    4. Test js-controller v2.0.x (GitHub)
      apollon77 @Jan1 last edited by
      @Jan1 Ich hätte mindestesn eine Meldung "compact geht nicht daher starte ich normal" erwartet und dann sollte der start direkt erfolgen und ein pot. gestarteter compact sollte sich beenden.
        Jan1 @apollon77 last edited by Jan1
        @apollon77
        so hab noch mal die 0.9.0 drauf und den compact modus aktiviert, jetzt waren plötzlich viele Fehler im Log
        host.Beelink.compactgroup1	2019-09-23 08:56:08.158	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:56:08.157	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble	2019-09-23 08:56:08.097	error	(13338) ble.0 already running
        ble.0	2019-09-23 08:56:07.851	info	(COMPACT) monitored services: fe95
        ble.0	2019-09-23 08:56:07.851	info	(COMPACT) enabled plugins: mi-flora, _default
        ble.0	2019-09-23 08:56:07.850	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        ble.0	2019-09-23 08:56:07.721	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
        host.Beelink.compactgroup1	2019-09-23 08:56:07.407	info	instance system.adapter.ble.0 started with pid 13338
           2019-09-23 08:56:07.385	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:56:07.385	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        host.Beelink.compactgroup1	2019-09-23 08:55:37.362	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:55:37.361	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble	2019-09-23 08:55:37.295	error	(12663) ble.0 already running
        ble.0	2019-09-23 08:55:37.177	info	(COMPACT) terminating
        ble.0	2019-09-23 08:55:37.175	info	(COMPACT) terminating
        ble	2019-09-23 08:55:36.694	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        ble	2019-09-23 08:55:36.693	error	(COMPACT) ble.0 already running
        ble.0	2019-09-23 08:55:36.676	info	(COMPACT) terminating
        ble.0	2019-09-23 08:55:36.675	info	(COMPACT) stopping scan
        ble.0	2019-09-23 08:55:36.675	info	(COMPACT) Got terminate signal 12663
        ble.0	2019-09-23 08:55:36.674	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        ble.0	2019-09-23 08:55:36.674	info	(COMPACT) terminating
        ble.0	2019-09-23 08:55:36.673	info	(COMPACT) stopping scan
        ble.0	2019-09-23 08:55:36.672	info	(COMPACT) Got terminate signal -1
        host.Beelink.compactgroup1	2019-09-23 08:55:36.667	info	instance system.adapter.ble.0 started with pid 12663
           2019-09-23 08:55:36.648	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:55:36.648	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        host.Beelink.compactgroup1	2019-09-23 08:55:06.630	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:55:06.629	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble	2019-09-23 08:55:06.569	error	(11988) ble.0 already running
        ble.0	2019-09-23 08:55:06.435	info	(COMPACT) monitored services: fe95
        ble.0	2019-09-23 08:55:06.435	info	(COMPACT) enabled plugins: mi-flora, _default
        ble.0	2019-09-23 08:55:06.434	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        ble.0	2019-09-23 08:55:06.278	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
        host.Beelink.compactgroup1	2019-09-23 08:55:05.904	info	instance system.adapter.ble.0 started with pid 11988
           2019-09-23 08:55:05.886	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:55:05.885	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        host.Beelink.compactgroup1	2019-09-23 08:54:35.866	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:54:35.865	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble	2019-09-23 08:54:35.798	error	(11309) ble.0 already running
        ble.0	2019-09-23 08:54:35.630	info	(COMPACT) terminating
        ble.0	2019-09-23 08:54:35.628	info	(COMPACT) terminating
        ble	2019-09-23 08:54:35.179	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        ble	2019-09-23 08:54:35.179	error	(COMPACT) ble.0 already running
        ble.0	2019-09-23 08:54:35.128	info	(COMPACT) terminating
        ble.0	2019-09-23 08:54:35.128	info	(COMPACT) stopping scan
        ble.0	2019-09-23 08:54:35.128	info	(COMPACT) Got terminate signal 11309
        ble.0	2019-09-23 08:54:35.127	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        ble.0	2019-09-23 08:54:35.126	info	(COMPACT) terminating
        ble.0	2019-09-23 08:54:35.125	info	(COMPACT) stopping scan
        ble.0	2019-09-23 08:54:35.124	info	(COMPACT) Got terminate signal -1
