    2. English
    3. Scripting / Logic
    5. ASTRO function. Does not work again
      ap2017 @RappiRN last edited by ap2017
      @RappiRN As you see, I use telegram for debugging, so schedule block works all the time (the light goes on, then off and I am getting notification from telegram), while astro works only once in a while, it works for sure once after restarting RPI by interrupting the power
        @RappiRN May be I was not clear in my response. In ASTRO block, both telegram and setting level do not work (to be precise, work once after resetting power to Raspberry PI). In SCHEDULE block telegram and level setting work fine all the time.
          Ok, in the settings from the javascript-Adapter you must set your location, or check to use the ioBroker location.
          Enrico
            @RappiRN I am aware of this and it was done. Don't forget, in my case ASTRO work right once after fresh power up, it turns up the light in expected time.
              The right once working, is it also at the right time?
              Which location settings you are using, from the adapter or from ioBroker? Sometimes it was a problem to use the ioBroker settings instead the adapter settings.
              Sorry i have not really an idea what the matter with your astro-function.
              Enrico
                @RappiRN Yes, when I say it works right once, it means the timing is right. I tried both location settings, from the adapter as well as from system with same result.
                  ap2017 last edited by
                  Have brand new ioBroker installation on different platform (x64) with same script as show above, the Astro function still does not work. What am I doing wrong?
                  • iomountain
                    iomountain last edited by iomountain
                    @ap2017 for debuging use debug, not telegram.
                    substitute telegram whith debug to see what's going on.
                    Look at the LOG.
                    mine works:
                    c8d8d908-8721-440c-b8e0-f1d21907f888-image.png ,
                    Do you wanna Post an export of your Blockly?
                      ap2017 @iomountain last edited by
                      @iomountain Thank you for your response. I changed my script as you suggested, where do I find debugging log?
                      • iomountain
                        Try Log at main screen Admin
                        There you will find your "debug output" Messages
                          @iomountain I think that after long time of straggling I am getting close to resolving the issue with ASTRO function that I am experiencing. It looks like ASTRO algorithm does not like GEO coordinates in North America since it started to work fine after I set ASTRO for Berlin, Germany. Maybe negative value of Longitude confuses the algorithm?
                          Could you do me a favor and try your script with GEO set to Hartford CT in USA? Thank you.
                          • iomountain
                            It works, United States Hartford 41.76 -72.68
                            If you wanna see all astro times try the Script
                            // Astrotime for today - V2.0
                            console.log("=====================");
                            console.log("Astro time for today");
                            var nightEnd = getAstroDate("nightEnd");
                            console.log(" (0) nightEnd (End of night)........................: " + nightEnd.toLocaleTimeString());
                            var nauticalDawn = getAstroDate("nauticalDawn");
                            console.log(" (1) nauticalDawn (naut. Dämmerung Morgens)...........: " + nauticalDawn.toLocaleTimeString());
                            var dawn = getAstroDate("dawn");
                            console.log(" (2) dawn (Dämmerung Morgens).........................: " + dawn.toLocaleTimeString());
                            var sunrise = getAstroDate("sunrise");
                            console.log(" (3) sunrise (Sonnenaufgang)..........................: " + sunrise.toLocaleTimeString());
                            var sunriseEnd = getAstroDate("sunriseEnd");
                            console.log(" (4) sunriseEnd (Ende des Sonnenaufgangs).............: " + sunriseEnd.toLocaleTimeString());
                            var goldenHourEnd = getAstroDate("goldenHourEnd");
                            console.log(" (5) goldenHourEnd (Ende der Golden Hour VM)..........: " + goldenHourEnd.toLocaleTimeString());
                            var solarNoon = getAstroDate("solarNoon");
                            console.log(" (6) solarNoon (Mittag)...............................: " + solarNoon.toLocaleTimeString());
                            var goldenHour = getAstroDate("goldenHour");
                            console.log(" (7) goldenHour (Start der Golden Hour NM)............: " + goldenHour.toLocaleTimeString());
                            var sunsetStart = getAstroDate("sunsetStart");
                            console.log(" (8) sunsetStart (Start des Sonnenuntergangs).........: " + sunsetStart.toLocaleTimeString());
                            var sunset = getAstroDate("sunset");
                            console.log(" (9) sunset (Sonnenuntergang).........................: " + sunset.toLocaleTimeString());
                            var dusk = getAstroDate("dusk");
                            console.log("(10) dusk (Dämmerung Abends)..........................: " + dusk.toLocaleTimeString());
                            var nauticalDusk = getAstroDate("nauticalDusk");
                            console.log("(11) nauticalDusk (naut. Dämmerung Abends)............: " + nauticalDusk.toLocaleTimeString());
                            var night = getAstroDate("night");
                            console.log("(12) night (Start of night)..........................: " + night.toLocaleTimeString());
                            var nadir = getAstroDate("nadir");
                            console.log("(13) nadir (midnight)..............................: " + nadir.toLocaleTimeString());
                            var today = new Date();
                            var tomorrow = today.setDate(today.getDate()+1);
                            var tomorrowNight = getAstroDate("night", tomorrow);
                            console.log("Night starts tomorrow at " + tomorrowNight.toLocaleTimeString());
                            console.log(obj.id);
                            @ap2017
                              @iomountain I will try to set ASTRO back to US, thanks
                              • iomountain
                                @ap2017 don't forget to restart iobroker. Like "iobroker stop" and "iobroker start"
                                A 2 Replies Last reply Reply Quote 0
                                  @iomountain Day I switched to US the ASTRO stopped working (no ASTRO string in LOG file). I restarted computer after I made a change. I will try your ASTRO script
                                  Here is my script:
                                  // Living Room Light
                                  schedule({astro: "goldenHour", shift: 0}, function () {
                                  console.log('astro_on');
                                  setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                                  schedule("0 18 * * *", function () {
                                  console.log('schedule_on');
                                  schedule("30 23 * * *", function () {
                                  console.log('schedule_off');
                                  setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                                    @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
                                    2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
                                    2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
                                    2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
                                    2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                                    2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                    2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
                                    2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
                                    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
                                    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
                                    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
                                    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
                                    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
                                    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
                                    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
                                    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
