    4. [Aufruf] Asterisk VoIP Adapter
      LJSven @Stuebi last edited by LJSven
      @Stuebi sagte in [Aufruf] Asterisk VoIP Adapter:
      asterisk -rvvvvv
      Habe das gemacht - und es sieht wie folgt aus?
      Last login: Fri Sep 20 11:47:29 2019 from 192.168.178.201
      root@tinkerboardmaster:~# ps -ef | grep asterisk
      root 5701 5446 0 13:12 pts/0 00:00:00 grep asterisk
      asterisk 29297 1 0 Sep20 ? 00:00:05 /usr/sbin/asterisk -g -f -U asterisk
      iobroker 30356 1007 0 Sep20 ? 00:02:01 io.asterisk.0
      root@tinkerboardmaster:~# /etc/init.d/asterisk restart
      [ ok ] Restarting asterisk (via systemctl): asterisk.service.
      root@tinkerboardmaster:~# asterisk -rvvvvv
      Asterisk 13.14.1~dfsg-2+deb9u4, Copyright (C) 1999 - 2014, Digium, Inc. and others.
      Created by Mark Spencer markster@digium.com
      Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
      This is free software, with components licensed under the GNU General Public
      License version 2 and other licenses; you are welcome to redistribute it under
      certain conditions. Type 'core show license' for details.
      Connected to Asterisk 13.14.1~dfsg-2+deb9u4 currently running on tinkerboardmaster (pid = 6229)
      == Manager 'manager' logged on from 192.168.178.15
      tinkerboardmaster*CLI>
      Wenn ich den Anruf tätige, kommt aber nichts in der Konsole? Wo kann da der Fehler liegen?
      Im ioBroker Log erscheint folgende Meldung:
      2019-09-23 13:14:02.854 - error: asterisk.0 Error while dialing (1). Error: {"response":"Error","actionid":"b6b4a776-7b5f-7cb7-4690-c90337215915","message":"Extension does not exist."}, Result: {"parameter":{"callerid":"","telnr":"0176*******","text":"Dies ist ein test","extension":"00004711","audiofile":"/tmp/audio_1568975223267","delete":"delete"},"options":{"action":"originate","channel":"SIP/00004711/0176*********","context":"ael-ansage","exten":"0176********","priority":1,"timeout":60000,"variable":{"repeat":5,"file":"/tmp/audio_1568975223267","del":"delete"},"callerid":""},"guid":"b6b4a776-7b5f-7cb7-4690-c90337215915","result":{"response":"Error","actionid":"b6b4a776-7b5f-7cb7-4690-c90337215915","message":"Extension does not exist."}}
      Die Audio-Datei wird erzeugt und liegt im Ordner "tmp" (allerdings mit einer Endung):
      root@tinkerboardmaster:/tmp# ls
      armbian-hardware-optimization.9V5FHE audio_69868967.gsm
      asterisk_dtmf.gsm npm-15773-c798b5de
      audio_1568973325897.gsm pulse-PKdhtXMmr18n
      audio_1568974802049.gsm ssh-dpKOoyy86DWy
      audio_1568974806323.gsm
      Stuebi 1 Reply Last reply Reply Quote 0
      • Stuebi
        Stuebi @LJSven last edited by Stuebi
        @LJSven ,
        der Asterisk Prozess läuft. Hast Du auch die Konfigurationsdateien kopiert?
        sudo mv /tmp/extensions.ael /etc/asterisk/extensions.ael
        sudo mv /tmp/manager.conf /etc/asterisk/manager.conf
        sudo mv /tmp/sip_fritzbox.conf /etc/asterisk/sip.conf
        sudo mv /tmp/rtp.conf /etc/asterisk/rtp.conf
        und stimmen die IP Adressen. Da Du keine Verbindung zu Asterisk bekommst (manager nicht connected) stimmt etwas an den IP Adressen nicht. Schaue Dir bitte nochmals genau die Doku hierzu an und ob das mit Deinen Einstellungen stimmt.