        host.Beelink.compactgroup1	2019-09-23 08:54:35.095	info	instance system.adapter.ble.0 started with pid 11309
           2019-09-23 08:54:35.071	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:54:35.071	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        host.Beelink.compactgroup1	2019-09-23 08:54:05.056	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:54:05.056	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble	2019-09-23 08:54:04.991	error	(10634) ble.0 already running
        ble.0	2019-09-23 08:54:04.623	info	(COMPACT) monitored services: fe95
        ble.0	2019-09-23 08:54:04.623	info	(COMPACT) enabled plugins: mi-flora, _default
        ble.0	2019-09-23 08:54:04.622	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        ble.0	2019-09-23 08:54:04.510	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
        host.Beelink.compactgroup1	2019-09-23 08:54:04.130	info	instance system.adapter.ble.0 started with pid 10634
           2019-09-23 08:54:04.105	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:54:04.104	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        node-red.0	2019-09-23 08:54:03.727	warn	23 Sep 08:54:03 - [warn] Projekte inaktiviert: setze editorTheme.projects.enabled=true zum Aktivieren
        node-red.0	2019-09-23 08:54:03.727	warn	(10445) 23 Sep 08:54:03 - [info] Benutzerverzeichnis: /opt/iobroker/iobroker-data/node-red/
        node-red.0	2019-09-23 08:54:03.317	warn	(10445) 23 Sep 08:54:03 - [warn] rpi-gpio : Pi RPi.GPIO-Python-Bibliothek nicht gefunden
        node-red.0	2019-09-23 08:54:03.311	warn	(10445) 23 Sep 08:54:03 - [warn] rpi-gpio : Raspberry Pi-spezifische Nodes inaktiv
        node-red.0	2019-09-23 08:53:59.523	info	(10445) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
        node-red.0	2019-09-23 08:53:58.974	info	(10445) starting. Version 1.9.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v10.16.3
        host.Beelink	2019-09-23 08:53:57.433	info	instance system.adapter.node-red.0 started with pid 10445
        host.Beelink	2019-09-23 08:53:53.437	info	instance system.adapter.sonoff.0 started with pid 10418
        host.Beelink	2019-09-23 08:53:49.417	info	instance system.adapter.ble.0 is handled by compact group controller pid 8673
        iqontrol.0	2019-09-23 08:53:45.419	info	(COMPACT) state system.adapter.iqontrol.0.sigKill changed: 0 (ack = false)
        host.Beelink	2019-09-23 08:53:45.418	info	instance system.adapter.iqontrol.0 is handled by compact group controller pid 8673
        tr-064-community.0	2019-09-23 08:53:43.109	info	(10087) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
        host.Beelink	2019-09-23 08:53:41.430	info	instance system.adapter.tr-064-community.0 started with pid 10087
        host.Beelink	2019-09-23 08:53:37.456	info	instance system.adapter.zigbee.0 started with pid 10056
        wifilight.0	2019-09-23 08:53:35.007	info	(9890) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v10.16.3
        host.Beelink.compactgroup1	2019-09-23 08:53:34.094	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:53:34.093	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble	2019-09-23 08:53:34.028	error	(9878) ble.0 already running
        ble.0	2019-09-23 08:53:33.778	info	(COMPACT) terminating
        ble.0	2019-09-23 08:53:33.777	info	(COMPACT) terminating
        host.Beelink	2019-09-23 08:53:33.437	info	instance system.adapter.wifilight.0 started with pid 9890
        ble	2019-09-23 08:53:33.287	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        ble	2019-09-23 08:53:33.287	error	(COMPACT) ble.0 already running
        ble.0	2019-09-23 08:53:33.271	info	(COMPACT) terminating
        ble.0	2019-09-23 08:53:33.271	info	(COMPACT) stopping scan
        ble.0	2019-09-23 08:53:33.270	info	(COMPACT) Got terminate signal 9878
        ble.0	2019-09-23 08:53:33.267	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        ble.0	2019-09-23 08:53:33.266	info	(COMPACT) terminating
        ble.0	2019-09-23 08:53:33.265	info	(COMPACT) stopping scan
        ble.0	2019-09-23 08:53:33.264	info	(COMPACT) Got terminate signal -1
        host.Beelink.compactgroup1	2019-09-23 08:53:33.260	info	instance system.adapter.ble.0 started with pid 9878
           2019-09-23 08:53:33.237	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:53:33.237	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        enigma2.0	2019-09-23 08:53:31.542	info	(9519) enigma2 Verbunden!
