    4. Test js-controller v2.0.x (GitHub)
    • SBorg
      Hier mal das Debug-Log, Issue mache ich dann heute früh dazu:
      2019-10-01 19:26:02.883 - debug: daswetter.0 (23979) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2019-10-01 19:26:03.100 - debug: daswetter.0 (23979) objectDB connected
      2019-10-01 19:26:03.108 - debug: daswetter.0 (23979) Redis States: Use Redis connection: 127.0.0.1:9000
      2019-10-01 19:26:03.114 - debug: daswetter.0 (23979) Objects connected to redis: 127.0.0.1:9001
      2019-10-01 19:26:03.129 - debug: daswetter.0 (23979) statesDB connected
      2019-10-01 19:26:03.196 - debug: daswetter.0 (23979) States connected to redis: 127.0.0.1:9000
      2019-10-01 19:26:04.073 - info: daswetter.0 (23979) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.16.1
      2019-10-01 19:26:04.134 - debug: daswetter.0 (23979) set timeout to 60 sec
      2019-10-01 19:26:04.135 - debug: daswetter.0 (23979) using new data structure
      2019-10-01 19:26:04.138 - debug: daswetter.0 (23979) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxx&affiliate_id=xxx
      2019-10-01 19:26:04.496 - debug: daswetter.0 (23979) 7 days forecast done, objects in list 107
      2019-10-01 19:26:04.499 - debug: daswetter.0 (23979) calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxx&affiliate_id=xxx&v=2.0
      2019-10-01 19:26:04.892 - debug: daswetter.0 (23979) 5 days forecast done, objects in list 1059
      2019-10-01 19:26:04.896 - debug: daswetter.0 (23979) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=xxx&affiliate_id=xxx&v=2.0&h=1
      2019-10-01 19:26:05.797 - debug: daswetter.0 (23979) hourly forecast done, objects in list 2699
      2019-10-01 19:26:05.801 - debug: daswetter.0 (23979) objects in list: 2699
      2019-10-01 19:27:04.135 - error: daswetter.0 (23979) force terminate, objects still in list: 1777
      2019-10-01 19:27:04.184 - error: host.Ubuntu instance system.adapter.daswetter.0 terminated with code 15 (15)
        darkiop Most Active @Stabilostick last edited by
        @Stabilostick Die Firmware des RPI4 ist aktuell.
          darkiop Most Active @apollon77 last edited by darkiop
          @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
          Also das darf an sich nicht passieren. Ja, nach dem Restore sind erstmal alle Adapter ausser Admin deaktiviert. Kann er bei änderungen das objects.json File (glaube bist ja nicht auf Redis) neu schreiben? Nicht das da was kaputt ist. Wenn Du den Adapter im Admin wieder aktivierst muss das persistiert werden ... Schau mal ob sich das File Date ändert.
          Unter 2.0.18 ändert sich die objects.json definitiv nicht. Hab Testweise den info.0 beendet, die objects.json blieb unverändert. Dann wieder zurück zur 1.5.14 und hier wird sie nach ein Änderung immer neu angelegt.
          Genau, Ich bin noch auf file/file - bin mir nicht sicher ob es Sinn macht im aktuellen Zustand auf redis/redis zu gehen. Grundsätzlich fühlt sich das ganze System gerade nicht mehr gut an, heute Morgen war auch unter 1.5.14 das System zusammengebrochen. Ich hatte irgendwann mal einen nächtlichen Restart für den javascript.0 eingeplant und der hat folgendes geworfen. Danach war dann wohl admin.0/web.0 nicht mehr zu erreichen obwohl die Prozesse noch liefen. Bei einem manuellen Restart des javascript.0 ist der Fehler reproduzierbar.
          2019-10-02 07:28:24.595  - error: Caught by controller[0]: (node:20475) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'enabled' of undefined
          2019-10-02 07:28:24.595  - error: Caught by controller[1]: (node:20475) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
          2019-10-02 07:28:24.596  - error: Caught by controller[1]: (node:20475) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          Die 2.0.18 hat auch leider nicht geholfen bzgl. des IPv4 Themas. Und dazu kommt jetzt noch, das nach der Installation der 2.0.18 (danach lasse ich auch immer noch schnell den fixer laufen) der iobroker-hwr nicht mehr mit init.d sondern mit systemd gestartet wird, d.h. mein sleep-fix ist weg 🙂
            ChrisXY @apollon77 last edited by
            @apollon77 hm ich denke nicht der redis client kann sich ja auch verbinden ..
