    4. Test js-controller v2.0.x (GitHub)
      apollon77 @e-i-k-e last edited by
      @e-i-k-e Ppuuuhhhh ... jetzt wird schwierig ... keine Ahnung was das sein kann ... hollllaalllaa. Mal schauen ob ich da was finde.
        sven12 @apollon77 last edited by
        @apollon77
        Nicht wirklich viel mehr Infos.....
        iobroker@iobroker-host:/opt/iobroker$ node node_modules/iobroker.shelly/shelly.js --force --logs
        2019-10-04 20:27:32.109  - error: shelly.0 (22205) shelly.0 invalid process id scenario 22181 vs. 22205. Stopping
        2019-10-04 20:27:44.707  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:27:44.742  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 22651 vs own PID 22205
        2019-10-04 20:28:17.631  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:28:17.640  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 23570 vs own PID 22205
        2019-10-04 20:28:49.488  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:28:49.499  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 24494 vs own PID 22205
        2019-10-04 20:29:21.317  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:29:21.328  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 25431 vs own PID 22205
        2019-10-04 20:29:21.486  - info: shelly.0 (22205) Got terminate signal TERMINATE_YOURSELF
        2019-10-04 20:29:28.431  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:29:28.442  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 25668 vs own PID 22205
        2019-10-04 20:30:00.174  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:30:00.186  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 26586 vs own PID 22205
        2019-10-04 20:30:36.686  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 0 vs own PID 22205
        2019-10-04 20:30:36.697  - warn: shelly.0 (22205) Got terminate signal. Checking desired PID: 27752 vs own PID 22205
        iobroker Log
        2019-10-04 20:29:22.826  - error: shelly.0 (25431) adapter disabled
        2019-10-04 20:29:22.880  - warn: shelly.0 (25431) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        2019-10-04 20:29:22.898  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        2019-10-04 20:29:23.686  - info: mqtt.0 (27417) Client [WetterStation] connected with secret 1570213763685_8509
        2019-10-04 20:29:23.713  - info: mqtt.0 (27417) Client [WetterStation] subscribes on "mqtt.0.WetterStation"
        2019-10-04 20:29:23.713  - info: mqtt.0 (27417) Client [WetterStation] publishOnSubscribe
        2019-10-04 20:29:24.429  - info: host.iobroker-host instance system.adapter.poolcontroller.0 terminated with code 0 (NO_ERROR)
        2019-10-04 20:29:28.427  - info: host.iobroker-host "system.adapter.shelly.0" enabled
        2019-10-04 20:29:28.443  - info: host.iobroker-host instance system.adapter.shelly.0 started with pid 25668
        2019-10-04 20:29:29.142  - debug: shelly.0 (25668) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2019-10-04 20:29:29.184  - debug: shelly.0 (25668) objectDB connected
        2019-10-04 20:29:29.186  - debug: shelly.0 (25668) Redis States: Use Redis connection: 0.0.0.0:9000
        2019-10-04 20:29:29.188  - debug: shelly.0 (25668) Objects connected to redis: 0.0.0.0:9001
        2019-10-04 20:29:29.192  - debug: shelly.0 (25668) statesDB connected
        2019-10-04 20:29:29.205  - debug: shelly.0 (25668) States connected to redis: 0.0.0.0:9000
        2019-10-04 20:29:29.969  - info: shelly.0 (25668) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
        2019-10-04 20:29:30.041  - info: shelly.0 (25668) Stating Shelly adapter in CoAP modus.
        2019-10-04 20:29:30.162  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
        2019-10-04 20:29:30.163  - info: host.iobroker-host Restart adapter system.adapter.shelly.0 because enabled
        • coyote
          coyote Most Active last edited by
          @apollon77 nochmal kurz ins Log geschaut, also es war wohl bei allen Adapter, ich hänge das Stück vom Log mal an, irgendwann ist dann alles gut...
          Log.txt
          apollon77 2 Replies Last reply Reply Quote 0
            apollon77 @sven12 last edited by
            @sven12 Ok, dann bitte vorher die nroamellaufende shelly instanz stoppen und erst dann an der Kommandozeile ausführen. Doppelt laufen geht kaputt ggf
              apollon77 @coyote last edited by
              @coyote Bitte sei mal etwas grösszügiger mit dem Anfang des Logs ... direkt da zu starten wo die Fehler kommen ist da nicht sehr hilfreich weil irgendwas muss die ja verursachen ... bedeutet: Bitte noch etwas Log von davor
                @apollon77
                Wenn ich den Adapter im Admin gestoppt habe, kommt auf der Konsole das hier:
                2019-10-04 20:45:07.776  - error: shelly.0 (20885) adapter disabled
                2019-10-04 20:45:07.779  - info: shelly.0 (20885) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
                2019-10-04 20:45:07.841  - info: shelly.0 (20885) Stating Shelly adapter in CoAP modus.