        host.Beelink	2019-09-23 08:53:29.414	info	instance system.adapter.alexa2.0 is handled by compact group controller pid 8673
        info.0	2019-09-23 08:53:25.426	info	(COMPACT) ack is not set!
        info.0	2019-09-23 08:53:25.425	info	(COMPACT) stateChange system.adapter.info.0.sigKill {"val":0,"ack":false,"ts":1569221605415,"q":0,"from":"system.host.Beelink","lc":1569221570394}
        host.Beelink	2019-09-23 08:53:25.415	info	instance system.adapter.info.0 is handled by compact group controller pid 8673
        host.Beelink	2019-09-23 08:53:21.416	info	instance system.adapter.fritzdect.0 is handled by compact group controller pid 8673
        host.Beelink	2019-09-23 08:53:17.431	info	instance system.adapter.google-sharedlocations.0 started with pid 9550
        enigma2.0	2019-09-23 08:53:16.301	info	(9519) starting Polling every 15000 ms
        enigma2.0	2019-09-23 08:53:16.270	info	(9519) starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v10.16.3
        host.Beelink	2019-09-23 08:53:13.436	info	instance system.adapter.enigma2.0 started with pid 9519
        email.0	2019-09-23 08:53:10.755	info	(9360) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.email, node: v10.16.3
        host.Beelink	2019-09-23 08:53:09.430	info	instance system.adapter.email.0 started with pid 9360
        host.Beelink	2019-09-23 08:53:05.416	info	instance system.adapter.javascript.0 is handled by compact group controller pid 8673
        vr200.0	2019-09-23 08:53:03.576	info	(9174) devices found: 1
        host.Beelink.compactgroup1	2019-09-23 08:53:03.219	info	Restart adapter system.adapter.ble.0 because enabled
        host.Beelink.compactgroup1	2019-09-23 08:53:03.218	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ble.0	2019-09-23 08:53:03.174	info	(COMPACT) starting scan for services ["fe95"]
        ble	2019-09-23 08:53:03.153	error	(9328) ble.0 already running
        ble.0	2019-09-23 08:53:02.837	info	(COMPACT) monitored services: fe95
        ble.0	2019-09-23 08:53:02.835	info	(COMPACT) enabled plugins: mi-flora, _default
        vr200.0	2019-09-23 08:53:02.926	info	(9174) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.vr200, node: v10.16.3
        ble.0	2019-09-23 08:53:02.834	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        ble.0	2019-09-23 08:53:02.728	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
        host.Beelink.compactgroup1	2019-09-23 08:53:02.387	info	instance system.adapter.ble.0 started with pid 9328
           2019-09-23 08:53:02.362	error	ndefined
        host.Beelink.compactgroup1	2019-09-23 08:53:02.361	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
        host.Beelink	2019-09-23 08:53:01.431	info	instance system.adapter.vr200.0 started with pid 9174
        alexa2.0	2019-09-23 08:53:00.806	info	(COMPACT) Alexa-Push-Connection established. Disable Polling
        iqontrol.0	2019-09-23 08:52:59.028	info	(COMPACT) Deleting unused Objects...
        War ne blöde Idee noch mal auf 0.9.0 zurück zu gehen, jetzt startet der BLE Adapter nicht mehr. Bin gerade am reparieren.
