    4. Test js-controller v2.0.x (GitHub)
    • coyote
      coyote Most Active last edited by coyote
      @apollon77 gerade die 2.0.25 installiert. Läuft eigentlich unaufällig hoch, alle Adapter grün.
      Keine Redis Warnings mehr vorhanden 👍
      Ein Error im Log während hochlauf:
      javascript.1	2019-10-10 05:04:36.627	error	(23932)
      javascript.1	2019-10-10 05:04:36.626	error	(23932) Using request for node-pre-gyp https download
      javascript.1	2019-10-10 05:04:36.624	error	(23932)
      javascript.1	2019-10-10 05:04:36.622	error	(23932) WARN
      javascript.1	2019-10-10 05:04:36.621	error	(23932)
      javascript.1	2019-10-10 05:04:36.619	error	(23932) node-pre-gyp
      Das hier hatte ich noch im Log;
      host.debian	2019-10-10 05:05:32.727	info	instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
      host.debian	2019-10-10 05:05:32.727	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.debian	2019-10-10 05:05:32.727	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.debian	2019-10-10 05:05:32.726	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.debian	2019-10-10 05:05:32.725	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081)
      host.debian	2019-10-10 05:05:32.724	error	Caught by controller[0]: TypeError: Cannot read property '_id' of null
      javascript.1	2019-10-10 05:05:31.677	info	(23932) Terminated (NO_ERROR): Without reason
      javascript.1	2019-10-10 05:05:31.675	info	(23932) terminating
      javascript.1	2019-10-10 05:05:31.596	error	(23932) TypeError: Cannot read property '_id' of null at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081) at tryCatcher (/opt/iob
      javascript.1	2019-10-10 05:05:31.595	error	(23932) uncaught exception: Cannot read property '_id' of null
      javascript.1	2019-10-10 05:05:31.590	info	(23932) received all states
      host.debian	2019-10-10 05:05:28.381	info	Restart adapter system.adapter.javascript.0 because enabled
      host.debian	2019-10-10 05:05:28.381	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.debian	2019-10-10 05:05:28.380	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081)
      host.debian	2019-10-10 05:05:28.379	error	Caught by controller[0]: TypeError: Cannot read property '_id' of null
      javascript.0	2019-10-10 05:05:27.219	info	(24104) received all states
      javascript.0	2019-10-10 05:05:26.102	error	(24104) TypeError: Cannot read property '_id' of null at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:85081) at tryCatcher (/opt/iob
      javascript.0	2019-10-10 05:05:26.101	error	(24104) uncaught exception: Cannot read property '_id' of null
      Javascript Adapter hat sich dann neu gestartet und wieder gefangen, keine Fehler mehr. Schätze das war von irgend einem Script
        apollon77 @coyote last edited by apollon77
        @coyote zum ersten fehlt mir komplett context. Ich tippe auf npm Modul Installation beim start von JavaScript. Aber ohne bissl Mehring von drumrum dem Fehler kann ich das nur raten.
        Das zweite ist die Frage ob du es irgendwie provoziert bekommst?! Dann könnten wir versuchen die Stelle zu finden.
        Bzw auch hier zeig mal wie das log danach beim restart des JavaScript Adapters aussieht ...
          darkiop Most Active last edited by darkiop
          @apollon77 Guten Morgen!
          Dann wollen wir mal zum Endspurt 🙂
          Das mit den Logs beim Container-Start schaue ich mir nochmal an und melde mich ggf.
            @apollon77
            Alles absolut unauffällig, state get läuft auch! Ich lass die Logs mal noch ne Weile offen und werf ab und zu nen Blick drauf.
              msauer last edited by msauer
              Hi.
              soeben 2.0.25 installiert. Alles startet fehlerlos.
              Ich muss allerdings den Update immer mit
              sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
              machen. Der eigentliche Befehl "npm install ioBroker/ioBroker.js-controller" führt nur zu Fehlern
              1266 verbose stack Error: Command failed: git clone --mirror -q git://github.com/ioBroker/ioBroker.js-controller.git /root/.npm/_cacache/tmp/git-clone-5e92596b/.git
              1266 verbose stack fatal: Konnte führende Verzeichnisse von '/root/.npm/_cacache/tmp/git-clone-5e92596b/.git' nicht erstellen.
