    4. Test js-controller v2.0.x (GitHub)
    • coyote
      coyote Most Active last edited by
      @apollon77 irgendwie wollen manche Scripte nicht laufen und warum steht bei mir an jedem Script "Instanz deaktiviert" obwohl sie aktiviert ist? 🤔
      Dieses Script hier will auch nicht mehr:
      var HueApi = require("node-hue-api").HueApi;
      // Replace IP and username!!!
       var host = "192.168.66.31",
           username = "16f4f7d727e98e3f3eaXXXXXXX",
           api = new HueApi(host, username);
       var groups_ = [],
           lights_ = [],
           objects_ = [];
       // Log JSON results
       var displayResults = function(result) {
           console.log('Reponse: '+JSON.stringify(result, null, 2));
       // Parse Light Group 0 (All Lights)
       var parseGroup0 = function(result) {
           if (!result.lights){return} // Empty group
           var id = result.id,
               lights = result.lights,
               name = "All Lights";
           console.debug('group: '+name+', lights: '+lights);
           groups_[lights] = name;
       // Parse Light Groups
       var parseGroups = function(result) {
           for (var i = 0; i < result.length; i++) {
               if (!result[i].lights){continue} // Empty group
               var id = result[i].id,
                   lights = result[i].lights,
                   name = result[i].name;
       // Parse Lights
       var parseLights = function(result) {
               console.debug('light: '+name+', id: '+id);
               lights_[id] = name;
       // Create States in ioBroker
       var createStates = function(result) {
           // Resync button
           createState('PhilipsHue.Scenes.Resync', false, {role: "button", name: 'Resync Philips Hue Groups, Lights and Scenes'});
               if (!result[i].appdata.data){continue} // skip internal szenes
                   name = result[i].name.replace(/"/g,''),
                   pathname = name.replace(/ /g,'_');
               // Get light names
               var light_names = [];
               for (var j = 0; j < lights.length; j++) {
                   var light_name = lights_[lights[j]];
                   light_names.push(light_name);
               // Room, group or lights linked with scene
               var group = 'Group: '+groups_[lights] || 'Lights: '+light_names.join(", ");
               // Create States and skip duplicates
               if (!objects_[lights+pathname]){
                   console.debug('scene: '+name+', '+group);
                   createState('PhilipsHue.Scenes.'+pathname+'.'+id, false, {role: "button", name: 'Scene: '+name+' ('+group+')'});
                   objects_[lights+pathname] = true;
       // Delete States
       function deleteStates(){
           console.log('Deleting current objects for scenes...');
           objects_ = [];
           $('javascript.0.PhilipsHue.Scenes.*').each(function (id) {
               deleteState(id);
       // Fetch data from Hue API
       function init(){
           api.getGroup(0, function(err, group0) {
               if (err) throw err;
               console.log('Processing group 0...');
               //displayResults(group0);
               parseGroup0(group0);
           api.groups(function(err, groups) {
               if (err) throw err;
               console.log('Processing ' + groups.length + ' groups...');
               //displayResults(groups);
               parseGroups(groups);
           api.lights(function(err, lights) {
               if (err) throw err;
               console.log('Processing ' + lights.lights.length + ' lights...');
               //displayResults(lights);
               parseLights(lights.lights);
           api.scenes(function(err, scenes) {
               if (err) throw err;
               console.log('Processing ' + scenes.length + ' scenes...');
               //displayResults(scenes);
               createStates(scenes);
       // Init on start
       init();
       // Activate scene
       on({id: /^javascript\.0\.PhilipsHue.Scenes\./, val: true}, function (obj) {
           if (obj.id == 'javascript.0.PhilipsHue.Scenes.Resync'){return}
           sceneId = obj.id.split('.').pop();
           console.log('Activating '+obj.name);
           api.activateScene(sceneId, function(err, result) {
               if (err) throw err;
               displayResults(result);
           setState(obj.id, false);
       // Resync
       on({id: 'javascript.0.PhilipsHue.Scenes.Resync', val: true}, function (obj) {
           console.log('Resync triggered...');
           groups_ = [];
           lights_ = [];
           deleteStates();
           init();
       /*schedule("0 3 * * *", function () {
           groups_ = [];
           lights_ = [];
           deleteStates();
           init();
      javascript.0	2019-10-10 19:49:59.137	info	(15370) script.js.Hue_Szenen_abfragen: registered 2 subscriptions and 1 schedule
      javascript.0	2019-10-10 19:49:59.099	info	(15370) Start javascript script.js.Hue_Szenen_abfragen
      javascript.0	2019-10-10 19:49:55.995	info	(15370) Stop script script.js.Hue_Szenen_abfragen
      Das wars mehr kommt da nicht mehr... Ne Idee wo ich suchen kann? Mir ist es nur aufgefallen, als meine Hue Lampe heute nicht an ging, wird über ein Script gesteuert.
        apollon77 @Guest last edited by
        @Nuggelbeb ok wenn zigbee das überschreibt bitte issue bei zigbee anlegen.
          apollon77 @coyote last edited by
          @coyote ich hab beim JavaScript Adapter dazu ein issue gesehn.
          • coyote
            coyote Most Active @apollon77 last edited by
            @apollon77 ah ok, alles klar.
