Anwesenheit mit 2 Personen
Blocklyimport
<xml xmlns="http://www.w3.org/1999/xhtml"> <block type="on_ext" id="Jh[=rfzMv*8me+BZSL,1" x="63" y="-87"> <mutation items="2"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="vA(aMx#j?#RdTmQiZ!Pn"> <field name="oid">radar2.0.Mi8</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="[MO:0aHP1UmWa}lKP+Pa"> <field name="oid">radar2.0.RedMi5Plus</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="+nr4Q.X)L~Cn|kLQkYzc"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="/K,ghpx,wJfJ7W`7Ws4o"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="$zNh)Ncf$frBFAWa_7i|"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="]OqOcY/EcQX|%-46;CpI"> <field name="ATTR">val</field> <field name="OID">radar2.0.Mi8</field> </block> </value> <value name="B"> <block type="logic_boolean" id="0p7ZL:e0f}@s~dEKa1[."> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="g^y$j^X@Ye+oUgFhUng*"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="6}(=WW/NwMkiw0aZ|5P7"> <field name="ATTR">val</field> <field name="OID">radar2.0.RedMi5Plus</field> </block> </value> <value name="B"> <block type="logic_boolean" id="+hT(L4z;:CQxUD!ei2;x"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="update" id="8/*P1Txi_+8.@W%h|)aw"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.jemandanwesend</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="Dt)){5!D#pO{?T86,1Zh"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <value name="IF1"> <block type="logic_operation" id="30k$#%/o(._QWWH$[WWf"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="j!ChX]LGqbO^?KwD(+N#"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="wv7Fr*l0l-tb-_98-Y`~"> <field name="ATTR">val</field> <field name="OID">radar2.0.Mi8</field> </block> </value> <value name="B"> <block type="logic_boolean" id="KSV~{Id?([xTz)3p/0k{"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="`EEmctf{HV1#{s/`Sm7p"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="!sO5~|y]Tq{D@s%C_=R%"> <field name="ATTR">val</field> <field name="OID">radar2.0.RedMi5Plus</field> </block> </value> <value name="B"> <block type="logic_boolean" id=";qD)Jy$GH05AB.{)Jb!2"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="update" id="^iTw.Z=P=PT!r7Yd4_pn"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.jemandanwesend</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="R+yn0;4/vgem`xeVUJ^}"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </statement> </block> </xml>
@eMd sagte in Anwesenheit mit 2 Personen:
Blocklyimport
Danke euch , jetzt läuft es
Moin, ich hab euer skript übernommen und es macht was es soll zumindest fast
ich schalte damit 2 weitere skripte auf false und das geht auch nur arbeiten die skripte trotzdem weiter.
<xml xmlns="http://www.w3.org/1999/xhtml"> <block type="on_ext" id="Jh[=rfzMv*8me+BZSL,1" x="63" y="-87"> <mutation items="2"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="vA(aMx#j?#RdTmQiZ!Pn"> <field name="oid">radar2.0.Elli</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="[MO:0aHP1UmWa}lKP+Pa"> <field name="oid">radar2.0.Moppel</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="+nr4Q.X)L~Cn|kLQkYzc"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="/K,ghpx,wJfJ7W`7Ws4o"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="$zNh)Ncf$frBFAWa_7i|"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="]OqOcY/EcQX|%-46;CpI"> <field name="ATTR">val</field> <field name="OID">radar2.0.Elli</field> </block> </value> <value name="B"> <block type="logic_boolean" id="0p7ZL:e0f}@s~dEKa1[."> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="g^y$j^X@Ye+oUgFhUng*"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="6}(=WW/NwMkiw0aZ|5P7"> <field name="ATTR">val</field> <field name="OID">radar2.0.Moppel</field> </block> </value> <value name="B"> <block type="logic_boolean" id="+hT(L4z;:CQxUD!ei2;x"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="update" id="8/*P1Txi_+8.@W%h|)aw"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.scriptEnabled.Beleuchtung_Haus.Licht_Flur_unten</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="Dt)){5!D#pO{?T86,1Zh"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="update" id="8Fd6b0gN]@`%[/SgO=@U"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.scriptEnabled.Beleuchtung_Haus.Licht_Flur_oben</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="jL-;MBl%?c@Im9usfP%!"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_operation" id="30k$#%/o(._QWWH$[WWf"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="j!ChX]LGqbO^?KwD(+N#"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="wv7Fr*l0l-tb-_98-Y`~"> <field name="ATTR">val</field> <field name="OID">radar2.0.Elli</field> </block> </value> <value name="B"> <block type="logic_boolean" id="KSV~{Id?([xTz)3p/0k{"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="`EEmctf{HV1#{s/`Sm7p"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="!sO5~|y]Tq{D@s%C_=R%"> <field name="ATTR">val</field> <field name="OID">radar2.0.Moppel</field> </block> </value> <value name="B"> <block type="logic_boolean" id=";qD)Jy$GH05AB.{)Jb!2"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="update" id="^iTw.Z=P=PT!r7Yd4_pn"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.scriptEnabled.Beleuchtung_Haus.Licht_Flur_unten</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="R+yn0;4/vgem`xeVUJ^}"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="update" id="IFg8znJ|r@+O|XdwDXz+"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.scriptEnabled.Beleuchtung_Haus.Licht_Flur_oben</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="^T6cM!A#6~lWYn)9av8b"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block> </xml>
Ich möchte erreichen das wenn 2 Personen nicht im Haus sind die beiden BW nicht funktionieren da wir Katzen haben und diese ständig das licht einschalten was sie aber nicht brauchen.