        Läuft wieder nach dem der Fixer drüber ist
        root@Beelink:/opt/iobroker# iobroker list instances
        + system.adapter.admin.0                 : admin                 -  enabled, compact enabled (group 1), port: 8081, bind: 0.0.0.0, run as: admin
         system.adapter.admin.1                 : admin                 - disabled, compact disabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                : alexa2                -  enabled, compact enabled (group 1)
        + system.adapter.backitup.0              : backitup              -  enabled, compact enabled (group 1)
        + system.adapter.ble.0                   : ble                   -  enabled, compact enabled (group 1)
        + system.adapter.email.0                 : email                 -  enabled, compact disabled
        + system.adapter.enigma2.0               : enigma2               -  enabled, compact disabled
        + system.adapter.fritzdect.0             : fritzdect             -  enabled, compact enabled (group 1)
        + system.adapter.google-sharedlocations.0: google-sharedlocations -  enabled, compact disabled
        + system.adapter.harmony.0               : harmony               -  enabled, compact enabled (group 1)
        + system.adapter.history.0               : history               -  enabled, compact enabled (group 1)
         system.adapter.ical.0                  : ical                  -  enabled, compact disabled
        + system.adapter.info.0                  : info                  -  enabled, compact enabled (group 1)
        + system.adapter.iot.0                   : iot                   -  enabled, compact enabled (group 1)
        + system.adapter.iqontrol.0              : iqontrol              -  enabled, compact enabled (group 1)
        + system.adapter.javascript.0            : javascript            -  enabled, compact enabled (group 1)
        + system.adapter.milight-smart-light.0   : milight-smart-light   -  enabled, compact disabled
        + system.adapter.node-red.0              : node-red              -  enabled, compact disabled, port: 1880, bind: 0.0.0.0
         system.adapter.openweathermap.0        : openweathermap        -  enabled, compact disabled
        + system.adapter.scenes.0                : scenes                -  enabled, compact disabled
         system.adapter.simple-api.0            : simple-api            -  enabled, compact enabled (group 1), port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                : sonoff                -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled, compact enabled (group 1)
        + system.adapter.telegram.0              : telegram              -  enabled, compact enabled (group 1), port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064-community.0      : tr-064-community      -  enabled, compact disabled
        + system.adapter.vr200.0                 : vr200                 -  enabled, compact disabled
        + system.adapter.web.0                   : web                   -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wifilight.0             : wifilight             -  enabled, compact disabled
        + system.adapter.zigbee.0                : zigbee                -  enabled, compact disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED3DD2-if00
        + instance is alive
          Ok, sehe schon 🙂 alles ok. Ich fixe noch was ... grrrr 🙂
          • SBorg
            SBorg Forum Testing Most Active @apollon77 last edited by
            @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
            @SBorg den git clone Fehler hatte Arteck auch mal plötzlich. Ursache muss irgendwo bei npm liegen...
            Zumindest habe ich ihn jetzt permanent. Ohne "sudo -H..." lässt sich nichts mehr installieren. Die Fehlermeldung seitens npm scheint mir aber auch irreführend. Ich habe ja alle Rechte im tmp-Verzeichnis und spaßeshalber ein chmod 777 darauf bringt keinerlei Besserung. Ev. bringt ja ein neues npm-Release Besserung 😉
              CADYTA last edited by Stabilostick
              Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden, darf der js-controller nicht mir npm aktualisiert werden. Es wird eine neue Version des Windows Installers geben, die das Update des js-controllers mit wenigen Mausklicks ermöglicht. Wir updaten dazu hier im Thread.
              [Edit: Defekte Links entfernt. 24.09.19, stabilostick]
              • AlCalzone
                AlCalzone Developer @SBorg last edited by
                @SBorg sagte in [Aufruf] js-controller 2.0 Beta Test:
                Mal den Fixer ausgeführt?
                • SBorg
                  @AlCalzone Mehrmals, dürfte aber nix bringen, da NPM meckert, dass er im /[User-Verzeichnis]/.npm/_cacache/tmp/git-clone... das Verzeichnis zum DL nicht anlegen kann. Mit NPM 6.4.1 ging es noch, erst mit dem Update auf 6.11.3 trat es bei mir auf. NPM selbst verriet ja noch, dass es bei älteren Versionen durchaus zu Fehlern in den Userrechten kam. Der vorgeschlagene Fix fruchtet aber auch nicht.
                  Ist zumindest kein Problem vom Broker/JS-Controller.
                  AlCalzone 2 Replies Last reply Reply Quote 0
                  • AlCalzone
                    @SBorg Ich sehe üblicherweise die Fehler, dass npm als non-root ausgeführt wird (wie es sein sollte), aber versucht in /root/.npm zu schreiben. Das kommt meiner Erfahrung nach daher, dass die Rechte im Zielordner falsch sind und npm daher auf das falsche Cache-Verzeichnis zugreifen will.
                      e-i-k-e @apollon77 last edited by
                      Danke @apollon77.
                      Habe das komplette System auf 2.0.7 aktualisiert.
                      Leider werden die Adapter auch mit dieser Version erst grün, wenn ich die Slave neustarte.
