp rebuild
      make: Verzeichnis â/media/HDD/node_modules/unix-dgram/buildâ wird betreten
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Verzeichnis â/media/HDD/node_modules/unix-dgram/buildâ wird verlassen
      > ursa-optional@0.9.10 install /media/HDD/node_modules/ursa-optional
      > node rebuild.js
      > diskusage@1.1.3 install /media/HDD/node_modules/diskusage
      > node-gyp rebuild
      make: Verzeichnis â/media/HDD/node_modules/diskusage/buildâ wird betreten
        CXX(target) Release/obj.target/diskusage/src/main.o
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Verzeichnis â/media/HDD/node_modules/diskusage/buildâ wird verlassen
      > iobroker.js-controller@2.0.5 install /media/HDD/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      > acme-v2@1.8.5 postinstall /media/HDD/node_modules/acme-v2
      > node scripts/postinstall
       ððððððððððððððð
      ð                             ð
      ð  Do you rely on Greenlock?  ð
      ð               (or ACME.js)  ð
      ð                             ð
       ððððððððððððððð
      Hey! Let's Encrypt will STOP WORKING with Greenlock and ACME.js at the end of Oct 2019.
      WITHOUT YOUR HELP we won't get the next release out in time.
      If Greenlock (or ACME.js) has saved you time and money, and taken stress out of your life,
      or you just love it, please reach out to return the favor today:
      SAVE GREENLOCK / ACME.js:
      https://indiegogo.com/at/greenlock
      npm WARN saveError ENOENT: no such file or directory, open '/media/HDD/package.json'
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN enoent ENOENT: no such file or directory, open '/media/HDD/package.json'
      npm WARN HDD No description
      npm WARN HDD No repository field.
      npm WARN HDD No README data
      npm WARN HDD No license field.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.0.7 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.js-controller@2.0.5
      added 295 packages from 282 contributors and audited 588 packages in 84.376s
      found 0 vulnerabilities
      in iobroker zeigt er weiter 2.0.3 an, also nochmal versucht, gleicher Fehler, danach mal sudo probiert, geht aber noch weniger
      santa@ubuntuserver:~$ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
      npm ERR! code EPERM
      npm ERR! syscall spawn
      npm ERR! errno EPERM
      npm ERR! Error: spawn EPERM
      npm ERR!     at ChildProcess.spawn (internal/child_process.js:366:11)
      npm ERR!     at spawn (child_process.js:551:9)
      npm ERR!     at execFile (child_process.js:221:15)
      npm ERR!     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      npm ERR!     at ret (eval at makeNodePromisifiedEval (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promisify.js:184:12), <anonymous>:16:23)
      npm ERR!     at promiseRetry (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/util/git.js:192:14)
      npm ERR!     at /usr/local/lib/node_modules/npm/node_modules/promise-retry/index.js:29:24
      npm ERR!  { Error: spawn EPERM
      npm ERR!   cause:
      npm ERR!        at /usr/local/lib/node_modules/npm/node_modules/promise-retry/index.js:29:24 errno: 'EPERM', code: 'EPERM', syscall: 'spawn' },
      npm ERR!   stack:
      npm ERR!    'Error: spawn EPERM\n    at ChildProcess.spawn (internal/child_process.js:366:11)\n    at spawn (child_process.js:551:9)\n    at execFile (child_process.js:221:15)\n    at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)\n    at ret (eval at makeNodePromisifiedEval (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promisify.js:184:12), <anonymous>:16:23)\n    at promiseRetry (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/util/git.js:192:14)\n    at /usr/local/lib/node_modules/npm/node_modules/promise-retry/index.js:29:24',
      npm ERR!   errno: 'EPERM',
      npm ERR!   code: 'EPERM',
      npm ERR!   syscall: 'spawn' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2019-09-21T18_37_50_217Z-debug.log
        e-i-k-e last edited by
        Guten Abend,
        habe folgenden festgestellt.
        Wenn ich bei meinem Multihost System den Master neustarte, werden die Adapter der Slave Geräte nicht grün. Erst durch einen manuellen neustart der Slave, wechselt der Status zu grün.