Danke schonmal für euere Hilfe
@moppel2810
Am einfachsten ist es wenn Du einen Anwesenheits DP anlegst und den einfach als UND Bedingung bei Scripten abfragst die in Abhänigkeit der Anwasesenheit laufen sollen. -
@Jan1
Was ist ein DP? Ich bin leider noch nicht so lange an iobroker und skripten dran hab da also noch nicht so viel Ahnung. -
@moppel2810
Ein DatenPunkt der eben über das Script anzeigt ob Anwesenheit true oder false ist. Kannst manuell erstellen oder über Blockly machen lassen. -
@Jan1
Also müßte ich in das skript welches das Licht steuert irgendwie die Anwesenheit mit einbinden das Licht nur gesteuert wird wenn einer von beiden anwesend ist? -
<xml xmlns="http://www.w3.org/1999/xhtml"> <variables> <variable type="undefined" id="timeout">timeout</variable> </variables> <block type="comment" id="JaAyU2y,{(6@:diUAQNL" x="-312" y="-1537"> <field name="COMMENT">Bewegungsmelder Treppe</field> <next> <block type="on" id="S9XTQg1w}QoHz7*_kQ,b"> <field name="OID">deconz.0.Sensors.24.presence</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id="RLo#Q(I9N_J^h=zpR?1{"> <field name="NAME">timeout</field> <next> <block type="controls_if" id="[+6pK-?N+WQ.)y(TXg7f"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_ternary" id="wGj;;=Ss[I[-{]7UubI]"> <value name="IF"> <block type="logic_operation" id="csg_mJs/3Pp{F3d3(e%]"> <field name="OP">OR</field> <value name="A"> <block type="get_value" id="mE3uVm96c#O`P%GDRv_/"> <field name="ATTR">val</field> <field name="OID">radar2.0.Elli</field> </block> </value> <value name="B"> <block type="get_value" id="/`@w1FUQ,akFrg(D[4QK"> <field name="ATTR">val</field> <field name="OID">radar2.0.Moppel</field> </block> </value> </block> </value> <value name="THEN"> <block type="logic_operation" id="xp8s;E6mdfRJ3Nqbi:As" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="O+OB)G0w[.=-,gh}v(Q1"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="14ar~dElwIyL0TSmhwlI"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.22.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="^ljVS=y+vK!hnU5NWv9)"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="DnqN.CqO0l+JJkaO.qW}"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="uGgpU+W5ZND=z]Aw9!(("> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.24.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="d:-_8#x+q`()c(?;eF/["> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="procedures_callnoreturn" id="KFE*W!t{vwv~S}[_e)D;"> <mutation name="LichtEin"></mutation> </block> </statement> <value name="IF1"> <block type="logic_ternary" id="3{8|1n50Y/dmST:jWf6Y"> <value name="IF"> <block type="logic_operation" id="lgQ@4/8k-CD?u$zBUC;%"> <field name="OP">OR</field> <value name="A"> <block type="get_value" id="F@,9$cMBOl1Pz6UglZ4q"> <field name="ATTR">val</field> <field name="OID">radar2.0.Elli</field> </block> </value> <value name="B"> <block type="get_value" id="YS[@~*!Xy9@#.]#`Zo,d"> <field name="ATTR">val</field> <field name="OID">radar2.0.Moppel</field> </block> </value> </block> </value> <value name="ELSE"> <block type="logic_operation" id=")C^ymRknP$I2,-sxxE_," inline="false"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="+;G;TPy]A04sGE@[}Zy0"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="AZU$+X*.bh%@`#PbL2.^"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.22.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="6PTmy@[Lr|VD[ap^(ycB"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="UQe[=}kS]/eHJwFgwzjg"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="fPQjT=v6}syT#)gt=8H?"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.24.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="TG9sn=j?_:}+JmyIF~:l"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="procedures_callnoreturn" id="qI(:@,K3-%~k@q~5QYU*"> <mutation name="LichtAus"></mutation> </block> </statement> </block> </next> </block> </statement> </block> </next> </block> <block type="comment" id="}RyaEXElWAG2x/SK(i%L" x="-1388" y="-1413"> <field name="COMMENT">Bewegungsmelder Flur oben</field> <next> <block type="on" id="Qfwz.Sg-A_%8B6m[U2m}"> <field name="OID">deconz.0.Sensors.22.presence</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id="z239D8cLX|D=iPl3;D4^"> <field name="NAME">timeout</field> <next> <block type="controls_if" id="_gcLj*t^DqEZ]!