    4. Test js-controller v2.0.x (GitHub)
      ChrisXY last edited by
      @apollon77 Leider auch hier mit der neuen Version. Was nun neu ist das 2x Connected auftaucht
      Connecting to previous DB "file"...
      Creating backup ...
      This can take some time ... please be patient!
      host.iobroker 16726 states saved
      host.iobroker 19327 objects saved
      Backup created: /opt/iobroker/backups/2019_10_01-17_06_19_backupiobroker-migration.tar.gz
      Connecting to new DB "redis" ...
      connected
      connected
      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:28
              if (!options.states) throw 'Invalid arguments: states is missing';
        apollon77 @ChrisXY last edited by
        @ChrisXY ich hab nochmal was geändert: Installier nochmal neu. Version bleibt gleich. Was ist jetzt die Ausgabe?
          darkiop Most Active @apollon77 last edited by
          @apollon77 Unsere Vermutung war Richtig, mit nem sleep 10 passts ...
          Grundsätzlich sollte der iobroker aber ja erst starten nach dem das Netzwerk oben ist ... 😄
          #!/bin/bash
          ### BEGIN INIT INFO
          # Provides:          iobroker.sh
          # Required-Start:    $network $local_fs $remote_fs
          # Required-Stop:     $network $local_fs $remote_fs
          # Should-Start:      redis-server
          # Should-Stop:       redis-server
          # Default-Start:     2 3 4 5
          # Default-Stop:      0 1 6
          # Short-Description: starts ioBroker
          # Description:       starts ioBroker
          ### END INIT INFO
          PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
          NODECMD=$(which node)
          RETVAL=0
          start() {
          echo -n "Starting ioBroker"
          sleep 10
          su - iobroker -s "/bin/bash" -c "$NODECMD /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start"
          RETVAL=$?
          stop() {
          echo -n "Stopping ioBroker"
          su - iobroker -s "/bin/bash" -c "$NODECMD /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js stop"
          RETVAL=$?
          if [ "$1" = "start" ]; then
          start
          elif [ "$1" = "stop" ]; then
          stop
          elif [ "$1" = "restart" ]; then
          stop
          start
          else
          echo "Usage: iobroker \{start\|stop\|restart\}"
          exit 1
          fi
          exit $RETVAL
          Stabilostick 1 Reply Last reply Reply Quote 0
          • coyote
            coyote Most Active @apollon77 last edited by
            @apollon77 jetzt bekomm ich das hier (neueste Version):
            Creating backup ...
            host.debian 38611 states saved
            host.debian 44497 objects saved
            Backup created: /opt/iobroker/backups/2019_10_01-17_30_24_backupiobroker-migration.tar.gz
            States  NOT connected
            Objects NOT connected
            New Database could not be connected. Please check your settings. No settings have been changed.
            root@debian:/opt/iobroker#
              @apollon77 exakt das selbe wie bei coyote
              • Stuebi
                Stuebi @ChrisXY last edited by
                @ChrisXY , den Ring Fehler habe ich behoben, aber die Version befindet sich noch lokal auf meiner Entwicklungsumgebung.
                Ich werde das heute Abend hoffentlich freigeben. Ich muss nur neue Features die noch nicht fertig umgesetzt sind (habe wenig Zeit, da ich einen neuen Job habe) ausbauen.
                C 1 Reply Last reply Reply Quote 1
                  ChrisXY @Stuebi last edited by
                  @Stuebi Uhh das hört sich ja sehr gut an. Bin sehr gespannt 🙂 Danke
                  Stuebi 1 Reply Last reply Reply Quote 0
                    apollon77 @coyote last edited by
                    @coyote und redis-cli tut? Ihr kommt auf den redis selbst drauf von dem Host aus?
                    • Stabilostick
                      Stabilostick @darkiop last edited by Stabilostick
                      @darkiop sagte in [Aufruf] js-controller 2.0 Beta Test:
                      Der Slave kommt dann auch nicht mehr automatisch auf die Beine nach einen Reboot, starte ich ihn aber manuell mit iobroker start schafft er es:
                      Mir fällt auf, dass Du dann Probleme hast, wenn der Slave keine IPv4-Adresse hat:
                      Hast Du schon einmal nachgesehen, was in Deiner Infrastruktur zu diesem Zustand nach dem Booten führt?