            Neuste Version von gerade hat auch nicht geklappt:
            Connecting to previous DB "file"...
            Creating backup ...
            This can take some time ... please be patient!
            host.iobroker 16727 states saved
            host.iobroker 19327 objects saved
            Backup created: /opt/iobroker/backups/2019_10_02-07_55_13_backupiobroker-migration.tar.gz
            Connecting to new DB "redis" ...
            States  NOT connected
            Objects NOT connected
            New Database could not be connected. Please check your settings. No settings have been changed.
              e-i-k-e @apollon77 last edited by
              @apollon77
              Okay ich bin mal auf die Suche genagen. habe NPM 6.9.0 und NPM x.x.x (aktuelle Version) auf meinem System gehabt. Das konnte ich beheben. Allerdings wird mir immer noch der selbe Fehler angezeigt. Könnte ich noch eine eine dritte Version auf meinem System haben? Wenn ja, wie finde ich die?
                e-i-k-e last edited by e-i-k-e
                Version 2.0.17
                Hatte heute morgen folgende Warnungen im log.
                avascript.0	2019-10-02 08:46:29.966	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:29.966	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:29.965	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:29.965	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:29.965	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.965	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:29.965	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:29.965	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:29.964	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:29.964	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:29.964	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.964	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:29.964	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:29.964	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:29.963	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:29.963	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:24:5)
                javascript.0	2019-10-02 08:46:29.962	warn	(15268) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1276:20)
                javascript.0	2019-10-02 08:46:29.961	warn	(15268) State "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found
                javascript.0	2019-10-02 08:46:29.961	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:29.960	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:29.960	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:29.960	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:29.960	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.960	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:29.960	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:29.959	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:29.959	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:29.959	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:29.959	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.959	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:29.959	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:29.958	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:29.958	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:29.958	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:23:7)
                javascript.0	2019-10-02 08:46:29.956	warn	(15268) getState "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found (3)
                javascript.0	2019-10-02 08:46:29.667	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:29.666	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:29.666	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:29.666	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:29.666	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.666	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:29.666	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:29.665	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:29.665	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:29.665	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:29.665	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.665	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:29.664	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:29.664	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:29.664	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:29.664	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:24:5)
                javascript.0	2019-10-02 08:46:29.664	warn	(15268) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1276:20)
                javascript.0	2019-10-02 08:46:29.663	warn	(15268) State "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found
                javascript.0	2019-10-02 08:46:29.662	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:29.662	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:29.662	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:29.662	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:29.662	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.661	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:29.661	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:29.661	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:29.661	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:29.661	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:29.660	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.660	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:29.660	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:29.660	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:29.660	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:29.659	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:23:7)
                javascript.0	2019-10-02 08:46:29.658	warn	(15268) getState "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found (3)
                javascript.0	2019-10-02 08:46:29.245	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:29.245	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:29.245	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:29.245	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:29.245	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.245	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:29.244	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:29.244	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:29.244	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:29.244	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:29.244	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.244	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:29.243	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:29.243	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:29.243	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:29.243	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:24:5)
                javascript.0	2019-10-02 08:46:29.243	warn	(15268) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1276:20)
                javascript.0	2019-10-02 08:46:29.242	warn	(15268) State "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found
                javascript.0	2019-10-02 08:46:29.241	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:29.241	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:29.241	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:29.241	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:29.241	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.241	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:29.240	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:29.240	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:29.240	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:29.240	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:29.240	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:29.239	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:29.239	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:29.239	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:29.239	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:29.238	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:23:7)
                javascript.0	2019-10-02 08:46:29.236	warn	(15268) getState "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found (3)