/B/JX["> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_ternary" id="X^IOeWi%.tR%%uSHvLHC"> <value name="IF"> <block type="logic_operation" id="/K,ghpx,wJfJ7W`7Ws4o"> <field name="OP">OR</field> <value name="A"> <block type="get_value" id="]OqOcY/EcQX|%-46;CpI"> <field name="ATTR">val</field> <field name="OID">radar2.0.Elli</field> </block> </value> <value name="B"> <block type="get_value" id="6}(=WW/NwMkiw0aZ|5P7"> <field name="ATTR">val</field> <field name="OID">radar2.0.Moppel</field> </block> </value> </block> </value> <value name="THEN"> <block type="logic_operation" id="Bl!KG[(Bz?#_pPYl%L%*" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="$}3B,%c-i8|Ll;?Jb8b%"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Xi;NNqR4P}W6U8N)Ws?["> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.22.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="{5Y3DYbmas,-~.{~HJHX"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="-q7)@@WEY[,Vv6e^4x1?"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="$GY|I:$(sm*/RIb~n:/c"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.24.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="GuD+@!I.2yZq~`aXh!G/"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="procedures_callnoreturn" id="[U(07y/di1Lah#}|?Fo+"> <mutation name="LichtEin"></mutation> </block> </statement> <value name="IF1"> <block type="logic_ternary" id="N?yYP4x#2VY=w6W:;aDp"> <value name="IF"> <block type="logic_operation" id="Qk=BV%uDk59nwzXulaU%"> <field name="OP">OR</field> <value name="A"> <block type="get_value" id="I63$*VtetdmqfS{|+F.E"> <field name="ATTR">val</field> <field name="OID">radar2.0.Elli</field> </block> </value> <value name="B"> <block type="get_value" id="Cn.l85H=M#QHVf=NScD^"> <field name="ATTR">val</field> <field name="OID">radar2.0.Moppel</field> </block> </value> </block> </value> <value name="ELSE"> <block type="logic_operation" id="-=@rt8N0Fl7!H^bX1enh" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="G^qc7*zDSJl1Qkoev/o4"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="P-REUF##P*f]aD}]U?Ah"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.22.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="L_zB}mJ5yri(AmzC4Qwn"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="8N]a7cY9teVw[v3SwrEF"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="m|n6weU5|FYXK,-5!`?D"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.24.presence</field> </block> </value> <value name="B"> <block type="logic_boolean" id="AN=*G]+S7b^I^])kV(l#"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="procedures_callnoreturn" id="~eR_,:~y}S*vx2a~@%FG"> <mutation name="LichtAus"></mutation> </block> </statement> </block> </next> </block> </statement> </block> </next> </block> <block type="procedures_defnoreturn" id="=ecpK:QcQ6}Srk*]ID~{" x="-312" y="-987"> <field name="NAME">LichtAus</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"> <block type="timeouts_settimeout" id="=2C#^/49i2XIrk/nGd)A"> <field name="NAME">timeout</field> <field name="DELAY">30</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control" id="%Z8Jlm0qgkQ.fM2?U;Fl"> <mutation delay_input="false"></mutation> <field name="OID">hm-rpc.1.000E1A498CCE86.2.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="jyHq%mcf)(kXsI!twT^1"> <field name="NUM">0</field> </block> </value> </block> </statement> </block> </statement> </block> <block type="procedures_defnoreturn" id="}a~Yc4#7SiTBR.rQ)s{i" x="-1387" y="-787"> <field name="NAME">LichtEin</field> <comment pinned="false" h="80" w="160">Beschreibe diese Funktion …</comment> <statement name="STACK"> <block type="controls_if" id="!iO$$kwAdtjUyp+SbUD-"> <mutation elseif="1" else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="ahjkAHocCu7rj;ZoU4@@" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="time_compare" id="B#?oX=Bv;mppdZgF(no{"> <mutation end_time="true"></mutation> <field name="OPTION">between</field> <field name="START_TIME">18:00</field> <field name="END_TIME">19:59</field> </block> </value> <value name="B"> <block type="logic_operation" id="^Y:GGp:;pn|F+7_Hsw1v" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="get_value" id="yg9V@[o_|C,;p4*C;|ad"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.22.presence</field> </block> </value> <value name="B"> <block type="get_value" id="owDR?