    4. Test js-controller v2.0.x (GitHub)
    • MathiasJ
      MathiasJ last edited by MathiasJ
      nein, eine andere Baustelle, darum habe ich hier nichts geschrieben, sonst wäre es OT...... was es jetzt auch geworden ist. 😄
      Radar habe ich immer noch die 1.2.0 am laufen.Weil da kann man auch hci only einstellen.
      Und Broadlink2 habe ich auch.........
        darkiop Most Active last edited by
        @apollon77
        Mir ist noch aufgefallen das beim Starten des Docker Containers mit 2.0 dies hier im Log des Containers geworfen wird. Bei 1.5 ist Ruhe.
        TCP Timeout
        (node:2126) UnhandledPromiseRejectionWarning: Error: TCP Timeout
            at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/tplink-smarthome-api/lib/client.js:226:20)
        (node:2521) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'replace' of undefined
        (node:2521) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
        (node:2521) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        Tue, 08 Oct 2019 16:14:06 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
        In the future, you will have to enable it yourself.
        See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:778:30
        (node:2521) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        mania25 created this issue in yagop/node-telegram-bot-api
        closed Error: cannot enable cancellation after promises are in use #319
          apollon77 @MathiasJ last edited by
          @MathiasJ Am Ende ist der Fix "einfach" und weiter oben hier kommentiert. Man muss ein File ändern wie hier ersichtlich. https://github.com/frankjoke/myAdapter/pull/1/files
          File liegt normslerweise in node_modules/@frankjoke/myadapter/myAdapter.js Dann passt es wieder. ggf suchen ob es noch irgendwo in node_modules/iobroker.radar2/node_modules oder node_modules/iobroker.boradlink2/node_modules liegt
          Apollon77 created this issue in frankjoke/myAdapter
          open create a new Promise wrapper that also binds correctly for the class #1
            apollon77 @darkiop last edited by apollon77
            @darkiop Bitte bissl mehr log context (par Zeilen mehr davor und dahinter ... sonst ist es ein schönes Raten weil ich dann fragen muss ... wo verwendest Du denn irgendwas mit tplink?
            Kann es hs100 Adapter sein?
            • SBorg
              SBorg Forum Testing Most Active @apollon77 last edited by
              @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
              ...Für broadlink2 fehlt noch eine Version. Aber da bereite ich heute meinen fork vor so dass man davon installieren kann.
              Falls es dir hilft: myAdapter.js
              Fertig gepatcht (mit beiden Änderungen, also auch .bind(adapter) ) und seit etlichen Tagen getestet und im Einsatz 🙂
                erledigt
                ich gebe es auf
                  apollon77 @Guest last edited by
                  @Nuggelbeb sagte in [Aufruf] js-controller 2.0 Beta Test:
                  ich gebe es auf
                  Was. einst Du ?
                    Hallo an alle Tester,
                    auf GitHub gibt es jetzt die 2.0.25 (aka RC2) von neuen js-controller.
                    @Nuggelbeb Ich glaube warst nicht "verrückt". Dein Grossbuchstabe deiner eigenen Objekte war nicht ganz erwartet 😉 Tut jetzt.
                    @SBorg Die Redis Meldungen beim Start sollten jetzt auch weg sein.
                    @darkiop "iobroker state get ..." geht jetzt auch wieder wie vorher.
                    Ansonsten sind noch ein paar Kleinigkeiten drin.
                    Bitte jetzt nochmal ALLE aktualisieren und checken. Wenn von Euch nichts mehr kommt geht die 2.0.25 am Freitag ins Latest Repo für alle!! Endspurt 😉
                    Ingo
                    • coyote
                      coyote Most Active last edited by coyote
                      @apollon77 gerade die 2.0.25 installiert. Läuft eigentlich unaufällig hoch, alle Adapter grün.
                      Keine Redis Warnings mehr vorhanden 👍
                      Ein Error im Log während hochlauf:
                      javascript.1	2019-10-10 05:04:36.627	error	(23932)
                      javascript.1	2019-10-10 05:04:36.626	error	(23932) Using request for node-pre-gyp https download
                      javascript.1	2019-10-10 05:04:36.624	error	(23932)
                      javascript.1	2019-10-10 05:04:36.622	error	(23932) WARN
                      javascript.1	2019-10-10 05:04:36.621	error	(23932)
                      javascript.1	2019-10-10 05:04:36.619	error	(23932) node-pre-gyp
                      Das hier hatte ich noch im Log;
                      host.debian	2019-10-10 05:05:32.727	info	instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
                      host.debian	2019-10-10 05:05:32.727	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                      host.debian	2019-10-10 05:05:32.727	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      host.debian	2019-10-10 05:05:32.726	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      host.debian	2019-10-10 05:05:32.725	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081)
                      host.debian	2019-10-10 05:05:32.724	error	Caught by controller[0]: TypeError: Cannot read property '_id' of null
                      javascript.1	2019-10-10 05:05:31.677	info	(23932) Terminated (NO_ERROR): Without reason
                      javascript.1	2019-10-10 05:05:31.675	info	(23932) terminating
                      javascript.1	2019-10-10 05:05:31.596	error	(23932) TypeError: Cannot read property '_id' of null at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081) at tryCatcher (/opt/iob
                      javascript.1	2019-10-10 05:05:31.595	error	(23932) uncaught exception: Cannot read property '_id' of null
                      javascript.1	2019-10-10 05:05:31.590	info	(23932) received all states
                      host.debian	2019-10-10 05:05:28.381	info	Restart adapter system.adapter.javascript.0 because enabled
                      host.debian	2019-10-10 05:05:28.381	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081)
                      host.debian	2019-10-10 05:05:28.379	error	Caught by controller[0]: TypeError: Cannot read property '_id' of null
                      javascript.0	2019-10-10 05:05:27.219	info	(24104) received all states
                      javascript.0	2019-10-10 05:05:26.102	error	(24104) TypeError: Cannot read property '_id' of null at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081) at tryCatcher (/opt/iob
                      javascript.0	2019-10-10 05:05:26.101	error	(24104) uncaught exception: Cannot read property '_id' of null
                      Javascript Adapter hat sich dann neu gestartet und wieder gefangen, keine Fehler mehr. Schätze das war von irgend einem Script
                        apollon77 @coyote last edited by apollon77
                        @coyote zum ersten fehlt mir komplett context. Ich tippe auf npm Modul Installation beim start von JavaScript. Aber ohne bissl Mehring von drumrum dem Fehler kann ich das nur raten.