                Exception: Error: addMembership EADDRINUSE/Error: addMembership EADDRINUSE
                2019-10-04 20:45:07.960  - error: shelly.0 (20885) Exception: Error: addMembership EADDRINUSE
                2019-10-04 20:45:07.961  - info: shelly.0 (20885) Closing Adapter
                  @sven12 Kann es sein das da irgendwie noch eine Instanz läuft? Schau al mit "ps auxww|grep shelly"
                    @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                    iobroker@iobroker-host:/opt/iobroker$ ps auxww|grep shelly
                    iobroker 26889  0.0  0.0  12780   928 pts/3    S+   20:48   0:00 grep shelly
                    2019-10-04 20:48:48.376  - error: shelly.0 (27548) shelly.0 invalid process id scenario 25918 vs. 27548. Stopping
                    • coyote
                      coyote Most Active @apollon77 last edited by
                      @apollon77 sorry, klar macht vllt mehr Sinn...
                      Hier mal ab Start von iobroker bis Anfang der Warnings:
                      Log.txt
                      Übrigens habe ich noch ein kleines Problem, es gibt ein Unifi Script von liv-in-the-sky, dass schreibt ein html file nach /opt/iobroker/iobroker-data/files/iqontrol/htmlclients.html
                      Die Datei ist auch definitiv dort vorhanden und wird auch stetig geändert, nur wird sie mir jetzt nach der Umstellung in iQontrol nicht mehr angezeigt und iQontrol sagt, nicht vorhanden.
                      Muss in iQontrol der Pfad jetzt geändert werden oder woran kann das liegen?
                        @sven12 Un dläuft auf dem Slave vllt noch ein Prozess?
                          @coyote Das bitte im iqontrol Thread besprechen. Userfiles wurden bei dem Adapter generell in einen andern Pfad verschoben. Und am Ende sind wir wieder bei "komische Wege an den unterstützten Standards vorbei ;-))
                          Das Skript sollte das mit "writeFile" korrekt im ioBroker-Storage ablegen und nicht an allem vorbei 😉 Aber wie gesagt: Thema am besten im iqontrol Thread besprechen
                            @apollon77
                            Nein auf beiden läuft kein Prozess mehr...
                            • coyote
                              @apollon77 ok, dann werde ich das dort mal anschneiden.
                              Was ist mit den Warnings im Log? Ist da was zu erkennen warum die beim Start kamen? Oder einfach mal so lassen und sich freuen, dass jetzt alles läuft 😉
                                @coyote Wieviele Objekte/States hast Du? Siehst Du in ioBroker unter Tab "Objekte"
                                • coyote
                                  @apollon77 sind ein paar 😉
                                  Objekte: 44287, Zustände: 40604
                                    @coyote Ok, I need to think about it ... I have a solution, but don't know if I want this ... https://github.com/ioBroker/ioBroker.js-controller/issues/487
                                    Apollon77 created this issue in ioBroker/ioBroker.js-controller
                                    closed Redis-LUA scripts need too long ... #487
                                      @sven12 Sehr strange ... wenn Meldungen wie bei deinem manuellen Log kommen bzw "addrinuse" dann nutzt irgendwas den Port. Magst Du mal einen Reboot versuchen?
                                      • coyote
                                        @apollon77 alles klar, dann weiß ich Bescheid, sagen wir einfach ich habe zu viele States 😉
                                        sigi234 apollon77 2 Replies Last reply Reply Quote 0
                                          addrinuse
                                          Also das "addrinuse" kam ja nur weil die alte Instanz noch nicht sauber beendet war als ich die Instanz neu gestartet habe.
                                          Ich glaube das kann ich mittlerweile ausschließen. Habe einfach zu schnell den Adapter neu gestartet
                                          Die letzten Logs haben das ja auch nicht mehr angezeigt.... Ich glaube das ist nicht das Problem..
                                          Reboot geht heute nicht mehr.. Morgen evtl.
                                            sigi234 Forum Testing Most Active @coyote last edited by
                                            @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
                                            Sind nicht wenige. Ich habe 18500 😀
                                            js-controller
                                            48
                                            1047
                                            309573
