    4. Apple Homekit Siri
    Apple Homekit Siri
    • eric2905
      eric2905 last edited by
      @Homoran:
      Habe oben den Link mal editiert.
      Probier es jetzt mal 😉 `
      Oh shit …. wie dämlich kann ich denn noch sein .. das ich das nicht selber gesehen habe ...
      Ok, jetzt muss ich noch Git installieren ...
      • eric2905
        Der Start sah schon vielversprechend aus … aber dann doch ein Abbruch:
        make: Entering directory `/opt/iobroker/node_modules/ioBroker.homekit/node_modules/HAP-NodeJS/node_modules/mdns/build'
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
        In file included from ../src/dns_sd.cpp:1:0:
        ../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
         #include <dns_sd.h>
        compilation terminated.
        make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
        make: Leaving directory `/opt/iobroker/node_modules/ioBroker.homekit/node_modules/HAP-NodeJS/node_modules/mdns/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
        gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
        gyp ERR! System Linux 3.4.79
        gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/ioBroker.homekit/node_modules/HAP-NodeJS/node_modules/mdns
        gyp ERR! node -v v0.10.22
        gyp ERR! node-gyp -v v0.11.0
        gyp ERR! not ok
        npm ERR! mdns@2.2.10 install: `node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the mdns@2.2.10 install script.
        npm ERR! This is most likely a problem with the mdns package,
        npm ERR! not with npm itself.
        npm ERR! Tell the author that this fails on your system:
        npm ERR!     node-gyp rebuild
        npm ERR! You can get their info via:
        npm ERR!     npm owner ls mdns
        npm ERR! There is likely additional logging output above.
        npm ERR! System Linux 3.4.79
        npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production"
        npm ERR! cwd /opt/iobroker
        npm ERR! node -v v0.10.22
        npm ERR! npm -v 1.3.14
        npm ERR! code ELIFECYCLE
        npm ERR!
        npm ERR! Additional logging details can be found in:
        npm ERR!     /opt/iobroker/npm-debug.log
        npm ERR! not ok code 0</dns_sd.h>
        Hab jetzt keine Lust mehr und schaue mir das morgen in Ruhe an.
        Es sei denn, jemand hat die zündende Idee (und ich muss morgen nicht suchen) 😛
        Gruß,
        Eric
          Zum ELIFECYCLE gab es hier schon mal öfter was.
          Dann spuckt er dir die Version von nodejs und npm aus.
          Hat es vorher ein WARN gegeben, in der auf die nodejs-Version hingewiesen wurde?
          Sonst noch einen schönen Abend
          Rainer
          • eric2905
            Ich denke eher, das noch was fehlt .. er mault:
             #include
            und
            Morgen nochmal machen und dann das ganze Log mal durchlesen.
            Gruß,
            Eric
            • V
              versteckt last edited by
              Ich hab es auf OS X entwickelt, werde es morgen mal auf meiner Raspi installieren und schauen ob ich dort auch den Fehler bekomme.
              Sieht stark danach aus, als wie wenn er eine Abhängigkeit nicht auflösen kann.
              Welche node Version verwendest du?
              Gesendet von meinem iPhone mit Tapatalk
                @eric2905:
                npm ERR! npm -v 1.3.14 `
                2716_tablet.txt
                • V
                  Der mdns lässt sich nicht kompilieren.
                  Schaut mal hier in den Bereich Installation https://github.com/agnat/node_mdns/blob … /README.md
                  Die schreiben hier von einem Paket, welches installiert sein muss unter Debian (Raspi).
                  • eric2905
                    @versteckt:
                    …, welches installiert sein muss unter Debian (Raspi). `
                    Werde ich mir morgen mal ansehen - allerdings läuft's bei mir nicht auf einem Raspi, sondern auf einem Cubietruck (aber auch unter Debian).
                    Gruß,
                    Eric
                    • V
                      Guten Morgen!
                      Lt. https://github.com/KhaosT/HAP-NodeJS/wiki/Installing gibt es Abhängigkeiten zu bestimmten Linux Paketen.
                      Habe die package.json im Bereich scripts angepasst. Jetzt sollte die Installation funktionieren.
                      Bei mir läuft auf dem odroid node version 0.12.6 von http://node-arm.herokuapp.com/
                      Ob das kompatibel zu ioBroker ist, muss ich aber erst selbst testen.