        Dies war bei der älteren Version <2.0 nicht der Fall.
          apollon77 @e-s last edited by
          @e-s Bist DU im richtigen verzeicznis? Sieht mir nach "root" oder nem Userverzeichnis aus und nicht ioBroker Verzeichnis?
            apollon77 @e-i-k-e last edited by
            @e-i-k-e hast Du mal das Log von einem Slave js-controller?
              e-i-k-e @apollon77 last edited by
              @apollon77
              Anbei die logfile vom Slave.
              iobroker.2019-09-21.log
                Ich mal wieder,
                Auf GitHub gibt es die Version 2.0.6.
                • Die "Key Not Exists" Meldungen im Log sollten weg sein
                • Die "Invalid Instance object" Meldungen im Log sollten weg sein
                • Bitte nochmal ble checken. sollte jetzt vllt besser tun das es als normaler Prozess gestartet wird und das andere sollte sich beenden. Log würde mich wieder interessieren
                • Die Version bringt auch etwas Funktionalität für iqontrol, aber hier muss auch am Adapter was getan werden
                  @e-i-k-e hast Du noch kurz zeitlich ein paar Eckdaten wann Du was manuell getan hast? Also wann hast Du den Master restartet? Wann hast Du manuell was am Slave gemacht ...
                    e-i-k-e @apollon77 last edited by e-i-k-e
                    @apollon77
                    Ja. neuer log vom Slave.
                    iobroker.2019-09-22.log
                    Neustart Master um 1.32 Uhr.
                    Neustart Slave um 1.34 Uhr.
                      sigi234 Forum Testing Most Active @apollon77 last edited by
                      @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                      So ist es, keine Änderung es werden keine Daten angezeigt.
                        @e-i-k-e Danke. Hab ne Idee.N8 erstmal.
                        E J 2 Replies Last reply Reply Quote 1
                          Einstein67 last edited by Einstein67
                          @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
                          Ja die Meldungen sind weg!
                          Vielen Dank
                          • opossum
                            opossum @apollon77 last edited by opossum
                            Ps: die Idee war das wir einen „User-files“ Ordner anlegen und auch dahin uploads erlauben. Aber auch dann wäre das wohl ein anderer Name als dein aktueller 😉
                            … wo muss ich meine eigenen Icons jetzt hinkopieren? In meinen Views werden alle eigenen Icons nicht mehr angezeigt, ich kann sie auch nicht mehr in dem ursprünglichen Pfad auswählen (auch dort werden sie nicht mehr angezeigt im Auswahldialog). Ich würde dann halt meine Views umbauen müssen. Aber ich möchte das nur einmal machen, daher wäre es gut, wenn ich den Pfad wüsste. Ich habe unter vis.0 einmal main/img/ und einmal /Project_1/ mehrere Ordner mit eigenen Icons. Vielen Dank.
                            Egbert
                              @apollon77
                              Oh Mann, ist das peinlich. Hatte tatsächlich das cd vergessen. Passiert wenn man sich nur schnell über Putty einloggt und über die hochtaste die letzten Befehle wiederholen will und nicht weit genug nach oben geht. Hatte aber trotzdem wieder Fehlermeldungen:
                              santa@ubuntuserver:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller
                              npm ERR! code EPERM
                              npm ERR!   cause:
                              npm ERR!   stack:
                              npm ERR!   syscall: 'spawn',
                              npm ERR!   parent: 'iobroker' }
                              npm ERR!
                              npm ERR!
                              npm ERR!     /media/HDD/.npm/_logs/2019-09-22T06_17_39_413Z-debug.log
                              Anschließend die sudo Variante, Update lief jetzt mit warns durch und wird auch mit 2.0.6 in iobroker angezeigt:
                              santa@ubuntuserver:/opt/iobroker$ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                              [sudo] Passwort für santa:
                              > iobroker.js-controller@2.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                              NPM version: 6.11.3
                              > iobroker.js-controller@2.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              + iobroker.js-controller@2.0.6
                              added 4 packages from 3 contributors, removed 1 package, updated 4 packages and audited 27832 packages in 75.021s
                              found 34 vulnerabilities (23 low, 11 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                                Jan1 @apollon77 last edited by
                                @apollon77
                                Hab nun ein großes Problem mit der Version 2.0.6, IOBroker stürzt ab bevor alle Instanzen wieder laufen.
