    4. Test Adapter zoneminder v0.3.x
      djsirius last edited by
      @Meistertr ist das die Datei debug in /var/log/ ?
      • coyote
        coyote Most Active @djsirius last edited by
        @djsirius /opt/iobroker/log
          djsirius @Meistertr last edited by
          @Meistertr iobroker.2019-10-06.log
          Meistertr 1 Reply Last reply Reply Quote 0
          • Meistertr
            Meistertr Developer @djsirius last edited by
            @djsirius hier wird erklärt wie man einen adapter auf debug umstellt:
            https://www.youtube.com/watch?v=-1PCHancttc&t=143s
            mir reicht ein auszug aus den ersten minuten
              @Meistertr
              zoneminder.0	2019-10-06 22:36:47.181	warn	No monitors found, please configure monitors in your zoneminder!
              zoneminder.0	2019-10-06 22:36:47.180	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
              zoneminder.0	2019-10-06 22:36:47.172	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
              zoneminder.0	2019-10-06 22:36:47.171	debug	SetStates
              zoneminder.0	2019-10-06 22:36:42.177	warn	No monitors found, please configure monitors in your zoneminder!
              zoneminder.0	2019-10-06 22:36:42.177	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
              zoneminder.0	2019-10-06 22:36:42.167	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
              zoneminder.0	2019-10-06 22:36:42.166	debug	SetStates
              zoneminder.0	2019-10-06 22:36:37.186	warn	No monitors found, please configure monitors in your zoneminder!
              zoneminder.0	2019-10-06 22:36:37.185	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unautho
              zoneminder.0	2019-10-06 22:36:37.167	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
              zoneminder.0	2019-10-06 22:36:37.167	debug	SetStates
              zoneminder.0	2019-10-06 22:36:32.179	warn	No monitors found, please configure monitors in your zoneminder!
              zoneminder.0	2019-10-06 22:36:32.179	debug	reposerrStatusCodeError: 401 - "{\"success\":false,\"data\":{\"name\":\"Not Authenticated\",\"message\":\"Not Authenticated\",\"url\":\"\\/zm\\/api\\/monitors.json\",\"exception\":{\"class\":\"Unauth
              zoneminder.0	2019-10-06 22:36:32.163	debug	REQUEST: Options {"method":"GET","uri":"http://192.168.1.16/zm/api/monitors.json","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":true}
              zoneminder.0	2019-10-06 22:36:32.162	debug	SetStates
              zoneminder.0	2019-10-06 22:36:27.242	info	check user admin pw ioboker: false
              zoneminder.0	2019-10-06 22:36:27.188	info	check group user admin group admin: false
              zoneminder.0	2019-10-06 22:36:27.182	debug	reposerrStatusCodeError: 401 - "\n{\"success\":false,\"data\":{\"name\":\"User not found\",\"message\":\"User not found\",\"url\":\"\\/zm\\/api\\/host\\/login.json\",\"exception\":{\"class\":\"Unauth
              zoneminder.0	2019-10-06 22:36:27.154	debug	REQUEST: Options {"method":"POST","uri":"http://192.168.1.16/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-length":21,"
              zoneminder.0	2019-10-06 22:36:27.153	debug	data: {"user":"admin","password":"admin","host":"http://192.168.1.16/zm"}
              zoneminder.0	2019-10-06 22:36:27.143	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.16.0
              zoneminder.0	2019-10-06 22:36:27.128	debug	statesDB connected
              zoneminder.0	2019-10-06 22:36:27.117	debug	objectDB connected
              host.debian	2019-10-06 22:36:26.717	info	instance system.adapter.zoneminder.0 started with pid 8577
              host.debian	2019-10-06 22:36:26.709	info	"system.adapter.zoneminder.0" enabled
              • Meistertr
                @djsirius zoneminder antwortet dass er admin mit pw admin nicht kennt ...
                D M 2 Replies Last reply Reply Quote 0
                  @Meistertr moin. Tja und nun? Das sind genau die User und Passwort, die ich vergeben hab. Und damit kann ich mich auf der Konsole von Zoneminder ja auch anmelden.
                  Ich habe auch schon mehrere unterschiedliche User mit unterschiedlichen Passwörtern angelegt und er bringt immer diese Meldung, dass er User und Passwort nicht kennt.
                  Dann ist doch der Adapter kaputt!!!???
                    djsirius @djsirius last edited by
                    Hallo.
                    Sooooo, das Problem ist beseitigt!
                    In den Einstallungen hatte ich bei OPT_USE_AUTH Authenticate user logins to ZoneMinder (?) einen Haken drin. Haken raus, Zoneminder neustart, der Adapter verbindet sich!!!
                    • Meistertr
                      @djsirius das ist aber nur ein wurkaround und nicht die Lösung, zeig mal ein Screenshot deiner Config. Eigentlich sollte es mit Admin Admin gehen müssen...
                          mikiline @Meistertr last edited by
                          @Meistertr
                          Das mit den Events (Motion) lässt sich mit dem zmeventmanager lösen. Diesen habe ich nun installiert und mir die App "zmninja" gezogen. Läuft alles wunderbar.
                          Im Eventmanager ist auch ein MQTT Server/Client mit dabei, mit dem Du dann sicher auch etwas im Adapter verwenden kannst 😉
                            Könnt ihr mal bitte mit http://server/zm/api/host/getVersion.json schauen, welche Version ihr von zoneminder installiert habt?
                            Ich habe folgende Version installiert:
                            {"version":"1.30.4","apiversion":"1.0"}
                            Vielleicht liegt es daran, weil auf der Homepage steht:
                            Login process for ZoneMinder v1.32.0 and above:
                            curl -XPOST -d "user=XXXX&pass=YYYY" -c cookies.txt  http://yourzmip/zm/api/host/login.json
                            Login process for older versions of ZoneMinder:
                            curl -d "username=XXXX&password=YYYY&action=login&view=console" -c cookies.txt  http://yourzmip/zm/index.php
                            coyote M D 3 Replies Last reply Reply Quote 0
                            • coyote
                              @djsirius sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                              Ich habe die 1.32.3
                                mikiline @djsirius last edited by mikiline
                                "version":"1.33.14","apiversion":"2.0"}
                                • Meistertr
                                  Meistertr Developer @mikiline last edited by
                                  @mikiline sagte in [Aufruf] Zoneminder 0.2.0 Testen:
                                  zmeventmanager
                                  das war auch mein plan... konnte ihn aber noch nciht umsetzen
                                    Wie bekomme ich denn meine Zoneminder Version geupdatet?
                                    • Meistertr
                                      Meistertr Developer @djsirius last edited by Meistertr
                                      @djsirius
                                      add-apt-repository ppa:iconnor/zoneminder-1.32
                                        @Meistertr said in [Aufruf] Zoneminder 0.2.0 Testen:
                                        Das funktioniert nicht.
                                        Ich habe debian 9 installiert.
                                        Xsev 1 Reply Last reply Reply Quote 0
                                        • Xsev
                                          Xsev @djsirius last edited by
                                          @djsirius
                                          schau mal hier da ist eigentlich alles beschrieben für die Installation von 1.32.2 auf Debian 9.
                                            @djsirius said in [Aufruf] Zoneminder 0.2.0 Testen:
                                            @Meistertr könnte es daran liegen, dass mein Zoneminder-Adapter sich nicht mit Zoneminder verbinden kann?
                                            31.7k
                                            79.9k
                                            camera motion zoneminder
                                            23
                                            206
                                            24401