            Warum das Script nicht mehr korrekt läuft, muss ich selbst mal schauen, irgendwas passt da nicht.
            Die anderen Scripte laufen anscheinend ja.
              @Nuggelbeb welche zigbee Version?
                A Former User @apollon77 last edited by
                @apollon77
                Installierte Version: 0.11.3
                  @Nuggelbeb @arteck sagte mir du sollst mal aktuelle GitHub nehmen.
                    @apollon77
                    Auf GitHub ist es doch die aktuelle Version.
                      darkiop Most Active last edited by
                      Direkt von Github installieren (Adapter --> Katze Symbol oder 'iobroker url http://.....), dann hast die letzten Commits unabhängig der letzten Version.
                        A Former User @darkiop last edited by
                        @darkiop
                        Okay, da ist es V 0.11.4
                        Bis jetzt geht es. melde mich morgen noch einmal.
                        • MathiasJ
                          MathiasJ last edited by
                          Weiß jemand, was mit Frankjoke los ist?
                          So wie ich mich kenne, zerschieße ich was bei einer Änderung. Dashalb lasse ich es lieber.......
                            apollon77 @MathiasJ last edited by
                            @MathiasJ Er ist dran. Das eine File manuell abzupassen tut vorher und nachher!
                            • coyote
                              @apollon77 kannst du mir vllt da weiterhelfen? Habe diese "node-hue-api" gerade nochmal neu in die javascript instanz hinzugefügt, dann kommt folgendes:
                              host.debian	2019-10-10 22:53:54.042	info	instance system.adapter.javascript.0 terminated with code 156 (156)
                              host.debian	2019-10-10 22:53:54.042	error	Caught by controller[9]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                              host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                              host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                              host.debian	2019-10-10 22:53:54.042	error	Caught by controller[7]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[5]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[3]: (node:20588) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[2]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                              host.debian	2019-10-10 22:53:54.041	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[1]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: ********************************************************************************
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: Please consult the documentation at https://github.com/peter-murray/node-hue-api for the documentation on the new API.
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: require("node-hue-api").v3
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: You need to migrate your code to use the new API available via import
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This will be removed in v4.x of node-hue-api.
                              host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This shim provides a limited backporting of the features available in the updated API in v3.x.
                              host.debian	2019-10-10 22:53:54.039	error	Caught by controller[0]: Backwards compatibility shim for node-hue-api.
                              host.debian	2019-10-10 22:53:54.035	error	Caught by controller[0]: ********************************************************************************
                              javascript.0	2019-10-10 22:53:52.981	info	(20588) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              javascript.0	2019-10-10 22:53:52.432	info	(20588) Got terminate signal TERMINATE_YOURSELF
                              Vorher hatte das ohne Probleme funktioniert
                                @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
                                192.168.66.31:443
                                Also einmal 192.168.66.31:443 ECONREFUSED heist Connection Refused. DU kannst dich da nicht hin verbinden oder sowas. Da sist aber jetzt 100% Offtopic hier
                                • coyote
                                  coyote Most Active @apollon77 last edited by coyote
                                  @apollon77 ja das ist mir eigentlich schon klar, die HueBridge ist aber erreichbar, also eigentlich kann es da nicht dran liegen und der Fehler kam ja erst als ich den node-hue-api in der Javascript Instanz nochmal hinzugefügt hab, deshalb dachte ich es könnte was mit dem js-controller zu tun haben, da es vorher ohne Probleme lief.
                                  Es geht mir eher um die unteren Zeilen
                                    @coyote Docker? Netzwerk? Firewall? SOwas vllt? Kannst Du von dem ioBroker Host die seite mit curl oder so erreichen? Owas ... aber anderer Thread Bitte!
                                    • coyote
                                      @apollon77 weder noch und ja ich kann auch über die iobroker objekte von hue, direkt meine lampen schalten, also ist die Bridge ja erreichbar. Hat damit nichts zu tun. Mir geht es nur um diese node-hue-api, das funktioniert nicht mehr. Gestern mit der 2.0.24 ging das ja noch ohne Probleme, sonst noch ne Idee?
                                        @coyote keine ohne jetzt tief rein zu schauen. Die Änderungen 24->25 sind diesbezüglich auch an sich irrelevant.
                                        • coyote
                                          @apollon77 hm ok, naja könnte auch schon vorher ein Problem gewesen sein und ich hab es nicht gemerkt, erst als ich heute die Objekte neu synchronisieren wollte. Naja, dann weiß ich es momentan erst auch mal nicht, muss ich weiter suchen. Keine Ahnung was er jetzt für ein Problem mit dem node-hue-api hat, da bin ich nicht tief genug drin in der Materie.
                                          • coyote
                                            @apollon77 falls du irgendwann Zeit hast kannst du vllt mal kurz in die Log Datei schauen. Habe gerade die Javascript Instanz auf 4.3.0 upgedatet und Fehler im Log, weiß aber jetzt nicht, ob das mit dem js-controller zusammenhängt. Wenn nicht mach ich nen neuen Beitrag dazu.
                                            Hier:Log.txt
                                            js-controller
                                            48
                                            1047
                                            312515