                                Bin jetzt gerade am Testen welche Instanz den Absturz verursacht und ob es am compakt mode liegt, der eigentlich genau das vermeiden soll.
                                • Dr. Bakterius
                                  Dr. Bakterius Most Active @opossum last edited by Dr. Bakterius
                                  @opossum sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  Am Besten im VIS-Editor unter 'Setup' - 'Dateimanager' in den Ordner '/vis.0/' hochladen indem du auf den Upload-Button klickst.
                                  Unter vis.0 kann man auch eigene Unterordner erstellen.
                                  Wenn man das direkt auf dem ioBroker-Rechner machen möchte, gehören die Dateien nach /opt/iobroker/iobroker-data/files/vis.0
                                  apollon77 opossum 2 Replies Last reply Reply Quote 0
                                    Jan1 last edited by
                                    @apollon77
                                    Der compact mode läuft mit Version 2.0.6 nicht mehr. Der admin restartet ständig.
                                    hier mal ein Log:
                                    admin.0	2019-09-22 08:50:22.584	info	(COMPACT) received all states
                                    admin.0	2019-09-22 08:50:22.024	info	(COMPACT) Request actual repository...
                                    admin.0	2019-09-22 08:50:22.024	info	(COMPACT) requesting all objects
                                    admin.0	2019-09-22 08:50:22.022	info	(COMPACT) requesting all states
                                    admin.0	2019-09-22 08:50:22.015	info	(COMPACT) starting. Version 3.6.5 in /opt/iobroker/node_modules/iobroker.admin, node: v10.16.3
                                    admin.0	2019-09-22 08:49:51.387	info	(COMPACT) terminating
                                    admin.0	2019-09-22 08:49:50.884	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    admin.0	2019-09-22 08:49:50.881	info	(COMPACT) terminating
                                    admin.0	2019-09-22 08:49:50.880	info	(COMPACT) terminating http server on port 8081
                                    admin.0	2019-09-22 08:49:50.877	info	(COMPACT) Got terminate signal.
                                    tankerkoenig.0	2019-09-22 08:49:44.927	info	(COMPACT) Reading data from tankerkoenig ...
                                    tankerkoenig.0	2019-09-22 08:49:44.907	info	(COMPACT) Sync time set to 9 minutes or 540000 ms
                                    tankerkoenig.0	2019-09-22 08:49:44.905	info	(COMPACT) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v10.16.3
                                    telegram.0	2019-09-22 08:49:43.651	info	(COMPACT) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v10.16.3
                                    host.Beelink.compactgroup1	2019-09-22 08:49:43.068	info	instance system.adapter.telegram.0 started in COMPACT mode
                                    harmony.0	2019-09-22 08:49:38.881	info	(COMPACT) [PROCESS] Synced hub config for Harmony Hub (192.168.100.44)
                                    host.Beelink.compactgroup1	2019-09-22 08:49:38.871	info	instance system.adapter.tankerkoenig.0 started in COMPACT mode
                                    harmony.0	2019-09-22 08:49:37.791	info	(COMPACT) [CONNECT] Connected to Harmony Hub (192.168.100.44)
                                    harmony.0	2019-09-22 08:49:36.633	info	(COMPACT) [CONNECT] Connecting to Harmony Hub (192.168.100.44)
                                    harmony.0	2019-09-22 08:49:36.556	info	(COMPACT) [DISCOVER] Discovered Harmony Hub (192.168.100.44) and will try to connect
                                    harmony.0	2019-09-22 08:49:35.362	info	(COMPACT) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
                                    harmony.0	2019-09-22 08:49:35.354	info	(COMPACT) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.harmony, node: v10.16.3
                                    host.Beelink.compactgroup1	2019-09-22 08:49:34.995	info	instance system.adapter.harmony.0 started in COMPACT mode
                                    history.0	2019-09-22 08:49:31.181	info	(COMPACT) enabled logging of admin.0.Datenpunkte.Heizung.HZ_Regelung_laeuft (Count=1), Alias=false
                                    history.0	2019-09-22 08:49:31.155	info	(COMPACT) starting. Version 1.8.7 in /opt/iobroker/node_modules/iobroker.history, node: v10.16.3
                                    host.Beelink.compactgroup1	2019-09-22 08:49:30.736	info	instance system.adapter.history.0 started in COMPACT mode
                                    backitup.0	2019-09-22 08:49:28.851	info	(COMPACT) [total] backup was activated at 03:00 every 7 day(s)
                                    backitup.0	2019-09-22 08:49:28.838	info	(COMPACT) [minimal] backup was activated at 02:00 every 2 day(s)
                                    backitup.0	2019-09-22 08:49:28.818	info	(COMPACT) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.16.3
                                    host.Beelink.compactgroup1	2019-09-22 08:49:27.952	info	instance system.adapter.backitup.0 started in COMPACT mode
                                    admin.0	2019-09-22 08:49:25.560	info	(COMPACT) Repository received successfully.
                                    admin.0	2019-09-22 08:49:25.004	info	(COMPACT) Use link "http://localhost:8081" to configure.
                                    admin.0	2019-09-22 08:49:25.003	info	(COMPACT) http server listening on port 8081
                                    admin.0	2019-09-22 08:49:24.916	info	(COMPACT) received all objects
                                    admin.0	2019-09-22 08:49:24.626	info	(COMPACT) received all states