                      LG Christian
                      • V
                        Hallo, grade Version 0.0.2 hochgeladen.
                        Jetzt werden die Werte (Temperatur, Licht) beim Refresh der Räume auch neu geladen.
                        Das war in der 0.0.1 nur beim starten des Adapters drinnen.
                        LG Christian
                          mimquadrat last edited by
                          ich habs installiert,
                          wenn ich die Instanz dann hinzufügen möchte kommt der Fehler hier
                          ! $ ./iobroker add homekit
                          ! ERROR: host.raspberrypi Unknown packetName homekit
                          ! ERROR: process exited with code 5
                          das hier war im log zu dem Thema zu finden:
                          ` > iobroker 2015-09-27 16:43:36 info exit 5
                          iobroker 2015-09-27 16:43:36 error host.raspberrypi Unknown packetName homekit
                          iobroker 2015-09-27 16:43:34 info add homekit `
                          ich nutze einen stink normalen Raspi, mit stink normalen raspian wheezy
                            steinwedel last edited by
                            Der Fehler tritt bei mir auch auf. Ursache ist ein Groß-/Kleinschreibe-Fehler. Das Verzeichnis heißt "ioBroker.homekit". Es muss aber "iobroker.homekit" heißen. Wenn man es umbenennt, dann ist der Fehler weg.
                              Bei mir stürzt der Adapter immer wieder ab:
                              > warn host.iobroker instance system.adapter.homekit.0 terminated due to SIGSEGV
                              • V
                                Guten Morgen! Das Problem hatte ich gestern leider auch schon, muss ich heute Abend analysieren.
                                  apollon77 last edited by
                                  Hi "versteckt",
                                  für CCU gibts auch schon eine Version für Homebridge als Erweiterung … Der kann schon sehr viele Aktoren ... vllt kann man ja hier Code-Synergien nutzen ohne alles von Grund auf für weitere Device-Typen neu bauen zu müssen ...
                                  https://github.com/thkl/homebridge
                                    An dieser Stelle einen ganz herzlichen Dank an den Entwickler des Adapters.
                                    Nun noch eine Anregung. Die (teilweise) Ablage der Konfiguration in den enums halte ich nicht für sinnvoll. Der iobroker ist so gestrickt, dass man mehrere Instanzen mit unterschiedlichen Konfigurationen ausführen kann. Ob man das braucht ist eine persönliche Sache. Mit mehreren Instanzen könnte man z,B, realisieren, dass nicht jeder Nutzer auf alles zugreifen darf. Durch die Ablage der enums, können wesentliche Teile nicht pro Adapter konfiguriert werden. Daher rege ich an dieses zu ändern. Desweiteren schlage ich für die Zukunft vor (gibt bestimmt schon Planungen), auf der Seite zur Konfiguration des Adapters diejenigen Objekte in einer Liste bzw. Treeview anzuzeigen und selektierbar zu machen, die der Adapter untersstützt. Dann dürfte die Konfiguration auch für weniger ambitionierte User nutzbar werden.
                                    Herzlichen Gruß
                                    Gerhard
                                    • V
                                      danke schon mal für euer Feedback.
                                      @steinwedel: Die Implementierung per enums ist für mich immer der erste Schritt, das mal nur bestimmte Objekte eingesetzt werden können.
                                      Ist in occ derzeit auch noch so, wird aber geändert.
                                      @apollon77: Hab ich gestern bereits gesehen, muss ich mir noch genauer anschauen.
                                      @All: Dieser Adapter ist im Moment noch im Alpha Stadium, mir ging es in erster Instanz darum, zu zeigen, wie einfach es ist, eine neue Schnittstelle
                                      zu erzeugen.
                                      Dieser Adapter wird natürlich weiterentwickelt. Für aktives Testen und Fehlermelden bin ich jetzt schon mal sehr dankbar.
