    3. Entwicklung
    4. [Neuer VIS-Adpater] Material Design Widgets
      sigi234 Forum Testing Most Active @liv-in-sky last edited by
      @liv-in-sky
      Danke, überlege gerade wie ich die uptime in Sekunden so umwandle:
      X Tage - X Stunden - X Minuten
      In Tage habe ich ja schon mit : Wert multiplizieren 1.157407407407407e-5
        liv-in-sky @sigi234 last edited by liv-in-sky
        @sigi234 du meinst im widget über binding berechnen oder über ein extra script mit extra datenpunkt
        man könnt evielleicht ein script machen, das alles adapter up-zeiten einliest und einen ordner mit einem datenpunkt für jeden adapter erstellt - und das jede minute laufen kassen
          @liv-in-sky sagte in [Neuer VIS-Adpater] Material Design Widgets:
          Ja
          [{"tpl":"tplValueFloat","data":{"oid":"system.adapter.admin.0.uptime","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1.157407407407407e-5","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"is_tdp":true,"digits":"1","html_append_plural":" Tage","html_prepend":"Betriebszeit "},"style":{"left":"32px","top":"77px","width":"122px","height":"15px","z-index":"2","text-align":"left","font-family":"RobotoCondensed-Light","font-size":"small"},"widgetSet":"basic"}]
            @sigi234
            auf dieser seite gibt es sowas - was man alles machen kann mit bindings - wenn du lust hast mach morgen einen thread auf und setzt mich mal mit rein - dann können wir mal testen
            https://github.com/ioBroker/ioBroker.vis
              @sigi234
              Ok
                dos1973 @sigi234 last edited by
                @sigi234
                @liv-in-sky
                wäre euch dankbar, wenn ihr mich auch mitnehmt. ich hatte genau diese Anforderung mal irgendwo unter script gestellt, aber nie eine Antwort erhalten.
                  gibt ein neues Widget List Beta, geht das bei wem?
                  • Scrounger
                    Scrounger Developer @sigi234 last edited by
                    @sigi234 sagte in [Neuer VIS-Adpater] Material Design Widgets:
                    Das geht noch nicht, da arbeite ich aktuell dran. Also alle widgets mit Beta Kennzeichnung sind in der Bearbeitung. Sobald es fertig und zum testen bereitsteht, gibt's hier ne Info
                    • Meistertr
                      Der slider Knopf beilbt auf dem Handy und wenn ich am PC bei Chrome f12 drücke nur auf der linken Seite und lässt sich ncith bedienen.
                      Scrounger sigi234 2 Replies Last reply Reply Quote 0
                        sigi234 Forum Testing Most Active @Scrounger last edited by
                        @Scrounger sagte in [Neuer VIS-Adpater] Material Design Widgets:
                        Ok, könnte man noch Farben für Hintergrund und Beschriftung mit aufnehmen?
                          darkiop Most Active last edited by
                          @Meistertr sagte in [Neuer VIS-Adpater] Material Design Widgets:
                          Ohne es heute nochmal getestet zu haben, das hatte ich gestern auch mit der Firefox Developer Edition. Aufm Ipad mit Safari hats funktioniert.
                          • Meistertr
                            @Scrounger noch etwas ist mir gerade aufgefallen das widgetset hat wauswirkungen auf das normale view in 8 widget. in meinem hauprojekt nutze ich es und dort ist nun alles nach links verschoben Ursache sieh bild:
                            • Scrounger
                              Scrounger Developer @Meistertr last edited by Scrounger
                              Tritt das verhalten nur auf wenn die View Teil von der TopAppBar ist, oder genrell?
                              Hab gard ein fix dafür hochgeladen. Bitte testen, kann das verhalten bei mir nicht nachstellen.
                                sigi234 Forum Testing Most Active @Meistertr last edited by sigi234
                                Kann ich bestätigen. Habe ihn als Volume drinnen für Alexa Dot.
                                Wenn ich im Editor den Slider verschiebe geht es.
                                In der Runtime nicht, da geht der Wert sofort auf 100 % und der Slider ist nicht verschiebbar.
                                Welche Unterschiede gibt es eigentlich zwischen den 2 Slider?
                                View in Bearbeitung
                                • Scrounger
                                  d.h. die Slider sind bei dir nicht in der View der TopAppBar?
                                  siehe https://github.com/Scrounger/iobroker.vis-materialdesign#slider
                                    Step marker😀
                                      sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
                                      Nein, in einer View die ich dann einblende.
                                      Stelle fast alles auf deine Widgets um.
                                      Aber auch in der View in der TopBar das selbe:
                                      • Scrounger
                                        Scrounger Developer last edited by Scrounger
                                        Die List ist fertig zum testen. Folgende Funktionen sind implementiert:
                                        • checkbox
                                        • switch
                                        • text
                                        • button state
                                        • button toggle
                                        • button link
                                        • button navigation
                                        • Scrounger
                                          Scrounger Developer @sigi234 last edited by Scrounger
                                          Ich habe eine Attribut 'initDelay' beim slider hinzugefügt. Mit dem könnt ihr die Verzögerung beim Initialisieren des Sliders einstellen - Eingabe in ms.
                                          Testet bei euren Browsen ob höhere Wert das Phänom beheben.
                                          Falls ja, dann bitte rückmelden welchen Wert ihr eingestellt habt und welchen Browser ihr benutzt.
                                            Leider nein, in Edit Modus geht es einwandfrei. In der Runtime mit Chrome und FF nicht.
                                            Die Linie geht Richtig mit, aber der Knopf nicht. Auch beim betätigen am Dot selbst von + und - funktioniert alles bis auch den Knopf. Die Werte werden auch Richtig angezeigt.
                                            Ich teste mal weiter.
                                            adapter
                                            30
                                            271
                                            42387