                                    host.Beelink	2019-09-22 08:49:24.613	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                    admin.0	2019-09-22 08:49:24.112	info	(COMPACT) Request actual repository...
                                    admin.0	2019-09-22 08:49:24.110	info	(COMPACT) requesting all objects
                                    admin.0	2019-09-22 08:49:24.108	info	(COMPACT) requesting all states
                                    admin.0	2019-09-22 08:49:24.100	info	(COMPACT) starting. Version 3.6.5 in /opt/iobroker/node_modules/iobroker.admin, node: v10.16.3
                                    host.Beelink.compactgroup1	2019-09-22 08:49:23.304	info	instance system.adapter.admin.0 started in COMPACT mode
                                    host.Beelink.compactgroup1	2019-09-22 08:49:22.703	info	starting 6 instances
                                    host.Beelink.compactgroup1	2019-09-22 08:49:22.546	info	connected to Objects and States
                                    host.Beelink.compactgroup1	2019-09-22 08:49:22.465	info	iobroker.js-controller version 2.0.6 js-controller starting
                                    host.Beelink	2019-09-22 08:49:21.895	info	instance system.adapter.telegram.0 is handled by compact group controller pid 10508
                                    host.Beelink	2019-09-22 08:49:21.876	info	start controller for compactgroup 1
                                       2019-09-22 08:49:20.872	info	"system.adapter.admin.0","system.adapter.backitup.0","system.adapter.iot.0","system.adapter.history.0","system.adapter.harmony.0","system.adapter.tankerkoenig.0","system.adapter.telegram.0","system.ad
                                    host.Beelink	2019-09-22 08:49:20.872	info	Restart compact group controller 1
                                    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at Timer.processTimers (timers.js:223:10)
                                    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at listOnTimeout (timers.js:263:5)
                                    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at tryOnTimeout (timers.js:300:5)
                                    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at ontimeout (timers.js:436:11)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at process.exit (internal/process/per_thread.js:168:15)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at process.emit (events.js:203:15)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Object.onceWrapper (events.js:286:20)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Adapter.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: TypeError: Cannot read property 'setState' of null
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at Timer.processTimers (timers.js:223:10)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at listOnTimeout (timers.js:263:5)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at tryOnTimeout (timers.js:300:5)
                                    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at ontimeout (timers.js:436:11)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at process.exit (internal/process/per_thread.js:168:15)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at process.emit (events.js:203:15)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Object.onceWrapper (events.js:286:20)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Adapter.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: TypeError: Cannot read property 'setState' of null
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at Timer.processTimers (timers.js:223:10)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at listOnTimeout (timers.js:263:5)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at tryOnTimeout (timers.js:300:5)
                                    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at ontimeout (timers.js:436:11)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at process.exit (internal/process/per_thread.js:168:15)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at process.emit (events.js:203:15)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Object.onceWrapper (events.js:286:20)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Adapter.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: TypeError: Cannot read property 'setState' of null
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[8]: at Timer.processTimers (timers.js:223:10)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[8]: at listOnTimeout (timers.js:263:5)
                                    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[8]: at tryOnTimeout (timers.js:300:5)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at ontimeout (timers.js:436:11)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at process.exit (internal/process/per_thread.js:168:15)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at process.emit (events.js:203:15)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Object.onceWrapper (events.js:286:20)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Adapter.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: TypeError: Cannot read property 'setState' of null
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[7]: at Timer.processTimers (timers.js:223:10)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[7]: at listOnTimeout (timers.js:263:5)