              1266 verbose stack
              1266 verbose stack     at ChildProcess.exithandler (child_process.js:294:12)
              1266 verbose stack     at ChildProcess.emit (events.js:198:13)
              1266 verbose stack     at maybeClose (internal/child_process.js:982:16)
              1266 verbose stack     at Socket.stream.socket.on (internal/child_process.js:389:11)
              1266 verbose stack     at Socket.emit (events.js:198:13)
              1266 verbose stack     at Pipe._handle.close (net.js:606:12)
              1267 verbose cwd /opt/iobroker
              1268 verbose Linux 4.19.0-6-amd64
              1269 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "ioBroker/ioBroker.js-controller"
              1270 verbose node v10.16.3
              1271 verbose npm  v6.11.3
              1272 error code 128
              1273 error Command failed: git clone --mirror -q git://github.com/ioBroker/ioBroker.js-controller.git /root/.npm/_cacache/tmp/git-clone-5e92596b/.git
              1273 error fatal: Konnte führende Verzeichnisse von '/root/.npm/_cacache/tmp/git-clone-5e92596b/.git' nicht erstellen.
              Wie kann ich das denn beheben, bzw. wird dies auch beim späteren "iobroker upgrade self" auftreten?
              AlCalzone apollon77 2 Replies Last reply Reply Quote 1
              • AlCalzone
                AlCalzone Developer @msauer last edited by
                @msauer sagte in [Aufruf] js-controller 2.0 Beta Test:
                Bist du normalerweise als ein nicht-root-User angemeldet? Dann haben wir ggf. einen Fix in der Mache, der braucht aber noch ein bisschen Feinschliff.
                  @AlCalzone sagte in [Aufruf] js-controller 2.0 Beta Test:
                  Nein..immer nur als root
                  • AlCalzone
                    @msauer Ok, aber das könnte die gleiche Ursache haben. Müssen wir sehen... Wird dann ggf. in naher Zukunft vom Fixer gerade gebogen.
                    J E 2 Replies Last reply Reply Quote 0
                      Jan1 @AlCalzone last edited by
                      @apollon77
                      Also mit 2.0.25 sind sämtliche Errors und Warnungen aus dem Log verschwunden die ich oben gepostet hatte.
                      @AlCalzone
                      bei mir geht auch nur die zweite Variante des Update Befehl, egal ob root oder normaler User.
                        darkiop Most Active @Jan1 last edited by
                        @Jan1 sagte in [Aufruf] js-controller 2.0 Beta Test:
                        Dem schließ mich mich an, sowohl im Container (immer root) als auch aufm RPI (mein User).
                          e-s @AlCalzone last edited by
                          @AlCalzone
                          das mit dem sudo kommt erst wenn man npm auf 6.11.3 updated, alle User die dies noch nicht gemacht haben, die brauchen den sudo Befehl auch nicht.
                            apollon77 @msauer last edited by apollon77
                            @msauer Ja das ist irgendwelcher npm Rechte-Foo ...
                            Ein iobroker upgrade selfsollte immer mit automatisch alles quasi mit "sudo -u iobroker -H" ausführen was es startet, damit sollte das Problem hier nicht auftreten.
                            J AlCalzone 2 Replies Last reply Reply Quote 0
                              Jan1 @apollon77 last edited by
                              @apollon77
                              OK, muss meine Aussage von oben doch noch mal korrigieren. Eben noch mal in die Logs geschaut und das hier gefunden:
                              host.Beelink	2019-10-10 08:45:02.335	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.335	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.335	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.335	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.334	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.334	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.334	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.334	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.334	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.334	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.333	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.333	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.333	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.333	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.333	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.333	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.331	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.331	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.330	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.330	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.330	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.330	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.330	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.330	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.329	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.329	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.329	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.329	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.329	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.329	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.328	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.328	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.328	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.328	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.328	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.328	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.327	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.327	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.327	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.327	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.327	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.327	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.326	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.326	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.326	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.326	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.326	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.326	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[14]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[14]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[14]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[14]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[14]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[14]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[13]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.325	error	Caught by controller[13]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[13]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[13]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[13]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[13]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[12]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[12]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[12]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[12]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.324	error	Caught by controller[12]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[12]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[11]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[11]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[11]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[11]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[11]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[11]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[10]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.323	error	Caught by controller[10]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[10]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[10]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[10]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[10]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[9]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[9]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[9]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[9]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.322	error	Caught by controller[9]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[9]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[8]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[8]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[8]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[8]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[8]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[8]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[7]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[7]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                              host.Beelink	2019-10-10 08:45:02.321	error	Caught by controller[7]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                              host.Beelink	2019-10-10 08:45:02.320	error	Caught by controller[7]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:436:21)
                              host.Beelink	2019-10-10 08:45:02.320	error	Caught by controller[7]: at /opt/iobroker/node_modules/iobroker.fritzdect/main.js:127:46
                              host.Beelink	2019-10-10 08:45:02.320	error	Caught by controller[7]: ReferenceError: log is not defined
                              host.Beelink	2019-10-10 08:45:02.320	error	Caught by controller[6]: at process._tickCallback (internal/process/next_tick.js:68:7)
                              Müsste wieder das DB Problemchen sein, nur der Neustart liegt lag zu dem Zeitpunkt schon ein paar Minuten in der Vergangenheit.