                javascript.0	2019-10-02 08:46:28.946	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:28.945	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:28.945	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:28.945	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:28.945	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.945	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:28.944	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:28.944	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:28.944	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:28.944	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:28.943	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.943	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:28.943	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:28.943	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:28.942	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:28.942	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:24:5)
                javascript.0	2019-10-02 08:46:28.942	warn	(15268) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1276:20)
                javascript.0	2019-10-02 08:46:28.941	warn	(15268) State "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found
                javascript.0	2019-10-02 08:46:28.941	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:28.940	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:28.939	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:28.939	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:28.939	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.939	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:28.939	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:28.939	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:28.938	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:28.938	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:23:7)
                javascript.0	2019-10-02 08:46:28.937	warn	(15268) getState "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found (3)
                javascript.0	2019-10-02 08:46:28.483	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:28.483	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:28.483	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:28.483	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:28.482	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.482	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:28.482	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:28.482	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:28.482	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:28.482	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:28.481	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.481	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:28.481	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:28.481	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:28.481	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:28.481	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:24:5)
                javascript.0	2019-10-02 08:46:28.480	warn	(15268) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1276:20)
                javascript.0	2019-10-02 08:46:28.479	warn	(15268) State "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found
                javascript.0	2019-10-02 08:46:28.479	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:28.479	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:28.479	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:28.478	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:28.478	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.478	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:28.478	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:28.477	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:28.477	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:28.477	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:28.477	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.477	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:28.476	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:28.476	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:28.476	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:28.476	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:23:7)
                javascript.0	2019-10-02 08:46:28.474	warn	(15268) getState "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found (3)
                javascript.0	2019-10-02 08:46:28.188	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:28.188	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:28.188	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:28.188	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:28.188	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.187	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:28.187	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:28.187	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:28.187	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                javascript.0	2019-10-02 08:46:28.187	warn	(15268) at DataHandler.handleSubscriberReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:87:32)
                javascript.0	2019-10-02 08:46:28.187	warn	(15268) at Redis.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.186	warn	(15268) at Redis.sub.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:202:37)
                javascript.0	2019-10-02 08:46:28.186	warn	(15268) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4554:37)
                javascript.0	2019-10-02 08:46:28.186	warn	(15268) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:378:25)
                javascript.0	2019-10-02 08:46:28.186	warn	(15268) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:38)
                javascript.0	2019-10-02 08:46:28.186	warn	(15268) at Object.<anonymous> (script.js.Magiccube_zur_Steuerung_Wohnzimmer:24:5)
                javascript.0	2019-10-02 08:46:28.185	warn	(15268) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1276:20)
                javascript.0	2019-10-02 08:46:28.184	warn	(15268) State "milight-smart-light.0.Stehlampe_Sofs.fullColor-1.whiteTemperature" not found
                javascript.0	2019-10-02 08:46:28.184	warn	(15268) at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
                javascript.0	2019-10-02 08:46:28.184	warn	(15268) at Socket.Readable.push (_stream_readable.js:224:10)
                javascript.0	2019-10-02 08:46:28.184	warn	(15268) at readableAddChunk (_stream_readable.js:269:11)
                javascript.0	2019-10-02 08:46:28.184	warn	(15268) at addChunk (_stream_readable.js:288:12)
                javascript.0	2019-10-02 08:46:28.184	warn	(15268) at Socket.emit (events.js:198:13)
                javascript.0	2019-10-02 08:46:28.183	warn	(15268) at Socket.DataHandler.redis.stream.on.data (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:25:20)
                javascript.0	2019-10-02 08:46:28.183	warn	(15268) at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:544:14)
                javascript.0	2019-10-02 08:46:28.183	warn	(15268) at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:21:22)
                javascript.0	2019-10-02 08:46:28.183	warn	(15268) at DataHandler.returnReply (/opt/iobroker/node_modules/ioredis/built/DataHandler.js:47:18)
                  apollon77 @SBorg last edited by
                  @SBorg Also das Log sieht an sich ok aus, würde nur bedeuten das bei dir das setzen der 2699 Objekte und Daten (hollala) sehr langsam ist und er einfach nicht fertig wird. Bisher ist bei keinen so eine schlechte Performance gesehen worden. Strange. Muss ich versuchen nachzustellen. Erklären kann ich es mir nicht. Bisher weder bei Arteck noch anderen in der Form passiert
                    apollon77 @darkiop last edited by
                    @darkiop Ich habe noch ein was gefunden was abhänfig von der nodejs Version vllt die Ursache gewesen sein könnte. Wenn die Objects.json jetzt nicht gespeichert wird (der timeout sind 5s nach letzter Änderung an Objekten) bin ich wieder ratlos. Eine 2.0.19 kommt gleich
                    Auch für das komische mit Javascript und danach andere Adapter ist sehr Strange, Müsste man jetzt genau logs schauen.