                                    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[7]: at tryOnTimeout (timers.js:300:5)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at ontimeout (timers.js:436:11)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at process.exit (internal/process/per_thread.js:168:15)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at process.emit (events.js:203:15)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Object.onceWrapper (events.js:286:20)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Adapter.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: TypeError: Cannot read property 'setState' of null
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Timer.processTimers (timers.js:223:10)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at listOnTimeout (timers.js:263:5)
                                    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at tryOnTimeout (timers.js:300:5)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at ontimeout (timers.js:436:11)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at process.exit (internal/process/per_thread.js:168:15)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at process.emit (events.js:203:15)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Object.onceWrapper (events.js:286:20)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Adapter.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: TypeError: Cannot read property 'setState' of null
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[6]: at process._tickCallback (internal/process/next_tick.js:61:11)
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[6]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                                    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[6]: at Socket.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[6]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[6]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[6]: TypeError: Cannot read property 'pushMessage' of null
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at process._tickCallback (internal/process/next_tick.js:61:11)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at Socket.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: TypeError: Cannot read property 'pushMessage' of null
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[4]: at process._tickCallback (internal/process/next_tick.js:61:11)
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[4]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                                    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[4]: at Socket.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[4]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[4]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[4]: TypeError: Cannot read property 'pushMessage' of null
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:61:11)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at Socket.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: TypeError: Cannot read property 'pushMessage' of null
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:61:11)
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                                    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[2]: at Socket.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[2]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[2]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[2]: TypeError: Cannot read property 'pushMessage' of null
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:61:11)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at Socket.emit (events.js:198:13)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: TypeError: Cannot read property 'pushMessage' of null
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:778:30
                                    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[0]: In the future, you will have to enable it yourself.
                                    host.Beelink	2019-09-22 08:49:20.862	error	Caught by controller[0]: Sun, 22 Sep 2019 06:49:06 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	warn	stopInstance system.adapter.simple-api.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.simple-api.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.iqontrol.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.alexa2.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.info.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.fritzdect.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	info	stopInstance system.adapter.javascript.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	warn	stopInstance system.adapter.telegram.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	info	stopInstance system.adapter.telegram.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	warn	stopInstance system.adapter.tankerkoenig.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	info	stopInstance system.adapter.tankerkoenig.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	warn	stopInstance system.adapter.harmony.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.733	info	stopInstance system.adapter.harmony.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.733	warn	stopInstance system.adapter.history.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.733	info	stopInstance system.adapter.history.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.732	info	stopInstance system.adapter.iot.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.732	warn	stopInstance system.adapter.backitup.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.732	info	stopInstance system.adapter.backitup.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.731	warn	stopInstance system.adapter.admin.0 not running
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.731	info	stopInstance system.adapter.admin.0
                                    host.Beelink.compactgroup1	2019-09-22 08:49:20.728	warn	Slave controller detected disconnection. Stop all instances.
