    4. Gelöst! Floureon 1080P Dome Kamera und VIS
      probier hier mit
      [{"tpl":"tplMfdCamSnapshot","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"interval":"1000","dialog_width":"800","dialog_height":"550","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"url":"http://192.168.178.20/browse/mjpeg/shot.htm","dialog_top":"10","dialog_left":"10","autoclose":"30000","name":"kamera tür","class":"","title":"Eingang"},"style":{"left":"692px","top":"700px","z-index":"1","width":"70px","height":"63px"},"widgetSet":"jqui-mfd"}]
        Peller6151 last edited by
        Danke dir für die Hilfe,
        habs ausprobiert. Leider ist nur ein Fragezeichen zu sehen. Obwohl die Passwortabfrage kommt.
        Der Link funktioniert aber bei jedem verfügbaren Broser. Ein Bild zeit er dort an.
        Hab mal das Iframe Tile Dialoge Widget ausprobiert. Dort den Pfad eingegeben. Und siehe da, ein Bild. Allerdings nur wenn ich auf das Fenster Tippe. Leider nicht das was ich brauche, zumal ich kein Vorschaubild habe und das Bild sich nicht aktualisiert.
          dann mal was zum lesen
          https://www.ispyconnect.com/man.aspx?n=floureon#
            Die Seite kenne ich. Habe alles ausprobiert.
            Es ging tatsächlich nur der Link den ich oben angegeben habe.
            Was ich nicht verstehe, dass es im Browser geht, aber in keinem cam-Widgets.
            • Ralla66
              Ralla66 Most Active last edited by
              Probiere mal
              http ://Benutzername:Passwort@192.168.178.20/browse/mjpeg/shot.htm
              oder Video
              rtsp ://admin:admin@IP-Adresse/1/h264major
              rtsp ://IP-Adresse/1/h264major
                @Ralla66:
                Probiere mal
                oder Video
                rtsp ://IP-Adresse/1/h264major `
                Super, damit hat es geklappt.
                Lieben Dank!
                • Ralla66
                  Prima,
                  schreibe bitte oben im Thema gelöst.
                  Unter Icon und Dialog deine URL eintragen, dann kannst du mit einem klick in Vis das Bild vergrößern.
                  Bild anbei.
                  :mrgreen:
                    blacktiger last edited by
                    Ich habe die gleich Cam und würde diese auch gerne in ioBroker einbinden. 2 Foscams konnte ich ohne Probleme bereits einbinden. Habe die URL wie beschrieben verwendet - klappt auch im Browser bei mir. In ioBroker klappts bei mir leider nicht - welches Widget hast du dafür genommen? Könntest du das eventuell mit in die Antwort kopieren? Mit dem Widget von Ralla66 hat es nicht geklappt. Ich würde gerne das Bild als selbst aktualisierendes Icon visualieren bzw. bei Klick darauf als Dialog öffnen - bei den anderen Cams (Foscams) habe ich das hinbekommen…..
                      RalfEngelberth @blacktiger last edited by
                      Ich habe das gleiche Problem wie blacktiger.
                      Ich habe verschiedene Icon ausprobiert und bekomme die unterschiedlichsten Ergebnisse.
                      Im VLC-Player bekomme ich alle Cams angezeigt.
                      Meine Cams sind von Geovision, Sricam und Floureon.
                      Visualisiere ich meine Cams über IoBroker werden aber nicht alle angezeigt.
                      Es gibt auch Unterschiede, ob ich einen PC, IPad oder Samsung-Pad verwende.
                      Es dauert auch min. 1 min. bis das ein Bild im Icon angezeigt wird.
                      Als Icon habe ich auch schon einige ausprobiert.
                      Die besten Ergebnisse erhalte ich mit dem jqui-mfd - Cam/Snapshot - Dialog.
                      hat noch einer einen Tipp?
                        RalfEngelberth @RalfEngelberth last edited by
                        @RalfEngelberth sagte in Gelöst! Floureon 1080P Dome Kamera und VIS:
                        Hat keiner einen Vorschlag?
                        • Glasfaser
                          Glasfaser @RalfEngelberth last edited by
                          Firefox schon mal ausprobiert !?
                          Nutze das Widget Basic Image über Einzelbilder .. Updateintervall 1400ms .
                            Danke Glasfaser,
                            der Tipp mit Firefox war schon gut.
                            Jetzt werden mir alle Cams angezeigt.
                            Der Tipp mit dem Widget Basic Image über Einzelbilder .. Updateintervall 1400ms funktioniert aber nur bei der Floureon.
                            Hier der Code:http://user:password@192.168.1.xx/snap.jpg?usr=user&pwd=password
                            Wenn ich das Widget Basic Image über Einzelbilder .. Updateintervall 1400ms mit der Geovision mache bekomme ich nichts angezeigt.
                            Hier der Code: http://www.xxxxxx.de:87/mjpeg?cam=9
                            Ich hatte vorher das Widget "jqui-mfd - cam/Snapshot - Dialo" .
                            Hier öffnete sich beim Anklicken ein Fenster mit dem Videobild.
                            Kann ich das hiermit auch realisieren?
                            • Glasfaser
                              @RalfEngelberth
                              Du musst schon mit dem Updateintervall ein wenig rumspielen bis es irgendwie bei dir passt .
                              Bei mir waren es 1400ms ,wenn ich darunter bin wird mir auch nichts mehr angezeigt !
                              3878
