    4. [Vorstellung] Meine zweite Visualisierung
      sigi234 Forum Testing Most Active last edited by sigi234
      Hallo @Kuddel ,
      arbeite gerade an einer Echo Show5 Vis. Wie bekomme ich den Hintergrund Transparent beim jqi-input Widget?
      Beiße mir gerade die Zähne aus.😀
      [{"tpl":"tplJquiInput","data":{"oid":"alexa2.0.Echo-Devices.G0913L0592570PHD.Music-Provider.Amazon-Music-Playlist","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","label":"Playlist to play with AM","digits":"0","size":"81","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"asString":true},"style":{"left":"28px","top":"558px","z-index":"5","background-color":"transparent","color":"#d7cec1","font-family":"RobotoCondensed-Light","font-size":"large","background":"transparent","width":"766px","height":"33px"},"widgetSet":"jqui"}]
        Kuddel @sigi234 last edited by
        @sigi234 habs bei mir importiert. Leider wird bei mir der Hintergrund auch weiß dargestellt.
        Bei meinen anderen Input Widgets wurde der Hintergrund mit Verwendung des Material-Designs durchsichtig.
        Leider scheint das hier nicht zu funktionieren. Da bin ich gerade ein wenig überfragt.
          sigi234 Forum Testing Most Active @Kuddel last edited by sigi234
          @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
          Aha, hab es, es ändert sich mit dem Thema.Aber leider nicht Transparent.
          • Negalein
            @Kuddel
            Hi Kuddel!
            Du hast bei deinem Anwesenheitsblockly unteranderem auf den DP javascript.0.echo.sprachausgabe_wohnzimmer verwiesen.
            In deinen Scripts finde ich leider kein Script, dass in diesen erstellten DP schreibt.
            Könntest du es hier reinstellen?
              David16 @David16 last edited by
              @Kuddel Also es gab seit dem keine Probleme mehr. - Vielen Dank für deine Unterstützung!
                @David16 said in [Vorstellung] Meine zweite Visualisierung:
                @Kuddel
                Also meine Version ist 4.1.16.
                Ansonsten passen die Versionen soweit auch:
                Ich habe gestern Abend aber mal den iobroker komplett neu gestartet. Die Adapter leuchtet jetzt "grün". In den Logs sind auch keine Fehlermeldung mehr zu erkennen. - Keine Ahnung an was es gelegen haben soll.
                In der VIS ist die Rollo-Steuerung und Astro-Steuerung auch wieder da und die Rollos sind auch um 19:45 heruntergefahren:
                Ich beobachte das mal die nächsten Tage intensiv und berichte dann. - Dir vielen Dank für drüber schauen!👍
                  @Kuddel kannst du eine Flot-Einstellungen für das Temperatur auslesen hier nochmal hochladen? - Komme nicht ganz mit den Einstelllungen hin.
                  Ebenso wie du das Objekt in den History-Parametern eingestellt hast. 😊
                    Kuddel @David16 last edited by
                    @David16
                      Kuddel @Negalein last edited by
                      @Negalein ich hatte mal rumgestestet, dass Alexa mich beim nach Hause kommen bergrüßt.
                      Das funktioniert aber nicht wirklich. Daher nutze ich das nicht mehr.
                        David16 @Kuddel last edited by
                        @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                        @David16
                        Besten Dank sollte jetzt gehen! 👍 👍
                          Puch last edited by
                          Guten Morgen,
                          erstmal vielen Dank für die Bereitstellung! das ist wirklich Wahnsinn!
                          Ich hab es auch Installiert nur bekomme ich die Icons nicht dargestellt...
                          Grüß und vielen dank!
                          Negalein K 2 Replies Last reply Reply Quote 0
                          • Negalein
                            Negalein Global Moderator @Puch last edited by
                            @Puch sagte in [Vorstellung] Meine zweite Visualisierung:
                            Liegen die Icons im richtigem Ordner?
                            Zeig mal den Screenshot vom Pfad des Icons.
                              Kuddel @Puch last edited by
                              @Puch dir fehlt noch ein Adapter.
                              installiere mal icons-mfd-png, dann wird alles richtig angezeigt
                              P Pat1968 2 Replies Last reply Reply Quote 0
                                Puch @Kuddel last edited by
                                @Kuddel Danke!! das wars.... 🙂
                                • Pat1968
                                  Pat1968 @Kuddel last edited by
                                  @Kuddel
                                  Hallo
                                  Wie hast du es hinbekommen mit den BVB Spiele?
                                  Ueber script oder iCal?
                                  Mfg
                                    Kuddel @Pat1968 last edited by
                                    @Pat1968 ist ein ical Kalender in meinem Google Account
                                    Pat1968 1 Reply Last reply Reply Quote 0
                                    • Pat1968
                                      @Kuddel
                                      Ok das heisst du hast die alle manuel eingegeben?
                                        @Pat1968 nein, die habe ich mir natürlich alle importiert
                                        https://www.fussball-spielplan.de/spielplan-borussia-dortmund-als-ical-abonnieren/
                                        • Pat1968
                                          @Kuddel
                                          Danke Dir 👍
                                          • Pat1968
                                            @Kuddel
                                            Hallo
                                            Wie hast du den integriert. Versuche es mit google kalender aber def ladet die daten nicht?
                                            template vis
                                            148
                                            1324
                                            490695