                                      LG Christian
                                        Für die Auswahl wäre vllt das wie es das highcharts-Adon macht auch eine coole Idee: "Einfach" pro Homekit-Adapter in der UI bei den Channeln eine weitere Spalte einblenden mit ner Checkbox wo man wählen kann ob es dabei sein soll oder nicht … das wäre dann die "Luxus"-Variante der Enum 🙂
                                          Trident last edited by
                                          ich hab mal versucht den Adapter zu installieren. Klappt aber nicht. Hab folgendes gemacht:
                                          npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
                                          Danach kamen folgende Fehlermeldungen im Terminal:
                                          npm http GET https://github.com/husky-koglhof/ioBroker.homekit/tarball/master
                                          npm http 200 https://github.com/husky-koglhof/ioBroker.homekit/tarball/master
                                          > ioBroker.homekit@0.0.3 preinstall /opt/iobroker/node_modules/ioBroker.homekit
                                          > sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
                                          Reading package lists... Done
                                          Building dependency tree
                                          libavahi-compat-libdnssd-dev is already the newest version.
                                          git-core is already the newest version.
                                          libnss-mdns is already the newest version.
                                          0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                                          1 not fully installed or removed.
                                          After this operation, 0 B of additional disk space will be used.
                                          Setting up linux-image-sunxi (4.3) ...
                                          ln: failed to create symbolic link `/boot/zImage': Operation not permitted
                                          cp: writing `/boot/zImage': No space left on device
                                          cp: failed to extend `/boot/zImage': No space left on device
                                          dpkg: error processing linux-image-sunxi (--configure):
                                           subprocess installed post-installation script returned error exit status 1
                                          Errors were encountered while processing:
                                           linux-image-sunxi
                                          E: Sub-process /usr/bin/dpkg returned an error code (1)
                                          npm ERR! ioBroker.homekit@0.0.3 preinstall: `sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y`
                                          npm ERR! Exit status 100
                                          npm ERR!
                                          npm ERR! Failed at the ioBroker.homekit@0.0.3 preinstall script.
                                          npm ERR! This is most likely a problem with the ioBroker.homekit package,
                                          npm ERR!     sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
                                          npm ERR!     npm owner ls ioBroker.homekit
                                          npm ERR! System Linux 3.4.108-sunxi
                                          npm ERR!
                                          Hab ich was falsch gemacht?
                                          Viele Grüße
                                          Trident
                                            hab den Fehler selbst entdeckt… Muss natürlich vorher die aktuelle Version von Github laden.
                                            Installiert ist nun eine Instanz. Beim Start bekomme ich im iobroker-log folgende Meldungen:
                                            host-cubietruck	2015-09-28 20:36:16	error	instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                                            SyntaxError:	2015-09-28 20:36:16	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                            SyntaxError:	2015-09-28 20:36:16	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                            SyntaxError:	2015-09-28 20:36:16	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                                            SyntaxError:	2015-09-28 20:36:16	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                                            SyntaxError:	2015-09-28 20:36:16	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:151:27)
                                            SyntaxError:	2015-09-28 20:36:16	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2375:60
                                            SyntaxError:	2015-09-28 20:36:16	error	at /opt/iobroker/node_modules/iobroker.homekit/main.js:43:61
                                            SyntaxError:	2015-09-28 20:36:16	error	at /opt/iobroker/node_modules/iobroker.homekit/main.js:20:13
                                            SyntaxError:	2015-09-28 20:36:16	error	at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:201:33)
                                            SyntaxError:	2015-09-28 20:36:16	error	at Object.parse (native)
                                            SyntaxError:	2015-09-28 20:36:16	error	Unexpected token u
                                            uncaught	2015-09-28 20:36:16	error	exception: Unexpected token u
                                            homekit-0	2015-09-28 20:36:16	info	Parent Object Adress: hm-rpc.0.LEQ0277589
                                            homekit-0	2015-09-28 20:36:16	info	HAP-NodeJS starting...
                                            homekit-0	2015-09-28 20:36:16	info	received all states
                                            homekit-0	2015-09-28 20:36:15	info	received all objects
                                            homekit-0	2015-09-28 20:36:13	info	requesting all objects
                                            homekit-0	2015-09-28 20:36:13	info	requesting all states
                                            homekit-0	2015-09-28 20:36:13	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.homekit
                                            homekit-0	2015-09-28 20:36:13	debug	statesDB connected
                                            homekit-0	2015-09-28 20:36:13	debug	objectDB connected
                                            host-cubietruck	2015-09-28 20:36:10	info	instance system.adapter.homekit.0 started with pid 7122
                                            Nur als Info für die Entwickler…. Vielleicht liegt es auch an mir?
                                            Viele Grüße
                                            Trident
                                            250
                                            52376