                      Wenn der Fehler das nächste Mal passiert, dann gib in der Konsole ifconfig eth0 ein (falls Dein Netzwerkinterface eth0 ist).
                      Wenn dort im Inet-Eintrag Deine IPv4-Adresse erscheint, dann ist die Konfiguration in Ordnung. Sonst gibst Du in der Konsole einfach sudo dhclient eth0 ein.
                      Dann sollte eine neue ipv4-Adresse vom DHCP-Server gezogen werden. Mit dem Befehl von oben kannst Du das dann wieder prüfen.
                      Und: Kann Dein Master überhaupt IPv6?
                        darkiop Most Active @Stabilostick last edited by darkiop
                        @Stabilostick Stimmt, das sieht stark danach aus als hätte der RPI zu diesem Zeitpunkt noch keine IPv4 Adresse.
                        Die kommt bei mir von einem Unifi Security Gateway. IPv6 habe ich da eigentlich auch nicht aktiv.
                        Startet der js-controller2.0 schneller als der 1.5 und es kommt so zu diesem Zustand? 🙂
                        apollon77 Stabilostick 2 Replies Last reply Reply Quote 0
                          apollon77 @darkiop last edited by
                          @darkiop schneller starten : mag sein. Wie oben schon gesagt sind es jetzt auch reine TCP Verbindungen. Interessanter Effekt.
                          Versuch doch mal ein Delay im init Skript ..
                          • Stabilostick
                            @darkiop Auf dem Master IPv6 aktivieren und glücklich sein. 😎
                            • coyote
                              @apollon77 was brauchst du denn genau? Reicht ein redis-cli ping und es kommt ein PONG zurück?
                              Oder brauchst du redis-cli info?
                              Redis Server habe ich in der gleichen VM installiert wie iobroker
                                @apollon77 Das habe ich, siehe ein paar Beiträge weiter oben. Mit nem sleep 10 bzw. zur Sicherheit sleep 15 läuft es erstmal Quick n Dirty.
                                Aktuell habe ich das Probelm, das sich ioBroker nicht merkt welche Adapter gestartet sind. Nach einen Reboot sind alle bis auf admin.0 und backitup.0 deaktiviert. Das war der Ausgangszustand nach dem Restore aus dem minimal Backup. Fixer hab ich bereits laufen lassen.
                                Wo wird denn gespeichert welcher Adapter aktiv sein soll?
                                paul53 Stabilostick apollon77 3 Replies Last reply Reply Quote 0
                                  @Stabilostick der Master ist ein Docker Container welcher mit
                                  --network=mac0 \
                                  --ip=192.168.1.82 \
                                  --dns=192.168.1.43 \
                                  mit einer fixen IPv4 versehen wurde. Auf diese IP habe ich hier im lokalen LAN auch einen DNS Namen vergeben.
                                  IPv6 ist aktuell noch eine Blackbox für mich 🙂
                                    paul53 @darkiop last edited by
                                    @darkiop sagte:
                                    In der Eigenschaft common.enabled des Instanz-Objektes system.adapter.adaptername.N.
                                    • Stabilostick
                                      @darkiop
                                      Im Ernst:
                                      Hast Du einen Pi 4? Da haben mehr Leute Probleme:
                                      https://github.com/raspberrypi/linux/issues/3034
                                      https://github.com/raspberrypi/linux/issues/3108
                                      mii-tool -r eth0
                                      ist da der Workaround.
                                      M-Reimer created this issue in raspberrypi/linux
                                      closed Raspberry Pi 4: Network non-functional directly after (re)boot #3034
                                      open Raspberry Pi 4: Network non-functional directly after (re)boot #3108
                                        @Stabilostick Ja ist ein Pi4. Danke schaue ich gleich mal rein.
                                          darkiop Most Active @paul53 last edited by
                                          @paul53 Hier? Da gibt es die nicht.
                                            @darkiop sagte:
                                            Hier?
                                            Nein, das ist ein Datenpunkt, der den Zustand anzeigt.
                                            Direkt darüber ist das Objekt "system.adapter.bring.0", dessen Eigenschaften man mit dem Bleistift-Symbol rechts sehen kann.
                                            js-controller
                                            48
                                            1047
                                            294975