                                apollon77 @Jan1 last edited by apollon77
                                iobroker.fritzdect
                                Ne, Adapter Bug
                                https://github.com/Apollon77/ioBroker.fritzdect/blob/master/main.js#L127 das "-" ist falsch
                                Ist 'Comet_' + id + '.targettemp' (musst mal schauen welch "id" das betreffen kann) leer?
                                Fix für dich zum checken: Editiere /opt/iobroker/node_modules/iobroker.fritzdect/main.js: zeile 127 und schreibe "adapter.log" anstelle "adapter-log". Geht es dann wieder wie erwartet? Wirst halt diese "log meldung als Fehler" bekommen... aber da kenne ich die semantik des Adapters nicht
                                • AlCalzone
                                  AlCalzone Developer @apollon77 last edited by
                                  @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  Außer es ist schon kaputt 😉
                                  @e-s Ich hab ähnliche Fehler bei mir schon mit 6.9.x gehabt.
                                    A Former User @apollon77 last edited by
                                    @apollon77
                                    ok, werde ich heute testen - Bericht kommt heute Abend.
                                    DANKE
                                      apollon77 @AlCalzone last edited by
                                      @AlCalzone Was sollte ich denn in die Anleitung für "latest"schreiben? Offiziell war ich bei "iobroker upgrade self" ... mus da im Notfall auch nochmal das sudo zeug avor?
                                      • SBorg
                                        Tut was er soll 🙂
                                        Ist das eigentlich ein Überbleibsel, Mac geschuldet, Schönheitsfehler, ...(ist ja nicht wirklich relevant):
                                        Einen "Fehler" hatte ich aber. Gestern den JS-Adapter von 4.1.16 auf 4.2.1 gezogen, lief soweit auch alles. Dann heute den JS-Controller auf die 2.0.25 und dann das:
                                        2019-10-10 09:16:45.770 - info: host.Ubuntu iobroker.js-controller version 2.0.25 js-controller starting
                                        2019-10-10 09:16:45.786 - info: host.Ubuntu Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
                                        2019-10-10 09:16:45.788 - info: host.Ubuntu hostname: Ubuntu, node: v8.16.1
                                        2019-10-10 09:16:45.795 - info: host.Ubuntu ip addresses: 192.168.1.30
                                        2019-10-10 09:16:47.351 - info: host.Ubuntu connected to Objects and States
                                        2019-10-10 09:16:47.982 - info: host.Ubuntu 82 instances found
                                        2019-10-10 09:16:48.097 - info: host.Ubuntu starting 60 instances
                                        2019-10-10 09:16:48.134 - warn: host.Ubuntu startInstance cannot find adapter "javascript@4.1.16". Try to install it... 1 attempt
                                        2019-10-10 09:16:48.135 - info: host.Ubuntu iobroker install javascript@4.1.16 using installedVersion
                                        Ok, kein echtes Problem, also nach dem automatischen downgrade wieder auf die 4.2.1 gezogen, aber anscheinend hat da was mit der neuen speichern Funktion nicht so ganz funktioniert?
                                          zu 1.) Da sist leider NPM. ioBroker unterstützts Linux, Windows und Macos und daher brauchen wir Libraries für alle drei Systeme und einige sind damit auf den anderen Systemen optional. Das sind diese Meldungen. Ignore. Keine Ahnung wie man die wegbekommt.
                                          2.) Schau mal bitte ob Du in deinem Objekten (alle Filter aus machen) ein "system.adapter.javascript@4.1.16" hast? Es gab in der 1.5.10/11 glaube ich einen Bug der solche komischen Dinge verursacht hat. Wenn das - warum auch immer - aktiv wird könnte der Fehler da her kommen.
                                          Falls solche system.adapter.x" einträge mit nem "@" im Namen da sind bitte alle löschen.
                                          • BBTown
                                            BBTown @apollon77 last edited by
                                            @apollon77
                                            verhällt es sich bei mir ähnlich?
                                            js-controller
                                            48
                                            1047
                                            311231