                      Was mir allerdings gefällt, die Slave Geräte behalten Ihren letzten GPIO (RPI Adapter) Status. (glaube ich ;))
                      Anbei der log vom Slave. iobroker.2019-09-23.log
                      Neustart Master: 18:45 Uhr
                      Neustart Slave: 18:52 Uhr
                      Unabhängig davon werden mit im log vom Master folgenden warn angezeigt.
                      admin.2	2019-09-23 18:46:36.260	info	(1343) starting. Version 3.6.5 in /opt/iobroker/node_modules/iobroker.admin, node: v10.16.3
                      Error	2019-09-23 18:46:32.940	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.939	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.936	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.934	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.919	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.917	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.906	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.904	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.900	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.898	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      Error	2019-09-23 18:46:32.895	warn	from InMemDB: Error: Unknown Script 47ca5e051ba19850d94c45a1fc8725ff04ae868f
                      host.ioBroker-Rock	2019-09-23 18:46:32.380	info	instance system.adapter.admin.2 started with pid 1343
                      host.ioBroker-Rock	2019-09-23 18:46:32.330	warn	Multihost discovery server: service started on 0.0.0.0:50005
                        apollon77 @e-i-k-e last edited by
                        @e-i-k-e hast du hier mal das volle Master log? Kommen sie auch wenn du Admin neu startest?
                        • AlCalzone
                          @SBorg Kannst du mal probieren, den Eigentümer im ioBroker-Ordner zu korrigieren?
                          sudo chown -R iobroker /opt/iobroker
                          Das sollte der Fixer eigentlich machen, aber vielleicht stimmt da ja doch was nicht.
                            e-i-k-e @apollon77 last edited by e-i-k-e
                            @apollon77
                            Anbei das log vom Master.
                            Könntest du dir bitte auch die Uhrzeit ~1.15 Uhr anschauen. Ich habe seit einigen Tagen Probleme mit meinem ioBroker, dieser hängt sich mehrmals täglich auf. Ich wäre dir sehr dankbar.
                            Den Admin habe ich nicht neugestartet. Kann ich aber gerne testen.
                              apollon77 last edited by apollon77
                              Auf GitHub gibt es jetzt die 2.0.8 . Ich habe nochmal das Stoppen und Restarting angeschaut und überarbeitet.
                              Ich habe mal mit meinem Redis/Redis Testsystem getestet und einen Redis restart hat es gut weggesteckt
                              @e-i-k-e Kannst bitte das Slave Thema nochnal checken ... bin gespannt auf die Logs. Das "unknown Skript" kann ich mir eher nicht erklären. States und Objects sind "file" oder Objects in Redis?
                              sigi234 E 2 Replies Last reply Reply Quote 0
                                @e-i-k-e Was passiert denn 1:15? Bringt /var/log/syslog irgendwas zu dem Zeitpunkt? Sieht wie ein Reboot aus ... kann RAM kram sein, kann schlechte Stromversorgung sein oder sowas
                                  sigi234 Forum Testing Most Active @apollon77 last edited by
                                  Läuft.😀
                                    @apollon77
                                    Das sieht sehr gut aus, alle Adapter der Slave sind grün👍
                                    Bei mir sind die Objects in Redis.
                                    Anbei das log vom:
                                    Master: iobroker.2019-09-24.log
                                    Slave: iobroker.2019-09-24.log
                                    Neustart Master: ~00:07Uhr
                                    Neustart Slave: ~00:14 Uhr
                                    apollon77 2 Replies Last reply Reply Quote 1
                                      @e-i-k-e perfekt. Checke es morgen. Jetzt Bett 😉 N8
                                        @apollon77
                                        Eigentlich nichts geplantes. Der Absturz passiert auch zu anderen Uhrzeiten. 😕
                                        Anbei mal das syslog, ich selbst kann da nicht viel mit anfangen. syslog
                                        N8 und bis morgen. 😉
                                          @e-i-k-e sieht alles ok aus. Was war denn da 0:91 los wo wegen „_id of undefined“ die JavaScript Instanz gestorben ist. Passiert das öfter? Ist da ein Script kaputt? Irgendwie reproduzierbar?
                                            @e-i-k-e hast du syslog auch von davor? Das 0:17 s geübt für Zeit gewesen zu sein Die Dieuhr hatte beim restart. Würde dann aber auf 6:XX aktualisiert. Daher denke ichbdad der Crash eher da ist.
                                            Um 6:2x macht das System meistens Daily Aufgaben und so und dadurch kann last entstehen.
                                            Was ist für ein Netzteil dran (wird gerade off topic für diesen Thread) 😉
                                            js-controller
                                            48
                                            1047
                                            305683