                                    tankerkoenig.0	2019-09-22 08:49:20.286	info	(COMPACT) terminating
                                    harmony.0	2019-09-22 08:49:20.285	info	(COMPACT) terminating
                                    backitup.0	2019-09-22 08:49:20.279	info	(COMPACT) terminating
                                    admin.0	2019-09-22 08:49:20.278	info	(COMPACT) terminating
                                    telegram.0	2019-09-22 08:49:19.786	error	(COMPACT) exception by stop: Cannot read property 'setState' of null
                                    telegram.0	2019-09-22 08:49:19.786	error	at Timer.processTimers (timers.js:223:10)
                                    telegram.0	2019-09-22 08:49:19.786	error	at listOnTimeout (timers.js:263:5)
                                    telegram.0	2019-09-22 08:49:19.786	error	at tryOnTimeout (timers.js:300:5)
                                    telegram.0	2019-09-22 08:49:19.786	error	at ontimeout (timers.js:436:11)
                                    telegram.0	2019-09-22 08:49:19.786	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    telegram.0	2019-09-22 08:49:19.786	error	at process.exit (internal/process/per_thread.js:168:15)
                                    telegram.0	2019-09-22 08:49:19.786	error	at process.emit (events.js:203:15)
                                    telegram.0	2019-09-22 08:49:19.786	error	at Object.onceWrapper (events.js:286:20)
                                    telegram.0	2019-09-22 08:49:19.786	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    telegram.0	2019-09-22 08:49:19.786	error	at Adapter.emit (events.js:198:13)
                                    telegram.0	2019-09-22 08:49:19.786	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    telegram.0	2019-09-22 08:49:19.786	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    telegram.0	2019-09-22 08:49:19.786	error	(COMPACT) TypeError: Cannot read property 'setState' of null
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Timer.processTimers (timers.js:223:10)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at listOnTimeout (timers.js:263:5)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at tryOnTimeout (timers.js:300:5)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at ontimeout (timers.js:436:11)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at process.exit (internal/process/per_thread.js:168:15)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at process.emit (events.js:203:15)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Object.onceWrapper (events.js:286:20)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Adapter.emit (events.js:198:13)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    tankerkoenig.0	2019-09-22 08:49:19.785	error	(COMPACT) TypeError: Cannot read property 'setState' of null
                                    history.0	2019-09-22 08:49:19.783	info	(COMPACT) terminating
                                    history.0	2019-09-22 08:49:19.783	error	at Timer.processTimers (timers.js:223:10)
                                    history.0	2019-09-22 08:49:19.783	error	at listOnTimeout (timers.js:263:5)
                                    history.0	2019-09-22 08:49:19.783	error	at tryOnTimeout (timers.js:300:5)
                                    history.0	2019-09-22 08:49:19.783	error	at ontimeout (timers.js:436:11)
                                    history.0	2019-09-22 08:49:19.783	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    history.0	2019-09-22 08:49:19.783	error	at process.exit (internal/process/per_thread.js:168:15)
                                    history.0	2019-09-22 08:49:19.783	error	at process.emit (events.js:203:15)
                                    history.0	2019-09-22 08:49:19.783	error	at Object.onceWrapper (events.js:286:20)
                                    history.0	2019-09-22 08:49:19.783	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    history.0	2019-09-22 08:49:19.783	error	at Adapter.emit (events.js:198:13)
                                    history.0	2019-09-22 08:49:19.783	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    history.0	2019-09-22 08:49:19.783	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    history.0	2019-09-22 08:49:19.783	error	(COMPACT) TypeError: Cannot read property 'setState' of null
                                    backitup.0	2019-09-22 08:49:19.778	error	at Timer.processTimers (timers.js:223:10)
                                    backitup.0	2019-09-22 08:49:19.778	error	at listOnTimeout (timers.js:263:5)
                                    backitup.0	2019-09-22 08:49:19.778	error	at tryOnTimeout (timers.js:300:5)
                                    backitup.0	2019-09-22 08:49:19.778	error	at ontimeout (timers.js:436:11)
                                    backitup.0	2019-09-22 08:49:19.778	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    backitup.0	2019-09-22 08:49:19.778	error	at process.exit (internal/process/per_thread.js:168:15)