[UN(aK3`b[1ujcA"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.24.presence</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="FXA/Vw1|{hK-3s(I1:gc"> <mutation delay_input="false"></mutation> <field name="OID">hm-rpc.1.000E1A498CCE86.2.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="0K4C!$9tB?I5KOZ:Qg)U"> <field name="NUM">35</field> </block> </value> <next> <block type="procedures_callnoreturn" id="nt2#WxC%-nemqb[N`U6{"> <mutation name="LichtAus"></mutation> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_operation" id="}xr3g6(F4w}1gn!nN}3i" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="a?~^):5Ue|gf-b:]aCJY" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="time_compare" id="b[%.Px/JX82QQ%cT`o%w"> <mutation end_time="true"></mutation> <field name="OPTION">between</field> <field name="START_TIME">20:00</field> <field name="END_TIME">23:59</field> </block> </value> <value name="B"> <block type="time_compare" id="V;m%!/4s]IZt88Cp78qZ"> <mutation end_time="true"></mutation> <field name="OPTION">between</field> <field name="START_TIME">00:00</field> <field name="END_TIME">07:00</field> </block> </value> </block> </value> <value name="B"> <block type="logic_operation" id="$%oH~ohfn%5sY*})}/,n" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="get_value" id="PDqApLhbr.4bvxs)~Z8/"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.22.presence</field> </block> </value> <value name="B"> <block type="get_value" id="4Fc;y(ZD2*}15eKyN8;1"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.24.presence</field> </block> </value> </block> </value> </block> </value> <statement name="DO1"> <block type="control" id="[9Ea]nJqm08TK(2@#!P8"> <mutation delay_input="false"></mutation> <field name="OID">hm-rpc.1.000E1A498CCE86.2.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="jeVvW[$,L]}[Ot$cpw9R"> <field name="NUM">2</field> </block> </value> <next> <block type="procedures_callnoreturn" id="OD2^oqyZwVdj}1}U,Pwz"> <mutation name="LichtAus"></mutation> </block> </next> </block> </statement> <statement name="ELSE"> <block type="control" id="PbQ1;ebrN)H:O$ZVKH[Q"> <mutation delay_input="false"></mutation> <field name="OID">hm-rpc.1.000E1A498CCE86.2.LEVEL</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="trk!Ma2@w=[C~VKHG8M6"> <field name="NUM">75</field> </block> </value> <next> <block type="procedures_callnoreturn" id="=$J*-o;,)i-yaX:`(XKj"> <mutation name="LichtAus"></mutation> </block> </next> </block> </statement> </block> </statement> </block> </xml>
So läuft das leider nicht aber ich hab bestimmt einen Denkfehler
Jetzt funktioniert es aber warum braucht es so lange nach Anwesenheitserkennung um zu funktionieren?
@moppel2810
Poste doch mal das Blocky, oder machst das mit Javascript?
Hast ein DP angelegt der die Anwedenheit signalisiert? Wenn ja, dann schau doch mal wie und wann der DP wechselt. -
Ich hab doch das exportierte Blocky gepostet.
@moppel2810
Und ich soll das lesen können unter Palmen -
@moppel2810
Da hast aber was gebastelt
Den Anwesenheits DP finde ich darin nicht und das mit Funktionen zu lösen ist auch etwas übertrieben, nutzt man eigentlich wenn ein und die selbe Funktion öfter verwendet wird, so wird das nur unübersuchtlich.
Das prüfe in der falls Bedingungung ist wohl auch falsch, da das eigetlich schon die falls erledigen soll. -
Was müßte ich denn ändern das es funktioniert?
@moppel2810
Leg doch mal den DP für die Anwesenheit an. Den fütterst Du dann mit einem separaten Script. Den DP kannst dann aber überall verwenden, wo etwas in Abhänigkeit der Anwesenheit passieren soll, hatte ich oben schon mal geschrieben. Das macht dann auch das Blockly übersichtlicher.
Dann die falls mit dem angeschlossenen überprüfe Block ist unnötig und eh falsch, zumindest das was ich da rauslese. Einfach den falls Block und da die Bedingung dran, dann was passieren soll.
Du willst was recht einfaches und verwndest dafür Funktionen, was das unnötig unübersichtlich macht.
Eine falls Bedingung muss man auch nicht auf true prüfen, weil sie das eh macht.
So kannst eigentlich ganz einfach das ganze in der Art aufbauen:
Trigger Bewegung wurde erkannt.
Falls jemand zu hause, dann Licht an. -
so in etwa?
@paul53 sagte in Anwesenheit mit 2 Personen:
@moppel2810 sagte:
so in etwa?
Besser so:
Wert findet man unter Trigger.
Komisch ich hab Block "Wert" nicht in Trigger ???
Block "setze ____ auf" finde ich bei mir auch nicht?