                                    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
                                    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
                                    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
                                    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
                                    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
                                    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                    2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
                                    2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
                                    2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
                                    2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
                                    2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
                                    2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
                                    2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
                                    iomountain 1 Reply Last reply Reply Quote 0
                                    • iomountain
                                      iomountain @ap2017 last edited by
                                      @ap2017 sagte in ASTRO function:
                                      shows that the AstroFunktion works
                                      What about the log of your script?
                                        @iomountain Here is my complete log from yesterday. Notice that in 18:58 I added your script with ASTRO Time for Day. Thank you for your help!
                                        10-20-19 Log.txt
                                        • iomountain
                                          something going wrong with ASTRO, still testing.
                                          • iomountain
                                            Could you please test this for 24 hours:
                                             <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
                                               <field name="COMMENT">Test Astro</field>
                                                 <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
                                                   <field name="TYPE">sunrise</field>
                                                   <field name="OFFSET">0</field>
                                                     <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                                                       <field name="Severity">error</field>
                                                       <value name="TEXT">
                                                         <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                                                           <field name="TEXT">Sonnenaufgang</field>
                                                         <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                                                             <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                                                               <mutation format="true" language="false"></mutation>
                                                               <field name="OPTION">custom</field>
                                                               <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                                                     <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                                                       <field name="TYPE">sunriseEnd</field>
                                                         <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                                                               <field name="TEXT">Sonnenaufgang ende</field>
                                                             <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                                                               <value name="TEXT">
        <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                                                         <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                                                           <field name="TYPE">goldenHourEnd</field>
                                                             <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                                                               <value name="TEXT">
        <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
        <field name="TEXT">Golden hour Ende</field>
        <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
        <value name="TEXT">
        <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                                                             <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                                                               <field name="TYPE">solarNoon</field>
        <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
        <value name="TEXT">
        <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
        <field name="TEXT">Sonnenmittag</field>
        <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
        <value name="TEXT">
        <block type="time_get" id="63mXGB7G3:L?++1KLilu">
        <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
        <field name="TYPE">goldenHour</field>
        <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
        <value name="TEXT">
        <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
        <field name="TEXT">Golden hour</field>
        <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
        <value name="TEXT">
        <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
        <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
        <field name="TYPE">sunsetStart</field>
        <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
        <value name="TEXT">
        <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
        <field name="TEXT">Sonnenuntergang Anfang</field>
        <block type="debug" id="88*2`mY-$F4-h46R$bsh">
        <value name="TEXT">
        <block type="time_get" id="=yV74{gTTEshyETA[YT+">
        <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
        <field name="TYPE">sunset</field>
        <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
        <value name="TEXT">
        <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
        <field name="TEXT">Sonnenuntergang</field>
        <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
        <value name="TEXT">
        <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
        <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
        <field name="TYPE">dusk</field>
        <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
        <value name="TEXT">
        <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
        <field name="TEXT">Abenddämmerung</field>
        <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
        <value name="TEXT">
        <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
        <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
        <field name="TYPE">nauticalDusk</field>
        <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
        <value name="TEXT">
        <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
        <field name="TEXT">Nautische Abenddämmerung</field>
        <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
        <value name="TEXT">
        <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
        <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
        <field name="TYPE">night</field>
        <block type="debug" id="76(?!SO)O1xP:}liKAC%">
        <value name="TEXT">
        <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
        <field name="TEXT">Nacht</field>
        <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
        <value name="TEXT">
        <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
        <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
        <field name="TYPE">nightEnd</field>
        <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
        <value name="TEXT">
        <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
        <field name="TEXT">Nachtende</field>
        <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
        <value name="TEXT">
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
        <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
        <field name="TYPE">nauticalDawn</field>
        <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
        <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
        <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
                                            blockly
                                            7589