                    File/File ist komplett ok, war nur für mich zur Klarstellung.
                    ich kapiere nur immer noch nicht warum das mit ipv6 nicht tut 😞
                      apollon77 @e-i-k-e last edited by
                      @e-i-k-e sagte in [Aufruf] js-controller 2.0 Beta Test:
                      DIe meldung sagt das er auf diesen State zugreifen will der aber nicht existiert bzw keinen Wert zu haben scheint. Was zeigen die Objekte? Ist der da der State?
                        @e-i-k-e Der selbe fehler? Du meinst diese vis widget auto install fehler?
                        Ok, dann schauen wir da rein: Zeig mal den Raw Objekt Inhalt von system.adapter.vis-material UND system.adapter.vis-material.0
                        Der Adapte rist in Vereuon 0.1.5 und im latest repo (und damit npm) nur in 0.1.3
                        Und bitte screenshot wie der Admin aussieht für den Adapter im Adapter-Tab
                          darkiop Most Active last edited by
                          @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                          Ok, dann teste ich die direkt heute Mittag. Spiele hier auch gerne weiterhin den Tester - Morgen evtl. weniger Zeit dafür, aber Freitag passt es wieder.
                          Soll ich dir die kompletten Logs mal zukommen lassen? Wenn ja schick mir einfach mal deine Mail Adresse per PN.
                          apollon77 2 Replies Last reply Reply Quote 0
                            apollon77 @ChrisXY last edited by
                            @ChrisXY Ok, kann es reproduzieren ... fix in Arbeit
                              This post is deleted!
                                @darkiop sagte in [Aufruf] js-controller 2.0 Beta Test:
                                Gern, aber wenns geht mit "zeit-pointern" 🙂 Sonst such ich nahc der Nadel im heuhaufen.
                                iobroker@fischer-ka.de
                                  2.0.19 auf GitHub:
                                  • (Apollon77) fix migration
                                  • (Apollon77) fix potential cases where objects/states files were not stored
                                  D coyote 2 Replies Last reply Reply Quote 0
                                  • SBorg
                                    SBorg Forum Testing Most Active @apollon77 last edited by
                                    Gotcha 🙂
                                    Unter 1.5.14 hatte ich 60 Sekunden und funktioniert.
                                    Da es seit 2.x nicht mehr ging hatte ich versuchsweise 120 Sekunden, ging auch nicht.
                                    Nach deinem Post habe ich es jetzt auf 5 Minuten erhöht und es geht. Strange, denn dann wäre es > 5x langsamer
                                      apollon77 @SBorg last edited by apollon77
                                      @SBorg Hast Du noch alte 1.5.x logs um zu sehen wie lange zwischen start und end war und wie lange es jetzt ist? hast ja die "starting " und "wurde beendet" logs ...
                                      Und: Was ist das für ein System? Effektiv das wo der Master läuft (wil ist ja file/file korrekt?)
                                        Funktioniert! Daumen hoch!
                                        Logs schicke ich später.
                                          @darkiop Strange nummer. Welche nodejs version hast du?
                                          • coyote
                                            coyote Most Active @apollon77 last edited by coyote
                                            @apollon77 leider will redis immer noch nicht...
                                            Creating backup ...
                                            Backup created: /opt/iobroker/backups/2019_10_02-13_54_13_backupiobroker-migration.tar.gz
                                            Kann ich sonst noch irgendwas überprüfen, wo es haken könnte?
                                            js-controller
                                            48
                                            1047
                                            310067