                        Das zweite ist die Frage ob du es irgendwie provoziert bekommst?! Dann könnten wir versuchen die Stelle zu finden.
                        Bzw auch hier zeig mal wie das log danach beim restart des JavaScript Adapters aussieht ...
                          darkiop Most Active last edited by darkiop
                          @apollon77 Guten Morgen!
                          Dann wollen wir mal zum Endspurt 🙂
                          Das mit den Logs beim Container-Start schaue ich mir nochmal an und melde mich ggf.
                            @apollon77
                            Alles absolut unauffällig, state get läuft auch! Ich lass die Logs mal noch ne Weile offen und werf ab und zu nen Blick drauf.
                              msauer last edited by msauer
                              Hi.
                              soeben 2.0.25 installiert. Alles startet fehlerlos.
                              Ich muss allerdings den Update immer mit
                              sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                              machen. Der eigentliche Befehl "npm install ioBroker/ioBroker.js-controller" führt nur zu Fehlern
                              1266 verbose stack Error: Command failed: git clone --mirror -q git://github.com/ioBroker/ioBroker.js-controller.git /root/.npm/_cacache/tmp/git-clone-5e92596b/.git
                              1266 verbose stack fatal: Konnte führende Verzeichnisse von '/root/.npm/_cacache/tmp/git-clone-5e92596b/.git' nicht erstellen.
                              1266 verbose stack
                              1266 verbose stack     at ChildProcess.exithandler (child_process.js:294:12)
                              1266 verbose stack     at ChildProcess.emit (events.js:198:13)
                              1266 verbose stack     at maybeClose (internal/child_process.js:982:16)
                              1266 verbose stack     at Socket.stream.socket.on (internal/child_process.js:389:11)
                              1266 verbose stack     at Socket.emit (events.js:198:13)
                              1266 verbose stack     at Pipe._handle.close (net.js:606:12)
                              1267 verbose cwd /opt/iobroker
                              1268 verbose Linux 4.19.0-6-amd64
                              1269 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "ioBroker/ioBroker.js-controller"
                              1270 verbose node v10.16.3
                              1271 verbose npm  v6.11.3
                              1272 error code 128
                              1273 error Command failed: git clone --mirror -q git://github.com/ioBroker/ioBroker.js-controller.git /root/.npm/_cacache/tmp/git-clone-5e92596b/.git
                              1273 error fatal: Konnte führende Verzeichnisse von '/root/.npm/_cacache/tmp/git-clone-5e92596b/.git' nicht erstellen.
                              Wie kann ich das denn beheben, bzw. wird dies auch beim späteren "iobroker upgrade self" auftreten?
                              AlCalzone apollon77 2 Replies Last reply Reply Quote 1
                              • AlCalzone
                                AlCalzone Developer @msauer last edited by
                                @msauer sagte in [Aufruf] js-controller 2.0 Beta Test:
                                Bist du normalerweise als ein nicht-root-User angemeldet? Dann haben wir ggf. einen Fix in der Mache, der braucht aber noch ein bisschen Feinschliff.
                                  @AlCalzone sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  Nein..immer nur als root
                                  • AlCalzone
                                    @msauer Ok, aber das könnte die gleiche Ursache haben. Müssen wir sehen... Wird dann ggf. in naher Zukunft vom Fixer gerade gebogen.
                                    J E 2 Replies Last reply Reply Quote 0
                                      Jan1 @AlCalzone last edited by
                                      @apollon77
                                      Also mit 2.0.25 sind sämtliche Errors und Warnungen aus dem Log verschwunden die ich oben gepostet hatte.
                                      @AlCalzone
                                      bei mir geht auch nur die zweite Variante des Update Befehl, egal ob root oder normaler User.
                                        darkiop Most Active @Jan1 last edited by
                                        @Jan1 sagte in [Aufruf] js-controller 2.0 Beta Test:
                                        Dem schließ mich mich an, sowohl im Container (immer root) als auch aufm RPI (mein User).
                                          e-s @AlCalzone last edited by
                                          @AlCalzone
                                          das mit dem sudo kommt erst wenn man npm auf 6.11.3 updated, alle User die dies noch nicht gemacht haben, die brauchen den sudo Befehl auch nicht.
                                            apollon77 @msauer last edited by apollon77
                                            @msauer Ja das ist irgendwelcher npm Rechte-Foo ...
                                            Ein iobroker upgrade selfsollte immer mit automatisch alles quasi mit "sudo -u iobroker -H" ausführen was es startet, damit sollte das Problem hier nicht auftreten.
                                            J AlCalzone 2 Replies Last reply Reply Quote 0
                                            js-controller
                                            48
                                            1047
                                            263528