                                    backitup.0	2019-09-22 08:49:19.778	error	at process.emit (events.js:203:15)
                                    backitup.0	2019-09-22 08:49:19.778	error	at Object.onceWrapper (events.js:286:20)
                                    backitup.0	2019-09-22 08:49:19.778	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    backitup.0	2019-09-22 08:49:19.778	error	at Adapter.emit (events.js:198:13)
                                    backitup.0	2019-09-22 08:49:19.778	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    backitup.0	2019-09-22 08:49:19.778	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    backitup.0	2019-09-22 08:49:19.778	error	(COMPACT) TypeError: Cannot read property 'setState' of null
                                    harmony.0	2019-09-22 08:49:19.784	info	(COMPACT) terminating
                                    harmony.0	2019-09-22 08:49:19.784	info	(COMPACT) [END] Terminating
                                    harmony.0	2019-09-22 08:49:19.784	error	at Timer.processTimers (timers.js:223:10)
                                    harmony.0	2019-09-22 08:49:19.784	error	at listOnTimeout (timers.js:263:5)
                                    harmony.0	2019-09-22 08:49:19.784	error	at tryOnTimeout (timers.js:300:5)
                                    harmony.0	2019-09-22 08:49:19.784	error	at ontimeout (timers.js:436:11)
                                    harmony.0	2019-09-22 08:49:19.784	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
                                    harmony.0	2019-09-22 08:49:19.784	error	at process.exit (internal/process/per_thread.js:168:15)
                                    harmony.0	2019-09-22 08:49:19.784	error	at process.emit (events.js:203:15)
                                    harmony.0	2019-09-22 08:49:19.784	error	at Object.onceWrapper (events.js:286:20)
                                    harmony.0	2019-09-22 08:49:19.784	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
                                    harmony.0	2019-09-22 08:49:19.784	error	at Adapter.emit (events.js:198:13)
                                    harmony.0	2019-09-22 08:49:19.784	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
                                    harmony.0	2019-09-22 08:49:19.784	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
                                    harmony.0	2019-09-22 08:49:19.784	error	(COMPACT) TypeError: Cannot read property 'setState' of null
                                    harmony.0	2019-09-22 08:49:19.784	error	(COMPACT) uncaught exception: Cannot read property 'setState' of null
                                    admin.0	2019-09-22 08:49:19.777	info	(COMPACT) terminating
                                    admin.0	2019-09-22 08:49:19.776	info	(COMPACT) terminating http server on port 8081
                                    mania25 created this issue in yagop/node-telegram-bot-api
                                    closed Error: cannot enable cancellation after promises are in use #319
                                    apollon77 2 Replies Last reply Reply Quote 0
                                      apollon77 @Dr. Bakterius last edited by
                                      @Dr-Bakterius direkt ins file Skootern ist nicht wirklich supporters weil dann Meta Daten fehlen.
                                        apollon77 @Jan1 last edited by
                                        @Jan1 Mist. Schaue ich mir an
                                          @apollon77
                                          keine Panik, wenn ich den compact modus disable, läuft ja alles und das ist in ein paar Sekunden umgestellt 😉
                                          • opossum
                                            opossum @Dr. Bakterius last edited by
                                            erst mal danke für die schnelle Antwort.
                                            @Dr-Bakterius sagte in [Aufruf] js-controller 2.0 Beta Test:
                                            habe ich kopiert:
                                            Aber sie werden mir im Auswahldialog leider nicht angezeigt:
                                            Irgend etwas ist noch nicht korrekt bei mir. Klicke ich auf den Uploadbutton, dann kommt bei mir folgendes:
                                            Ich kann von dort auch hochladen, aber in der Auswahl sieht das dann so aus:
                                            Dabei stehen die Rechte der Dateien wie folgt:
                                            Sorry, wenn ich nerve.
                                            Egbert
                                            1.5k
                                            js-controller
                                            48
                                            1047
                                            306160