        https://github.com/schmupu/ioBroker.asterisk/blob/master/docs/SIP_FRITZBOX.md
        VG
        Stübi
        P.S: Wenn Du Logfiles einfügst, tue es als Code. Dann ist es einfacher zu lesen
          @LJSven ,
          VG
          Stübi
          Das ist meine manager.conf
          [general] ; Do not change
          enabled = yes ; Do not change
          port = 5038 ; Do not change
          bindaddr = 0.0.0.0 ; Do not change
          [manager] ; Do not change
          secret = ******** ; Change Manager password for ioBroker asterisk adapter
          permit = 0.0.0.0/0.0.0.0 ; Change to your subnet and netmask
          read = all ; Do not change
          write = all ; Do not change
          Und das ist meine sip.conf
          port = 5060 ; Do not change
          context = default ; Do not change
          subscribecontext = default ; Do not change
          register => 00004711:*********7@192.168.178.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
          [00004711] ; Change to username of Fritzbox WLAN/LAN telephone
          type = friend ; Do not change
          username = 00004711 ; Change to username of Fritzbox WLAN/LAN telephone
          host = 192.168.178.1 ; Change hostname / IP address of Fritzbox
          secret = Hanna**** ; Change password of Fritzbox WLAN/LAN telephone
          fromdomain = 192.168.178.1 ; Change hostname / IP address of Fritzbox
          fromuser = 00004711 ; Change username of Fritzbox WLAN/LAN telephone
          PS. der Manager looged sich doch ein ->
          Stuebi 2 Replies Last reply Reply Quote 0
          • Stuebi
            @LJSven , in der Asterisk Konsole wird ja etwas angzeigt.
            Sobald Du das siehst, nocmals in ioBroke rüber die Datenpunkte in ioBroker einen Anruf durchführen. Du solltest dann etwas in der Konsole sehen.
            • Stuebi
              @LJSven , kannst du einmal die Screenshots von den Fritzbox Telefoneinstellungen schicken. Ich würde gerne sehen wie diese aussehen und die /etc/asterisk/rtp.conf und die /etc/asterisk/extensions.ael
                  Da kommt nichts in der Konsole.
                    rtp.conf
                    [general]
                    rtpstart=30000
                    rtpend=30100
                    /extensions.ael
                    root@tinkerboardmaster:~# cat  /etc/asterisk/extensions.ael
                    context default {
                      	1000 => {
                            Goto(ael-antwort,s,1);
                    context ael-ansage {
                    	_. => {
                            Answer();
                            Wait(1);
                    		Read(dtmf,${file}&beep,0,s,${repeat},1);
                    		if ("${dtmf}"  != "") {
                    			SayDigits(${dtmf});
                    		Hangup();
                    	h =>  {
                        	if ("${del}" = "delete") {
                    				NoOp(/bin/rm ${file}.*);
                                    System(/bin/rm ${file}.*);
                    context ael-antwort {
                    	s  => {
                    		Answer();
                    		Wait(1);
                    		Set(repeat=5);
                    		Read(dtmf,/tmp//asterisk_dtmf&beep,0,s,${repeat},1);
                    			SayDigits(${dtmf});
                        		Hangup();
                    	_.  => {
                    • Stuebi
                      @LJSven , schicke bitte auch nochmals die Screenshot von den Asterisk ioBroker Admin Einstellungen
                        @Stuebi
                        • Stuebi
                          @LJSven , ersetze bitte einmal fritz.box in der ioBroker Asterisk Admin Oberflächen durch 192.168.178.1 (das ist doch die IP Adresse Deiner Fritzbox?).
                            Hatte ich vorher / geht aber auch nicht.
                            • Stuebi
                              @LJSven , Du musst bitte die ioBroker Asterisk Admin Konfiguration so lassen wie sie ist. Also in dem Zustand, mit denen Du die Konfigurationsfiles erzeugt hast. Sonst machst Du mir die Arbeit nur unnötig schwer. Am besten also nochmals jetzt erzeugen und die Files vom /tmp/ Verzeichnis in das /etc/asterisk Verzeichnis kopieren.
                              Welche ioBroker Asterisk Version hast Du installiert?
                                @Stuebi Habe ich gemacht. Asterisk Version ist 1.0.6
                                • Stuebi
                                  @LJSven , ich habe Dir einmal einen Chat Nachricht geschickt.
                                  31.7k
                                  79.8k
                                  adapter asterisk sip voip
                                  10
                                  71
                                  8305
